path: root/drivers/usb/gadget/ndis.h
2012-05-12usb/net: rndis: break out <linux/rndis.h> definesLinus Walleij
As a first step to consolidate the RNDIS implementations, break out a common file with all the #defines and move it to <linux/rndis.h>. This also deletes the immediate duplicated defines in the <linux/rndis.h> file that yields a lot of compilation warnings. Reviewed-by: Haiyang Zhang <haiyangz@microsoft.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-09-09usb gadget: clean up FSF boilerplate textKlaus Schwarzkopf
remove the following two paragraphs as they are not needed: This program is distributed in the hope that it will be useful, but WITHOUT ANY WARRANTY; without even the implied warranty of MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU General Public License for more details. You should have received a copy of the GNU General Public License along with this program; if not, write to the Free Software Foundation, Inc.,59 Temple Place - Suite 330, Boston, MA 02111-1307, USA. Signed-off-by: Klaus Schwarzkopf <schwarzkopf@sensortherm.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-07-21usb gadget: RNDIS cleanupsDavid Brownell
Some cleanup to the RNDIS code: - Minor bugfix: rndis_unit() is supposed to put the link into the RNDIS_UNINITIALIZED state, which does not mean "unused". There's a separate method to stop using the link. (Bug doesn't affect anything right now because of how the code is used.) - Reduce coupling between RNDIS code and its user(s), in preparation for updates in that code: * Decouple RNDIS_RESPONSE_AVAILABLE notifications from net_device by passing just a void* handle. (Also, remove the unused return value of the notification callback.) * When it needs a copy of net_device stats, just ask for it - Remove unused/untested code backing various never-used OIDs: * RNDIS_PM, RNDIS_WAKEUP ... "should" get implemented, but the relevant docs were unclear, ambguous, and incomplete. Someone with access to the Hidden Gospels (maybe in the EU?) might be able to figure out what this should do. * RNDIS_OPTIONAL_STATS ... as the name suggests, optional. Never implemented in part because not all the semantics were clear. * OID_GEN_RNDIS_CONFIG_PARAMETER, which has been #if 0 forever. - A few small whitespace fixes Plus switch the VERBOSE symbol over to the newer VERBOSE_DEBUG style. There should be no functional changes because of this patch; it's a net source code shrink (because of the dead/unused code removal) and a small object code shrink (a couple hundred bytes on ARMv5). Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-06-27[PATCH] USB: rndis updates (mostly cleanup)David Brownell
Some bugfixes and lots of cleanup (net code shrink): - On reset, force the RNDIS state machine its initial state - Hook up the RNDIS (outgoing) filters to the CDC mechanism - Lots of cleanup: * Eliminate duplicate copy of OID table; * Unify handlying of the OID "query" response data pointer; * Reduce code duplication for calculating query response lengths; * Remove some checks for "can't happen" errors; * Get rid of debugging #ifdefs by making the debug flag an integer level Most of the patch, by volume, relates to those query response cleanups. It incidentally shaves off a few hundred bytes of object code. Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
