path: root/drivers/usb/chipidea
2018-04-13usb: chipidea: properly handle host or gadget initialization failureJisheng Zhang
[ Upstream commit c4a0bbbdb7f6e3c37fa6deb3ef28c5ed99da6175 ] If ci_hdrc_host_init() or ci_hdrc_gadget_init() returns error and the error != -ENXIO, as Peter pointed out, "it stands for initialization for host or gadget has failed", so we'd better return failure rather continue. And before destroying the otg, i.e ci_hdrc_otg_destroy(ci), we should also check ci->roles[CI_ROLE_GADGET]. Signed-off-by: Jisheng Zhang <jszhang@marvell.com> Signed-off-by: Peter Chen <peter.chen@nxp.com> Signed-off-by: Sasha Levin <alexander.levin@microsoft.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-10-08usb: chipidea: vbus event may exist before starting gadgetPeter Chen
[ Upstream commit c3b674a04b8ab62a1d35e86714d466af0a0ecc18 ] At some situations, the vbus may already be there before starting gadget. So we need to check vbus event after switching to gadget in order to handle missing vbus event. The typical use cases are plugging vbus cable before driver load or the vbus has already been there after stopping host but before starting gadget. Signed-off-by: Peter Chen <peter.chen@nxp.com> Tested-by: Stephen Boyd <stephen.boyd@linaro.org> Reported-by: Stephen Boyd <stephen.boyd@linaro.org> Signed-off-by: Sasha Levin <alexander.levin@verizon.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-06-14usb: chipidea: debug: check before accessing ci_roleMichael Thalmeier
commit 0340ff83cd4475261e7474033a381bc125b45244 upstream. ci_role BUGs when the role is >= CI_ROLE_END. Signed-off-by: Michael Thalmeier <michael.thalmeier@hale.at> Signed-off-by: Peter Chen <peter.chen@nxp.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-06-14usb: chipidea: udc: fix NULL pointer dereference if udc_start failedJisheng Zhang
commit aa1f058d7d9244423b8c5a75b9484b1115df7f02 upstream. Fix below NULL pointer dereference. we set ci->roles[CI_ROLE_GADGET] too early in ci_hdrc_gadget_init(), if udc_start() fails due to some reason, the ci->roles[CI_ROLE_GADGET] check in ci_hdrc_gadget_destroy can't protect us. We fix this issue by only setting ci->roles[CI_ROLE_GADGET] if udc_start() succeed. [ 1.398550] Unable to handle kernel NULL pointer dereference at virtual address 00000000 ... [ 1.448600] PC is at dma_pool_free+0xb8/0xf0 [ 1.453012] LR is at dma_pool_free+0x28/0xf0 [ 2.113369] [<ffffff80081817d8>] dma_pool_free+0xb8/0xf0 [ 2.118857] [<ffffff800841209c>] destroy_eps+0x4c/0x68 [ 2.124165] [<ffffff8008413770>] ci_hdrc_gadget_destroy+0x28/0x50 [ 2.130461] [<ffffff800840fa30>] ci_hdrc_probe+0x588/0x7e8 [ 2.136129] [<ffffff8008380fb8>] platform_drv_probe+0x50/0xb8 [ 2.142066] [<ffffff800837f494>] driver_probe_device+0x1fc/0x2a8 [ 2.148270] [<ffffff800837f68c>] __device_attach_driver+0x9c/0xf8 [ 2.154563] [<ffffff800837d570>] bus_for_each_drv+0x58/0x98 [ 2.160317] [<ffffff800837f174>] __device_attach+0xc4/0x138 [ 2.166072] [<ffffff800837f738>] device_initial_probe+0x10/0x18 [ 2.172185] [<ffffff800837e58c>] bus_probe_device+0x94/0xa0 [ 2.177940] [<ffffff800837c560>] device_add+0x3f0/0x560 [ 2.183337] [<ffffff8008380d20>] platform_device_add+0x180/0x240 [ 2.189541] [<ffffff800840f0e8>] ci_hdrc_add_device+0x440/0x4f8 [ 2.195654] [<ffffff8008414194>] ci_hdrc_usb2_probe+0x13c/0x2d8 [ 2.201769] [<ffffff8008380fb8>] platform_drv_probe+0x50/0xb8 [ 2.207705] [<ffffff800837f494>] driver_probe_device+0x1fc/0x2a8 [ 2.213910] [<ffffff800837f5ec>] __driver_attach+0xac/0xb0 [ 2.219575] [<ffffff800837d4b0>] bus_for_each_dev+0x60/0xa0 [ 2.225329] [<ffffff800837ec80>] driver_attach+0x20/0x28 [ 2.230816] [<ffffff800837e880>] bus_add_driver+0x1d0/0x238 [ 2.236571] [<ffffff800837fdb0>] driver_register+0x60/0xf8 [ 2.242237] [<ffffff8008380ef4>] __platform_driver_register+0x44/0x50 [ 2.248891] [<ffffff80086fd440>] ci_hdrc_usb2_driver_init+0x18/0x20 [ 2.255365] [<ffffff8008082950>] do_one_initcall+0x38/0x128 [ 2.261121] [<ffffff80086e0d00>] kernel_init_freeable+0x1ac/0x250 [ 2.267414] [<ffffff800852f0b8>] kernel_init+0x10/0x100 [ 2.272810] [<ffffff8008082680>] ret_from_fork+0x10/0x50 Fixes: 3f124d233e97 ("usb: chipidea: add role init and destroy APIs") Signed-off-by: Jisheng Zhang <jszhang@marvell.com> Signed-off-by: Peter Chen <peter.chen@nxp.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-05-14usb: chipidea: Handle extcon events properlyStephen Boyd
commit a89b94b53371bbfa582787c2fa3378000ea4263d upstream. We're currently emulating the vbus and id interrupts in the OTGSC read API, but we also need to make sure that if we're handling the events with extcon that we don't enable the interrupts for those events in the hardware. Therefore, properly emulate this register if we're using extcon, but don't enable the interrupts. This allows me to get my cable connect/disconnect working properly without getting spurious interrupts on my device that uses an extcon for these two events. Acked-by: Peter Chen <peter.chen@nxp.com> Cc: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Cc: "Ivan T. Ivanov" <iivanov.xz@gmail.com> Fixes: 3ecb3e09b042 ("usb: chipidea: Use extcon framework for VBUS and ID detect") Signed-off-by: Stephen Boyd <stephen.boyd@linaro.org> Signed-off-by: Peter Chen <peter.chen@nxp.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-05-14usb: chipidea: Only read/write OTGSC from one placeStephen Boyd
commit f60f8ccd54e03c1afafb2b20ceb029a0eaf7a134 upstream. With the id and vbus detection done via extcon we need to make sure we poll the status of OTGSC properly by considering what the extcon is saying, and not just what the register is saying. Let's move this hw_wait_reg() function to the only place it's used and simplify it for polling the OTGSC register. Then we can make certain we only use the hw_read_otgsc() API to read OTGSC, which will make sure we properly handle extcon events. Acked-by: Peter Chen <peter.chen@nxp.com> Cc: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Cc: "Ivan T. Ivanov" <iivanov.xz@gmail.com> Fixes: 3ecb3e09b042 ("usb: chipidea: Use extcon framework for VBUS and ID detect") Signed-off-by: Stephen Boyd <stephen.boyd@linaro.org> Signed-off-by: Peter Chen <peter.chen@nxp.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-02-26Revert "usb: chipidea: imx: enable CI_HDRC_SET_NON_ZERO_TTHA"Peter Chen
commit 1bc7da87c7410c6990c3251589e3854e64c55af2 upstream. This reverts commit e765bfb73ff7. In the most of cases, we only use one transaction per frame and the frame rate may be high, If the platforms want to support multiple transactions but less frame rate cases like [1] and [2], it can set "non-zero-ttctrl-ttha" at dts. [1] http://www.spinics.net/lists/linux-usb/msg123125.html [2] http://www.spinics.net/lists/linux-usb/msg118679.html Signed-off-by: Peter Chen <peter.chen@nxp.com> Cc: Martin Fuzzey <mfuzzey@parkeon.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-12-02usb: chipidea: move the lock initialization to core filePeter Chen
commit a5d906bb261cde5f881a949d3b0fbaa285dcc574 upstream. This can fix below dump when the lock is accessed at host mode due to it is not initialized. [ 46.119638] INFO: trying to register non-static key. [ 46.124643] the code is fine but needs lockdep annotation. [ 46.130144] turning off the locking correctness validator. [ 46.135659] CPU: 0 PID: 690 Comm: cat Not tainted 4.9.0-rc3-00079-g4b75f1d #1210 [ 46.143075] Hardware name: Freescale i.MX6 SoloX (Device Tree) [ 46.148923] Backtrace: [ 46.151448] [<c010c460>] (dump_backtrace) from [<c010c658>] (show_stack+0x18/0x1c) [ 46.159038] r7:edf52000 [ 46.161412] r6:60000193 [ 46.163967] r5:00000000 [ 46.165035] r4:c0e25c2c [ 46.169109] [<c010c640>] (show_stack) from [<c03f58a4>] (dump_stack+0xb4/0xe8) [ 46.176362] [<c03f57f0>] (dump_stack) from [<c016d690>] (register_lock_class+0x4fc/0x56c) [ 46.184554] r10:c0e25d24 [ 46.187014] r9:edf53e70 [ 46.189569] r8:c1642444 [ 46.190637] r7:ee9da024 [ 46.193191] r6:00000000 [ 46.194258] r5:00000000 [ 46.196812] r4:00000000 [ 46.199185] r3:00000001 [ 46.203259] [<c016d194>] (register_lock_class) from [<c0171294>] (__lock_acquire+0x80/0x10f0) [ 46.211797] r10:c0e25d24 [ 46.214257] r9:edf53e70 [ 46.216813] r8:ee9da024 [ 46.217880] r7:c1642444 [ 46.220435] r6:edcd1800 [ 46.221502] r5:60000193 [ 46.224057] r4:00000000 [ 46.227953] [<c0171214>] (__lock_acquire) from [<c01726c0>] (lock_acquire+0x74/0x94) [ 46.235710] r10:00000001 [ 46.238169] r9:edf53e70 [ 46.240723] r8:edf53f80 [ 46.241790] r7:00000001 [ 46.244344] r6:00000001 [ 46.245412] r5:60000193 [ 46.247966] r4:00000000 [ 46.251866] [<c017264c>] (lock_acquire) from [<c096c8fc>] (_raw_spin_lock_irqsave+0x40/0x54) [ 46.260319] r7:ee1c6a00 [ 46.262691] r6:c062a570 [ 46.265247] r5:20000113 [ 46.266314] r4:ee9da014 [ 46.270393] [<c096c8bc>] (_raw_spin_lock_irqsave) from [<c062a570>] (ci_port_test_show+0x2c/0x70) [ 46.279280] r6:eebd2000 [ 46.281652] r5:ee9da010 [ 46.284207] r4:ee9da014 [ 46.286810] [<c062a544>] (ci_port_test_show) from [<c0248d04>] (seq_read+0x1ac/0x4f8) [ 46.294655] r9:edf53e70 [ 46.297028] r8:edf53f80 [ 46.299583] r7:ee1c6a00 [ 46.300650] r6:00000001 [ 46.303205] r5:00000000 [ 46.304273] r4:eebd2000 [ 46.306850] [<c0248b58>] (seq_read) from [<c039e864>] (full_proxy_read+0x54/0x6c) [ 46.314348] r10:00000000 [ 46.316808] r9:c0a6ad30 [ 46.319363] r8:edf53f80 [ 46.320430] r7:00020000 [ 46.322986] r6:b6de3000 [ 46.324053] r5:ee1c6a00 [ 46.326607] r4:c0248b58 [ 46.330505] [<c039e810>] (full_proxy_read) from [<c021ec98>] (__vfs_read+0x34/0x118) [ 46.338262] r9:edf52000 [ 46.340635] r8:c0107fc4 [ 46.343190] r7:00020000 [ 46.344257] r6:edf53f80 [ 46.346812] r5:c039e810 [ 46.347879] r4:ee1c6a00 [ 46.350447] [<c021ec64>] (__vfs_read) from [<c021fbd0>] (vfs_read+0x8c/0x11c) [ 46.357597] r9:edf52000 [ 46.359969] r8:c0107fc4 [ 46.362524] r7:edf53f80 [ 46.363592] r6:b6de3000 [ 46.366147] r5:ee1c6a00 [ 46.367214] r4:00020000 [ 46.369782] [<c021fb44>] (vfs_read) from [<c0220a4c>] (SyS_read+0x4c/0xa8) [ 46.376672] r8:c0107fc4 [ 46.379045] r7:00020000 [ 46.381600] r6:b6de3000 [ 46.382667] r5:ee1c6a00 [ 46.385222] r4:ee1c6a00 [ 46.387817] [<c0220a00>] (SyS_read) from [<c0107e20>] (ret_fast_syscall+0x0/0x1c) [ 46.395314] r7:00000003 [ 46.397687] r6:b6de3000 [ 46.400243] r5:00020000 [ 46.401310] r4:00020000 Fixes: 26c696c678c4 ("USB: Chipidea: rename struct ci13xxx variables from udc to ci") Signed-off-by: Peter Chen <peter.chen@nxp.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-09-24usb: chipidea: udc: fix NULL ptr dereference in isr_setup_status_phaseClemens Gruber
commit 6f3c4fb6d05e63c9c6d8968302491c3a5457be61 upstream. Problems with the signal integrity of the high speed USB data lines or noise on reference ground lines can cause the i.MX6 USB controller to violate USB specs and exhibit unexpected behavior. It was observed that USBi_UI interrupts were triggered first and when isr_setup_status_phase was called, ci->status was NULL, which lead to a NULL pointer dereference kernel panic. This patch fixes the kernel panic, emits a warning once and returns -EPIPE to halt the device and let the host get stalled. It also adds a comment to point people, who are experiencing this issue, to their USB hardware design. Signed-off-by: Clemens Gruber <clemens.gruber@pqgruber.com> Signed-off-by: Peter Chen <peter.chen@nxp.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-09-07usb: chipidea: udc: don't touch DP when controller is in host modeLi Jun
commit c4e94174983a86c935be1537a73e496b778b0287 upstream. When the controller is configured to be dual role and it's in host mode, if bind udc and gadgt driver, those gadget operations will do gadget disconnect and finally pull down DP line, which will break host function. Signed-off-by: Li Jun <jun.li@nxp.com> Signed-off-by: Peter Chen <peter.chen@nxp.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-03-09usb: chipidea: otg: change workqueue ci_otg as freezablePeter Chen
commit d144dfea8af7108f613139623e63952ed7e69c0c upstream. If we use USB ID pin as wakeup source, and there is a USB block device on this USB OTG (ID) cable, the system will be deadlock after system resume. The root cause for this problem is: the workqueue ci_otg may try to remove hcd before the driver resume has finished, and hcd will disconnect the device on it, then, it will call device_release_driver, and holds the device lock "dev->mutex", but it is never unlocked since it waits workqueue writeback to run to flush the block information, but the workqueue writeback is freezable, it is not thawed before driver resume has finished. When the driver (device: sd 0:0:0:0:) resume goes to dpm_complete, it tries to get its device lock "dev->mutex", but it can't get it forever, then the deadlock occurs. Below call stacks show the situation. So, in order to fix this problem, we need to change workqueue ci_otg as freezable, then the work item in this workqueue will be run after driver's resume, this workqueue will not be blocked forever like above case since the workqueue writeback has been thawed too. Tested at: i.mx6qdl-sabresd and i.mx6sx-sdb. [ 555.178869] kworker/u2:13 D c07de74c 0 826 2 0x00000000 [ 555.185310] Workqueue: ci_otg ci_otg_work [ 555.189353] Backtrace: [ 555.191849] [<c07de4fc>] (__schedule) from [<c07dec6c>] (schedule+0x48/0xa0) [ 555.198912] r10:ee471ba0 r9:00000000 r8:00000000 r7:00000002 r6:ee470000 r5:ee471ba4 [ 555.206867] r4:ee470000 [ 555.209453] [<c07dec24>] (schedule) from [<c07e2fc4>] (schedule_timeout+0x15c/0x1e0) [ 555.217212] r4:7fffffff r3:edc2b000 [ 555.220862] [<c07e2e68>] (schedule_timeout) from [<c07df6c8>] (wait_for_common+0x94/0x144) [ 555.229140] r8:00000000 r7:00000002 r6:ee470000 r5:ee471ba4 r4:7fffffff [ 555.235980] [<c07df634>] (wait_for_common) from [<c07df790>] (wait_for_completion+0x18/0x1c) [ 555.244430] r10:00000001 r9:c0b5563c r8:c0042e48 r7:ef086000 r6:eea4372c r5:ef131b00 [ 555.252383] r4:00000000 [ 555.254970] [<c07df778>] (wait_for_completion) from [<c0043cb8>] (flush_work+0x19c/0x234) [ 555.263177] [<c0043b1c>] (flush_work) from [<c0043fac>] (flush_delayed_work+0x48/0x4c) [ 555.271106] r8:ed5b5000 r7:c0b38a3c r6:eea439cc r5:eea4372c r4:eea4372c [ 555.277958] [<c0043f64>] (flush_delayed_work) from [<c00eae18>] (bdi_unregister+0x84/0xec) [ 555.286236] r4:eea43520 r3:20000153 [ 555.289885] [<c00ead94>] (bdi_unregister) from [<c02c2154>] (blk_cleanup_queue+0x180/0x29c) [ 555.298250] r5:eea43808 r4:eea43400 [ 555.301909] [<c02c1fd4>] (blk_cleanup_queue) from [<c0417914>] (__scsi_remove_device+0x48/0xb8) [ 555.310623] r7:00000000 r6:20000153 r5:ededa950 r4:ededa800 [ 555.316403] [<c04178cc>] (__scsi_remove_device) from [<c0415e90>] (scsi_forget_host+0x64/0x68) [ 555.325028] r5:ededa800 r4:ed5b5000 [ 555.328689] [<c0415e2c>] (scsi_forget_host) from [<c0409828>] (scsi_remove_host+0x78/0x104) [ 555.337054] r5:ed5b5068 r4:ed5b5000 [ 555.340709] [<c04097b0>] (scsi_remove_host) from [<c04cdfcc>] (usb_stor_disconnect+0x50/0xb4) [ 555.349247] r6:ed5b56e4 r5:ed5b5818 r4:ed5b5690 r3:00000008 [ 555.355025] [<c04cdf7c>] (usb_stor_disconnect) from [<c04b3bc8>] (usb_unbind_interface+0x78/0x25c) [ 555.363997] r8:c13919b4 r7:edd3c000 r6:edd3c020 r5:ee551c68 r4:ee551c00 r3:c04cdf7c [ 555.371892] [<c04b3b50>] (usb_unbind_interface) from [<c03dc248>] (__device_release_driver+0x8c/0x118) [ 555.381213] r10:00000001 r9:edd90c00 r8:c13919b4 r7:ee551c68 r6:c0b546e0 r5:c0b5563c [ 555.389167] r4:edd3c020 [ 555.391752] [<c03dc1bc>] (__device_release_driver) from [<c03dc2fc>] (device_release_driver+0x28/0x34) [ 555.401071] r5:edd3c020 r4:edd3c054 [ 555.404721] [<c03dc2d4>] (device_release_driver) from [<c03db304>] (bus_remove_device+0xe0/0x110) [ 555.413607] r5:edd3c020 r4:ef17f04c [ 555.417253] [<c03db224>] (bus_remove_device) from [<c03d8128>] (device_del+0x114/0x21c) [ 555.425270] r6:edd3c028 r5:edd3c020 r4:ee551c00 r3:00000000 [ 555.431045] [<c03d8014>] (device_del) from [<c04b1560>] (usb_disable_device+0xa4/0x1e8) [ 555.439061] r8:edd3c000 r7:eded8000 r6:00000000 r5:00000001 r4:ee551c00 [ 555.445906] [<c04b14bc>] (usb_disable_device) from [<c04a8e54>] (usb_disconnect+0x74/0x224) [ 555.454271] r9:edd90c00 r8:ee551000 r7:ee551c68 r6:ee551c9c r5:ee551c00 r4:00000001 [ 555.462156] [<c04a8de0>] (usb_disconnect) from [<c04a8fb8>] (usb_disconnect+0x1d8/0x224) [ 555.470259] r10:00000001 r9:edd90000 r8:ee471e2c r7:ee551468 r6:ee55149c r5:ee551400 [ 555.478213] r4:00000001 [ 555.480797] [<c04a8de0>] (usb_disconnect) from [<c04ae5ec>] (usb_remove_hcd+0xa0/0x1ac) [ 555.488813] r10:00000001 r9:ee471eb0 r8:00000000 r7:ef3d9500 r6:eded810c r5:eded80b0 [ 555.496765] r4:eded8000 [ 555.499351] [<c04ae54c>] (usb_remove_hcd) from [<c04d4158>] (host_stop+0x28/0x64) [ 555.506847] r6:eeb50010 r5:eded8000 r4:eeb51010 [ 555.511563] [<c04d4130>] (host_stop) from [<c04d09b8>] (ci_otg_work+0xc4/0x124) [ 555.518885] r6:00000001 r5:eeb50010 r4:eeb502a0 r3:c04d4130 [ 555.524665] [<c04d08f4>] (ci_otg_work) from [<c00454f0>] (process_one_work+0x194/0x420) [ 555.532682] r6:ef086000 r5:eeb502a0 r4:edc44480 [ 555.537393] [<c004535c>] (process_one_work) from [<c00457b0>] (worker_thread+0x34/0x514) [ 555.545496] r10:edc44480 r9:ef086000 r8:c0b1a100 r7:ef086034 r6:00000088 r5:edc44498 [ 555.553450] r4:ef086000 [ 555.556032] [<c004577c>] (worker_thread) from [<c004bab4>] (kthread+0xdc/0xf8) [ 555.563268] r10:00000000 r9:00000000 r8:00000000 r7:c004577c r6:edc44480 r5:eddc15c0 [ 555.571221] r4:00000000 [ 555.573804] [<c004b9d8>] (kthread) from [<c000fef0>] (ret_from_fork+0x14/0x24) [ 555.581040] r7:00000000 r6:00000000 r5:c004b9d8 r4:eddc15c0 [ 553.429383] sh D c07de74c 0 694 691 0x00000000 [ 553.435801] Backtrace: [ 553.438295] [<c07de4fc>] (__schedule) from [<c07dec6c>] (schedule+0x48/0xa0) [ 553.445358] r10:edd3c054 r9:edd3c078 r8:edddbd50 r7:edcbbc00 r6:c1377c34 r5:60000153 [ 553.453313] r4:eddda000 [ 553.455896] [<c07dec24>] (schedule) from [<c07deff8>] (schedule_preempt_disabled+0x10/0x14) [ 553.464261] r4:edd3c058 r3:0000000a [ 553.467910] [<c07defe8>] (schedule_preempt_disabled) from [<c07e0bbc>] (mutex_lock_nested+0x1a0/0x3e8) [ 553.477254] [<c07e0a1c>] (mutex_lock_nested) from [<c03e927c>] (dpm_complete+0xc0/0x1b0) [ 553.485358] r10:00561408 r9:edd3c054 r8:c0b4863c r7:edddbd90 r6:c0b485d8 r5:edd3c020 [ 553.493313] r4:edd3c0d0 [ 553.495896] [<c03e91bc>] (dpm_complete) from [<c03e9388>] (dpm_resume_end+0x1c/0x20) [ 553.503652] r9:00000000 r8:c0b1a9d0 r7:c1334ec0 r6:c1334edc r5:00000003 r4:00000010 [ 553.511544] [<c03e936c>] (dpm_resume_end) from [<c0079894>] (suspend_devices_and_enter+0x158/0x504) [ 553.520604] r4:00000000 r3:c1334efc [ 553.524250] [<c007973c>] (suspend_devices_and_enter) from [<c0079e74>] (pm_suspend+0x234/0x2cc) [ 553.532961] r10:00561408 r9:ed6b7300 r8:00000004 r7:c1334eec r6:00000000 r5:c1334ee8 [ 553.540914] r4:00000003 [ 553.543493] [<c0079c40>] (pm_suspend) from [<c0078a6c>] (state_store+0x6c/0xc0) [ 555.703684] 7 locks held by kworker/u2:13/826: [ 555.708140] #0: ("%s""ci_otg"){++++.+}, at: [<c0045484>] process_one_work+0x128/0x420 [ 555.716277] #1: ((&ci->work)){+.+.+.}, at: [<c0045484>] process_one_work+0x128/0x420 [ 555.724317] #2: (usb_bus_list_lock){+.+.+.}, at: [<c04ae5e4>] usb_remove_hcd+0x98/0x1ac [ 555.732626] #3: (&dev->mutex){......}, at: [<c04a8e28>] usb_disconnect+0x48/0x224 [ 555.740403] #4: (&dev->mutex){......}, at: [<c04a8e28>] usb_disconnect+0x48/0x224 [ 555.748179] #5: (&dev->mutex){......}, at: [<c03dc2f4>] device_release_driver+0x20/0x34 [ 555.756487] #6: (&shost->scan_mutex){+.+.+.}, at: [<c04097d0>] scsi_remove_host+0x20/0x104 Cc: Jun Li <jun.li@nxp.com> Signed-off-by: Peter Chen <peter.chen@nxp.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-11-18usb: chipidea: imx: fix a possible NULL dereferenceLABBE Corentin
of_match_device could return NULL, and so cause a NULL pointer dereference later. Reported-by: coverity (CID 1324138) Signed-off-by: LABBE Corentin <clabbe.montjoie@gmail.com> Signed-off-by: Peter Chen <peter.chen@freescale.com>
2015-11-18usb: chipidea: usbmisc_imx: fix a possible NULL dereferenceLABBE Corentin
of_match_device could return NULL, and so cause a NULL pointer dereference later. Renaming tmp_dev to of_id (like all others do) in the process. Reported-by: coverity (CID 1324135) Signed-off-by: LABBE Corentin <clabbe.montjoie@gmail.com> Signed-off-by: Peter Chen <peter.chen@freescale.com>
2015-11-18usb: chipidea: otg: gadget module load and unload supportLi Jun
This patch is to support load and unload gadget driver in full OTG mode. Signed-off-by: Li Jun <jun.li@freescale.com> Signed-off-by: Peter Chen <peter.chen@freescale.com> Tested-by: Jiada Wang <jiada_wang@mentor.com> Cc: <stable@vger.kernel.org> #v4.0+
2015-11-18usb: chipidea: debug: disable usb irq while role switchLi Jun
Since the ci->role will be set after the host role start is complete, there will be nobody cared irq during start host if usb irq enabled. This error can be reproduced on i.mx6 sololite EVK board by: 1. disable otg id irq(IDIE) and disable all real otg properties of usbotg1 in dts. 2. boot up the board with ID cable and usb device connected. 3. echo gadget > /sys/kernel/debug/ci_hdrc.0/role 4. echo host > /sys/kernel/debug/ci_hdrc.0/role 5. irq 212: nobody cared. Cc: <stable@vger.kernel.org> # v3.10+ Signed-off-by: Li Jun <jun.li@freescale.com> Signed-off-by: Peter Chen <peter.chen@freescale.com>
2015-11-18usb: chipidea: imx: refine clock operations to adapt for all platformsPeter Chen
Some i.mx platforms need three clocks to let controller work, but others only need one, refine clock operation to adapt for all platforms, it fixes a regression found at i.mx27. Signed-off-by: Peter Chen <peter.chen@freescale.com> Tested-by: Fabio Estevam <fabio.estevam@freescale.com> Cc: <stable@vger.kernel.org> #v4.1+
2015-10-22Merge tag 'usb-ci-v4.4-rc1' of ↵Greg Kroah-Hartman
git://git.kernel.org/pub/scm/linux/kernel/git/peter.chen/usb into usb-next Peter writes: USB Chipidea updates for v4.4-rc1 - Use extcon framework for VBUS and ID detect - Add imx6sx and imx7d support - Other small changes
2015-10-22usb: chipidea: otg: don't wait vbus drops below BSV when starts hostLi Jun
Some HW design may use ID pin state to control vbus for otg port, so before host role start, the vbus is already turned on, in this case, we do not need wait vbus dropping below BSV. Signed-off-by: Li Jun <jun.li@freescale.com> Signed-off-by: Peter Chen <peter.chen@freescale.com>
2015-10-22chipidea: ci_hdrc_pci: use PCI_VDEVICE() instead of PCI_DEVICE()Sergei Shtylyov
Fix using the PCI_DEVICE() macro instead of less verbose PCI_VDEVICE(). Signed-off-by: Sergei Shtylyov <sergei.shtylyov@cogentembedded.com> Signed-off-by: Peter Chen <peter.chen@freescale.com>
2015-10-22usb: chipidea: imx: add imx6ul usb supportPeter Chen
Add imx6ul usb support. Signed-off-by: Peter chen <peter.chen@freescale.com> Signed-off-by: Li Jun <jun.li@freescale.com> Signed-off-by: Peter Chen <peter.chen@freescale.com>
2015-10-22usb: chipidea: imx: add usb support for imx7dPeter Chen
Add imx7d usb support. Signed-off-by: Peter Chen <peter.chen@freescale.com> Signed-off-by: Li Jun <jun.li@freescale.com>
2015-10-22usb: chipidea: Add support for 'phy-clkgate-delay-us' propertyFabio Estevam
Add support for the optional 'phy-clkgate-delay-us' property that is used to describe the delay time between putting PHY into low power mode and turning off the PHY clock. Signed-off-by: Li Jun <jun.li@freescale.com> Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com> Signed-off-by: Peter Chen <peter.chen@freescale.com>
2015-10-22usb: chipidea: Use extcon framework for VBUS and ID detectIvan T. Ivanov
On recent Qualcomm platforms VBUS and ID lines are not routed to USB PHY LINK controller. Use extcon framework to receive connect and disconnect ID and VBUS notification. Signed-off-by: Ivan T. Ivanov <ivan.ivanov@linaro.org> Signed-off-by: Peter Chen <peter.chen@freescale.com>
2015-09-27usb: common: of_usb_get_dr_mode to usb_get_dr_modeHeikki Krogerus
By using the unified device property interface, the function can be made available for all platforms and not just the ones using DT. Signed-off-by: Heikki Krogerus <heikki.krogerus@linux.intel.com> Signed-off-by: Felipe Balbi <balbi@ti.com>
2015-09-27usb: common: of_usb_get_maximum_speed to usb_get_maximum_speedHeikki Krogerus
2015-09-16usb: chipidea: imx: fix a typo for imx6sxLi Jun
Use imx6sx instead of imx6sl's platform flags for imx6sx. Fixes: e14db48dfcf3 ("usb: chipidea: imx: add runtime power management support") Cc: <stable@vger.kernel.org> # v4.1+ Signed-off-by: Li Jun <jun.li@freescale.com> Signed-off-by: Peter Chen <peter.chen@freescale.com>
2015-09-15usb: chipidea: add xilinx zynq platform dataNathan Sullivan
Due to having hardware tx buffers less than 512 bytes in size, streaming must be enabled on the Zynq for the udc to work at all. Add platform data specific to the Zynq udc, which does not set the CI_HDRC_DISABLE_STREAMING flag. Based on a patch by the same name from the Xilinx vendor tree. Signed-off-by: Nathan Sullivan <nathan.sullivan@ni.com> Signed-off-by: Peter Chen <peter.chen@freescale.com>
2015-09-15usb: chipidea: udc: using the correct stall implementationPeter Chen
According to spec, there are functional and protocol stalls. For functional stall, it is for bulk and interrupt endpoints, below are cases for it: - Host sends SET_FEATURE request for Set-Halt, the udc driver needs to set stall, and return true unconditionally. - The gadget driver may call usb_ep_set_halt to stall certain endpoints, if there is a transfer in pending, the udc driver should not set stall, and return -EAGAIN accordingly. These two kinds of stall need to be cleared by host using CLEAR_FEATURE request (Clear-Halt). For protocol stall, it is for control endpoint, this stall will be set if the control request has failed. This stall will be cleared by next setup request (hardware will do it). It fixed usbtest (drivers/usb/misc/usbtest.c) Test 13 "set/clear halt" test failure, meanwhile, this change has been verified by USB2 CV Compliance Test and MSC Tests. Cc: <stable@vger.kernel.org> #3.10+ Cc: Alan Stern <stern@rowland.harvard.edu> Cc: Felipe Balbi <balbi@ti.com> Signed-off-by: Peter Chen <peter.chen@freescale.com>
2015-08-14Merge tag 'usb-ci-v4.3-rc1' of ↵Greg Kroah-Hartman
git://git.kernel.org/pub/scm/linux/kernel/git/peter.chen/usb into usb-next Peter writes: USB: chipidea updates for v4.3-rc1 The main changes are adding several system interfaces for tuning performance, and each vendors can adjust them according to their design configurations. Others are tiny improvements, like more well siTD supports, USB_DEVICE_A_HNP_SUPPORT supports, etc.
2015-08-14Merge tag 'usb-for-v4.3' of ↵Greg Kroah-Hartman
git://git.kernel.org/pub/scm/linux/kernel/git/balbi/usb into usb-next Felipe writes: usb: patches for v4.3 merge window New support for Allwinne SoC on the MUSB driver has been added to the list of glue layers. MUSB also got support for building all DMA engines in one binary; this will be great for distros. DWC3 now has no trace of dev_dbg()/dev_vdbg() usage. We will rely solely on tracing to debug DWC3. There was also a fix for memory corruption with EP0 when maxpacket size transfers are > 512 bytes. Robert's EP capabilities flags is making EP selection a lot simpler. UDCs are now required to set these flags up when adding endpoints to the framework. Other than these, we have the usual set of miscelaneous cleanups and minor fixes. Signed-off-by: Felipe Balbi <balbi@ti.com>
2015-08-14usb: chipidea: add tx/rx burst size configuration interfacePeter Chen
The user can adjust it through dts or platform data Signed-off-by: Peter Chen <peter.chen@freescale.com>
2015-08-14usb: chipidea: usbmisc_imx: add non-burst setting for imx6Peter Chen
With this setting and AHBBRST at SBUSCFG as "Incremental burst of unspecified length", each non-burst size can be taken as single transfer. It is benefit for non-burst size transfer. Signed-off-by: Peter Chen <peter.chen@freescale.com>
2015-08-14usb: chipidea: add ahb burst configuration interfacePeter Chen
The users can change it through dts or platform data if they want to change the default value. Signed-off-by: Peter Chen <peter.chen@freescale.com>
2015-08-14usb: chipidea: imx: add stream mode enable for device mode at imx6sl/imx6sxPeter Chen
Stream mode enable is known for better performance, this stream mode enable patch has been passed with stress tests at device mode for imx6sl and imx6sx, and no issue is found. Signed-off-by: Peter Chen <peter.chen@freescale.com>
2015-08-14usb: chipidea: define stream mode disable for both rolesPeter Chen
The system bus and chipidea IP have different limitations for both host and device mode. For example, with below errata, we need to enable SDIS(Stream Disable Mode) at host mode. But we don't want it for device mode at the same system. TAR 9000378958 Title: Non-Double Word Aligned Buffer Address Sometimes Causes Host to Hang on OUT Retry Impacted Configuration: Host mode, all transfer types Description: The host core operating in streaming mode may under run while sending the data packet of an OUT transaction. This under run can occur if there are unexpected system delays in fetching the remaining packet data from memory. The host forces a bad CRC on the packet, the device detects the error and discards the packet. The host then retries a Bulk, Interrupt, or Control transfer if an under run occurs according to the USB specification. During simulations, it was found that the host does not issue the retry of the failed bulk OUT. It does not issue any other transactions except SOF packets that have incorrect frame numbers. The second failure mode occurs if the under run occurs on an ISO OUT transaction and the next ISO transaction is a zero byte packet. The host does not issue any transactions (including SOFs). The device detects a Suspend condition, reverts to full speed, and waits for resume signaling. A third failure mode occurs when the host under runs on an ISO OUT and the next ISO in the schedule is an ISO OUT with two max packets of 1024 bytes each. The host should issue MDATA for the first OUT followed by DATA1 for the second. However, it drops the MDATA transaction, and issues the DATA1 transaction. The system impact of this bug is the same regardless of the failure mode observed. The host core hangs, the ehci_ctrl state machine waits for the protocol engine to send the completion status for the corrupted transaction, which never occurs. No indication is sent to the host controller driver, no register bits change and no interrupts occur. Eventually the requesting application times out. Detailed internal behavior: The EHCI control state machine (ehci_ctrl) in the DMA block is responsible for parsing the schedules and initiating all transactions. The ehci_ctrl state machine passes the transaction details to the protocol block by writing the transaction information in to the TxFIFO. It then asserts the pe_hst_run_pkt signal to inform the host protocol state machine (pe_hst_state) that there is a packet in the TxFIFO. A tag of 0x0 indicates a start of packet with the data providing the following information: 35:32 Tag 31:30 Reserved 29:23 Endpoint (lowest 4 bits) 22:16 Address 15:10 Reserved 9:8 Endpoint speed 7:6 Endpoint type 5:6 Data Toggle 3:0 PID The pe_hst_state reads the packet information and constructs the packet and issues it to the PHY interface. The ehci_ctrl state machine writes the start transaction information in to the TxFIFO as 0x03002910c for the OUT packet that had the under run error. However, it writes 0xC3002910C for the retry of the Out transaction, which is incorrect. The pe_hst_state enters a bus timeout state after sending the bad CRC for the packet that under ran. It then purges any data that was back filled in to the TxFIFO for the packet that under ran. The pe_hst_state machine stops purging the TxFIFO when it is empty or if it reads a location that has a tag of 0x0, indicating a start of packet command. The pe_hst_state reads 0xC3002910C and discards it as it does not decode to a start of packet command. It continues to purge the OUT data that has been pre-buffered for the OUT retry . The pe_hst_state detects the hst_packet_run signal and attempts to read the PID and address information from the TxFIFO. This location has packet data and so does not decode to a valid PID and so falls through to the PE_HST_SOF_LOAD state where the frame_num_counter is updated. The frame_num_counter is updated with the data in the TxFIFO. In this case, the data is incorrect as the ehci_ctrl state machine did not initiate the load. The hst_pe_state machine detects the SOF request signal and sends an SOF with the bad frame number. Meanwhile, the ehci_ctrl state machine waits indefinitely in the run_pkt state waiting for the completion status from pe_hst_state machine, which will never happen. The ISO failure case is similar except that there is no retry for ISO. The ehci_ctrl state machine moves to the next transfer in the periodic schedule. If the under run occurs on the last entry of the periodic list then it moves to the Async schedule. In the case of ISO OUT simulations, the next ISO is a zero byte OUT and again the start of packet command gets corrupted. The TxFIFO is empty when the hst_pe_state attempts to read the Address and PID information as the transaction is a zero byte packet. This results in the hst_pe_state machine staying in the GET_PID state, which means that it does not issue any transactions (including SOFs). The device detects a Suspend condition and reverts to full speed mode and waits for a Resume or Reset signal. The EHCI specification allows a Non-DoubleWord (32 bits) offset to be used as a current offset for Buffer Pointer Page 0 of the qTD. In Non-DoubleWord aligned cases, the core reads the packet data from the AHB memory, performs the alignment operation before writing it in to the TxFIFO as a 32 bit data word. An End Of Packet tag (EOP) is written to the TxFIFO after all the packet data has been written in to the TxFIFO. The alignment function is reset to Idle by the EOP tag. The corruption of the start of packet command arises because the packet buffer for the OUT transaction that under ran is not aligned to a DoubleWord, and hence no EOP tag is written to the TxFIFO. The alignment function is still active when the start packet information is written in to the TxFIFO for the retry of the bulk packet or for the next transaction in the case of an under run on an ISO. This results in the corruption of the start tag and the transaction information. Click for waveform showing the command 0x 0000300291 being written in to the TX FIFO for the Out that under ran. Click for waveform showing the command 0xC3002910C written to the TxFIFO instead of 0x 0000300291 Versions affected: Versions 2.10a and previous versions How discovered: Customer simulation Workaround: 1- The EHCI specification allows a non-DoubleWord offset to be used as a current offset for Buffer Pointer Page 0 of the qTD. However, if a DoubleWord offset is used then this issue does not arise. 2- Use non streaming mode to eliminate under runs. Resolution: The fix involves changes to the traffic state machine in the vusb_hs_dma_traf block. The ehci_ctrl state machine updates the context information by encoding the transaction results on the hst_op_context_update signals at the end of a transaction. The signal hst_op_context_update is added to the traffic state machine, and the tx_fifo_under_ran_r signal is generated if the transaction results in an under run error. Click for waveform The traffic state machine then traverses to the do_eop states if the tx_fifo_under_ran error is asserted. Thus an EOP tag is written in to the TxFIFO as shown in this waveform . The EOP tag resets the align state machine to the Idle state ensuring that the next command written by the echi_ctrl state machine does not get corrupted. File(s) modified: RTL code fixed: ….. Method of reproducing: This failure cannot be reproduced in the current test bench. Date Found: March 2010 Date Fixed: June 2010 Update information: Added the RTL code fix Signed-off-by: Peter Chen <peter.chen@freescale.com>
2015-08-14usb: chipidea: udc: zero-length packet is only needed for TXPeter Chen
The zero-length packet is the sendor tells the receiver that there is no more data, so it is only needed at the TX side. Signed-off-by: Peter Chen <peter.chen@freescale.com>
2015-08-14usb: chipidea: host: override hcd reset APIPeter Chen
The system configuration API should be called before the controller run, otherwise, undefined results may occur. So, we override hcd reset API, and add system configuration API after controller reset. Cc: Li Jun <peter.chen@freescale.com> Cc: Alan Stern <stern@rowland.harvard.edu> Acked-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: Peter Chen <peter.chen@freescale.com>
2015-08-14usb: chipidea: imx: properly check for usbmiscTomeu Vizoso
If usbmisc hasn't probed yet, defer the probe. It's not enough to check if the platform device for the OF node of the usbmisc has been registered, but it also needs to have been probed already before we can call imx_usbmisc_init(). This can happen if the order in which devices are probed change due to async probing or on-demand probing of dependencies. Signed-off-by: Tomeu Vizoso <tomeu.vizoso@collabora.com>
2015-08-14usb: chipidea: debug: add runtime pm for register accessLi Jun
Add runtime pm operations for registers access to avoid system hang. Signed-off-by: Li Jun <jun.li@freescale.com>
2015-08-14usb:chipidea:Make the function hw_alloc_repmap have a return type of voidNicholas Krause
This makes the function hw_alloc_repmap be declared to have a return type of void now due to this particular function never returning a error code to its caller due to this function always running successfully to completion nor it's caller putting the return value into a variable in order to check if a error code is passed from the function hw_alloc_repmap when calling this function. Signed-off-by: Nicholas Krause <xerofoify@gmail.com>
2015-08-14usb: chipidea: host: delete the redundancy ci_hdrc structPeter Chen
The struct ci_hdrc is the drvdata for hcd device, so we don't need to introduce extra ci_hdrc structure for ehci. Signed-off-by: Peter Chen <peter.chen@freescale.com>
2015-08-14usb: chipidea: introduce ITC tuning interfacePeter Chen
ITC (Interrupt Threshold Control) is used to set the maximum rate at which the host/device controller will issue interrupts. The default value is 8 (1ms) for it. EHCI core will modify it to 1, but device mode keeps it as default value. In some use cases like Android ADB, it only has one usb request for each direction, and maximum payload data is only 4KB, so the speed is 4MB/s at most, it needs controller to trigger interrupt as fast as possible to increase the speed. The USB performance will be better if the interrupt can be triggered faster. Reduce ITC value is benefit for USB performance, but the interrupt number is increased at the same time, it may increase cpu utilization too. Most of use case cares about performance, but some may care about cpu utilization, so, we leave a platform interface for user. We set ITC as 1 (1 micro-frame) as default value which is aligned with ehci core default value. Signed-off-by: Peter Chen <peter.chen@freescale.com>
2015-08-14usb: chipidea: introduce ci_platform_configurePeter Chen
It is used to configure controller parameters according to platform data, like speed, stream mode, etc, both host and device's initialization need it, most of code are the same for both roles, with this new interface, it can reduce the duplicated code and be easy to maintain in future. Signed-off-by: Peter Chen <peter.chen@freescale.com>
2015-08-14usb: chipidea: otg_fsm: delete the duplicated reset controller operationPeter Chen
At host_stop, it will call usb_remove_hcd, and reset controller later. Signed-off-by: Peter Chen <peter.chen@freescale.com>
2015-08-14usb: chipidea: udc: add USB_DEVICE_A_HNP_SUPPORT request supportPeter Chen
We can support USB OTG 1.3 USB_DEVICE_A_HNP_SUPPORT request when the driver supports OTG FSM mode. Signed-off-by: Peter Chen <peter.chen@freescale.com>
2015-08-14usb: chipidea: imx: enable CI_HDRC_SET_NON_ZERO_TTHAPeter Chen
For i.mx platform, set ttctrl.ttha with non-zero value only affects sitd, and ehci core makes sure the schedule is not full when accepts new request, so it will not occur the transaction which will acorss the SoF. Signed-off-by: Peter Chen <peter.chen@freescale.com>
2015-08-14usb: chipidea: add ttctrl.ttha control interfacePeter Chen
The register of ttctrl.ttha describes like below: - Internal TT Hub Address Representation - RW - Default = 0000000b This field is used to match against the Hub Address field in QH & siTD to determine if the packet is routed to the internal TT for directly attached FS/LS devices. If the Hub Address in the QH or siTD does not match this address then the packet will be broadcast on the High Speed ports destined for a downstream High Speed hub with the address in the QH/siTD. In silicon RTL, this entry only affects QH and siTD, and the hub.addr at both QH and siTD are 0 in ehci core for chipidea (with hcd->has_tt = 1). So, for QH, if the "usage_tt" flag at RTL is 0, set CI_HDRC_SET_NON_ZERO_TTHA will not affect QH (with non-hs device); for siTD, set this flag will change remaining space requirement for the last transaction from 1023 bytes to 188 bytes, it can increase the number of transactions within one frame, ehci periodic schedule code will not queue the packet if the frame space is full, so it is safe to set this flag for siTD. With this flag, it can fix the problem Alan Stern reported below: http://www.spinics.net/lists/linux-usb/msg123125.html And may fix Michael Tessier's problem too. http://www.spinics.net/lists/linux-usb/msg118679.html CC: stern@rowland.harvard.edu CC: michael.tessier@axiontech.ca Signed-off-by: Peter Chen <peter.chen@freescale.com>
2015-08-04usb: chipidea: udc: add ep capabilities supportRobert Baldyga
Convert endpoint configuration to new capabilities model. Signed-off-by: Robert Baldyga <r.baldyga@samsung.com> Signed-off-by: Felipe Balbi <balbi@ti.com>
2015-08-03usb: chipidea: add ci->is_otg condition for otg judgementLi Jun
Since some chipidea based controller is not otg capable, add ci->is_otg condition when setting is_otg flag for gadget. Signed-off-by: Li Jun <jun.li@freescale.com> Reviewed-by: Roger Quadros <rogerq@ti.com> Acked-by: Peter Chen <peter.chen@freescale.com> Signed-off-by: Felipe Balbi <balbi@ti.com>
2015-07-29usb: chipidea: update ci_otg_is_fsm_mode conditionsLi Jun
After introduce usb otg properties, update ci_otg_is_fsm_mode conditions to be depending on both usb hardware properties and usb driver config, also resolve a compile issue in debug.c after the API change. Acked-by: Peter Chen <peter.chen@freescale.com> Signed-off-by: Li Jun <jun.li@freescale.com> Signed-off-by: Felipe Balbi <balbi@ti.com>
