path: root/drivers/uio/uio.c
2018-02-11vfs: do bulk POLL* -> EPOLL* replacementLinus Torvalds
This is the mindless scripted replacement of kernel use of POLL* variables as described by Al, done by this script: for V in IN OUT PRI ERR RDNORM RDBAND WRNORM WRBAND HUP RDHUP NVAL MSG; do L=`git grep -l -w POLL$V | grep -v '^t' | grep -v /um/ | grep -v '^sa' | grep -v '/poll.h$'|grep -v '^D'` for f in $L; do sed -i "-es/^\([^\"]*\)\(\<POLL$V\>\)/\\1E\\2/" $f; done done with de-mangling cleanups yet to come. NOTE! On almost all architectures, the EPOLL* constants have the same values as the POLL* constants do. But they keyword here is "almost". For various bad reasons they aren't the same, and epoll() doesn't actually work quite correctly in some cases due to this on Sparc et al. The next patch from Al will sort out the final differences, and we should be all done. Scripted-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2017-11-28the rest of drivers/*: annotate ->poll() instancesAl Viro
2017-05-16uio: fix incorrect memory leak cleanupSuman Anna
Commit 75f0aef6220d ("uio: fix memory leak") has fixed up some memory leaks during the failure paths of the addition of uio attributes, but still is not correct entirely. A kobject_uevent() failure still needs a kobject_put() and the kobject container structure allocation failure before the kobject_init() doesn't need a kobject_put(). Fix this properly. Fixes: 75f0aef6220d ("uio: fix memory leak") Signed-off-by: Suman Anna <s-anna@ti.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-04-08uio: Allow handling of non page-aligned memory regionsMichal Sojka
Since commit b65502879556 ("uio: we cannot mmap unaligned page contents") addresses and sizes of UIO memory regions must be page-aligned. If the address in the BAR register is not page-aligned (which is the case of the mf264 card), the mentioned commit forces the UIO driver to round the address down to the page size. Then, there is no easy way for user-space to learn the offset of the actual memory region within the page, because the offset seen in /sys/class/uio/uio?/maps/map?/offset is calculated from the rounded address and thus it is always zero. Fix that problem by including the offset in struct uio_mem. UIO drivers can set this field and userspace can read its value from /sys/class/uio/uio?/maps/map?/offset. The following commits update the uio_mf264 driver to set this new offs field. Drivers for hardware with page-aligned BARs need not to be modified provided that they initialize struct uio_info (which contains uio_mem) with zeros. Signed-off-by: Michal Sojka <sojkam1@fel.cvut.cz> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-03-02sched/headers: Prepare to move signal wakeup & sigpending methods from ↵Ingo Molnar
<linux/sched.h> into <linux/sched/signal.h> Fix up affected files that include this signal functionality via sched.h. Acked-by: Linus Torvalds <torvalds@linux-foundation.org> Cc: Mike Galbraith <efault@gmx.de> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: linux-kernel@vger.kernel.org Signed-off-by: Ingo Molnar <mingo@kernel.org>
2017-02-24mm, fs: reduce fault, page_mkwrite, and pfn_mkwrite to take only vmfDave Jiang
->fault(), ->page_mkwrite(), and ->pfn_mkwrite() calls do not need to take a vma and vmf parameter when the vma already resides in vmf. Remove the vma parameter to simplify things. [arnd@arndb.de: fix ARM build] Link: http://lkml.kernel.org/r/20170125223558.1451224-1-arnd@arndb.de Link: http://lkml.kernel.org/r/148521301778.19116.10840599906674778980.stgit@djiang5-desk3.ch.intel.com Signed-off-by: Dave Jiang <dave.jiang@intel.com> Signed-off-by: Arnd Bergmann <arnd@arndb.de> Reviewed-by: Ross Zwisler <ross.zwisler@linux.intel.com> Cc: Theodore Ts'o <tytso@mit.edu> Cc: Darrick J. Wong <darrick.wong@oracle.com> Cc: Matthew Wilcox <mawilcox@microsoft.com> Cc: Dave Hansen <dave.hansen@intel.com> Cc: Christoph Hellwig <hch@lst.de> Cc: Jan Kara <jack@suse.com> Cc: Dan Williams <dan.j.williams@intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-05-01uio: add missing error codesDan Carpenter
My static checker complains that "ret" could be uninitialized at the end, which is true but it's more likely that it would be set to zero. Signed-off-by: Dan Carpenter <dan.carpenter@oracle.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-10-04uio: fix false positive __might_sleep warning splatMichal Hocko
Andy has reported a __might_sleep warning [ 5174.883617] WARNING: CPU: 0 PID: 1532 at /home/agrover/git/kernel/kernel/sched/core.c:7389 __might_sleep+0x7d/0x90() [ 5174.884407] do not call blocking ops when !TASK_RUNNING; state=1 set at [<ffffffffa02a5821>] uio_read+0x91/0x170 [uio] [ 5174.885198] Modules linked in: tcm_loop target_core_user uio target_core_pscsi target_core_file target_core_iblock iscsi_target_mod target_core_mod uinput fuse nfsv3 nfs_acl nfs lockd grace fscache sunrpc microcode i2c_piix4 virtio_balloon i2c_core xfs libcrc32c crc32c_intel virtio_net virtio_blk [ 5174.887351] CPU: 0 PID: 1532 Comm: tcmu-runner Not tainted 4.2.0-rc7+ [ 5174.887853] Hardware name: QEMU Standard PC (i440FX + PIIX, 1996), BIOS 1.8.1-20150318_183358- 04/01/2014 [ 5174.888633] ffffffff81a3b870 ffff880045393ca8 ffffffff817afaae 0000000000000000 [ 5174.889224] ffff880045393cf8 ffff880045393ce8 ffffffff8109a846 ffff880045393cd8 [ 5174.889793] ffffffffa02a7150 00000000000002dc 0000000000000000 ffff880045008000 [ 5174.890375] Call Trace: [ 5174.890562] [<ffffffff817afaae>] dump_stack+0x4c/0x65 [ 5174.890938] [<ffffffff8109a846>] warn_slowpath_common+0x86/0xc0 [ 5174.891388] [<ffffffff8109a8c6>] warn_slowpath_fmt+0x46/0x50 [ 5174.891808] [<ffffffffa02a5821>] ? uio_read+0x91/0x170 [uio] [ 5174.892237] [<ffffffffa02a5821>] ? uio_read+0x91/0x170 [uio] [ 5174.892653] [<ffffffff810c584d>] __might_sleep+0x7d/0x90 [ 5174.893055] [<ffffffff811ea023>] __might_fault+0x43/0xa0 [ 5174.893448] [<ffffffff817b31ce>] ? schedule+0x3e/0x90 [ 5174.893820] [<ffffffffa02a58c2>] uio_read+0x132/0x170 [uio] [ 5174.894240] [<ffffffff810cbb80>] ? wake_up_q+0x70/0x70 [ 5174.894620] [<ffffffff81236168>] __vfs_read+0x28/0xe0 [ 5174.894993] [<ffffffff81353233>] ? security_file_permission+0xa3/0xc0 [ 5174.895541] [<ffffffff8123678f>] ? rw_verify_area+0x4f/0xf0 [ 5174.896006] [<ffffffff812368ba>] vfs_read+0x8a/0x140 [ 5174.896391] [<ffffffff817b28f5>] ? __schedule+0x425/0xcc0 [ 5174.896788] [<ffffffff812375d9>] SyS_read+0x49/0xb0 The warning is a false positive because uio_read doesn't depent on TASK_INTERRUPTIBLE after copy_to_user so it is safe to silence the warning by an explicit setting the state to TASK_RUNNING in the path which might call into TASK_RUNNING. Reported-by: Andy Grover <agrover@redhat.com> Signed-off-by: Michal Hocko <mhocko@suse.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-08-05uio: Destroy uio_idr on module exitJohannes Thumshirn
Destroy uio_idr on module exit, reclaiming the allocated memory. This was detected by the following semantic patch (written by Luis Rodriguez <mcgrof@suse.com>) <SmPL> @ defines_module_init @ declarer name module_init, module_exit; declarer name DEFINE_IDR; identifier init; @@ module_init(init); @ defines_module_exit @ identifier exit; @@ module_exit(exit); @ declares_idr depends on defines_module_init && defines_module_exit @ identifier idr; @@ DEFINE_IDR(idr); @ on_exit_calls_destroy depends on declares_idr && defines_module_exit @ identifier declares_idr.idr, defines_module_exit.exit; @@ exit(void) { ... idr_destroy(&idr); ... } @ missing_module_idr_destroy depends on declares_idr && defines_module_exit && !on_exit_calls_destroy @ identifier declares_idr.idr, defines_module_exit.exit; @@ exit(void) { ... +idr_destroy(&idr); } </SmPL> Signed-off-by: Johannes Thumshirn <jthumshirn@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-05-24uio: don't free irq that was not requestedStephen Hemminger
UIO base driver should only free_irq that it has requested. UIO supports drivers without interrupts (irq == 0) or custom handlers. This fixes warnings like: WARNING: CPU: 1 PID: 5478 at kernel/irq/manage.c:1244 __free_irq+0xa9/0x1e0() Trying to free already-free IRQ 0 Signed-off-by: Stephen Hemminger <stephen@networkplumber.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-03-20uio: Request/free irq separate from dev lifecycleBrian Russell
Separate irq request/free from the device lifecycle. After device unregister the parent module can call pci_disable_msi. >From the PCI MSI how to: "Before calling this function, a device driver must always call free_irq() on any interrupt for which it previously called request_irq(). Failure to do so results in a BUG_ON(), leaving the device with MSI enabled and thus leaking its vector." So we need to separately free the irq at unregister to allow the device to be kept around in the case of it still having open FDs. Signed-off-by: Brian Russell <brussell@brocade.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-11-07uio: support memory sizes larger than 32 bitsCristian Stoica
This is a completion to 27a90700a4275c5178b883b65927affdafa5185c The size field is also increased to allow values larger than 32 bits on platforms that have more than 32 bit physical addresses. Signed-off-by: Cristian Stoica <cristian.stoica@freescale.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-10-02uio: Export definition of struct uio_deviceAndy Grover
In order to prevent a O(n) search of the filesystem to link up its uio node with its target configuration, TCMU needs to know the minor number that UIO assigned. Expose the definition of this struct so TCMU can access this field. Signed-off-by: Andy Grover <agrover@redhat.com> Signed-off-by: Nicholas Bellinger <nab@linux-iscsi.org>
2014-06-17Revert "uio: fix vma io range check in mmap"Greg Kroah-Hartman
This reverts commit ddb09754e6c7239e302c7b675df9bbd415f8de5d. Linus objected to this originally, I can see why it might be needed, but given that no one spoke up defending this patch, I'm going to revert it. If you have hardware that requires this change, please speak up in the future and defend the patch. Reported-by: Linus Torvalds <torvalds@linux-foundation.org> Cc: Bin Wang <binw@marvell.com> Cc: Nobuhiro Iwamatsu <nobuhiro.iwamatsu.yj@renesas.com> Cc: Norbert Ciosek <norbertciosek@gmail.com> Cc: stable <stable@vger.kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-05-27uio: fix vma io range check in mmapBin Wang
the vma range size is always page size aligned in mmap, while the real io space range may not be page aligned, thus leading to range check failure in the uio_mmap_physical(). for example, in a case of io range size "mem->size == 1KB", and we have (vma->vm_end - vma->vm_start) == 4KB, due to "len" is aligned to page size in do_mmap_pgoff(). now fix this issue by align mem->size to page size in the check. Signed-off-by: Bin Wang <binw@marvell.com> Signed-off-by: Nobuhiro Iwamatsu <nobuhiro.iwamatsu.yj@renesas.com> Cc: stable <stable@vger.kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-12-20uio: fix devm_request_irq usageAaro Koskinen
Commit e6789cd3dfb553077606ccafeb05e0043f072481 (uio: Simplify uio error path by using devres functions) converted uio to use devm_request_irq(). This introduced a change in behaviour since the IRQ is associated with the parent device instead of the created UIO device. The IRQ will remain active after uio_unregister_device() is called, and some drivers will crash because of this. The patch fixes this. Signed-off-by: Aaro Koskinen <aaro.koskinen@nsn.com> Cc: stable <stable@vger.kernel.org> # 3.13 Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-12-02uio: we cannot mmap unaligned page contentsLinus Torvalds
In commit 7314e613d5ff ("Fix a few incorrectly checked [io_]remap_pfn_range() calls") the uio driver started more properly checking the passed-in user mapping arguments against the size of the actual uio driver data. That in turn exposed that some driver authors apparently didn't realize that mmap can only work on a page granularity, and had tried to use it with smaller mappings, with the new size check catching that out. So since it's not just the user mmap() arguments that can be confused, make the uio mmap code also verify that the uio driver has the memory allocated at page boundaries in order for mmap to work. If the device memory isn't properly aligned, we return [ENODEV] The fildes argument refers to a file whose type is not supported by mmap(). as per the open group documentation on mmap. Reported-by: Holger Brunck <holger.brunck@keymile.com> Acked-by: Greg KH <gregkh@linuxfoundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-11-07Merge tag 'char-misc-3.13-rc1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/char-misc Pull char/misc patches from Greg KH: "Here's the big char/misc driver patchset for 3.13-rc1. Lots of stuff in here, including some new drivers for Intel's "MIC" co-processor devices, and a new eeprom driver. Other things include the driver attribute cleanups, extcon driver updates, hyperv updates, and a raft of other miscellaneous driver fixes. All of these have been in linux-next for a while" * tag 'char-misc-3.13-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/char-misc: (121 commits) misc: mic: Fixes for randconfig build errors and warnings. tifm: fix error return code in tifm_7xx1_probe() w1-gpio: Use devm_* functions w1-gpio: Detect of_gpio_error for first gpio uio: Pass pointers to virt_to_page(), not integers uio: fix memory leak misc/at24: avoid infinite loop on write() misc/93xx46: avoid infinite loop on write() misc: atmel_pwm: add deferred-probing support mei: wd: host_init propagate error codes from called functions mei: replace stray pr_debug with dev_dbg mei: bus: propagate error code returned by mei_me_cl_by_id mei: mei_cl_link remove duplicated check for open_handle_count mei: print correct device state during unexpected reset mei: nfc: fix memory leak in error path lkdtm: add tests for additional page permissions lkdtm: adjust recursion size to avoid warnings lkdtm: isolate stack corruption test mei: move host_clients_map cleanup to device init mei: me: downgrade two errors to debug level ...
2013-10-29uio: Pass pointers to virt_to_page(), not integersBen Hutchings
Most architectures define virt_to_page() as a macro that casts its argument such that an argument of type unsigned long will be accepted without complaint. However, the proper type is void *, and passing unsigned long results in a warning on MIPS. Compile-tested only. Signed-off-by: Ben Hutchings <ben@decadent.org.uk> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-10-29uio: fix memory leakCong Ding
we have to call kobject_put() to clean up the kobject after function kobject_init(), kobject_add(), or kobject_uevent() is called. Signed-off-by: Cong Ding <dinggnu@gmail.com> Acked-by: Sebastian Andrzej Siewior <sebastian@breakpoint.cc> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-10-29Fix a few incorrectly checked [io_]remap_pfn_range() callsLinus Torvalds
Nico Golde reports a few straggling uses of [io_]remap_pfn_range() that really should use the vm_iomap_memory() helper. This trivially converts two of them to the helper, and comments about why the third one really needs to continue to use remap_pfn_range(), and adds the missing size check. Reported-by: Nico Golde <nico@ngolde.de> Cc: stable@kernel.org Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org.
2013-09-26uio: Simplify uio error path by using devres functionsMichal Simek
Using devres functions simplify driver error path. - Use devm_kzalloc - Use devm_request_irq Signed-off-by: Michal Simek <michal.simek@xilinx.com> Reviewed-by: Pavel Machek <pavel@ucw.cz> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-09-03Merge tag 'driver-core-3.12-rc1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core Pull driver core patches from Greg KH: "Here's the big driver core pull request for 3.12-rc1. Lots of tiny changes here fixing up the way sysfs attributes are created, to try to make drivers simpler, and fix a whole class race conditions with creations of device attributes after the device was announced to userspace. All the various pieces are acked by the different subsystem maintainers" * tag 'driver-core-3.12-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core: (119 commits) firmware loader: fix pending_fw_head list corruption drivers/base/memory.c: introduce help macro to_memory_block dynamic debug: line queries failing due to uninitialized local variable sysfs: sysfs_create_groups returns a value. debugfs: provide debugfs_create_x64() when disabled rbd: convert bus code to use bus_groups firmware: dcdbas: use binary attribute groups sysfs: add sysfs_create/remove_groups for when SYSFS is not enabled driver core: add #include <linux/sysfs.h> to core files. HID: convert bus code to use dev_groups Input: serio: convert bus code to use drv_groups Input: gameport: convert bus code to use drv_groups driver core: firmware: use __ATTR_RW() driver core: core: use DEVICE_ATTR_RO driver core: bus: use DRIVER_ATTR_WO() driver core: create write-only attribute macros for devices and drivers sysfs: create __ATTR_WO() driver-core: platform: convert bus code to use dev_groups workqueue: convert bus code to use dev_groups MEI: convert bus code to use dev_groups ...
2013-08-12uio: drop unused vma_count member in uio_device structUwe Kleine-König
vma_count is used write-only and so fails to be useful. So remove it. Signed-off-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-08-12uio: provide vm access to UIO_MEM_PHYS mapsUwe Kleine-König
This makes it possible to let gdb access mappings of the process that is being debugged. uio_mmap_logical was moved and uio_vm_ops renamed to group related code and differentiate to new stuff. Signed-off-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-07-24UIO: convert class code to use dev_groupsGreg Kroah-Hartman
The dev_attrs field of struct class is going away soon, dev_groups should be used instead. This converts the uio class code to use the correct field. Cc: Hans J. Koch <hjk@hansjkoch.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-07-03uio: use vma_pages() to replace (vm_end - vm_start) >> PAGE_SHIFTLibin
(*->vm_end - *->vm_start) >> PAGE_SHIFT operation is implemented as a inline funcion vma_pages() in linux/mm.h, so using it. Signed-off-by: Libin <huawei.libin@huawei.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-03-29drivers: uio: Fix UIO device registration failureDamian Hobson-Garcia
Until recently uio_get_minor() returned 0 for success and a negative value on failure. This became non-negative for suceess and negative for failure. Restore the original return value spec so that we can successfully initialize UIO devices with a non-zero minor device number. Cc: "Hans J. Koch" <hjk@hansjkoch.de> Signed-off-by: Damian Hobson-Garcia <dhobsong@igel.co.jp> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-02-27uio: convert to idr_alloc()Tejun Heo
Convert to the much saner new idr interface. Signed-off-by: Tejun Heo <tj@kernel.org> Acked-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Cc: "Hans J. Koch" <hjk@hansjkoch.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-10-09mm: kill vma flag VM_RESERVED and mm->reserved_vm counterKonstantin Khlebnikov
A long time ago, in v2.4, VM_RESERVED kept swapout process off VMA, currently it lost original meaning but still has some effects: | effect | alternative flags -+------------------------+--------------------------------------------- 1| account as reserved_vm | VM_IO 2| skip in core dump | VM_IO, VM_DONTDUMP 3| do not merge or expand | VM_IO, VM_DONTEXPAND, VM_HUGETLB, VM_PFNMAP 4| do not mlock | VM_IO, VM_DONTEXPAND, VM_HUGETLB, VM_PFNMAP This patch removes reserved_vm counter from mm_struct. Seems like nobody cares about it, it does not exported into userspace directly, it only reduces total_vm showed in proc. Thus VM_RESERVED can be replaced with VM_IO or pair VM_DONTEXPAND | VM_DONTDUMP. remap_pfn_range() and io_remap_pfn_range() set VM_IO|VM_DONTEXPAND|VM_DONTDUMP. remap_vmalloc_range() set VM_DONTEXPAND | VM_DONTDUMP. [akpm@linux-foundation.org: drivers/vfio/pci/vfio_pci.c fixup] Signed-off-by: Konstantin Khlebnikov <khlebnikov@openvz.org> Cc: Alexander Viro <viro@zeniv.linux.org.uk> Cc: Carsten Otte <cotte@de.ibm.com> Cc: Chris Metcalf <cmetcalf@tilera.com> Cc: Cyrill Gorcunov <gorcunov@openvz.org> Cc: Eric Paris <eparis@redhat.com> Cc: H. Peter Anvin <hpa@zytor.com> Cc: Hugh Dickins <hughd@google.com> Cc: Ingo Molnar <mingo@redhat.com> Cc: James Morris <james.l.morris@oracle.com> Cc: Jason Baron <jbaron@redhat.com> Cc: Kentaro Takeda <takedakn@nttdata.co.jp> Cc: Matt Helsley <matthltc@us.ibm.com> Cc: Nick Piggin <npiggin@kernel.dk> Cc: Oleg Nesterov <oleg@redhat.com> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Robert Richter <robert.richter@amd.com> Cc: Suresh Siddha <suresh.b.siddha@intel.com> Cc: Tetsuo Handa <penguin-kernel@I-love.SAKURA.ne.jp> Cc: Venkatesh Pallipadi <venki@google.com> Acked-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-10-18uio: Support physical addresses >32 bits on 32-bit systemsKai Jiang
To support >32-bit physical addresses for UIO_MEM_PHYS type we need to extend the width of 'addr' in struct uio_mem. Numerous platforms like embedded PPC, ARM, and X86 have support for systems with larger physical address than logical. Since 'addr' may contain a physical, logical, or virtual address the easiest solution is to just change the type to 'phys_addr_t' which should always be greater than or equal to the sizeof(void *) such that it can properly hold any of the address types. For physical address we can support up to a 44-bit physical address on a typical 32-bit system as we utilize remap_pfn_range() for the mapping of the memory region and pfn's are represnted by shifting the address by the page size (typically 4k). Signed-off-by: Kai Jiang <Kai.Jiang@freescale.com> Signed-off-by: Minghuan Lian <Minghuan.Lian@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org> Signed-off-by: Hans J. Koch <hjk@hansjkoch.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-08-22drivers:uio:change the goto label to consistent with othersWanlong Gao
Remove one *goto* label in uio.c. Signed-off-by: Wanlong Gao <gaowanlong@cn.fujitsu.com> Signed-off-by: "Hans J. Koch" <hjk@hansjkoch.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-04-19uio: fix allocating minor id for uio deviceHillf Danton
The number of uio devices that could be used should be less than UIO_MAX_DEVICES by design, and this work guards any cases in which id more than UIO_MAX_DEVICES is utilized. Signed-off-by: Hillf Danton <dhillf@gmail.com> Signed-off-by: Hans J. Koch <hjk@hansjkoch.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-04-19uio: fix finding mm index for vmaHillf Danton
When finding mm index for vma it looks more flexible that the mm could be sparse, and both the size of mm and the pgoff of vma could give correct selection. Signed-off-by: Hillf Danton <dhillf@gmail.com> Signed-off-by: Hans J. Koch <hjk@hansjkoch.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-11-10uio: Change mail address of Hans J. KochHans J. Koch
My old mail address doesn't exist anymore. This changes all occurrences to my new address. Signed-off-by: Hans J. Koch <hjk@hansjkoch.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-10-22Merge git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core-2.6: (31 commits) driver core: Display error codes when class suspend fails Driver core: Add section count to memory_block struct Driver core: Add mutex for adding/removing memory blocks Driver core: Move find_memory_block routine hpilo: Despecificate driver from iLO generation driver core: Convert link_mem_sections to use find_memory_block_hinted. driver core: Introduce find_memory_block_hinted which utilizes kset_find_obj_hinted. kobject: Introduce kset_find_obj_hinted. driver core: fix build for CONFIG_BLOCK not enabled driver-core: base: change to new flag variable sysfs: only access bin file vm_ops with the active lock sysfs: Fail bin file mmap if vma close is implemented. FW_LOADER: fix kconfig dependency warning on HOTPLUG uio: Statically allocate uio_class and use class .dev_attrs. uio: Support 2^MINOR_BITS minors uio: Cleanup irq handling. uio: Don't clear driver data uio: Fix lack of locking in init_uio_class SYSFS: Allow boot time switching between deprecated and modern sysfs layout driver core: remove CONFIG_SYSFS_DEPRECATED_V2 but keep it for block devices ...
2010-10-22uio: Statically allocate uio_class and use class .dev_attrs.Eric W. Biederman
Instead of adding uio class attributes manually after the uio device has been created and we have sent a uevent to userspace, use the class attribute mechanism. This removes races and makes the code simpler. At the same time don't bother to dynamically allocate a struct class for uio, just declare one statically. Less code is needed and it is easier to set the class parameters.tune the class Signed-off-by: Eric W. Biederman <ebiederm@aristanetworks.com> Reviewed-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Hans J. Koch <hjk@linutronix.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-10-22uio: Support 2^MINOR_BITS minorsEric W. Biederman
register_chrdev limits uio devices to 256 minor numbers which causes problems on one system I have with 384+ uio devices. So instead set UIO_MAX_DEVICES to the maximum number of minors and use alloc_chrdev_region to reserve the uio minors. The final result is that the code works the same but the uio driver now supports any minor the idr allocator comes up with. Signed-off-by: Eric W. Biederman <ebiederm@aristanetworks.com> Reviewed-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Hans J. Koch <hjk@linutronix.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-10-22uio: Cleanup irq handling.Eric W. Biederman
Change the value of UIO_IRQ_NONE -2 to 0. 0 is well defined in the rest of the kernel as the value to indicate an irq has not been assigned. Update the calls to request_irq and free_irq to only ignore UIO_IRQ_NONE and UIO_IRQ_CUSTOM allowing the rest of the kernel's possible irq numbers to be used. Signed-off-by: Eric W. Biederman <ebiederm@aristanetworks.com> Reviewed-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Hans J. Koch <hjk@linutronix.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-10-22uio: Don't clear driver dataEric W. Biederman
Currently uio sets it's driver data to NULL just as it is unregistering attributes. sysfs maks the guaranatee that it will not call attributes after device_destroy is called so this is unncessary and leads to lots of unnecessary code in uio.c Signed-off-by: Eric W. Biederman <ebiederm@aristanetworks.com> Reviewed-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Hans J. Koch <hjk@linutronix.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-10-22uio: Fix lack of locking in init_uio_classEric W. Biederman
There is no locking in init_uio_class so multiple drivers can race and create multiple uio classes. Fix this by simplifying the code. In particular always register the uio class during module_init and make things simpler. Signed-off-by: Eric W. Biederman <ebiederm@aristanetworks.com> Reviewed-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Hans J. Koch <hjk@linutronix.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
All file_operations should get a .llseek operation so we can make nonseekable_open the default for future file operations without a .llseek pointer. The three cases that we can automatically detect are no_llseek, seq_lseek and default_llseek. For cases where we can we can automatically prove that the file offset is always ignored, we use noop_llseek, which maintains the current behavior of not returning an error from a seek. New drivers should normally not use noop_llseek but instead use no_llseek and call nonseekable_open at open time. Existing drivers can be converted to do the same when the maintainer knows for certain that no user code relies on calling seek on the device file. The generated code is often incorrectly indented and right now contains comments that clarify for each added line why a specific variant was chosen. In the version that gets submitted upstream, the comments will be gone and I will manually fix the indentation, because there does not seem to be a way to do that using coccinelle. Some amount of new code is currently sitting in linux-next that should get the same modifications, which I will do at the end of the merge window. Many thanks to Julia Lawall for helping me learn to write a semantic patch that does all this. ===== begin semantic patch ===== // This adds an llseek= method to all file operations, // as a preparation for making no_llseek the default. // // The rules are // - use no_llseek explicitly if we do nonseekable_open // - use seq_lseek for sequential files // - use default_llseek if we know we access f_pos // - use noop_llseek if we know we don't access f_pos, // but we still want to allow users to call lseek // @ open1 exists @ identifier nested_open; @@ nested_open(...) { <+... nonseekable_open(...) ...+> } @ open exists@ identifier open_f; identifier i, f; identifier open1.nested_open; @@ int open_f(struct inode *i, struct file *f) { <+... ( nonseekable_open(...) | nested_open(...) ) ...+> } @ read disable optional_qualifier exists @ identifier read_f; identifier f, p, s, off; type ssize_t, size_t, loff_t; expression E; identifier func; @@ ssize_t read_f(struct file *f, char *p, size_t s, loff_t *off) { <+... ( *off = E | *off += E | func(..., off, ...) | E = *off ) ...+> } @ read_no_fpos disable optional_qualifier exists @ identifier read_f; identifier f, p, s, off; type ssize_t, size_t, loff_t; @@ ssize_t read_f(struct file *f, char *p, size_t s, loff_t *off) { ... when != off } @ write @ identifier write_f; identifier f, p, s, off; type ssize_t, size_t, loff_t; expression E; identifier func; @@ ssize_t write_f(struct file *f, const char *p, size_t s, loff_t *off) { <+... ( *off = E | *off += E | func(..., off, ...) | E = *off ) ...+> } @ write_no_fpos @ identifier write_f; identifier f, p, s, off; type ssize_t, size_t, loff_t; @@ ssize_t write_f(struct file *f, const char *p, size_t s, loff_t *off) { ... when != off } @ fops0 @ identifier fops; @@ struct file_operations fops = { ... }; @ has_llseek depends on fops0 @ identifier fops0.fops; identifier llseek_f; @@ struct file_operations fops = { ... .llseek = llseek_f, ... }; @ has_read depends on fops0 @ identifier fops0.fops; identifier read_f; @@ struct file_operations fops = { ... .read = read_f, ... }; @ has_write depends on fops0 @ identifier fops0.fops; identifier write_f; @@ struct file_operations fops = { ... .write = write_f, ... }; @ has_open depends on fops0 @ identifier fops0.fops; identifier open_f; @@ struct file_operations fops = { ... .open = open_f, ... }; // use no_llseek if we call nonseekable_open //////////////////////////////////////////// @ nonseekable1 depends on !has_llseek && has_open @ identifier fops0.fops; identifier nso ~= "nonseekable_open"; @@ struct file_operations fops = { ... .open = nso, ... +.llseek = no_llseek, /* nonseekable */ }; @ nonseekable2 depends on !has_llseek @ identifier fops0.fops; identifier open.open_f; @@ struct file_operations fops = { ... .open = open_f, ... +.llseek = no_llseek, /* open uses nonseekable */ }; // use seq_lseek for sequential files ///////////////////////////////////// @ seq depends on !has_llseek @ identifier fops0.fops; identifier sr ~= "seq_read"; @@ struct file_operations fops = { ... .read = sr, ... +.llseek = seq_lseek, /* we have seq_read */ }; // use default_llseek if there is a readdir /////////////////////////////////////////// @ fops1 depends on !has_llseek && !nonseekable1 && !nonseekable2 && !seq @ identifier fops0.fops; identifier readdir_e; @@ // any other fop is used that changes pos struct file_operations fops = { ... .readdir = readdir_e, ... +.llseek = default_llseek, /* readdir is present */ }; // use default_llseek if at least one of read/write touches f_pos ///////////////////////////////////////////////////////////////// @ fops2 depends on !fops1 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @ identifier fops0.fops; identifier read.read_f; @@ // read fops use offset struct file_operations fops = { ... .read = read_f, ... +.llseek = default_llseek, /* read accesses f_pos */ }; @ fops3 depends on !fops1 && !fops2 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @ identifier fops0.fops; identifier write.write_f; @@ // write fops use offset struct file_operations fops = { ... .write = write_f, ... + .llseek = default_llseek, /* write accesses f_pos */ }; // Use noop_llseek if neither read nor write accesses f_pos /////////////////////////////////////////////////////////// @ fops4 depends on !fops1 && !fops2 && !fops3 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @ identifier fops0.fops; identifier read_no_fpos.read_f; identifier write_no_fpos.write_f; @@ // write fops use offset struct file_operations fops = { ... .write = write_f, .read = read_f, ... +.llseek = noop_llseek, /* read and write both use no f_pos */ }; @ depends on has_write && !has_read && !fops1 && !fops2 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @ identifier fops0.fops; identifier write_no_fpos.write_f; @@ struct file_operations fops = { ... .write = write_f, ... +.llseek = noop_llseek, /* write uses no f_pos */ }; @ depends on has_read && !has_write && !fops1 && !fops2 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @ identifier fops0.fops; identifier read_no_fpos.read_f; @@ struct file_operations fops = { ... .read = read_f, ... +.llseek = noop_llseek, /* read uses no f_pos */ }; @ depends on !has_read && !has_write && !fops1 && !fops2 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @ identifier fops0.fops; @@ struct file_operations fops = { ... +.llseek = noop_llseek, /* no read or write fn */ }; ===== End semantic patch ===== Signed-off-by: Arnd Bergmann <arnd@arndb.de> Cc: Julia Lawall <julia@diku.dk> Cc: Christoph Hellwig <hch@infradead.org>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2010-03-07Driver core: Constify struct sysfs_ops in struct kobj_typeEmese Revfy
Constify struct sysfs_ops. This is part of the ops structure constification effort started by Arjan van de Ven et al. Benefits of this constification: * prevents modification of data that is shared (referenced) by many other structure instances at runtime * detects/prevents accidental (but not intentional) modification attempts on archs that enforce read-only kernel data at runtime * potentially better optimized code as the compiler can assume that the const data cannot be changed * the compiler/linker move const data into .rodata and therefore exclude them from false sharing Signed-off-by: Emese Revfy <re.emese@gmail.com> Acked-by: David Teigland <teigland@redhat.com> Acked-by: Matt Domsch <Matt_Domsch@dell.com> Acked-by: Maciej Sosnowski <maciej.sosnowski@intel.com> Acked-by: Hans J. Koch <hjk@linutronix.de> Acked-by: Pekka Enberg <penberg@cs.helsinki.fi> Acked-by: Jens Axboe <jens.axboe@oracle.com> Acked-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-10-11headers: remove sched.h from interrupt.hAlexey Dobriyan
After m68k's task_thread_info() doesn't refer to current, it's possible to remove sched.h from interrupt.h and not break m68k! Many thanks to Heiko Carstens for allowing this. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com>
2009-09-27const: mark struct vm_struct_operationsAlexey Dobriyan
* mark struct vm_area_struct::vm_ops as const * mark vm_ops in AGP code But leave TTM code alone, something is fishy there with global vm_ops being used. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-03-24UIO: Take offset into account when determining number of pages that can be ↵Ian Abbott
mapped If a UIO memory region does not start on a page boundary but straddles one, the number of actual pages that overlap the memory region may be calculated incorrectly because the offset isn't taken into account. If userspace sets the mmap length to offset+size, it may fail with -EINVAL if UIO thinks it's trying to allocate too many pages. Signed-off-by: Ian Abbott <abbotti@mev.co.uk> Cc: Hans J. Koch <hjk@linutronix.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-03-24UIO: Add name attributes for mappings and port regionsHans J. Koch
If a UIO device has several memory mappings, it can be difficult for userspace to find the right one. The situation becomes even worse if the UIO driver can handle different versions of a card that have different numbers of mappings. Benedikt Spranger has such cards and pointed this out to me. Thanks, Bene! To address this problem, this patch adds "name" sysfs attributes for each mapping. Userspace can use these to clearly identify each mapping. The name string is optional. If a driver doesn't set it, an empty string will be returned, so this patch won't break existing drivers. The same problem exists for port region information, so a "name" attribute is added there, too. Signed-off-by: Hans J. Koch <hjk@linutronix.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-01-06UIO: Pass information about ioports to userspace (V2)Hans J. Koch
Devices sometimes have memory where all or parts of it can not be mapped to userspace. But it might still be possible to access this memory from userspace by other means. An example are PCI cards that advertise not only mappable memory but also ioport ranges. On x86 architectures, these can be accessed with ioperm, iopl, inb, outb, and friends. Mike Frysinger (CCed) reported a similar problem on Blackfin arch where it doesn't seem to be easy to mmap non-cached memory but it can still be accessed from userspace. This patch allows kernel drivers to pass information about such ports to userspace. Similar to the existing mem[] array, it adds a port[] array to struct uio_info. Each port range is described by start, size, and porttype. If a driver fills in at least one such port range, the UIO core will simply pass this information to userspace by creating a new directory "portio" underneath /sys/class/uio/uioN/. Similar to the "mem" directory, it will contain a subdirectory (portX) for each port range given. Note that UIO simply passes this information to userspace, it performs no action whatsoever with this data. It's userspace's responsibility to obtain access to these ports and to solve arch dependent issues. The "porttype" attribute tells userspace what kind of port it is dealing with. This mechanism could also be used to give userspace information about GPIOs related to a device. You frequently find such hardware in embedded devices, so I added a UIO_PORT_GPIO definition. I'm not really sure if this is a good idea since there are other solutions to this problem, but it won't hurt much anyway. Signed-off-by: Hans J. Koch <hjk@linutronix.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-11-01saner FASYNC handling on file closeAl Viro
As it is, all instances of ->release() for files that have ->fasync() need to remember to evict file from fasync lists; forgetting that creates a hole and we actually have a bunch that *does* forget. So let's keep our lives simple - let __fput() check FASYNC in file->f_flags and call ->fasync() there if it's been set. And lose that crap in ->release() instances - leaving it there is still valid, but we don't have to bother anymore. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
