path: root/drivers/tty/tty_io.c
2012-11-21tty: Mark tty_del_file and __tty_hangup staticJosh Triplett
Nothing outside of drivers/tty/tty_io.c references these functions, so mark them static. Signed-off-by: Josh Triplett <josh@joshtriplett.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-10-25tty: Add get- ioctls to fetch tty status v3Cyrill Gorcunov
For checkpoint/restore we need to know if tty has exclusive or packet mode set, as well as if pty is currently locked. Just to be able to restore this characteristics. For this sake the following ioctl codes are introduced - TIOCGPKT to get packet mode state - TIOCGPTLCK to get Pty locked state - TIOCGEXCL to get Exclusive mode state Note this ioctls are a bit unsafe in terms of data obtained consistency. The tty characteristics might be changed right after ioctl complete. Keep it in mind and use this ioctl carefully. v2: - Use TIOC prefix for ioctl codes (by jslaby@) Signed-off-by: Cyrill Gorcunov <gorcunov@openvz.org> CC: Alan Cox <alan@lxorguk.ukuu.org.uk> CC: "H. Peter Anvin" <hpa@zytor.com> CC: Pavel Emelyanov <xemul@parallels.com> CC: Jiri Slaby <jslaby@suse.cz> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-10-22TTY: move tty buffers to tty_portJiri Slaby
So this is it. The big step why we did all the work over the past kernel releases. Now everything is prepared, so nothing protects us from doing that big step. | | \ \ nnnn/^l | | | | \ / / | | | '-,.__ => \/ ,-` => | '-,.__ | O __.´´) ( .` | O __.´´) ~~~ ~~ `` ~~~ ~~ The buffers are now in the tty_port structure and we can start teaching the buffer helpers (insert char/string, flip etc.) to use tty_port instead of tty_struct all around. Signed-off-by: Jiri Slaby <jslaby@suse.cz> Acked-by: Alan Cox <alan@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-10-22TTY: add port -> tty linkJiri Slaby
For that purpose we have to temporarily introduce a second tty back pointer into tty_port. It is because serial layer, and maybe others, still do not use tty_port_tty_set/get. So that we cannot set the tty_port->tty to NULL at will now. Yes, the fix would be to convert whole serial layer and all its users to tty_port_tty_set/get. However we are in the process of removing the need of tty in most of the call sites, so this would lead to a duplicated work. Instead we have now tty_port->itty (internal tty) which will be used only in flush_to_ldisc. For that one it is ensured that itty is valid wherever the work is run. IOW, the work is synchronously cancelled before we set itty to NULL and also before hangup is processed. After we need only tty_port and not tty_struct in most code, this shall be changed to tty_port_tty_set/get and itty removed completely. Signed-off-by: Jiri Slaby <jslaby@suse.cz> Acked-by: Alan Cox <alan@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-10-22TTY: move ldisc data from tty_struct: locksJiri Slaby
atomic_write_lock is not n_tty specific, so move it up in the tty_struct. And since these are the last ones to move, remove also the comment saying there are some ldisc' members. There are none now. Signed-off-by: Jiri Slaby <jslaby@suse.cz> Acked-by: Alan Cox <alan@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-10-22TTY: move ldisc data from tty_struct: simple membersJiri Slaby
Here we start moving all the n_tty related bits from tty_struct to the newly defined n_tty_data struct in n_tty proper. In this patch primitive members and bits are moved. The rest will be done per-partes in the next patches. Signed-off-by: Jiri Slaby <jslaby@suse.cz> Acked-by: Alan Cox <alan@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-10-22TTY: move devpts kill to ptyJiri Slaby
Now that we have control over tty->driver_data in pty, we can just kill the /dev/pts/ in pty code too. Namely, in ->shutdown hook of tty. For pty, this is called only once, for whichever end is closed last. But we don't care, both driver_data are the inode as it used to be till now. Signed-off-by: Jiri Slaby <jslaby@suse.cz> Acked-by: Alan Cox <alan@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-10-02Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs Pull vfs update from Al Viro: - big one - consolidation of descriptor-related logics; almost all of that is moved to fs/file.c (BTW, I'm seriously tempted to rename the result to fd.c. As it is, we have a situation when file_table.c is about handling of struct file and file.c is about handling of descriptor tables; the reasons are historical - file_table.c used to be about a static array of struct file we used to have way back). A lot of stray ends got cleaned up and converted to saner primitives, disgusting mess in android/binder.c is still disgusting, but at least doesn't poke so much in descriptor table guts anymore. A bunch of relatively minor races got fixed in process, plus an ext4 struct file leak. - related thing - fget_light() partially unuglified; see fdget() in there (and yes, it generates the code as good as we used to have). - also related - bits of Cyrill's procfs stuff that got entangled into that work; _not_ all of it, just the initial move to fs/proc/fd.c and switch of fdinfo to seq_file. - Alex's fs/coredump.c spiltoff - the same story, had been easier to take that commit than mess with conflicts. The rest is a separate pile, this was just a mechanical code movement. - a few misc patches all over the place. Not all for this cycle, there'll be more (and quite a few currently sit in akpm's tree)." Fix up trivial conflicts in the android binder driver, and some fairly simple conflicts due to two different changes to the sock_alloc_file() interface ("take descriptor handling from sock_alloc_file() to callers" vs "net: Providing protocol type via system.sockprotoname xattr of /proc/PID/fd entries" adding a dentry name to the socket) * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (72 commits) MAX_LFS_FILESIZE should be a loff_t compat: fs: Generic compat_sys_sendfile implementation fs: push rcu_barrier() from deactivate_locked_super() to filesystems btrfs: reada_extent doesn't need kref for refcount coredump: move core dump functionality into its own file coredump: prevent double-free on an error path in core dumper usb/gadget: fix misannotations fcntl: fix misannotations ceph: don't abuse d_delete() on failure exits hypfs: ->d_parent is never NULL or negative vfs: delete surplus inode NULL check switch simple cases of fget_light to fdget new helpers: fdget()/fdput() switch o2hb_region_dev_write() to fget_light() proc_map_files_readdir(): don't bother with grabbing files make get_file() return its argument vhost_set_vring(): turn pollstart/pollstop into bool switch prctl_set_mm_exe_file() to fget_light() switch xfs_find_handle() to fget_light() switch xfs_swapext() to fget_light() ...
2012-09-26make get_file() return its argumentAl Viro
simplifies a bunch of callers... Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2012-09-26new helper: iterate_fd()Al Viro
iterates through the opened files in given descriptor table, calling a supplied function; we stop once non-zero is returned. Callback gets struct file *, descriptor number and const void * argument passed to iterator. It is called with files->file_lock held, so it is not allowed to block. tty_io, netprio_cgroup and selinux flush_unauthorized_files() converted to its use. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2012-09-06tty_register_device_attr updated for tty-nextTomas Hlavacek
Added tty_device_create_release() and bound to dev->release in tty_register_device_attr(). Added tty_port_register_device_attr() and used in uart_add_one_port() instead of tty_register_device_attr(). Signed-off-by: Tomas Hlavacek <tmshlvck@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-09-06tty: uartclk value from serial_core exposed to sysfsTomas Hlavacek
Added file /sys/devices/.../tty/ttySX/uartclk to allow reading uartclk value in struct uart_port in serial_core via sysfs. tty_register_device() has been generalized and refactored in order to add support for setting drvdata and attribute_group to the device. Signed-off-by: Tomas Hlavacek <tmshlvck@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-09-05drivers:tty:fix up ENOIOCTLCMD error handlingWanlong Gao
At commit 07d106d0, Linus pointed out that ENOIOCTLCMD should be translated as ENOTTY to user mode. For example: fd = open("/dev/tty", O_RDWR); ioctl(fd, -1, &argp); then the errno should be ENOTTY but not EINVAL. Signed-off-by: Wanlong Gao <gaowanlong@cn.fujitsu.com> Acked-by: Alan Cox <alan@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-08-17TTY: check if tty->port is assignedJiri Slaby
And if not, complain loudly. None in-kernel module should trigger that, but let us find out for sure. On the other hand, all the out-of-tree modules will hit that. Give them some time (maybe one release) to catch up. Signed-off-by: Jiri Slaby <jslaby@suse.cz> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-08-13TTY: move cdev_add to tty_register_deviceJiri Slaby
We need the /dev/ node not to be available before we call tty_register_device. Otherwise we might race with open and tty_struct->port might not be available at that time. This is not an issue now, but would be a problem after "TTY: use tty_port_register_device" is applied. Signed-off-by: Jiri Slaby <jslaby@suse.cz> Acked-by: Alan Cox <alan@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-08-13TTY: add support for unnumbered device nodesJiri Slaby
This allows drivers like ttyprintk to avoid hacks to create an unnumbered node in /dev. It used to set TTY_DRIVER_DYNAMIC_DEV in flags and call device_create on its own. That is incorrect, because TTY_DRIVER_DYNAMIC_DEV may be set only if tty_register_device is called explicitly. Signed-off-by: Jiri Slaby <jslaby@suse.cz> Acked-by: Alan Cox <alan@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-08-13TTY: move allocations to tty_alloc_driverJiri Slaby
So now, that we have flags and know everything needed, keep a promise and move all the tables and ports allocation from tty_register_driver to tty_alloc_driver. Not only that it makes sense, but we need this for tty_port_link_device which needs tty_driver->ports but is to be called before tty_register_driver. Signed-off-by: Jiri Slaby <jslaby@suse.cz> Acked-by: Alan Cox <alan@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-08-10TTY: pass flags to alloc_tty_driverJiri Slaby
We need to allow drivers that use neither tty_port_install nor tty_port_register_device to link a tty_port to a tty somehow. To avoid a race with open, this has to be performed before tty_register_device. But currently tty_driver->ports is allocated even in tty_register_device because we do not know whether this is the PTY driver. The PTY driver is special here due to an excessive count of lines it declares to handle. We cannot handle tty_ports there this way. To circumvent this, we start passing tty_driver flags to alloc_tty_driver already and we create tty_alloc_driver for this purpose. There we can allocate tty_driver->ports and do all the magic between tty_alloc_driver and tty_register_device. Later we will introduce tty_port_link_device function for that purpose. All drivers should eventually switch to this new tty driver allocation interface. Signed-off-by: Jiri Slaby <jslaby@suse.cz> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-08-10tty: localise the lockAlan Cox
The termios and other changes mean the other protections needed on the driver tty arrays should be adequate. Turn it all back on. This contains pieces folded in from the fixes made to the original patches | From: Geert Uytterhoeven <geert@linux-m68k.org> (fix m68k) | From: Paul Gortmaker <paul.gortmaker@windriver.com> (fix cris) | From: Jiri Kosina <jkosina@suze.cz> (lockdep) | From: Eric Dumazet <eric.dumazet@gmail.com> (lockdep) Signed-off-by: Alan Cox <alan@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-08-10tty: handle NULL parameters in free_tty_struct()Dan Carpenter
We sometimes pass NULL pointers to free_tty_struct(). One example where it can happen is in the error handling code in pty_common_install(). Signed-off-by: Dan Carpenter <dan.carpenter@oracle.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-08-10tty: fix missing assignmentDan Carpenter
We're trying to save the termios state and we need to allocate a buffer to do it. Smatch complains that the buffer is leaked at the end of the function. Signed-off-by: Dan Carpenter <dan.carpenter@oracle.com> Signed-off-by: Alan Cox <alan@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-07-27tty: Fix race in tty releaseAlan Cox
Ian Abbott found that the tty layer would explode with the right set of parallel open and close operations. This is because we race in the handling of tty->drivers->termios[]. Correct this by Making tty_ldisc_release behave like nromal code (takes the lock, does stuff, drops the lock) Drop the tty lock earlier in tty_ldisc_release Taking the tty mutex around the driver->termios update in all cases Adding a WARN_ON to catch future screwups. I also forgot to clean up the pty resources properly. With a pty pair we need to pull both halves out of the tables. Signed-off-by: Alan Cox <alan@linux.intel.com> Tested-by: Ian Abbott <abbotti@mev.co.uk> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-07-17tty: Move the handling of the tty release logicAlan Cox
Now that we don't have tty->termios tied to drivers->tty we can untangle the logic here. In addition we can push the removal logic out of the destructor path. At that point we can think about sorting out tty_port and console and all the other ugly hangovers. Signed-off-by: Alan Cox <alan@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-07-16tty: move the termios object into the ttyAlan Cox
This will let us sort out a whole pile of tty related races. The alternative would be to keep points and refcount the termios objects. However 1. They are tiny anyway 2. Many devices don't use the stored copies 3. We can remove a pty special case Signed-off-by: Alan Cox <alan@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-07-16tty: revert incorrectly applied lock patchAlan Cox
I sent GregKH this after the pre-requisites. He dropped the pre-requesites for good reason and unfortunately then applied this patch. Without this reverted you get random kernel memory corruption which will make bisecting anything between it and the properly applied patches a complete sod. Signed-off-by: Alan Cox <alan@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-07-06tty: localise the lockAlan Cox
2012-06-13TTY: add ports array to tty_driverJiri Slaby
It will hold tty_port structures for all drivers which do not want to define tty->ops->install hook. We ignore PTY here because it wants 1 million lines and it installs tty_port in ->install anyway. Signed-off-by: Jiri Slaby <jslaby@suse.cz> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-06-13TTY: centralize fail paths in tty_register_driverJiri Slaby
Currently, some failures are handled in if's false branches, some at the end of tty_register_driver via goto-labels. Let us handle the failures at the end of the functions to have the failure handling at a single place. The only thing needed is to label the lines properly and jump there. Signed-off-by: Jiri Slaby <jslaby@suse.cz> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-06-02tty: Revert the tty locking series, it needs more workLinus Torvalds
This reverts the tty layer change to use per-tty locking, because it's not correct yet, and fixing it will require some more deep surgery. The main revert is d29f3ef39be4 ("tty_lock: Localise the lock"), but there are several smaller commits that built upon it, they also get reverted here. The list of reverted commits is: fde86d310886 - tty: add lockdep annotations 8f6576ad476b - tty: fix ldisc lock inversion trace d3ca8b64b97e - pty: Fix lock inversion b1d679afd766 - tty: drop the pty lock during hangup abcefe5fc357 - tty/amiserial: Add missing argument for tty_unlock() fd11b42e3598 - cris: fix missing tty arg in wait_event_interruptible_tty call d29f3ef39be4 - tty_lock: Localise the lock The revert had a trivial conflict in the 68360serial.c staging driver that got removed in the meantime. Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-05-04tty_lock: Localise the lockAlan Cox
In each remaining case the tty_lock is associated with a specific tty. This means we can now lock on a per tty basis. We do need tty_lock_pair() for the pty case. Uglier but still a step in the right direction. [fixed up calls in 3 missing drivers - gregkh] Signed-off-by: Alan Cox <alan@linux.intel.com> Acked-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-05-04tty_lock: undo the old tty_lock use on the cttyAlan Cox
get_current_tty has its own consistent locking. That means a pile of the tty lock cases are not needed. As get_current_tty also keeps a reference the tty object lifetime means we can propogate the lock removal out. Signed-off-by: Alan Cox <alan@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-03-28Remove all #inclusions of asm/system.hDavid Howells
Remove all #inclusions of asm/system.h preparatory to splitting and killing it. Performed with the following command: perl -p -i -e 's!^#\s*include\s*<asm/system[.]h>.*\n!!' `grep -Irl '^#\s*include\s*<asm/system[.]h>' *` Signed-off-by: David Howells <dhowells@redhat.com>
2012-03-08TTY: remove tty driver re-set from tty_reopenJiri Slaby
This is from tty_reopen: struct tty_driver *driver = tty->driver; ... tty->driver = driver; and it doesn't make sense at all. The driver is intended to be set in initialize_tty_struct from tty_init_dev (initial open). So this set in tty_reopen is not needed. Signed-off-by: Jiri Slaby <jslaby@suse.cz> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-03-08TTY: simplify tty_driver_lookup_tty a bitJiri Slaby
Remove the useless local variable and return the value itself. Signed-off-by: Jiri Slaby <jslaby@suse.cz> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-03-08TTY: let alloc_tty_driver deduce the owner automaticallyJiri Slaby
Like the rest of the kernel, make a stub from alloc_tty_driver which calls __alloc_tty_driver with proper owner. This will save us one more assignment on the driver side. Also this fixes some drivers which didn't set the owner. This allowed user to remove the module from the system even though a tty from the driver is still open. Signed-off-by: Jiri Slaby <jslaby@suse.cz> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-03-08TTY: tty_io, remove buffer re-assignmentsJiri Slaby
TTY buffer head and tail are initialized in tty_buffer_init. No need to do it once again in initialize_tty_struct where tty_buffer_init is called. Signed-off-by: Jiri Slaby <jslaby@suse.cz> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-02-24Revert "TTY: get rid of BTM around devpts_*"Greg Kroah-Hartman
This reverts commit d3bda5298aad98c7a27678bdd0dd9d008ab9e685. Sasha reported that this causes problems, so revert it. Cc: Sasha Levin <levinsasha928@gmail.com> Cc: Jiri Slaby <jslaby@suse.cz> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-02-02TTY: get rid of BTM around devpts_*Jiri Slaby
devpts operations are protected by inode mutexes and dentry refcounting. There is no need to hold BTM. Signed-off-by: Jiri Slaby <jslaby@suse.cz> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-02-02TTY: provide tty_standard_install helperJiri Slaby
There are currently many cut&paste copies of what tty_driver_install_tty does when custom ->install method is not provided. Let's get rid of the copies and create a helper with this setup code. Signed-off-by: Jiri Slaby <jslaby@suse.cz> Cc: Havard Skinnemoen <hskinnemoen@google.com> Acked-by: Alan Cox <alan@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-01-24tty: cleanup prohibition of direct opening for unix98 pty masterKonstantin Khlebnikov
cleanup hack added in v2.6.27-3203-g15582d3 comment from that patch: : pty: If the administrator creates a device for a ptmx slave we should not error : : The open path for ptmx slaves is via the ptmx device. Opening them any : other way is not allowed. Vegard Nossum found that previously this was not : the case and mknod foo c 128 42; cat foo would produce nasty diagnostics : : Signed-off-by: Alan Cox <alan@redhat.com> : Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> devpts_get_tty() returns non-null only for inodes on devpts, but there is no inodes for master-devices, /dev/ptmx (/dev/pts/ptmx) is the only way to open them. Thus we can completely forbid lookup for master-devices and eliminate that hack in tty_init_dev() because tty_open() will get EIO from tty_driver_lookup_tty(). Signed-off-by: Konstantin Khlebnikov <khlebnikov@openvz.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2012-01-09Merge branch 'tty-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty * 'tty-next' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty: (65 commits) tty: serial: imx: move del_timer_sync() to avoid potential deadlock imx: add polled io uart methods imx: Add save/restore functions for UART control regs serial/imx: let probing fail for the dt case without a valid alias serial/imx: propagate error from of_alias_get_id instead of using -ENODEV tty: serial: imx: Allow UART to be a source for wakeup serial: driver for m32 arch should not have DEC alpha errata serial/documentation: fix documented name of DCD cpp symbol atmel_serial: fix spinlock lockup in RS485 code tty: Fix memory leak in virtual console when enable unicode translation serial: use DIV_ROUND_CLOSEST instead of open coding it serial: add support for 400 and 800 v3 series Titan cards serial: bfin-uart: Remove ASYNC_CTS_FLOW flag for hardware automatic CTS. serial: bfin-uart: Enable hardware automatic CTS only when CTS pin is available. serial: make FSL errata depend on 8250_CONSOLE, not just 8250 serial: add irq handler for Freescale 16550 errata. serial: manually inline serial8250_handle_port serial: make 8250 timeout use the specified IRQ handler serial: export the key functions for an 8250 IRQ handler serial: clean up parameter passing for 8250 Rx IRQ handling ...
2012-01-03switch device_get_devnode() and ->devnode() to umode_t *Al Viro
both callers of device_get_devnode() are only interested in lower 16bits and nobody tries to return anything wider than 16bit anyway. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-11-15TTY: open/release, cleanup printksJiri Slaby
* use __func__ instead of hardcoded names (tty_release_dev is a non-existant function) * add missing \n's * unwrap for better grepping Signed-off-by: Jiri Slaby <jslaby@suse.cz> Cc: Alan Cox <alan@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-11-15TTY: move debug checking out of tty_releaseJiri Slaby
There is no need to taint the tty_release code with paranoia checking. So move it out of line to a separate function. Making thus tty_release more readable. [v2] don't introduce a hard to reproduce use after free (scheduled work would need to preempt the current thread) Signed-off-by: Jiri Slaby <jslaby@suse.cz> Cc: Alan Cox <alan@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-11-15TTY: move tty_lookup_driver to switch-casesJiri Slaby
The labels express more the nature of the decision tree. We returned from each if with a driver. Now we do this at the end of the function and the code flow is clear. While at it, remove an obsolete comment (we already take the reference). Signed-off-by: Jiri Slaby <jslaby@suse.cz> Cc: Alan Cox <alan@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-11-15TTY: coalesce fail paths in tty_openJiri Slaby
Move them to the end of the function and use gotos as usual. Signed-off-by: Jiri Slaby <jslaby@suse.cz> Cc: Alan Cox <alan@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-11-15TTY: extract driver lookup from tty_openJiri Slaby
The error handling in tty_open became unbearable. There were many errors fixed recently. Extract the tty driver lookup from tty_open to a separate function. This reduces the fail paths significantly and makes tty_open more readable. In the next patch we will move the fail path handling to the end of the function. Signed-off-by: Jiri Slaby <jslaby@suse.cz> Cc: Alan Cox <alan@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-11-15TTY: extract /dev/tty handling from tty_openJiri Slaby
This one is special to others (done in the next patch). We have the tty directly, not its driver and index. So this will reside in a separation function. In the next patch, the rest will be moved to another function. So now we set neither driver nor index. Hence we need to init driver and check whether we are supposed to put a ref of that. Signed-off-by: Jiri Slaby <jslaby@suse.cz> Cc: Alan Cox <alan@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-11-15TTY: move pgrp killingJiri Slaby
Move it to the only branch where tty_pgrp may be set. This is only a cleanup which allows having tty_pgrp defined at that place. Signed-off-by: Jiri Slaby <jslaby@suse.cz> Cc: Alan Cox <alan@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-10-26Merge branch 'tty-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty * 'tty-next' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty: (79 commits) TTY: serial_core: Fix crash if DCD drop during suspend tty/serial: atmel_serial: bootconsole removed from auto-enumerates Revert "TTY: call tty_driver_lookup_tty unconditionally" tty/serial: atmel_serial: add device tree support tty/serial: atmel_serial: auto-enumerate ports tty/serial: atmel_serial: whitespace and braces modifications tty/serial: atmel_serial: change platform_data variable name tty/serial: RS485 bindings for device tree TTY: call tty_driver_lookup_tty unconditionally TTY: pty, release tty in all ptmx_open fail paths TTY: make tty_add_file non-failing TTY: drop driver reference in tty_open fail path 8250_pci: Fix kernel panic when pch_uart is disabled h8300: drivers/serial/Kconfig was moved parport_pc: release IO region properly if unsupported ITE887x card is found tty: Support compat_ioctl get/set termios_locked hvc_console: display printk messages on console. TTY: snyclinkmp: forever loop in tx_load_dma_buffer() tty/n_gsm: avoid fifo overflow in gsm_dlci_data_output tty/n_gsm: fix a bug in gsm_dlci_data_output (adaption = 2 case) ... Fix up Conflicts in: - drivers/tty/serial/8250_pci.c Trivial conflict with removed duplicate device ID - drivers/tty/serial/atmel_serial.c Annoying silly conflict between "specify the port num via platform_data" and other changes to atmel_console_init
