path: root/drivers/usb/gadget/gmidi.c
2013-01-10usb: gadget: consider link speed for bMaxPowerSebastian Andrzej Siewior
The USB 2.0 specification says that bMaxPower is the maximum power consumption expressed in 2 mA units and the USB 3.0 specification says that it is expressed in 8 mA units. This patch renames bMaxPower to MaxPower and the various /2 and *2 are removed. Before reporting the config descriptor, the proper value is computer based on the speed, all in-tree users are updated. MaxPower is also increased to u16 so we can store the nokia gadget value which is larger than the max value allowed for u8. Signed-off-by: Sebastian Andrzej Siewior <bigeasy@linutronix.de> Signed-off-by: Felipe Balbi <balbi@ti.com>
2012-09-10usb: gadget: remove usb_gadget_controller_number()Sebastian Andrzej Siewior
The bcdDevice field is defined as |Device release number in binary-coded decimal in the USB 2.0 specification. We use this field to distinguish the UDCs from each other. In theory this could be used on the host side to apply certain quirks if the "special" UDC in combination with this gadget is used. This hasn't been done as far as I am aware. In practice it would be better to fix the UDC driver before shipping since a later release might not need this quirk anymore. There are some driver in tree (on the host side) which use the bcdDevice field to figure out special workarounds for a given firmware revision. This seems to make sense. Therefore this patch converts all gadgets (except a few) to use the kernel version instead a random 2 or 3 plus the UDC number. The few that don't report kernel's version are: - webcam This one reports always a version 0x10 so allow it to do so in future. - nokia This one reports always 0x211. The comment says that this gadget works only if the UDC supports altsettings so I added a check for this. - serial This one reports 0x2400 + UDC number. Since the gadget version is 2.4 this could make sense. Therefore bcdDevice is 0x2400 here. I also remove various gadget_is_<name> macros which are unused. The remaining few macros should be moved to feature / bug bitfield. Acked-by: Michal Nazarewicz <mina86@mina86.com> Signed-off-by: Sebastian Andrzej Siewior <bigeasy@linutronix.de> Signed-off-by: Felipe Balbi <balbi@ti.com>
2012-09-10usb: gadget: libcomposite: move composite.c into libcompositeSebastian Andrzej Siewior
This moves composite.c into libcomposite and updates all gadgets. Finally! Acked-by: Michal Nazarewicz <mina86@mina86.com> Signed-off-by: Sebastian Andrzej Siewior <bigeasy@linutronix.de> Signed-off-by: Felipe Balbi <balbi@ti.com>
2012-09-10usb: gadget: Provide a default implementation of default manufacturer stringSebastian Andrzej Siewior
Some gadgets provide custom entry here. Some may override it with an etntry that is also created by composite if there was no value sumbitted at all. This patch removes all "custom manufacturer" strings which are the same as these which are created by composite. Then it moves the creation of the default manufacturer string to usb_composite_overwrite_options() in case no command line argument has been used and the entry is still an empty string. By doing this we get rid of the global variable "composite_manufacturer" in composite. Acked-by: Michal Nazarewicz <mina86@mina86.com> Signed-off-by: Sebastian Andrzej Siewior <bigeasy@linutronix.de> Signed-off-by: Felipe Balbi <balbi@ti.com>
2012-09-10usb: gadget: make sure each gadget is using same index for Product, Serial,…Sebastian Andrzej Siewior
The index in usb_string array is defined by the gadget. The gadget can choose which index entry it assigns for the serial number and which the product name. The gadget has just to ensure that the descriptor contains the proper string id which is assigned by composite. If the composite layer knows the index of the "default" information which will be overwritten by module parameters, it can be used later to overwrite it. Acked-by: Michal Nazarewicz <mina86@mina86.com> Signed-off-by: Sebastian Andrzej Siewior <bigeasy@linutronix.de> Signed-off-by: Felipe Balbi <balbi@ti.com>
2012-09-10usb: gadget: push VID/PID/USB BCD module option into gadgetsSebastian Andrzej Siewior
This patch moves the module options idVendor, idProduct and bcdDevice from composite.c into each gadgets. This ensures compatibility with current gadgets and removes the global variable which brings me step closer towards composite.c in libcomposite Acked-by: Michal Nazarewicz <mina86@mina86.com> Signed-off-by: Sebastian Andrzej Siewior <bigeasy@linutronix.de> Signed-off-by: Felipe Balbi <balbi@ti.com>
2012-09-10usb: gadget: use usb_string_ids_tab instead multiple usb_string_id()Sebastian Andrzej Siewior
Using usb_string_ids_tab() instead multiple calls of usb_string_id() seems to be handy. It also allows to add string without many checks. Acked-by: Michal Nazarewicz <mina86@mina86.com> Signed-off-by: Sebastian Andrzej Siewior <bigeasy@linutronix.de> Signed-off-by: Felipe Balbi <balbi@ti.com>
2012-09-10usb: gadget: libcomposite: add epautoconf.c to libcompositeSebastian Andrzej Siewior
This patch adds epautoconf.c into libcomposite and updates all gadgets. Acked-by: Michal Nazarewicz <mina86@mina86.com> Signed-off-by: Sebastian Andrzej Siewior <bigeasy@linutronix.de> Signed-off-by: Felipe Balbi <balbi@ti.com>
2012-09-10usb: gadget: libcomposite: move config.c into libcompositeSebastian Andrzej Siewior
This patch moves config.c into libcomposite and updates all gadgets. Acked-by: Michal Nazarewicz <mina86@mina86.com> Signed-off-by: Sebastian Andrzej Siewior <bigeasy@linutronix.de> Signed-off-by: Felipe Balbi <balbi@ti.com>
2012-09-10usb: gadget: start with libcompositeSebastian Andrzej Siewior
This patch aims to be simple. It removes #include usbstribgs.c line from each gadget and creates libcomposite.ko which has only one member, that is usbstribgs.c. Acked-by: Michal Nazarewicz <mina86@mina86.com> Signed-off-by: Sebastian Andrzej Siewior <bigeasy@linutronix.de> Signed-off-by: Felipe Balbi <balbi@ti.com>
2012-09-10usb: gadget: move bind() callback back to struct usb_composite_driverSebastian Andrzej Siewior
This partly reverts 07a18bd7 ("usb gadget: don't save bind callback in struct usb_composite_driver") and fixes new drivers. The section missmatch problems was solved by whitelisting structs in question via __ref. Cc: devel@driverdev.osuosl.org Acked-by: Michal Nazarewicz <mina86@mina86.com> Signed-off-by: Sebastian Andrzej Siewior <bigeasy@linutronix.de> Signed-off-by: Felipe Balbi <balbi@ti.com>
2012-09-10usb: gadget: push all usb_composite_driver structs into __refdataSebastian Andrzej Siewior
As it turns out, Sam's comment was better than I initially assumed. This patch pushes as struct usb_composite_driver data structures into __refdata section to avoid a section missmatch report from modpost because the ->bind() can be marked __init. The only downside is that modpost does not check between ->bind() and other member. However, it is temporary. Cc: Sam Ravnborg <sam@ravnborg.org> Acked-by: Michal Nazarewicz <mina86@mina86.com> Signed-off-by: Sebastian Andrzej Siewior <bigeasy@linutronix.de> Signed-off-by: Felipe Balbi <balbi@ti.com>
2011-10-31usb: Add module.h to drivers/usb consumers who really use it.Paul Gortmaker
The situation up to this point meant that module.h was pretty much everywhere, regardless of whether you asked for it or not. We are fixing that, so give the USB folks who want it an actual include of it. Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2011-10-13USB: gadget: f_midi: allow a dynamic number of input and output portsDaniel Mack
The code in the MIDI gadget was already sort of prepared for multi-port configuration, so the streaming logic itself didn't need much tweaking. However, the descriptors change when the number of ports do, and so some rework of the the preparation algorithms were necessary. Successfully tested on Linux and Max OS X hosts for both input and output streams. Signed-off-by: Daniel Mack <zonque@gmail.com> Cc: Greg Kroah-Hartman <gregkh@suse.de> Signed-off-by: Felipe Balbi <balbi@ti.com>
2011-10-13USB: gadget: midi: refactor the device codeDaniel Mack
Make use of the newly added MIDI function in f_midi.c and strip down the MIDI gadget code radically. Also use the generic framework function to avoid code duplication and rename some symbols to bring them in sync with other code in the gadget framework. [ balbi@ti.com : fix Section mismatch warnings. rebased on top of usb_speed_string() patch to avoid conflicts. ] Signed-off-by: Daniel Mack <zonque@gmail.com> Cc: Greg Kroah-Hartman <gregkh@suse.de> Signed-off-by: Felipe Balbi <balbi@ti.com>
2011-09-18usb: Provide usb_speed_string() functionMichal Nazarewicz
In a few places in the kernel, the code prints a human-readable USB device speed (eg. "high speed"). This involves a switch statement sometimes wrapped around in ({ ... }) block leading to code repetition. To mitigate this issue, this commit introduces usb_speed_string() function, which returns a human-readable name of provided speed. It also changes a few places switch was used to use this new function. This changes a bit the way the speed is printed in few instances at the same time standardising it. Signed-off-by: Michal Nazarewicz <mina86@mina86.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-07-01usb: gadget: defer setting maxpacket till ->setup()Sebastian Andrzej Siewior
maxpacket is set by the udc driver for ep0 very early. This value is copied by the function gadget used later for the USB_DT_DEVICE and USB_DT_DEVICE_QUALIFIER query. This seems to work fine so far. For USB3 we need set a different value here. In SS speed it is 2^x with x=9 and in HS we set something <= 64. If the UDC starts in SS and continues in HS after the cable has been plugged it will report a too small value. There setting of this value is defered and taken automaticly from the ep0 pointer where the UDC driver can update it according to the speed it detected _after_ a cable has been plugged. Signed-off-by: Sebastian Andrzej Siewior <bigeasy@linutronix.de> Signed-off-by: Felipe Balbi <balbi@ti.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-06-28usb: gadget: add usb_endpoint_descriptor to struct usb_epTatyana Brokhman
Change usb_ep_enable() prototype to use endpoint descriptor from usb_ep. This optimization spares the FDs from saving the endpoint chosen descriptor. This optimization is not full though. To fully exploit this change, one needs to update all the UDCs as well since in the current implementation each of them saves the endpoint descriptor in it's internal (and extended) endpoint structure. Signed-off-by: Tatyana Brokhman <tlinder@codeaurora.org> Signed-off-by: Felipe Balbi <balbi@ti.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-10-22usb gadget: don't save bind callback in struct usb_gadget_driverUwe Kleine-König
To accomplish this the function to register a gadget driver takes the bind function as a second argument. To make things clearer rename the function to resemble platform_driver_probe. This fixes many section mismatches like WARNING: drivers/usb/gadget/g_printer.o(.data+0xc): Section mismatch in reference from the variable printer_driver to the function .init.text:printer_bind() The variable printer_driver references the function __init printer_bind() All callers are fixed. Signed-off-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de> [m.nazarewicz@samsung.com: added dbgp] Signed-off-by: Michał Nazarewicz <m.nazarewicz@samsung.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-10-22USB: Revert "USB: gadget: section mismatch warning fixed"Michal Nazarewicz
This reverts a commit which proposed an invalid solution for a section mismatch. Next 3 commits will fix it correctly. Conflicts: drivers/usb/gadget/mass_storage.c Signed-off-by: Michal Nazarewicz <m.nazarewicz@samsung.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-08-10USB: gadget: section mismatch warning fixedMichal Nazarewicz
In may gadgets bind and bind like functions were in a init section as they were only run during initialisation. However, being callback functions they were referenced from structures in “normal” sections. Changing the tag from “__init” to “__ref” fixes the warnings. Signed-off-by: Michal Nazarewicz <m.nazarewicz@samsung.com> Cc: Kyungmin Park <kyungmin.park@samsung.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-06-23ALSA: usb-audio: unify UAC macros and struct namesDaniel Mack
Get rid of the last occurances of _v1 suffixes, and move the version number right after the "uac" string. Now things are consitent again. Sorry for the forth and back, but it just looks much nicer this way. Signed-off-by: Daniel Mack <daniel@caiaq.de> Signed-off-by: Takashi Iwai <tiwai@suse.de>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2010-03-02USB: Remove unsupported usb gadget driversChristoph Egger
A bunch of USB gadget drivers where never ported from the linux 2.4 series to 2.6 kernels. However there's some code still in the tree for them which isn't used and is probably untested for ages. As the chance of these drivers being forward ported is probably quite small now it might be time to get rid of them. Signed-off-by: Christoph Egger <siccegge@stud.informatik.uni-erlangen.de> Cc: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-02-23usb/gadget/{f_audio,gmidi}.c: follow recent changes in audio.hDaniel Mack
Some structs in linux/usb/audio.h have got new names to mark them as part of version 1.0 of the USB audio standard. Follow these changes in the gadget drivers. Note that this header and the ALSA USB driver will undergo some refactoring soon, so there might be another update to the gadgets as well. Signed-off-by: Daniel Mack <daniel@caiaq.de> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2009-09-23USB audio gadget: Prefix all macro definitions with UAC_ in linux/usb/audio.hLaurent Pinchart
linux/usb/audio.h is a public header file that includes definitions exported to userspace. To avoid namespace clashes, prefix all macro definitions with UAC_. Existing macros and structures prefixed with USB_AC_ and USB_AS_ are renamed for consistency. Signed-off-by: Laurent Pinchart <laurent.pinchart@skynet.be> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-03-26Merge git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb-2.6: (97 commits) USB: qcserial: add device id for HP devices USB: isp1760: Add a delay before reading the SKIPMAP registers in isp1760-hcd.c USB: allow malformed LANGID descriptors USB: pxa27x_udc: typo fixes and code cleanups USB: gadget: gadget zero uses new suspend/resume hooks USB: gadget: composite device-level suspend/resume hooks USB: r8a66597-hcd: suspend/resume support USB: more u32 conversion after transfer_buffer_length and actual_length USB: Fix cp2101 USB serial device driver termios functions for console use USB: CP2101 New Device ID USB: ipaq: handle 4 endpoint devices USB: S3C: Move usb-control.h to platform include USB: ohci-hcd: Add ARCH_S3C24XX to the ohci-s3c2410.c glue USB: pedantic: spelling correction in comment for ch9.h USB: host: fix sparse warning: Using plain integer as NULL pointer USB: ohci-s3c2410: fix name of bus clock USB: ohci-s3c2410: remove <mach/hardware.h> include USB: serial: rename cp2101 driver to cp210x USB: CP2101 Reduce Error Logging USB: CP2101 Support AN205 baud rates ...
2009-03-24USB: replace uses of __constant_{endian}Harvey Harrison
The base versions handle constant folding now. Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-01-12drivers/usb/gadget: Convert to snd_card_create()Takashi Iwai
Convert from snd_card_new() to the new snd_card_create() function for gmidi. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2008-10-17usb gadget: USB_GADGET_VBUS_DRAW Kconfig optionDavid Brownell
Offer a "how much VBUS power to request" configuration option for USB gadgets that aren't using board-specific customization of their gadget or (composite) configuration drivers. Also remove a couple pointless "depends on USB_GADGET" bits from the Kconfig text; booleans inside an "if USB_GADGET" will already have that dependency. Based on a patch from Justin Clacherty. Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Cc: Justin Clacherty <justin@redfish-group.com> Tested-by: Robert Jarzmik <robert.jarzmik@free.fr> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-10-16usb gadget: link fixes for MIDI gadgetDavid Brownell
Change how the MIDI gadget driver builds: don't use separate compilation, since it works poorly when key parts are library code (with init sections etc). Instead be as close as we can to "gcc --combine ...". Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-07-25Rename WARN() to WARNING() to clear the namespaceArjan van de Ven
We want to use WARN() as a variant of WARN_ON(), however a few drivers are using WARN() internally. This patch renames these to WARNING() to avoid the namespace clash. A few cases were defining but not using the thing, for those cases I just deleted the definition. Signed-off-by: Arjan van de Ven <arjan@linux.intel.com> Acked-by: Greg KH <greg@kroah.com> Cc: Karsten Keil <kkeil@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-28drivers/usb annotations and fixesAl Viro
* endianness annotations * endianness fixes * missing get_unaligned/put_unaligned It's pretty much all over the place, changes to different files are independent. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Serial-parts-Acked-by: Alan Cox <alan@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-24USB: gadget section fixesDavid Brownell
Restore some section annotations: they were switched to "__devinit" while they should have been "__init", because of bogus warnings. The warnings are now fixed, so the runtime footprint of various drivers can now shrink a bit. On ARMv5, it's about 600 bytes except for the Ethernet gadget, where it can save a bit more. Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-02-01USB: gadget code switches to pr_err() and friendsDavid Brownell
We now have pr_err(), pr_warning(), and friends ... start using them in the gadget stack instead of printk(KERN_ERR) and friends. This gives us shorter lines and somewhat increased readability. Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-01-31[ALSA] Remove sound/driver.hTakashi Iwai
This header file exists only for some hacks to adapt alsa-driver tree. It's useless for building in the kernel. Let's move a few lines in it to sound/core.h and remove it. With this patch, sound/driver.h isn't removed but has just a single compile warning to include it. This should be really killed in future. Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@perex.cz>
2007-10-12USB: move <linux/usb_gadget.h> to <linux/usb/gadget.h>David Brownell
Move <linux/usb_gadget.h> to <linux/usb/gadget.h>, reducing some of the clutter in the main include directory. Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-10-12USB: gadget: gmidi cleanupsDavid Brownell
Clean up the midi gadget, using newer APIs and conventions: - Remove many now-needless #includes - Use the DEBUG (from Kconfig+Makefile) and VERBOSE_DEBUG conventions. - Whitespace fixes There should be no effect on object code size. Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Cc: Ben Williamson <ben.williamson@greyinnovation.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-07-12usb gadget stack: remove usb_ep_*_buffer(), part 1David Brownell
Remove usb_ep_{alloc,free}_buffer() calls, for small dma-coherent buffers. This patch just removes the interface and its users; later patches will remove controller driver support. - This interface is invariably not implemented correctly in the controller drivers (e.g. using dma pools, a mechanism which post-dates the interface by several years). - At this point no gadget driver really *needs* to use it. In current kernels, any driver that needs such a mechanism could allocate a dma pool themselves. Removing this interface is thus a simplification and improvement. Note that the gmidi.c driver had a bug in this area; fixed. Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-02-07USB: <linux/usb_ch9.h> becomes <linux/usb/ch9.h>David Brownell
This moves <linux/usb_ch9.h> to <linux/usb/ch9.h> to reduce some of the clutter of usb header files. Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-12-20USB: gadget driver unbind() is optional; section fixes; miscDavid Brownell
Allow gadget drivers to omit the unbind() method. When they're statically linked, that's an appropriate memory saving tweak. Similarly, provide consistent/simpler handling for a should-not-happen error case: removing a peripheral controller driver when a gadget driver is still loaded. Such code dates back to early versions of the first implementation of the gadget API, and has never been triggered. Includes relevant section annotation fixs for gmidi.c, file_storage.c, and serial.c; we don't yet have an "init or exit" annotation. Also some whitespace fixes in gmidi.c (space at EOL, before tabs, etc). Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-10-04Remove all inclusions of <linux/config.h>Dave Jones
kbuild explicitly includes this at build time. Signed-off-by: Dave Jones <davej@redhat.com>
2006-10-02[PATCH] namespaces: utsname: use init_utsname when appropriateSerge E. Hallyn
In some places, particularly drivers and __init code, the init utsns is the appropriate one to use. This patch replaces those with a the init_utsname helper. Changes: Removed several uses of init_utsname(). Hope I picked all the right ones in net/ipv4/ipconfig.c. These are now changed to utsname() (the per-process namespace utsname) in the previous patch (2/7) [akpm@osdl.org: CIFS fix] Signed-off-by: Serge E. Hallyn <serue@us.ibm.com> Cc: Kirill Korotaev <dev@openvz.org> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Cc: Herbert Poetzl <herbert@13thfloor.at> Cc: Andrey Savochkin <saw@sw.ru> Cc: Serge Hallyn <serue@us.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-09-27USB: gmidi: New USB MIDI Gadget class driver.Ben Williamson
This driver is glue between the USB gadget interface and the ALSA MIDI interface. It allows us to appear as a MIDI Streaming device to a host system on the other end of a USB cable. This includes linux/usb/audio.h and linux/usb/midi.h containing definitions from the relevant USB specifications for USB audio and USB MIDI devices. The following changes have been made since the first RFC posting: * Bug fixes to endpoint handling. * Workaround for USB_REQ_SET_CONFIGURATION handling, not understood yet. * Added SND and SND_RAWMIDI dependencies in Kconfig. * Moved usb_audio.h and usb_midi.h to usb/*.h * Added module parameters for ALSA card index and id. * Added module parameters for USB descriptor IDs and strings. * Removed some unneeded stuff inherited from zero.c, more to go. * Provide DECLARE_* macros for the variable-length structs. * Use kmalloc instead of usb_ep_alloc_buffer. * Limit source to 80 columns. * Return actual error code instead of -ENOMEM in a few places. Signed-off-by: Ben Williamson <ben.williamson@greyinnovation.com> Cc: David Brownell <david-b@pacbell.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
