SERIAL_DO_RESTART is not used by these 3 drivers; remove.
Signed-off-by: Peter Hurley <peter@hurleysoftware.com>
We should not be doing assignments within an if () block
so fix up the code to not do this.
change was created using Coccinelle.
CC: Jiri Slaby <jslaby@suse.cz>
Return a negative error code on failure.
A simplified version of the semantic match that finds this problem is as
follows: (http://coccinelle.lip6.fr/)
// <smpl>
identifier ret; expression e1,e2;
if (\(ret < 0\|ret != 0\))
{ ... return ret; }
ret = 0
... when != ret = e1
when != &ret
*if(...)
... when != ret = e2
when forall
return ret;
// </smpl>
Signed-off-by: Julia Lawall <Julia.Lawall@lip6.fr>
Signed-off-by: Alexander Shiyan <shc_work@mail.ru>
We use "fw" in the next line after we release it. I've shifted the call
to release_firmware() down a couple lines to fix this.
This code does an annoying thing where it writes to the array and then
checks later for array overflows. I don't know if it's actually
possible to overflow but let's check before using the array index.
The current driver triggers a lockdep warning for if tty_flip_buffer_push() is
called with uart_port->lock locked. This never shows up on UP kernels and comes
up only on SMP kernels.
Crash looks like this (produced with samsung.c driver):
[<c0014d58>] (unwind_backtrace+0x0/0xf8) from [<c0011908>] (show_stack+0x10/0x14)
[<c0011908>] (show_stack+0x10/0x14) from [<c035da34>] (dump_stack+0x6c/0xac)
[<c035da34>] (dump_stack+0x6c/0xac) from [<c01b59ac>] (do_raw_spin_unlock+0xc4/0xd8)
[<c01b59ac>] (do_raw_spin_unlock+0xc4/0xd8) from [<c03627e4>] (_raw_spin_unlock_irqrestore+0xc/0)
[<c03627e4>] (_raw_spin_unlock_irqrestore+0xc/0x38) from [<c020a1a8>] (s3c24xx_serial_rx_chars+0)
[<c020a1a8>] (s3c24xx_serial_rx_chars+0x12c/0x260) from [<c020aae8>] (s3c64xx_serial_handle_irq+)
[<c020aae8>] (s3c64xx_serial_handle_irq+0x48/0x60) from [<c006aaa0>] (handle_irq_event_percpu+0x)
[<c006aaa0>] (handle_irq_event_percpu+0x50/0x194) from [<c006ac20>] (handle_irq_event+0x3c/0x5c)
[<c006ac20>] (handle_irq_event+0x3c/0x5c) from [<c006d864>] (handle_fasteoi_irq+0x80/0x13c)
[<c006d864>] (handle_fasteoi_irq+0x80/0x13c) from [<c006a4a4>] (generic_handle_irq+0x20/0x30)
[<c006a4a4>] (generic_handle_irq+0x20/0x30) from [<c000f454>] (handle_IRQ+0x38/0x94)
[<c000f454>] (handle_IRQ+0x38/0x94) from [<c0008538>] (gic_handle_irq+0x34/0x68)
[<c0008538>] (gic_handle_irq+0x34/0x68) from [<c00123c0>] (__irq_svc+0x40/0x70)
Exception stack(0xc04cdf70 to 0xc04cdfb8)
df60: 00000000 00000000 0000166e 00000000
df80: c04cc000 c050278f c050278f 00000001 c04d444c 410fc0f4 c03649b0 00000000
dfa0: 00000001 c04cdfb8 c000f758 c000f75c 60070013 ffffffff
[<c00123c0>] (__irq_svc+0x40/0x70) from [<c000f75c>] (arch_cpu_idle+0x28/0x30)
[<c000f75c>] (arch_cpu_idle+0x28/0x30) from [<c0054888>] (cpu_startup_entry+0x5c/0x148)
[<c0054888>] (cpu_startup_entry+0x5c/0x148) from [<c0497aa4>] (start_kernel+0x334/0x38c)
BUG: spinlock lockup suspected on CPU#0, kworker/0:1/360
lock: s3c24xx_serial_ports+0x1d8/0x370, .magic: dead4ead, .owner: <none>/-1, .owner_cpu: -1
CPU: 0 PID: 360 Comm: kworker/0:1 Not tainted 3.11.0-rc6-next-20130819-00003-g75485f1 #2
Workqueue: events flush_to_ldisc
[<c035da34>] (dump_stack+0x6c/0xac) from [<c01b581c>] (do_raw_spin_lock+0x100/0x17c)
[<c01b581c>] (do_raw_spin_lock+0x100/0x17c) from [<c03628a0>] (_raw_spin_lock_irqsave+0x20/0x28)
[<c03628a0>] (_raw_spin_lock_irqsave+0x20/0x28) from [<c0203224>] (uart_start+0x18/0x34)
[<c0203224>] (uart_start+0x18/0x34) from [<c01ef890>] (__receive_buf+0x4b4/0x738)
[<c01ef890>] (__receive_buf+0x4b4/0x738) from [<c01efb44>] (n_tty_receive_buf2+0x30/0x98)
[<c01efb44>] (n_tty_receive_buf2+0x30/0x98) from [<c01f2ba8>] (flush_to_ldisc+0xec/0x138)
[<c01f2ba8>] (flush_to_ldisc+0xec/0x138) from [<c0031af0>] (process_one_work+0xfc/0x348)
[<c0031af0>] (process_one_work+0xfc/0x348) from [<c0032138>] (worker_thread+0x138/0x37c)
[<c0032138>] (worker_thread+0x138/0x37c) from [<c0037a7c>] (kthread+0xa4/0xb0)
[<c0037a7c>] (kthread+0xa4/0xb0) from [<c000e5f8>] (ret_from_fork+0x14/0x3c)
Release the port lock before calling tty_flip_buffer_push() and reacquire it
after the call.
Similar stuff was already done for few other drivers in the past, like:
commit 2389b272168ceec056ca1d8a870a97fa9c26e11a
Author: Thomas Gleixner <tglx@linutronix.de>
Date: Tue May 29 21:53:50 2007 +0100
[ARM] 4417/1: Serial: Fix AMBA drivers locking
Signed-off-by: Viresh Kumar <viresh.kumar@linaro.org>
icom_port->uart_port.membase is (unsigned char __iomem *); thus,
casting (unsigned char __iomem *) is necessary to fix the
following warning. Also, local symbols are staticized.
drivers/tty/serial/icom.c:108:26: warning: symbol 'start_proc' was not declared. Should it be static?
drivers/tty/serial/icom.c:116:26: warning: symbol 'stop_proc' was not declared. Should it be static?
drivers/tty/serial/icom.c:123:25: warning: symbol 'int_mask_tbl' was not declared. Should it be static?
drivers/tty/serial/icom.c:1569:54: warning: incorrect type in assignment (different address spaces)
drivers/tty/serial/icom.c:1569:54: expected unsigned char [noderef] <asn:2>*membase
drivers/tty/serial/icom.c:1569:54: got char *<noident>
drivers/tty/serial/icom.c:1090:9: warning: cast truncates bits from constant value (ffffff7f becomes 7f)
Signed-off-by: Jingoo Han <jg1.han@samsung.com>
remove cast for kzalloc return value.
Signed-off-by: Zhang Yanfei <zhangyanfei@cn.fujitsu.com>
Cc: Jiri Slaby <jslaby@suse.cz>
Now, we start converting tty buffer functions to actually use
tty_port. This will allow us to get rid of the need of tty in many
call sites. Only tty_port will needed and hence no more
tty_port_tty_get in those paths.
Now, the one where most of tty_port_tty_get gets removed:
tty_flip_buffer_push.
IOW we also closed all the races in drivers not using tty_port_tty_get
at all yet.
Also we move tty_flip_buffer_push declaration from include/linux/tty.h
to include/linux/tty_flip.h to all others while we are changing it
anyway.
tty_insert_flip_string this time.
tty_insert_flip_char is the next one to proceed. This one is used all
over the code, so the patch is huge.
Pull trivial branch from Jiri Kosina:
"Usual stuff -- comment/printk typo fixes, documentation updates, dead
code elimination."
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (39 commits)
HOWTO: fix double words typo
x86 mtrr: fix comment typo in mtrr_bp_init
propagate name change to comments in kernel source
doc: Update the name of profiling based on sysfs
treewide: Fix typos in various drivers
treewide: Fix typos in various Kconfig
wireless: mwifiex: Fix typo in wireless/mwifiex driver
messages: i2o: Fix typo in messages/i2o
scripts/kernel-doc: check that non-void fcts describe their return value
Kernel-doc: Convention: Use a "Return" section to describe return values
radeon: Fix typo and copy/paste error in comments
doc: Remove unnecessary declarations from Documentation/accounting/getdelays.c
various: Fix spelling of "asynchronous" in comments.
Fix misspellings of "whether" in comments.
eisa: Fix spelling of "asynchronous".
various: Fix spelling of "registered" in comments.
doc: fix quite a few typos within Documentation
target: iscsi: fix comment typos in target/iscsi drivers
treewide: fix typo of "suport" in various comments and Kconfig
treewide: fix typo of "suppport" in various comments
CONFIG_HOTPLUG is going away as an option so __devexit is no
longer needed.
Signed-off-by: Bill Pemberton <wfp5p@virginia.edu>
Cc: Jiri Slaby <jirislaby@gmail.com>
Cc: Alan Cox <alan@linux.intel.com>
Acked-by: Tobias Klauser <tklauser@distanz.ch>
Cc: Lucas Tavares <lucaskt@linux.vnet.ibm.com>
Cc: Daniel Walker <dwalker@fifo99.com>
Cc: Bryan Huntsman <bryanh@codeaurora.org>
Cc: Peter Korsgaard <jacmet@sunsite.dk>
Cc: Tony Prisk <linux@prisktech.co.nz>
Acked-by: David Brown <davidb@codeaurora.org>
CONFIG_HOTPLUG is going away as an option so __devinit is no longer
needed.
Acked-by: Nicolas Ferre <nicolas.ferre@atmel.com>
CONFIG_HOTPLUG is going away as an option so __devexit_p is no longer
needed.
Correct spelling typo in debug messages within tty drivers.
Signed-off-by: Masanari Iida <standby24x7@gmail.com>
Acked-by: Alan Cox <alan@linux.intel.com>
Remove all #inclusions of asm/system.h preparatory to splitting and killing
it. Performed with the following command:
perl -p -i -e 's!^#\s*include\s*<asm/system[.]h>.*\n!!' `grep -Irl '^#\s*include\s*<asm/system[.]h>' *`
Since commit [e58aa3d2: genirq: Run irq handlers with interrupts disabled],
We run all interrupt handlers with interrupts disabled
and we even check and yell when an interrupt handler
returns with interrupts enabled (see commit [b738a50a:
genirq: Warn when handler enables interrupts]).
So now this flag is a NOOP and can be removed.
Signed-off-by: Yong Zhang <yong.zhang0@gmail.com>
The serial drivers are really just tty drivers, so move them to
drivers/tty/ to make things a bit neater overall.
This is part of the tty/serial driver movement proceedure as proposed by
Arnd Bergmann and approved by everyone involved a number of months ago.
Cc: Alan Cox <alan@lxorguk.ukuu.org.uk>
Cc: Rogier Wolff <R.E.Wolff@bitwizard.nl>
Cc: Michael H. Warfield <mhw@wittsend.com>
