Use container_of instead of casting first structure member.
Signed-off-by: Fabian Frederick <fabf@skynet.be>
Commit 717f3bbab3c7628736ef738fdbf3d9a28578c26c,
'serial_core: Fix conditional start_tx on ring buffer not empty'
exposes an incorrect assumption in several drivers' start_tx methods;
the tx ring buffer can, in fact, be empty when restarting tx while
performing flow control.
Affected drivers:
sunsab.c
ip22zilog.c
pmac_zilog.c
sunzilog.c
m32r_sio.c
imx.c
Other in-tree serial drivers either are not affected or already
test for empty tx ring buffer before transmitting.
Test for empty tx ring buffer in start_tx() method, after transmitting
x_char (if applicable).
Reported-by: Aaro Koskinen <aaro.koskinen@iki.fi>
Cc: Seth Bollinger <sethb@digi.com>
Cc: Thomas Bogendoerfer <tsbogend@alpha.franken.de>
Signed-off-by: Peter Hurley <peter@hurleysoftware.com>
Cc: stable <stable@vger.kernel.org> # 3.15
If IGNBRK is set without either BRKINT or PARMRK set, some uart
drivers send a 0x00 byte for BREAK without the TTYBREAK flag to the
line discipline, when it should send either nothing or the TTYBREAK flag
set. This happens because the read_status_mask masks out the BI
condition, which uart_insert_char() then interprets as a normal 0x00 byte.
SUS v3 is clear regarding the meaning of IGNBRK; Section 11.2.2, General
Terminal Interface - Input Modes, states:
"If IGNBRK is set, a break condition detected on input shall be ignored;
that is, not put on the input queue and therefore not read by any
process."
Fix read_status_mask to include the BI bit if IGNBRK is set; the
lsr status retains the BI bit if a BREAK is recv'd, which is
subsequently ignored in uart_insert_char() when masked with the
ignore_status_mask.
Affected drivers:
8250 - all
serial_txx9
mfd
amba-pl010
amba-pl011
atmel_serial
bfin_uart
dz
ip22zilog
max310x
mxs-auart
netx-serial
pnx8xxx_uart
pxa
sb1250-duart
sccnxp
serial_ks8695
sirfsoc_uart
st-asc
vr41xx_siu
zs
sunzilog
fsl_lpuart
sunsab
ucc_uart
bcm63xx_uart
sunsu
efm32-uart
pmac_zilog
mpsc
msm_serial
m32r_sio
Unaffected drivers:
omap-serial
rp2
sa1100
imx
icom
Annotated for fixes:
altera_uart
mcf
Drivers without break detection:
21285
xilinx-uartps
altera_jtaguart
apbuart
arc-uart
clps711x
max3100
uartlite
msm_serial_hs
nwpserial
lantiq
vt8500_serial
Unknown:
samsung
mpc52xx_uart
bfin_sport_uart
cpm_uart/core
Fixes: Bugzilla #71651, '8250_core.c incorrectly handles IGNBRK flag'
Reported-by: Ivan <athlon_@mail.ru>
tty_flip_buffer_push()
The current driver triggers a lockdep warning for if tty_flip_buffer_push() is
called with uart_port->lock locked. This never shows up on UP kernels and comes
up only on SMP kernels.
Crash looks like this (produced with samsung.c driver):
[<c0014d58>] (unwind_backtrace+0x0/0xf8) from [<c0011908>] (show_stack+0x10/0x14)
[<c0011908>] (show_stack+0x10/0x14) from [<c035da34>] (dump_stack+0x6c/0xac)
[<c035da34>] (dump_stack+0x6c/0xac) from [<c01b59ac>] (do_raw_spin_unlock+0xc4/0xd8)
[<c01b59ac>] (do_raw_spin_unlock+0xc4/0xd8) from [<c03627e4>] (_raw_spin_unlock_irqrestore+0xc/0)
[<c03627e4>] (_raw_spin_unlock_irqrestore+0xc/0x38) from [<c020a1a8>] (s3c24xx_serial_rx_chars+0)
[<c020a1a8>] (s3c24xx_serial_rx_chars+0x12c/0x260) from [<c020aae8>] (s3c64xx_serial_handle_irq+)
[<c020aae8>] (s3c64xx_serial_handle_irq+0x48/0x60) from [<c006aaa0>] (handle_irq_event_percpu+0x)
[<c006aaa0>] (handle_irq_event_percpu+0x50/0x194) from [<c006ac20>] (handle_irq_event+0x3c/0x5c)
[<c006ac20>] (handle_irq_event+0x3c/0x5c) from [<c006d864>] (handle_fasteoi_irq+0x80/0x13c)
[<c006d864>] (handle_fasteoi_irq+0x80/0x13c) from [<c006a4a4>] (generic_handle_irq+0x20/0x30)
[<c006a4a4>] (generic_handle_irq+0x20/0x30) from [<c000f454>] (handle_IRQ+0x38/0x94)
[<c000f454>] (handle_IRQ+0x38/0x94) from [<c0008538>] (gic_handle_irq+0x34/0x68)
[<c0008538>] (gic_handle_irq+0x34/0x68) from [<c00123c0>] (__irq_svc+0x40/0x70)
Exception stack(0xc04cdf70 to 0xc04cdfb8)
df60: 00000000 00000000 0000166e 00000000
df80: c04cc000 c050278f c050278f 00000001 c04d444c 410fc0f4 c03649b0 00000000
dfa0: 00000001 c04cdfb8 c000f758 c000f75c 60070013 ffffffff
[<c00123c0>] (__irq_svc+0x40/0x70) from [<c000f75c>] (arch_cpu_idle+0x28/0x30)
[<c000f75c>] (arch_cpu_idle+0x28/0x30) from [<c0054888>] (cpu_startup_entry+0x5c/0x148)
[<c0054888>] (cpu_startup_entry+0x5c/0x148) from [<c0497aa4>] (start_kernel+0x334/0x38c)
BUG: spinlock lockup suspected on CPU#0, kworker/0:1/360
lock: s3c24xx_serial_ports+0x1d8/0x370, .magic: dead4ead, .owner: <none>/-1, .owner_cpu: -1
CPU: 0 PID: 360 Comm: kworker/0:1 Not tainted 3.11.0-rc6-next-20130819-00003-g75485f1 #2
Workqueue: events flush_to_ldisc
[<c035da34>] (dump_stack+0x6c/0xac) from [<c01b581c>] (do_raw_spin_lock+0x100/0x17c)
[<c01b581c>] (do_raw_spin_lock+0x100/0x17c) from [<c03628a0>] (_raw_spin_lock_irqsave+0x20/0x28)
[<c03628a0>] (_raw_spin_lock_irqsave+0x20/0x28) from [<c0203224>] (uart_start+0x18/0x34)
[<c0203224>] (uart_start+0x18/0x34) from [<c01ef890>] (__receive_buf+0x4b4/0x738)
[<c01ef890>] (__receive_buf+0x4b4/0x738) from [<c01efb44>] (n_tty_receive_buf2+0x30/0x98)
[<c01efb44>] (n_tty_receive_buf2+0x30/0x98) from [<c01f2ba8>] (flush_to_ldisc+0xec/0x138)
[<c01f2ba8>] (flush_to_ldisc+0xec/0x138) from [<c0031af0>] (process_one_work+0xfc/0x348)
[<c0031af0>] (process_one_work+0xfc/0x348) from [<c0032138>] (worker_thread+0x138/0x37c)
[<c0032138>] (worker_thread+0x138/0x37c) from [<c0037a7c>] (kthread+0xa4/0xb0)
[<c0037a7c>] (kthread+0xa4/0xb0) from [<c000e5f8>] (ret_from_fork+0x14/0x3c)
Release the port lock before calling tty_flip_buffer_push() and reacquire it
after the call.
Similar stuff was already done for few other drivers in the past, like:
commit 2389b272168ceec056ca1d8a870a97fa9c26e11a
Author: Thomas Gleixner <tglx@linutronix.de>
Date: Tue May 29 21:53:50 2007 +0100
[ARM] 4417/1: Serial: Fix AMBA drivers locking
Signed-off-by: Viresh Kumar <viresh.kumar@linaro.org>
Now, we start converting tty buffer functions to actually use
tty_port. This will allow us to get rid of the need of tty in many
call sites. Only tty_port will needed and hence no more
tty_port_tty_get in those paths.
Now, the one where most of tty_port_tty_get gets removed:
tty_flip_buffer_push.
IOW we also closed all the races in drivers not using tty_port_tty_get
at all yet.
Also we move tty_flip_buffer_push declaration from include/linux/tty.h
to include/linux/tty_flip.h to all others while we are changing it
anyway.
tty_insert_flip_char is the next one to proceed. This one is used all
over the code, so the patch is huge.
The struct serial_uart_config is hardly used at all, and the
use case like this one are somewhat needless. Remove the
trivial usage so that we can remove serial_uart_config.
Since the type field isn't really used at all, we also delete
the initialization and references of it here as well.
Cc: Hirokazu Takata <takata@linux-m32r.org>
Acked-by: Alan Cox <alan@lxorguk.ukuu.org.uk>
All of them do not use the ugly interface defined in that header.
We transform the offenders into a test of irq <= 0 which will be ok while
the ARM people get their platform sorted. Once that is done (or in a while
if they don't do it anyway) then we will change them all to !irq checks.
For arch specific drivers that are already using NO_IRQ = 0 we just test
against zero so we don't need to re-review them later.
Signed-off-by: Alan Cox <alan@linux.intel.com>
This driver was copied from the original 8250 driver and hence
got the DEC alpha errata workaround. But the workaround is ugly
and we don't really want it in any more places than it absolutely
needs to be. Obviously ARCH=m32r means ARCH != alpha, so just
remove the references to the ALPHA_KLUDGE_MCR define.
linux/tty_flip.h is included in linux/serial_core.h. But this may (and
will) change in the future. Then we would get build errors such as:
.../tty/serial/max3107.c: In function ‘put_data_to_circ_buf’:
.../tty/serial/max3107.c:149:2: error: implicit declaration of function ‘tty_insert_flip_string’
So fix all the drviers which call tty flip buffer helpers to really
include linux/tty_flip.h. And also make sure that those include
linux/tty.h when operating with struct tty_struct.
Cc: Alan Cox <alan@linux.intel.com>
Several fixes as well where the +1 was missing.
Done via coccinelle scripts like:
struct resource *ptr;
- ptr->end - ptr->start + 1
+ resource_size(ptr)
and some grep and typing.
Mostly uncompiled, no cross-compilers.
spin_lock_irqsave() requires unsigned long.
The serial drivers are really just tty drivers, so move them to
drivers/tty/ to make things a bit neater overall.
This is part of the tty/serial driver movement proceedure as proposed by
Arnd Bergmann and approved by everyone involved a number of months ago.
Cc: Alan Cox <alan@lxorguk.ukuu.org.uk>
Cc: Rogier Wolff <R.E.Wolff@bitwizard.nl>
Cc: Michael H. Warfield <mhw@wittsend.com>
