path: root/drivers/tty
2013-12-17tty: xuartps: Properly guard sysrq specific codeSoren Brinkmann
Commit 'tty: xuartps: Implement BREAK detection, add SYSRQ support' (0c0c47bc40a2e358d593b2d7fb93b50027fbfc0c) introduced sysrq support without properly guarding sysrq specific code which results in build errors when sysrq is disabled: DNAME=KBUILD_STR(xilinx_uartps)" -c -o drivers/tty/serial/.tmp_xilinx_uartps.o drivers/tty/serial/xilinx_uartps.c drivers/tty/serial/xilinx_uartps.c: In function 'xuartps_isr': drivers/tty/serial/xilinx_uartps.c:247:5: error: 'struct uart_port' has no member named 'sysrq' drivers/tty/serial/xilinx_uartps.c:247:5: error: 'struct uart_port' has no member named 'sysrq' drivers/tty/serial/xilinx_uartps.c:247:5: error: 'struct uart_port' has no member named 'sysrq' make[3]: *** [drivers/tty/serial/xilinx_uartps.o] Error 1 Reported-by: Masanari Iida <standby24x7@gmail.com> Cc: Vlad Lungu <vlad.lungu@windriver.com> Signed-off-by: Soren Brinkmann <soren.brinkmann@xilinx.com> Signed-off-by: Mark Brown <broonie@linaro.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-12-17n_tty: Fix apparent order of echoed outputPeter Hurley
With block processing of echoed output, observed output order is still required. Push completed echoes and echo commands prior to output. Introduce echo_mark echo buffer index, which tracks completed echo commands; ie., those submitted via commit_echoes but which may not have been committed. Ensure that completed echoes are output prior to subsequent terminal writes in process_echoes(). Fixes newline/prompt output order in cooked mode shell. Cc: <stable@vger.kernel.org> # 3.12.x : 39434ab n_tty: Fix missing newline echo Reported-by: Karl Dahlke <eklhad@comcast.net> Reported-by: Mikulas Patocka <mpatocka@redhat.com> Signed-off-by: Peter Hurley <peter@hurleysoftware.com> Tested-by: Karl Dahlke <eklhad@comcast.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-12-17serial: 8250_dw: add new ACPI IDsMika Westerberg
Newer Intel PCHs with LPSS have the same Designware controllers than Haswell but ACPI IDs are different. Add these IDs to the driver list. Signed-off-by: Mika Westerberg <mika.westerberg@linux.intel.com> Cc: stable <stable@vger.kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-12-16serial: 8250_dw: Fix LCR workaround regressionJames Hogan
Commit c49436b657d0 (serial: 8250_dw: Improve unwritable LCR workaround) caused a regression. It added a check that the LCR was written properly to detect and workaround the busy quirk, but the behaviour of bit 5 (UART_LCR_SPAR) differs between IP versions 3.00a and 3.14c per the docs. On older versions this caused the check to fail and it would repeatedly force idle and rewrite the LCR register, causing delays and preventing any input from serial being received. This is fixed by masking out UART_LCR_SPAR before making the comparison. Signed-off-by: James Hogan <james.hogan@imgtec.com> Cc: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Cc: Jiri Slaby <jslaby@suse.cz> Cc: Tim Kryger <tim.kryger@linaro.org> Cc: Ezequiel Garcia <ezequiel.garcia@free-electrons.com> Cc: Matt Porter <matt.porter@linaro.org> Cc: Markus Mayer <markus.mayer@linaro.org> Tested-by: Tim Kryger <tim.kryger@linaro.org> Tested-by: Ezequiel Garcia <ezequiel.garcia@free-electrons.com> Tested-by: Heikki Krogerus <heikki.krogerus@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-12-16tty: Fix hang at ldsem_down_read()Peter Hurley
When a controlling tty is being hung up and the hang up is waiting for a just-signalled tty reader or writer to exit, and a new tty reader/writer tries to acquire an ldisc reference concurrently with the ldisc reference release from the signalled reader/writer, the hangup can hang. The new reader/writer is sleeping in ldsem_down_read() and the hangup is sleeping in ldsem_down_write() [1]. The new reader/writer fails to wakeup the waiting hangup because the wrong lock count value is checked (the old lock count rather than the new lock count) to see if the lock is unowned. Change helper function to return the new lock count if the cmpxchg was successful; document this behavior. [1] edited dmesg log from reporter SysRq : Show Blocked State task PC stack pid father systemd D ffff88040c4f0000 0 1 0 0x00000000 ffff88040c49fbe0 0000000000000046 ffff88040c4a0000 ffff88040c49ffd8 00000000001d3980 00000000001d3980 ffff88040c4a0000 ffff88040593d840 ffff88040c49fb40 ffffffff810a4cc0 0000000000000006 0000000000000023 Call Trace: [<ffffffff810a4cc0>] ? sched_clock_cpu+0x9f/0xe4 [<ffffffff810a4cc0>] ? sched_clock_cpu+0x9f/0xe4 [<ffffffff810a4cc0>] ? sched_clock_cpu+0x9f/0xe4 [<ffffffff810a4cc0>] ? sched_clock_cpu+0x9f/0xe4 [<ffffffff817a6649>] schedule+0x24/0x5e [<ffffffff817a588b>] schedule_timeout+0x15b/0x1ec [<ffffffff810a4cc0>] ? sched_clock_cpu+0x9f/0xe4 [<ffffffff817aa691>] ? _raw_spin_unlock_irq+0x24/0x26 [<ffffffff817aa10c>] down_read_failed+0xe3/0x1b9 [<ffffffff817aa26d>] ldsem_down_read+0x8b/0xa5 [<ffffffff8142b5ca>] ? tty_ldisc_ref_wait+0x1b/0x44 [<ffffffff8142b5ca>] tty_ldisc_ref_wait+0x1b/0x44 [<ffffffff81423f5b>] tty_write+0x7d/0x28a [<ffffffff814241f5>] redirected_tty_write+0x8d/0x98 [<ffffffff81424168>] ? tty_write+0x28a/0x28a [<ffffffff8115d03f>] do_loop_readv_writev+0x56/0x79 [<ffffffff8115e604>] do_readv_writev+0x1b0/0x1ff [<ffffffff8116ea0b>] ? do_vfs_ioctl+0x32a/0x489 [<ffffffff81167d9d>] ? final_putname+0x1d/0x3a [<ffffffff8115e6c7>] vfs_writev+0x2e/0x49 [<ffffffff8115e7d3>] SyS_writev+0x47/0xaa [<ffffffff817ab822>] system_call_fastpath+0x16/0x1b bash D ffffffff81c104c0 0 5469 5302 0x00000082 ffff8800cf817ac0 0000000000000046 ffff8804086b22a0 ffff8800cf817fd8 00000000001d3980 00000000001d3980 ffff8804086b22a0 ffff8800cf817a48 000000000000b9a0 ffff8800cf817a78 ffffffff81004675 ffff8800cf817a44 Call Trace: [<ffffffff81004675>] ? dump_trace+0x165/0x29c [<ffffffff810a4cc0>] ? sched_clock_cpu+0x9f/0xe4 [<ffffffff8100edda>] ? save_stack_trace+0x26/0x41 [<ffffffff817a6649>] schedule+0x24/0x5e [<ffffffff817a588b>] schedule_timeout+0x15b/0x1ec [<ffffffff810a4cc0>] ? sched_clock_cpu+0x9f/0xe4 [<ffffffff817a9f03>] ? down_write_failed+0xa3/0x1c9 [<ffffffff817aa691>] ? _raw_spin_unlock_irq+0x24/0x26 [<ffffffff817a9f0b>] down_write_failed+0xab/0x1c9 [<ffffffff817aa300>] ldsem_down_write+0x79/0xb1 [<ffffffff817aada3>] ? tty_ldisc_lock_pair_timeout+0xa5/0xd9 [<ffffffff817aada3>] tty_ldisc_lock_pair_timeout+0xa5/0xd9 [<ffffffff8142bf33>] tty_ldisc_hangup+0xc4/0x218 [<ffffffff81423ab3>] __tty_hangup+0x2e2/0x3ed [<ffffffff81424a76>] disassociate_ctty+0x63/0x226 [<ffffffff81078aa7>] do_exit+0x79f/0xa11 [<ffffffff81086bdb>] ? get_signal_to_deliver+0x206/0x62f [<ffffffff810b4bfb>] ? lock_release_holdtime.part.8+0xf/0x16e [<ffffffff81079b05>] do_group_exit+0x47/0xb5 [<ffffffff81086c16>] get_signal_to_deliver+0x241/0x62f [<ffffffff810020a7>] do_signal+0x43/0x59d [<ffffffff810f2af7>] ? __audit_syscall_exit+0x21a/0x2a8 [<ffffffff810b4bfb>] ? lock_release_holdtime.part.8+0xf/0x16e [<ffffffff81002655>] do_notify_resume+0x54/0x6c [<ffffffff817abaf8>] int_signal+0x12/0x17 Reported-by: Sami Farin <sami.farin@gmail.com> Cc: <stable@vger.kernel.org> # 3.12.x Signed-off-by: Peter Hurley <peter@hurleysoftware.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-11-29n_tty: Fix missing newline echoPeter Hurley
When L_ECHONL is on, newlines are echoed regardless of the L_ECHO state; if set, ensure accumulated echoes are flushed before finishing the current input processing and before more output. Cc: <stable@vger.kernel.org> # 3.12.x Reported-by: Jason Gunthorpe <jgunthorpe@obsidianresearch.com Tested-by: Jason Gunthorpe <jgunthorpe@obsidianresearch.com> Signed-off-by: Peter Hurley <peter@hurleysoftware.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-11-25Revert "n_gsm: race between ld close and gsmtty open"Greg Kroah-Hartman
This reverts commit c284ee2cf12b55fa8496b2d098bf0938688f1c1c. Turns out the locking was incorrect. Reported-by: Fengguang Wu <fengguang.wu@intel.com> Cc: Chao Bi <chao.bi@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-11-25n_tty: Protect minimum_to_wake reset for concurrent readersPeter Hurley
With multiple, concurrent readers (each waiting to acquire the atomic_read_lock mutex), a departing reader may mistakenly reset minimum_to_wake after a new reader has already set a new value. Protect the minimum_to_wake reset with the atomic_read_lock critical section. Signed-off-by: Peter Hurley <peter@hurleysoftware.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-11-25tty: Reset hupped state on openPeter Hurley
A common security idiom is to hangup the current tty (via vhangup()) after forking but before execing a root shell. This hangs up any existing opens which other processes may have and ensures subsequent opens have the necessary permissions to open the root shell tty/pty. Reset the TTY_HUPPED state after the driver has successfully returned the opened tty (perform the reset while the tty is locked to avoid racing with concurrent hangups). Reported-by: Heorhi Valakhanovich <valahanovich@tut.by> Signed-off-by: Peter Hurley <peter@hurleysoftware.com> Cc: stable <stable@vger.kernel.org> # 3.12 Tested-by: Heorhi Valakhanovich <valahanovich@tut.by> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-11-25TTY: amiserial, add missing platform checkGeert Uytterhoeven
When booting a multi-platform m68k kernel on a non-Amiga with "console=ttyS0" on the kernel command line, it crashes with: Unable to handle kernel access at virtual address 81dff01c Oops: 00000000 PC: [<001e09a8>] serial_console_write+0xc/0x70 Add the missing platform check to amiserial_console_init() to fix this. Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-11-25TTY: pmac_zilog, check existence of ports in pmz_console_init()Geert Uytterhoeven
When booting a multi-platform m68k kernel on a non-Mac with "console=ttyS0" on the kernel command line, it crashes with: Unable to handle kernel NULL pointer dereference at virtual address (null) Oops: 00000000 PC: [<0013ad28>] __pmz_startup+0x32/0x2a0 ... Call Trace: [<002c5d3e>] pmz_console_setup+0x64/0xe4 The normal tty driver doesn't crash, because init_pmz() checks pmz_ports_count again after calling pmz_probe(). In the serial console initialization path, pmz_console_init() doesn't do this, causing the driver to crash later. Add a check for pmz_ports_count to fix this. Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Finn Thain <fthain@telegraphics.com.au> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-11-25n_gsm: race between ld close and gsmtty openChao Bi
ttyA has ld associated to n_gsm, when ttyA is closing, it triggers to release gsmttyB's ld data dlci[B], then race would happen if gsmttyB is opening in parallel. Here are race cases we found recently in test: CASE #1 ==================================================================== releasing dlci[B] race with gsmtty_install(gsmttyB), then panic in gsmtty_open(gsmttyB), as below: tty_release(ttyA) tty_open(gsmttyB) | | ----- gsmtty_install(gsmttyB) | | ----- gsm_dlci_alloc(gsmttyB) => alloc dlci[B] tty_ldisc_release(ttyA) ----- | | gsm_dlci_release(dlci[B]) ----- | | gsm_dlci_free(dlci[B]) ----- | | ----- gsmtty_open(gsmttyB) gsmtty_open() { struct gsm_dlci *dlci = tty->driver_data; => here it uses dlci[B] ... } In gsmtty_open(gsmttyA), it uses dlci[B] which was release, so hit a panic. ===================================================================== CASE #2 ===================================================================== releasing dlci[0] race with gsmtty_install(gsmttyB), then panic in gsmtty_open(), as below: tty_release(ttyA) tty_open(gsmttyB) | | ----- gsmtty_install(gsmttyB) | | ----- gsm_dlci_alloc(gsmttyB) => alloc dlci[B] | | ----- gsmtty_open(gsmttyB) fail | | ----- tty_release(gsmttyB) | | ----- gsmtty_close(gsmttyB) | | ----- gsmtty_detach_dlci(dlci[B]) | | ----- dlci_put(dlci[B]) | | tty_ldisc_release(ttyA) ----- | | gsm_dlci_release(dlci[0]) ----- | | gsm_dlci_free(dlci[0]) ----- | | ----- dlci_put(dlci[0]) In gsmtty_detach_dlci(dlci[B]), it tries to use dlci[0] which was released, then hit panic. ===================================================================== IMHO, n_gsm tty operations would refer released ldisc, as long as gsm_dlci_release() has chance to release ldisc data when some gsmtty operations are not completed.. This patch is try to avoid it by: 1) in n_gsm driver, use a global gsm spin lock to avoid gsm_dlci_release() run in parallel with gsmtty_install(); 2) Increase dlci's ref count in gsmtty_install() instead of in gsmtty_open(), the purpose is to prevent gsm_dlci_release() releasing dlci after gsmtty_install() allocats dlci but before gsmtty_open increases dlci's ref count; 3) Decrease dlci's ref count in gsmtty_remove(), which is a tty framework api, and this is the opposite process of step 2). Signed-off-by: Chao Bi <chao.bi@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-11-25tty/serial/8250: fix typo in help textRandy Dunlap
Commit 9326b047e4fd4a8da72e59d913214a1803e9709c includes a typo of "8350_core" instead of "8250_core", so correct it. Fixes kernel bugzilla #60724: https://bugzilla.kernel.org/show_bug.cgi?id=60724 Reported-by: Christoph Biedl <bugzilla.kernel.bpeb@manchmal.in-ulm.de> Signed-off-by: Randy Dunlap <rdunlap@infradead.org> Cc: Jiri Slaby <jslaby@suse.cz> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-11-25n_tty: Fix 4096-byte canonical readsPeter Hurley
Although the maximum allowable canonical line is specified to be 255 bytes (MAX_CANON), the practical limit has actually been the size of the line discipline read buffer (N_TTY_BUF_SIZE == 4096). Commit 32f13521ca68bc624ff6effc77f308a52b038bf0, n_tty: Line copy to user buffer in canonical mode, limited the line copy to 4095 bytes. With a completely full line discipline read buffer and a userspace buffer > 4095, _no_ data was copied, and the read() syscall returned 0, indicating EOF. Fix the interval arithmetic to compute the correct number of bytes to copy to userspace in the range [1..4096]. Cc: <stable@vger.kernel.org> # 3.12.x Signed-off-by: Peter Hurley <peter@hurleysoftware.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-11-25n_tty: Fix echo overrun tail computationPeter Hurley
Commit cbfd0340ae1993378fd47179db949e050e16e697, 'n_tty: Process echoes in blocks', introduced an error when consuming the echo buffer tail to prevent buffer overrun, where the incorrect operation code byte is checked to determine how far to advance the tail to the next echo byte. Check the correct byte for the echo operation code byte. Cc: <stable@vger.kernel.org> # 3.12.x : c476f65 tty: incorrect test of echo_buf() result for ECHO_OP_START Cc: <stable@vger.kernel.org> # 3.12.x Signed-off-by: Peter Hurley <peter@hurleysoftware.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-11-25n_tty: Ensure reader restarts worker for next readerPeter Hurley
A departing reader must restart a flush_to_ldisc() worker _before_ the next reader enters the read loop; this is to avoid the new reader concluding no more i/o is available and prematurely exiting, when the old reader simply hasn't re-started the worker yet. Cc: stable <stable@vger.kernel.org> # 3.12 Signed-off-by: Peter Hurley <peter@hurleysoftware.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-11-20Merge branch 'next' of git://git.infradead.org/users/vkoul/slave-dmaLinus Torvalds
Pull slave-dmaengine changes from Vinod Koul: "This brings for slave dmaengine: - Change dma notification flag to DMA_COMPLETE from DMA_SUCCESS as dmaengine can only transfer and not verify validaty of dma transfers - Bunch of fixes across drivers: - cppi41 driver fixes from Daniel - 8 channel freescale dma engine support and updated bindings from Hongbo - msx-dma fixes and cleanup by Markus - DMAengine updates from Dan: - Bartlomiej and Dan finalized a rework of the dma address unmap implementation. - In the course of testing 1/ a collection of enhancements to dmatest fell out. Notably basic performance statistics, and fixed / enhanced test control through new module parameters 'run', 'wait', 'noverify', and 'verbose'. Thanks to Andriy and Linus [Walleij] for their review. - Testing the raid related corner cases of 1/ triggered bugs in the recently added 16-source operation support in the ioatdma driver. - Some minor fixes / cleanups to mv_xor and ioatdma" * 'next' of git://git.infradead.org/users/vkoul/slave-dma: (99 commits) dma: mv_xor: Fix mis-usage of mmio 'base' and 'high_base' registers dma: mv_xor: Remove unneeded NULL address check ioat: fix ioat3_irq_reinit ioat: kill msix_single_vector support raid6test: add new corner case for ioatdma driver ioatdma: clean up sed pool kmem_cache ioatdma: fix selection of 16 vs 8 source path ioatdma: fix sed pool selection ioatdma: Fix bug in selftest after removal of DMA_MEMSET. dmatest: verbose mode dmatest: convert to dmaengine_unmap_data dmatest: add a 'wait' parameter dmatest: add basic performance metrics dmatest: add support for skipping verification and random data setup dmatest: use pseudo random numbers dmatest: support xor-only, or pq-only channels in tests dmatest: restore ability to start test at module load and init dmatest: cleanup redundant "dmatest: " prefixes dmatest: replace stored results mechanism, with uniform messages Revert "dmatest: append verify result to results" ...
2013-11-15Merge tag 'stable/for-linus-3.13-rc0-tag' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/xen/tip Pull Xen updates from Konrad Rzeszutek Wilk: "This has tons of fixes and two major features which are concentrated around the Xen SWIOTLB library. The short <blurb> is that the tracing facility (just one function) has been added to SWIOTLB to make it easier to track I/O progress. Additionally under Xen and ARM (32 & 64) the Xen-SWIOTLB driver "is used to translate physical to machine and machine to physical addresses of foreign[guest] pages for DMA operations" (Stefano) when booting under hardware without proper IOMMU. There are also bug-fixes, cleanups, compile warning fixes, etc. The commit times for some of the commits is a bit fresh - that is b/c we wanted to make sure we have the Ack's from the ARM folks - which with the string of back-to-back conferences took a bit of time. Rest assured - the code has been stewing in #linux-next for some time. Features: - SWIOTLB has tracing added when doing bounce buffer. - Xen ARM/ARM64 can use Xen-SWIOTLB. This work allows Linux to safely program real devices for DMA operations when running as a guest on Xen on ARM, without IOMMU support. [*1] - xen_raw_printk works with PVHVM guests if needed. Bug-fixes: - Make memory ballooning work under HVM with large MMIO region. - Inform hypervisor of MCFG regions found in ACPI DSDT. - Remove deprecated IRQF_DISABLED. - Remove deprecated __cpuinit. [*1]: "On arm and arm64 all Xen guests, including dom0, run with second stage translation enabled. As a consequence when dom0 programs a device for a DMA operation is going to use (pseudo) physical addresses instead machine addresses. This work introduces two trees to track physical to machine and machine to physical mappings of foreign pages. Local pages are assumed mapped 1:1 (physical address == machine address). It enables the SWIOTLB-Xen driver on ARM and ARM64, so that Linux can translate physical addresses to machine addresses for dma operations when necessary. " (Stefano)" * tag 'stable/for-linus-3.13-rc0-tag' of git://git.kernel.org/pub/scm/linux/kernel/git/xen/tip: (32 commits) xen/arm: pfn_to_mfn and mfn_to_pfn return the argument if nothing is in the p2m arm,arm64/include/asm/io.h: define struct bio_vec swiotlb-xen: missing include dma-direction.h pci-swiotlb-xen: call pci_request_acs only ifdef CONFIG_PCI arm: make SWIOTLB available xen: delete new instances of added __cpuinit xen/balloon: Set balloon's initial state to number of existing RAM pages xen/mcfg: Call PHYSDEVOP_pci_mmcfg_reserved for MCFG areas. xen: remove deprecated IRQF_DISABLED x86/xen: remove deprecated IRQF_DISABLED swiotlb-xen: fix error code returned by xen_swiotlb_map_sg_attrs swiotlb-xen: static inline xen_phys_to_bus, xen_bus_to_phys, xen_virt_to_bus and range_straddles_page_boundary grant-table: call set_phys_to_machine after mapping grant refs arm,arm64: do not always merge biovec if we are running on Xen swiotlb: print a warning when the swiotlb is full swiotlb-xen: use xen_dma_map/unmap_page, xen_dma_sync_single_for_cpu/device xen: introduce xen_dma_map/unmap_page and xen_dma_sync_single_for_cpu/device tracing/events: Fix swiotlb tracepoint creation swiotlb-xen: use xen_alloc/free_coherent_pages xen: introduce xen_alloc/free_coherent_pages ...
2013-11-15tree-wide: use reinit_completion instead of INIT_COMPLETIONWolfram Sang
Use this new function to make code more comprehensible, since we are reinitialzing the completion, not initializing. [akpm@linux-foundation.org: linux-next resyncs] Signed-off-by: Wolfram Sang <wsa@the-dreams.de> Acked-by: Linus Walleij <linus.walleij@linaro.org> (personally at LCE13) Cc: Ingo Molnar <mingo@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-11-12Merge tag 'devicetree-for-3.13' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/robh/linux Pull devicetree updates from Rob Herring: "DeviceTree updates for 3.13. This is a bit larger pull request than usual for this cycle with lots of clean-up. - Cross arch clean-up and consolidation of early DT scanning code. - Clean-up and removal of arch prom.h headers. Makes arch specific prom.h optional on all but Sparc. - Addition of interrupts-extended property for devices connected to multiple interrupt controllers. - Refactoring of DT interrupt parsing code in preparation for deferred probe of interrupts. - ARM cpu and cpu topology bindings documentation. - Various DT vendor binding documentation updates" * tag 'devicetree-for-3.13' of git://git.kernel.org/pub/scm/linux/kernel/git/robh/linux: (82 commits) powerpc: add missing explicit OF includes for ppc dt/irq: add empty of_irq_count for !OF_IRQ dt: disable self-tests for !OF_IRQ of: irq: Fix interrupt-map entry matching MIPS: Netlogic: replace early_init_devtree() call of: Add Panasonic Corporation vendor prefix of: Add Chunghwa Picture Tubes Ltd. vendor prefix of: Add AU Optronics Corporation vendor prefix of/irq: Fix potential buffer overflow of/irq: Fix bug in interrupt parsing refactor. of: set dma_mask to point to coherent_dma_mask of: add vendor prefix for PHYTEC Messtechnik GmbH DT: sort vendor-prefixes.txt of: Add vendor prefix for Cadence of: Add empty for_each_available_child_of_node() macro definition arm/versatile: Fix versatile irq specifications. of/irq: create interrupts-extended property microblaze/pci: Drop PowerPC-ism from irq parsing of/irq: Create of_irq_parse_and_map_pci() to consolidate arch code. of/irq: Use irq_of_parse_and_map() ...
2013-11-12Merge branch 'next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc Pull powerpc updates from Benjamin Herrenschmidt: "The bulk of this is LE updates. One should now be able to build an LE kernel and even run some things in it. I'm still sitting on a handful of patches to enable the new ABI that I *might* still send this merge window around, but due to the incertainty (they are pretty fresh) I want to keep them separate. Other notable changes are some infrastructure bits to better handle PCI pass-through under KVM, some bits and pieces added to the new PowerNV platform support such as access to the CPU SCOM bus via sysfs, and support for EEH error handling on PHB3 (Power8 PCIe). We also grew arch_get_random_long() for both pseries and powernv when running on P7+ and P8, exploiting the HW rng. And finally various embedded updates from freescale" * 'next' of git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc: (154 commits) powerpc: Fix fatal SLB miss when restoring PPR powerpc/powernv: Reserve the correct PE number powerpc/powernv: Add PE to its own PELTV powerpc/powernv: Add support for indirect XSCOM via debugfs powerpc/scom: Improve debugfs interface powerpc/scom: Enable 64-bit addresses powerpc/boot: Properly handle the base "of" boot wrapper powerpc/bpf: Support MOD operation powerpc/bpf: Fix DIVWU instruction opcode of: Move definition of of_find_next_cache_node into common code. powerpc: Remove big endianness assumption in of_find_next_cache_node powerpc/tm: Remove interrupt disable in __switch_to() powerpc: word-at-a-time optimization for 64-bit Little Endian powerpc/bpf: BPF JIT compiler for 64-bit Little Endian powerpc: Only save/restore SDR1 if in hypervisor mode powerpc/pmu: Fix ADB_PMU_LED_IDE dependencies powerpc/nvram: Fix endian issue when using the partition length powerpc/nvram: Fix endian issue when reading the NVRAM size powerpc/nvram: Scan partitions only once powerpc/mpc512x: remove unnecessary #if ...
2013-11-08Merge tag 'v3.12-rc5' into stable/for-linus-3.13Konrad Rzeszutek Wilk
Linux 3.12-rc5 Because the Stefano branch (for SWIOTLB ARM changes) is based on that. Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com> * tag 'v3.12-rc5': (550 commits) Linux 3.12-rc5 watchdog: sunxi: Fix section mismatch watchdog: kempld_wdt: Fix bit mask definition watchdog: ts72xx_wdt: locking bug in ioctl ARM: exynos: dts: Update 5250 arch timer node with clock frequency parisc: let probe_kernel_read() capture access to page zero parisc: optimize variable initialization in do_page_fault parisc: fix interruption handler to respect pagefault_disable() parisc: mark parisc_terminate() noreturn and cold. parisc: remove unused syscall_ipi() function. parisc: kill SMP single function call interrupt parisc: Export flush_cache_page() (needed by lustre) vfs: allow O_PATH file descriptors for fstatfs() ext4: fix memory leak in xattr ARC: Ignore ptrace SETREGSET request for synthetic register "stop_pc" ALSA: hda - Sony VAIO Pro 13 (haswell) now has a working headset jack ALSA: hda - Add a headset mic model for ALC269 and friends ALSA: hda - Fix microphone for Sony VAIO Pro 13 (Haswell model) compiler/gcc4: Add quirk for 'asm goto' miscompilation bug Revert "i915: Update VGA arbiter support for newer devices" ...
2013-11-08Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/s390/linux Pull s390 updates from Martin Schwidefsky: "The bulk of the patches for the 3.13 merge window. Heiko spent quite a bit of work to improve the code generation for the kernel. That includes the exploitation of the interlocked-access facility for the atomics and bitops implementation and the improvement for the -march and -mtune compiler settings. Another important change is the removal of the user_mode=home option, user processes now always run in primary space. The storage keys are not initialized at system startup any more, with that the storage key removal work is complete. For the PCI support the hibernation hooks have been implemented. And as usual cleanup and fixes" * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/s390/linux: (62 commits) s390/scm_blk: fix endless loop for requests != REQ_TYPE_FS s390/mm,tlb: correct tlb flush on page table upgrade s390/mm: page_table_realloc returns failure s390: allow to set gcc -mtune flag s390/percpu: remove this_cpu_xor() implementation s390/vtime: correct idle time calculation s390/time: fix get_tod_clock_ext inline assembly tty/hvc_iucv: remove redundant NULL check s390/dasd: Write to profile data area only if it is available s390: convert use of typedef ctl_table to struct ctl_table s390/pci: cleanup function information block s390/pci: remove CONFIG_PCI_DEBUG dependancy s390/pci: message cleanup Update default configuration s390: add a couple of useful defconfigs s390/percpu: make use of interlocked-access facility 1 instructions s390/percpu: use generic percpu ops for CONFIG_32BIT s390/compat: make psw32_user_bits a constant value again s390: fix handling of runtime instrumentation psw bit s390: fix save and restore of the floating-point-control register ...
2013-11-07Merge remote-tracking branch 'grant/devicetree/next' into for-nextRob Herring
2013-11-07Merge tag 'tty-3.13-rc1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty Pull tty/serial driver updates from Greg KH: "Here's the big tty/serial driver update for 3.13-rc1. There's some more minor n_tty work here, but nothing like previous kernel releases. Also some new driver ids, driver updates for new hardware, and other small things. All of this has been in linux-next for a while with no issues" * tag 'tty-3.13-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty: (84 commits) serial: omap: fix missing comma serial: sh-sci: Enable the driver on all ARM platforms serial: mfd: Staticize local symbols serial: omap: fix a few checkpatch warnings serial: omap: improve RS-485 performance mrst_max3110: fix unbalanced IRQ issue during resume serial: omap: Add support for optional wake-up serial: sirf: remove duplicate defines tty: xuartps: Fix build error when COMMON_CLK is not set tty: xuartps: Fix build error due to missing forward declaration tty: xuartps: Fix "may be used uninitialized" build warning serial: 8250_pci: add Pericom PCIe Serial board Support (12d8:7952/4/8) - Chip PI7C9X7952/4/8 tty: xuartps: Update copyright information tty: xuartps: Implement suspend/resume callbacks tty: xuartps: Dynamically adjust to input frequency changes tty: xuartps: Updating set_baud_rate() tty: xuartps: Force enable the UART in xuartps_console_write tty: xuartps: support 64 byte FIFO size tty: xuartps: Add polled mode support for xuartps tty: xuartps: Implement BREAK detection, add SYSRQ support ...
2013-10-31serial: omap: fix missing commaPhilippe Proulx
Reported-by: Stephen Rothwell <sfr@canb.auug.org.au>, Signed-off-by: Philippe Proulx <philippe.proulx@savoirfairelinux.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-10-30Merge branch 'dma_complete' into nextVinod Koul
2013-10-29serial: sh-sci: Enable the driver on all ARM platformsLaurent Pinchart
Renesas ARM platforms are transitioning from single-platform to multi-platform kernels using the new ARCH_SHMOBILE_MULTI. Make the driver available on all ARM platforms to enable it on both ARCH_SHMOBILE and ARCH_SHMOBILE_MULTI, and increase build testing coverage with COMPILE_TEST. Signed-off-by: Laurent Pinchart <laurent.pinchart+renesas@ideasonboard.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-10-29serial: mfd: Staticize local symbolsJingoo Han
These local symbols are used only in this file. Fix the following sparse warnings: drivers/tty/serial/mfd.c:296:6: warning: symbol 'hsu_dma_tx' was not declared. Should it be static? drivers/tty/serial/mfd.c:343:6: warning: symbol 'hsu_dma_start_rx_chan' was not declared. Should it be static? drivers/tty/serial/mfd.c:389:6: warning: symbol 'hsu_dma_rx' was not declared. Should it be static? drivers/tty/serial/mfd.c:1186:17: warning: symbol 'serial_hsu_pops' was not declared. Should it be static? Signed-off-by: Jingoo Han <jg1.han@samsung.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-10-29serial: omap: fix a few checkpatch warningsPhilippe Proulx
2013-10-29serial: omap: improve RS-485 performancePhilippe Proulx
If RS-485 is enabled, make the OMAP UART fire THR interrupts when both TX FIFO and TX shift register are empty instead of polling the equivalent status bit. This removes the burst of interrupt requests seen at every end of transmission. Also: the comment said that the TX FIFO trigger level was set at 16 characters when it's 32 in reality. Signed-off-by: Philippe Proulx <philippe.proulx@savoirfairelinux.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-10-29mrst_max3110: fix unbalanced IRQ issue during resumeChen, Jie
During resume, a startup will request_irq again, meantime resume function's enable_irq will cause unbalanced IRQ issue. Fix this issue by moving request_irq to probe function. Signed-off-by: David Cohen <david.a.cohen@linux.intel.com> Signed-off-by: Chen, Jie <jie.d.chen@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-10-29serial: omap: Add support for optional wake-upTony Lindgren
With the recent pinctrl-single changes, omaps can treat wake-up events from deeper idle states as interrupts. There's a separate "io chain" controller on most omaps that stays enabled when the device hits off-idle and the regular interrupt controller is powered off. Let's add support for the optional second interrupt for wake-up events. And then serial-omap can manage the wake-up interrupt from it's runtime PM calls to avoid spurious interrupts during runtime. Note that the wake interrupt is board specific as it uses the UART RX pin, and for omap3, there are six pin options for UART3 RX pin. Also Note that the legacy platform based booting handles the wake-ups in the legacy mux driver and does not need to pass the wake-up interrupt to the driver. And finally, to pass the wake-up interrupt in the dts file, either interrupt-map or the pending interrupts-extended property needs to be passed. It's probably best to use interrupts-extended when it's available. Cc: Felipe Balbi <balbi@ti.com> Cc: Kevin Hilman <khilman@linaro.org> Cc: Linus Walleij <linus.walleij@linaro.org> Reviewed-by: Felipe Balbi <balbi@ti.com> Reviewed-by: Roger Quadros <rogerq@ti.com> Signed-off-by: Tony Lindgren <tony@atomide.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-10-29serial: sirf: remove duplicate definesMichael Opdenacker
This patch removes duplicate defines in drivers/tty/serial/sirfsoc_uart.h Signed-off-by: Michael Opdenacker <michael.opdenacker@free-electrons.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-10-29tty: xuartps: Fix build error when COMMON_CLK is not setSoren Brinkmann
Clock notifiers are only available when CONFIG_COMMON_CLK is enabled. Hence all notifier related code has to be protected by corresponsing ifdefs. Signed-off-by: Soren Brinkmann <soren.brinkmann@xilinx.com> Reported-by: kbuild test robot <fengguang.wu@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-10-29tty: xuartps: Fix build error due to missing forward declarationSoren Brinkmann
If CONFIG_PM_SLEEP is enabled and CONFIG_SERIAL_XILINX_PS_UART_CONSOLE is not, a forward declaration of the uart_driver struct is not included, leading to a build error due to an undeclared variable. Fixing this by moving the definition of the struct uart_driver before the definition of the suspend/resume callbacks. Signed-off-by: Soren Brinkmann <soren.brinkmann@xilinx.com> Reported-by: kbuild test robot <fengguang.wu@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-10-29tty: xuartps: Fix "may be used uninitialized" build warningSoren Brinkmann
Initialize varibles for which a 'may be used uninitalized' warning is issued. Signed-off-by: Soren Brinkmann <soren.brinkmann@xilinx.com> Reported-by: kbuild test robot <fengguang.wu@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-10-28tty/hvc_iucv: remove redundant NULL checkHendrik Brueckner
Make smatch happy and remove this warning: drivers/tty/hvc/hvc_iucv.c:1320 hvc_iucv_init() info: redundant null check on hvc_iucv_filter calling kfree() Signed-off-by: Hendrik Brueckner <brueckner@linux.vnet.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2013-10-25serial: sh: use DMA_COMPLETE for dma completion statusVinod Koul
Acked-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Acked-by: Dan Williams <dan.j.williams@intel.com> Acked-by: Linus Walleij <linus.walleij@linaro.org> Signed-off-by: Vinod Koul <vinod.koul@intel.com>
2013-10-24of/irq: Use irq_of_parse_and_map()Thierry Reding
Replace some instances of of_irq_map_one()/irq_create_of_mapping() and of_irq_to_resource() by the simpler equivalent irq_of_parse_and_map(). Signed-off-by: Thierry Reding <treding@nvidia.com> Acked-by: Rob Herring <rob.herring@calxeda.com> [grant.likely: resolved conflicts with core code renames] Signed-off-by: Grant Likely <grant.likely@linaro.org>
2013-10-19serial: 8250_pci: add Pericom PCIe Serial board Support (12d8:7952/4/8) - ↵Angelo Butti
Chip PI7C9X7952/4/8 Signed-off-by: Angelo Butti <buttiangelo@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-10-19tty: xuartps: Update copyright informationSoren Brinkmann
Signed-off-by: Soren Brinkmann <soren.brinkmann@xilinx.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-10-19tty: xuartps: Implement suspend/resume callbacksSoren Brinkmann
Implement suspend and resume callbacks in order to support system suspend/hibernation. Signed-off-by: Soren Brinkmann <soren.brinkmann@xilinx.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-10-19tty: xuartps: Dynamically adjust to input frequency changesSoren Brinkmann
Add a clock notifier to dynamically handle frequency changes of the input clock by reprogramming the UART in order to keep the baud rate constant. Signed-off-by: Soren Brinkmann <soren.brinkmann@xilinx.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-10-19tty: xuartps: Updating set_baud_rate()Soren Brinkmann
The original algorithm to find the best baud rate dividers does not necessarily find the best set of dividers. And in the worst case may even write illegal values to the hardware. The new function should make better use of the hardware capabilities and be able to provide valid settings for a wider range of baud rates and also input clocks. Signed-off-by: Soren Brinkmann <soren.brinkmann@xilinx.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-10-19tty: xuartps: Force enable the UART in xuartps_console_writeLars-Peter Clausen
It is possible that under certain circumstances xuartps_console_write is entered while the UART disabled. When this happens the code will busy loop in xuartps_console_putchar, since the character is never written and the TXEMPTY flag is never set. The result is a system lockup. This patch force enables the UART for the duration of xuartps_console_write to avoid this. Signed-off-by: Lars-Peter Clausen <lars@metafoo.de> Signed-off-by: John Linn <john.linn@xilinx.com> Signed-off-by: Michal Simek <michal.simek@xilinx.com> Signed-off-by: Soren Brinkmann <soren.brinkmann@xilinx.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-10-19tty: xuartps: support 64 byte FIFO sizeSuneel
Changes to use the 64 byte FIFO depth and fix the issue by clearing the txempty interrupt in isr status for tx after filling in data in start_tx function Signed-off-by: Suneel Garapati <suneelg@xilinx.com> Signed-off-by: Soren Brinkmann <soren.brinkmann@xilinx.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-10-19tty: xuartps: Add polled mode support for xuartpsVlad Lungu
This allows KDB/KGDB to run. Signed-off-by: Vlad Lungu <vlad.lungu@windriver.com> Signed-off-by: Soren Brinkmann <soren.brinkmann@xilinx.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-10-19tty: xuartps: Implement BREAK detection, add SYSRQ supportVlad Lungu
The Cadence UART does not do break detection, even if the datasheet says it does. This patch adds break detection in software (tested in 8N1 mode only) and enables SYSRQ, allowing for Break-g to enter KDB and all the other goodies. Signed-off-by: Vlad Lungu <vlad.lungu@windriver.com> Signed-off-by: Soren Brinkmann <soren.brinkmann@xilinx.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-10-19tty: xuartps: Use devm_kzallocSoren Brinkmann
Use the device managed interface for memory allocation, simplifying error paths. Signed-off-by: Soren Brinkmann <soren.brinkmann@xilinx.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
