Remove duplicated include.
Signed-off-by: Wei Yongjun <yongjun_wei@trendmicro.com.cn>
Adds support for querying the phy bus width from the generic phy
subsystem. Configure UTMI bus width in GUSBCFG based on this value.
Signed-off-by: Matt Porter <mporter@linaro.org>
Acked-by: Kishon Vijay Abraham I <kishon@ti.com>
Signed-off-by: Felipe Balbi <balbi@ti.com>
Adds support for the generic PHY subsystem. Generic PHY
support is probed and then the driver falls back to checking
for an old style USB PHY and pdata if not found.
Enable support for the dwc2 binding.
Remove unused Samsung-specific machine include and Kconfig
dependency on S3C.
Reviewed-by: Markus Mayer <markus.mayer@linaro.org>
Reviewed-by: Tim Kryger <tim.kryger@linaro.org>
Linux 3.13-rc4
* tag 'v3.13-rc4': (1001 commits)
Linux 3.13-rc4
null_blk: mem garbage on NUMA systems during init
radeon_pm: fix oops in hwmon_attributes_visible() and radeon_hwmon_show_temp_thresh()
Revert "selinux: consider filesystem subtype in policies"
igb: Fix for issue where values could be too high for udelay function.
i40e: fix null dereference
ARM: fix asm/memory.h build error
dm array: fix a reference counting bug in shadow_ablock
dm space map: disallow decrementing a reference count below zero
mm: memcg: do not allow task about to OOM kill to bypass the limit
mm: memcg: fix race condition between memcg teardown and swapin
thp: move preallocated PTE page table on move_huge_pmd()
mfd/rtc: s5m: fix register updating by adding regmap for RTC
rtc: s5m: enable IRQ wake during suspend
rtc: s5m: limit endless loop waiting for register update
rtc: s5m: fix unsuccesful IRQ request during probe
drivers/rtc/rtc-s5m.c: fix info->rtc assignment
include/linux/kernel.h: make might_fault() a nop for !MMU
drivers/rtc/rtc-at91rm9200.c: correct alarm over day/month wrap
procfs: also fix proc_reg_get_unmapped_area() for !MMU case
This patch adds "maxpacket_limit" to struct usb_ep. This field contains
maximum value of maxpacket supported by driver, and is set in driver probe.
This value should be used by autoconfig() function, because value of field
"maxpacket" is set to value from endpoint descriptor when endpoint becomes
enabled. So when autoconfig() function will be called again for this endpoint,
"maxpacket" value will contain wMaxPacketSize from descriptior instead of
maximum packet size for this endpoint.
For this reason this patch adds new field "maxpacket_limit" which contains
value of maximum packet size (which defines maximum endpoint capabilities).
This value is used in ep_matches() function used by autoconfig().
Value of "maxpacket_limit" should be set in UDC driver probe function, using
usb_ep_set_maxpacket_limit() function, defined in gadget.h. This function
set choosen value to both "maxpacket_limit" and "maxpacket" fields.
This patch modifies UDC drivers by adding support for maxpacket_limit.
Signed-off-by: Robert Baldyga <r.baldyga@samsung.com>
This patch adds flushing TX FIFO in kill_all_requests() function in
dedicated-fifo mode. It's because when requests are killed (when endpoint is
disabled or in case of device reset/disconnection) in FIFO can stay some
unsent data. In the worst case FIFO can stay full, and then if endpoint will
be back enabled, sending new data will be impossible.
This patch set maximum possible maxpacket value for each speed. Previous
values didn't allow to use maxpacket sizes greater than 64 in full speed
and 512 in high speed, although hardware is able to handle up to 1023 in fs
and 1024 in hs.
Tested-by: Matt Porter <mporter@linaro.org>
This patch moves s3c_hsotg_disconnect function call from USBSusp interrupt
handler to SET_ADDRESS request handler.
It's because disconnected state can't be detected directly, because this
hardware doesn't support Disconnected interrupt for device mode. For both
Suspend and Disconnect events there is one interrupt USBSusp, but calling
s3c_hsotg_disconnect from this interrupt handler causes config reset in
composite layer, which is not undesirable for Suspended state.
For this reason s3c_hsotg_disconnect is called from SET_ADDRESS request
handler, which occurs always after disconnection, so we do disconnect
immediately before we are connected again. It's probably only way we
can do handle disconnection correctly.
This patch adds missing spinlock locking in s3c_hsotg_complete_setup function,
and unlocking for gadget setup call.
Value of can_write variable in s3c_hsotg_write_fifo function should be limited
to 512 only for non-periodic endpoints. There was some discrepancy between
comment and code, becouse comment suggests correct behavior, but in the code
limit was applied to periodic endpoints too. So there is additional check
causing the limitation concerns only non-periodic endpoints.
In dedicated-fifo mode TxFIFOEmpty interrupt should be asserted when TxFIFO
for this endpoint is completly empty, so NPTxFEmpLvl and PTxFEmpLvl bits are
set in GAHBCFG register.
In DIEPMSK register INTknTXFEmpMsk is set, becouse it's needed to indicate
FIFO Empty state.
All requests for endpoint are completed when it was halted and the halt was
cleared by CLEAR_FEATURE, but not when new state is same as previous.
Property "halted" of s3c_hsotg_ep structure is actually initialised when ep
enabled, and changed when halt is set/cleared.
In OEPInt/IEPInt interrupts handling added bitwise and of DAINT and
DAINTMSK, because we should handle masked interrupts only.
When s3c_hsotg_trytx is called for ep without enqueued request, interrupts
for this ep are disabled, to prevent interrupt flooding. Interrupts are
enabled when new request for this ep is starting.
mode
In s3c_hsotg_write_fifo function PTxFEmp/NPTxFEmp interrupts are enabled
only in shared-fifo mode. In dedicated-fifo mode they should not be used
(when enabled then cause interrupt storm).
After normal handling of SetupDone interrupt, XferCompl interrupt occurs, and
then we enqueue new setup request. But when ep0 is stalled, there is no
XferCompl, so we have to enqueue setup request immediately after stalling ep.
Otherwise incoming control requests won't be processed correctly.
This patch removes unused label.
This patch adds Multi Count support. It adds few modifications:
- Fix s3c_hsotg_set_ep_maxpacket() function. Field wMaxPacketSize of endpoint
descriptor is now splitted into maximum packet size value and number of
additional transaction per microframe.
- Modify s3c_hsotg_write_fifo() function. It actually calculates transfer
size, taking into account Multi Count value, which indicates number of
transactions per microframe.
- Fix s3c_hsotg_start_req() function by setting number of packets to Multi
Count field in DIEPTSIZ register for isochronous endpoints.
This patch adds isochronous transfer support. It adds few modifications:
- Modify s3c_hsotg_epint() function. Some interrupts are ignored for
isochronous endpoints, (e.g. INTknTXFEmpMsk) becouse isochronous request is
always transfered in single transaction, which ends with XferCompl interrupt.
- Add Odd/Even microframe toggle to allow data transfering in each microframe
in s3c_hsotg_epint() function.
- Fix s3c_hsotg_ep_enable() function by supporting isochronous endpoint type.
This patch fixes max packet size check in s3c_hsotg_set_ep_maxpacket()
function. According USB specification, bits 10..0 of mps specifies maximum
packet size, so there is bitwise AND between mps and 0x7ff value. Also added
check if maxpacket isn't grater than 1024 which is maximum size od single USB
transaction.
In s3c_hsotg_ep_enable() function added s3c_hsotg_set_ep_maxpacket() call
instead of setting ep.maxpacket value directly.
This patch changes ep maxpacket value from 512 to 1024, because it's needed
to handle interupt and isochronous endpoints in high-speed mode. This change
doesn't affect on driver functioning, because fifo size (3072) is still enough
for the maximum transaction payload (3*1024 for high-speed high-bandwidtch
endpoints).
checkpatch.pl has some valid complaints about style in s3c-hsotg.c:
- macro with 'if' should be really enclosed in 'do {} while (0)'
- seq_puts() is going to be slightly faster than seq_printf()
- pr_err() is shorter than printk(KERN_ERR ...)
Signed-off-by: Pavel Machek <pavel@denx.de>
[bzolnier: minor fixes]
Signed-off-by: Bartlomiej Zolnierkiewicz <b.zolnierkie@samsung.com>
DWC2 databook indicates if the core sets "ErlySusp" bit, an idle state has been
detected on the USB for 3 ms. This situation can be occurred when waiting
a request from user daemon. So, we should keep the connection between udc and
gadget even though this interrupt is occurred.
Signed-off-by: Chanho Park <chanho61.park@samsung.com>
After driver conversion to udc_start/udc_stop infrastructure (commit
"usb:hsotg:samsung: Use new udc_start and udc_stop callbacks"
f65f0f1098) the gadget unregistration function is almost always called
with 'driver' parameter being NULL, what caused that the unregistration
code has not been executed at all. This is a leftover from the earlier
verison of this function (which used simple start/stop interface), where
driver parameter was obligatory.
This patch removes the NULL check for the 'driver' pointer and removes
all dereferences of it. It also moves disabling voltage regulators out
of the atomic context, because handling regulators (which are usually
i2c devices) might require sleeping.
Use the wrapper function for retrieving the platform data instead of
accessing dev->platform_data directly.
Signed-off-by: Jingoo Han <jg1.han@samsung.com>
This patch adds OF match table to the driver to allow instantiating it
using device tree.
Signed-off-by: Tomasz Figa <t.figa@samsung.com>
usb_gadget_unmap_request()
'struct usb_request *' should be passed to usb_gadget_unmap_request(),
as the second argument; however, 'struct s3c_hsotg_req *' is used.
Fixed build warnings as below:
drivers/usb/gadget/s3c-hsotg.c: In function 's3c_hsotg_unmap_dma':
drivers/usb/gadget/s3c-hsotg.c:440:2: warning: passing argument 2 of 'usb_gadget_unmap_request' from incompatible pointer type
[enabled by default]
include/linux/usb/gadget.h:961:13: note: expected 'struct usb_request *' but argument is of type 'struct s3c_hsotg_req *'
drivers/usb/gadget/s3c-hsotg.c:434:22: warning: unused variable 'req' [-Wunused-variable]
PHY laye rno longer return NULL. We need to
switch over from IS_ERR_OR_NULL() to IS_ERR().
udc-core provides a better way to handle release
methods, let's use it.
udc-core now handles that for us, which means
we can remove it from our driver.
udc-core now sets dma-related and parent fields
for us, we don't need to do it ourselves.
we have generic implementations for a reason,
let's use them.
We don't need the ->register_my_device flag
anymore because all UDC drivers have been
properly converted.
Let's remove every history of it.
By simply setting a flag, we can drop some
boilerplate code.
Reviewed-by: Tomasz Figa <tomasz.figa@gmail.com>
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb
Pull USB patches from Greg Kroah-Hartman:
"Here's the big USB merge for 3.9-rc1
Nothing major, lots of gadget fixes, and of course, xhci stuff.
All of this has been in linux-next for a while, with the exception of
the last 3 patches, which were reverts of patches in the tree that
caused problems, they went in yesterday."
* tag 'usb-3.9-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb: (190 commits)
Revert "USB: EHCI: make ehci-vt8500 a separate driver"
Revert "USB: EHCI: make ehci-orion a separate driver"
Revert "USB: update host controller Kconfig entries"
USB: usb-storage: unusual_devs update for Super TOP SATA bridge
USB: ehci-omap: Fix autoloading of module
USB: ehci-omap: Don't free gpios that we didn't request
USB: option: add Huawei "ACM" devices using protocol = vendor
USB: serial: fix null-pointer dereferences on disconnect
USB: option: add Yota / Megafon M100-1 4g modem
drivers/usb: add missing GENERIC_HARDIRQS dependencies
USB: storage: properly handle the endian issues of idProduct
testusb: remove all mentions of 'usbfs'
usb: gadget: imx_udc: make it depend on BROKEN
usb: omap_control_usb: fix compile warning
ARM: OMAP: USB: Add phy binding information
ARM: OMAP2: MUSB: Specify omap4 has mailbox
ARM: OMAP: devices: create device for usb part of control module
git://git.kernel.org/pub/scm/linux/kernel/git/balbi/usb into usb-next
Felipe writes:
usb: xceiv: patches for v3.9 merge window
Two new PHY drivers coming here: one for Samsung,
one for OMAP. Both architectures are adding USB3
support to mainline kernel.
The PHY layer now allows us to have mulitple PHYs
of the same type, which is necessary for platforms
which provide more than one USB peripheral port.
There's also a few cleanups here: removal of __dev*
annotations, conversion of a cast to to_delayed_work(),
and mxs-phy learns about ->set_suspend.
Felipe writes:
usb: gadget: patches for v3.9 merge window
finally getting rid of the old ->start()/->stop() methods
in favor of the better and improved ->udc_start()/->udc_stop().
There were surprisingly quite a few users left, but all of them
have been converted.
f_mass_storage removed some dead code, which is always great ;-)
There's also a big cleanup to the gadget framework from Sebastian
which gets us a lot closer to having only function drivers in
kernel and move over to configfs-based binding.
Other than these, there's the usual set of cleanups: s3c UDCs are
moving over to devm_regulator_bulk_get() API, at91_udc removed
an unnecessary check for work_pending() before scheduling and
there's the removal of an unused variable from uac2_pcm_trigger().
Add the missing 'const' keyword to all struct
usb_gadget_ops in the gadget framework.
Convert all uses of devm_request_and_ioremap() to the newly introduced
devm_ioremap_resource() which provides more consistent error handling.
devm_ioremap_resource() provides its own error messages so all explicit
error messages can be removed from the failure code paths.
Signed-off-by: Thierry Reding <thierry.reding@avionic-design.de>
Acked-by: Alan Stern <stern@rowland.harvard.edu>
Acked-by: Felipe Balbi <balbi@ti.com>
Adding the transceiver to hsotg driver. Keeping the platform data
for continuing the smooth operation for boards which still uses it
Signed-off-by: Praveen Paneri <p.paneri@samsung.com>
Acked-by: Kyungmin Park <kyungmin.park@samsung.com>
devm_regulator_bulk_get is device managed and saves some cleanup
and exit code.
Signed-off-by: Sachin Kamat <sachin.kamat@linaro.org>
Since hsotg object is allocated using devm_kzalloc() API, there is no
need to free this explicitly. But we need to keep the release API to
prevent warnings.
Signed-off-by: Tushar Behera <tushar.behera@linaro.org>
CONFIG_HOTPLUG is going away as an option so __devexit is no
longer needed.
Signed-off-by: Bill Pemberton <wfp5p@virginia.edu>
Cc: Peter Korsgaard <jacmet@sunsite.dk>
Cc: Alexander Shishkin <alexander.shishkin@linux.intel.com>
Cc: Li Yang <leoli@freescale.com>
Cc: Alan Stern <stern@rowland.harvard.edu>
Cc: Wan ZongShun <mcuos.com@gmail.com>
Cc: Ben Dooks <ben-linux@fluff.org>
Cc: Kukjin Kim <kgene.kim@samsung.com>
CONFIG_HOTPLUG is going away as an option so __devinit is no longer
needed.
Cc: Geoff Levand <geoff@infradead.org>
Cc: Olav Kongas <ok@artecdesign.ee>
Cc: Lennert Buytenhek <kernel@wantstofly.org>
Acked-by: Nicolas Ferre <nicolas.ferre@atmel.com>
CONFIG_HOTPLUG is going away as an option so __devexit_p is no longer
needed.
Acked-by: Peter Korsgaard <jacmet@sunsite.dk>
usb: gadget: patches for v3.7 merge window
This pull request is large but the biggest part is the first part
of the cleanup on the gadget framework so we have a saner setup
to add configfs support for v3.8.
We have also some more conversions to the new udc_start/udc_stop
which makes us closer from dropping the old interfaces.
USB_GADGET_DUALSPEED and USB_GADGET_SUPERSPEED are finally gone,
thanks to Michal for his awesome work.
Other than that, we have the usual set of miscellaneous changes
and cleanups involving improvements to debug messages, removal
of duplicated includes, moving dereference after NULL test,
making renesas_hsbhs' irq handler Shared, unused code being dropped,
prevention of sleep-inside-spinlock bugs and a race condition fix
on udc-core.
devm_* functions are already used in this file. Hence
convert clk_get to devm_clk_get for completeness.
