Some gadgets provide custom entry here. Some may override it with an
etntry that is also created by composite if there was no value sumbitted
at all.
This patch removes all "custom manufacturer" strings which are the same
as these which are created by composite. Then it moves the creation of
the default manufacturer string to usb_composite_overwrite_options() in
case no command line argument has been used and the entry is still an
empty string.
By doing this we get rid of the global variable "composite_manufacturer"
in composite.
Acked-by: Michal Nazarewicz <mina86@mina86.com>
Signed-off-by: Sebastian Andrzej Siewior <bigeasy@linutronix.de>
Signed-off-by: Felipe Balbi <balbi@ti.com>
The index in usb_string array is defined by the gadget. The gadget can
choose which index entry it assigns for the serial number and which the
product name. The gadget has just to ensure that the descriptor contains
the proper string id which is assigned by composite.
If the composite layer knows the index of the "default" information
which will be overwritten by module parameters, it can be used later to
overwrite it.
This patch moves the module options idVendor, idProduct and bcdDevice
from composite.c into each gadgets. This ensures compatibility with
current gadgets and removes the global variable which brings me step
closer towards composite.c in libcomposite
Using usb_string_ids_tab() instead multiple calls of usb_string_id()
seems to be handy. It also allows to add string without many checks.
This patch adds epautoconf.c into libcomposite and updates all gadgets.
This patch moves config.c into libcomposite and updates all gadgets.
This patch aims to be simple. It removes #include usbstribgs.c line from each
gadget and creates libcomposite.ko which has only one member, that is
usbstribgs.c.
This partly reverts 07a18bd7 ("usb gadget: don't save bind callback in
struct usb_composite_driver") and fixes new drivers. The section missmatch
problems was solved by whitelisting structs in question via __ref.
Cc: devel@driverdev.osuosl.org
As it turns out, Sam's comment was better than I initially assumed. This
patch pushes as struct usb_composite_driver data structures into
__refdata section to avoid a section missmatch report from modpost
because the ->bind() can be marked __init. The only downside is that
modpost does not check between ->bind() and other member. However, it is
temporary.
remove the following two paragraphs as they are not needed:
This program is distributed in the hope that it will be useful, but
WITHOUT ANY WARRANTY; without even the implied warranty of MERCHANTABILITY or
FITNESS FOR A PARTICULAR PURPOSE. See the GNU General Public
License for more details.
You should have received a copy of the GNU General Public License along with
this program; if not, write to the Free Software Foundation, Inc.,59
Temple Place - Suite 330, Boston, MA 02111-1307, USA.
Signed-off-by: Klaus Schwarzkopf <schwarzkopf@sensortherm.de>
This field is used by the Gadget drivers to specify
the maximum speed they support, meaning: the maximum
speed they can provide descriptors for.
The driver speed will be set in consideration of this
value.
[ balbi@ti.com : dropped the ifdeffery ]
Signed-off-by: Tatyana Brokhman <tlinder@codeaurora.org>
This patches makes possible to use composite framework and f_ncm
NCM function driver to build a standalone NCM gadget device.
Signed-off-by: Yauheni Kaliuta <yauheni.kaliuta@nokia.com>
