path: root/drivers/tty/cyclades.c
2014-07-10tty: Remove tty_hung_up_p() tests from tty drivers' open()Peter Hurley
Since at least before 2.6.30, it has not been possible to observe a hung up file pointer in a tty driver's open() method unless/until the driver open() releases the tty_lock() (eg., before blocking). This is because tty_open() adds the file pointer while holding the tty_lock() _and_ doesn't release the lock until after calling the tty driver's open() method. [ Before tty_lock(), this was lock_kernel(). ] Since __tty_hangup() first waits on the tty_lock() before enumerating and hanging up the open file pointers, either __tty_hangup() will wait for the tty_lock() or tty_open() will not yet have added the file pointer. For example, CPU 0 | CPU 1 | tty_open | __tty_hangup .. | .. tty_lock | .. tty_reopen | tty_lock / blocks .. | tty_add_file(tty, filp) | .. | tty->ops->open(tty, filp) | tty_port_open | tty_port_block_til_ready | .. | while (1) | .. | tty_unlock | / unblocks schedule | for each filp on tty->tty_files | f_ops = tty_hung_up_fops; | .. | tty_unlock tty_lock | .. | tty_unlock | Note that since tty_port_block_til_ready() and similar drop the tty_lock while blocking, when woken, the file pointer must then be tested for having been hung up. Also, fix bit-rotted drivers that used extra_count to track the port->count bump. CC: Mikael Starvik <starvik@axis.com> CC: Samuel Ortiz <samuel@sortiz.org> CC: "David S. Miller" <davem@davemloft.net> Signed-off-by: Peter Hurley <peter@hurleysoftware.com> Acked-by: Jesper Nilsson <jesper.nilsson@axis.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-12-20tty: an overflow of multiplication in drivers/tty/cyclades.cQixue Xiao
there is an overflow in the code : cyz_polling_cycle = (arg * HZ) / 1000, the multiplicator arg comes from user, so it may be an overflow if arg is a big number. And the value of cyc_polling_cycle will be wrong when it is used next time. Reported-by: Qixue Xiao <xiaoqixue_1@163.com> Suggested-by: Yongjian Xu <xuyongjiande@gmail.com> Suggested-by: Yu Chen <chyyuu@gmail.com> Signed-off-by: Qixue Xiao <xiaoqixue_1@163.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-03-18TTY: add tty_port_tty_hangup helperJiri Slaby
It allows for cleaning up on a considerable amount of places. They did port_get, hangup, kref_put. Now the only thing needed is to call tty_port_tty_hangup which does exactly that. And they can also decide whether to consider CLOCAL or completely ignore that. Signed-off-by: Jiri Slaby <jslaby@suse.cz> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-01-15cyclades: push down tty_port_tty_getJiri Slaby
Now, the tty is not needed at all places in the ISR. So we can just request in on demand when really needed. This cleans TX and RX paths a bit as the indentation level can be dropped by two now when we also invert the char_count if condition. Signed-off-by: Jiri Slaby <jslaby@suse.cz> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-01-15TTY: switch tty_schedule_flipJiri Slaby
Now, we start converting tty buffer functions to actually use tty_port. This will allow us to get rid of the need of tty in many call sites. Only tty_port will needed and hence no more tty_port_tty_get in those paths. This is the last one: tty_schedule_flip Signed-off-by: Jiri Slaby <jslaby@suse.cz> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-01-15TTY: switch tty_insert_flip_charJiri Slaby
Now, we start converting tty buffer functions to actually use tty_port. This will allow us to get rid of the need of tty in many call sites. Only tty_port will needed and hence no more tty_port_tty_get in those paths. tty_insert_flip_char is the next one to proceed. This one is used all over the code, so the patch is huge. Signed-off-by: Jiri Slaby <jslaby@suse.cz> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-01-15TTY: convert more flipping functionsJiri Slaby
Now, we start converting tty buffer functions to actually use tty_port. This will allow us to get rid of the need of tty pointer in many call sites. Only tty_port will be needed and hence no more tty_port_tty_get calls in those paths. Now 4 string flipping ones are on turn: * tty_insert_flip_string_flags * tty_insert_flip_string_fixed_flag * tty_prepare_flip_string * tty_prepare_flip_string_flags Signed-off-by: Jiri Slaby <jslaby@suse.cz> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-01-15TTY: switch tty_buffer_request_room to tty_portJiri Slaby
Now, we start converting tty buffer functions to actually use tty_port. This will allow us to get rid of the need of tty pointer in many call sites. Only tty_port will be needed and hence no more tty_port_tty_get calls in those paths. Here we start with tty_buffer_request_room. Signed-off-by: Jiri Slaby <jslaby@suse.cz> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-11-21tty: remove use of __devexitBill Pemberton
CONFIG_HOTPLUG is going away as an option so __devexit is no longer needed. Signed-off-by: Bill Pemberton <wfp5p@virginia.edu> Cc: Jiri Slaby <jirislaby@gmail.com> Cc: Alan Cox <alan@linux.intel.com> Acked-by: Tobias Klauser <tklauser@distanz.ch> Cc: Lucas Tavares <lucaskt@linux.vnet.ibm.com> Cc: Daniel Walker <dwalker@fifo99.com> Cc: Bryan Huntsman <bryanh@codeaurora.org> Cc: "David S. Miller" <davem@davemloft.net> Cc: Peter Korsgaard <jacmet@sunsite.dk> Cc: Tony Prisk <linux@prisktech.co.nz> Acked-by: David Brown <davidb@codeaurora.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-11-21tty: remove use of __devinitBill Pemberton
CONFIG_HOTPLUG is going away as an option so __devinit is no longer needed. Signed-off-by: Bill Pemberton <wfp5p@virginia.edu> Cc: Jiri Slaby <jirislaby@gmail.com> Cc: Alan Cox <alan@linux.intel.com> Cc: Lucas Tavares <lucaskt@linux.vnet.ibm.com> Cc: "David S. Miller" <davem@davemloft.net> Cc: Peter Korsgaard <jacmet@sunsite.dk> Cc: Tony Prisk <linux@prisktech.co.nz> Acked-by: Tobias Klauser <tklauser@distanz.ch> Acked-by: Nicolas Ferre <nicolas.ferre@atmel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-11-21tty: remove use of __devexit_pBill Pemberton
CONFIG_HOTPLUG is going away as an option so __devexit_p is no longer needed. Signed-off-by: Bill Pemberton <wfp5p@virginia.edu> Cc: Jiri Slaby <jirislaby@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-11-15TTY: call tty_port_destroy in the rest of driversJiri Slaby
After commit "TTY: move tty buffers to tty_port", the tty buffers are not freed in some drivers. This is because tty_port_destructor is not called whenever a tty_port is freed. This was an assumption I counted with but was unfortunately untrue. So fix the drivers to fulfil this assumption. To be sure, the TTY buffers (and later some stuff) are gone along with the tty_port, we have to call tty_port_destroy at tear-down places. This is mostly where the structure containing a tty_port is freed. This patch does exactly that -- put tty_port_destroy at those places. Signed-off-by: Jiri Slaby <jslaby@suse.cz> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-09-05serial: add a new helper functionHuang Shijie
In most of the time, the driver needs to check if the cts flow control is enabled. But now, the driver checks the ASYNC_CTS_FLOW flag manually, which is not a grace way. So add a new wraper function to make the code tidy and clean. Signed-off-by: Huang Shijie <shijie8@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-08-13TTY: use tty_port_register_deviceJiri Slaby
Currently we have no way to assign tty->port while performing tty installation. There are two ways to provide the link tty_struct => tty_port. Either by calling tty_port_install from tty->ops->install or tty_port_register_device called instead of tty_register_device when the device is being set up after connected. In this patch we modify most of the drivers to do the latter. When the drivers use tty_register_device and we have tty_port already, we switch to tty_port_register_device. So we have the tty_struct => tty_port link for free for those. Signed-off-by: Jiri Slaby <jslaby@suse.cz> Acked-by: Alan Cox <alan@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-08-10tty: localise the lockAlan Cox
The termios and other changes mean the other protections needed on the driver tty arrays should be adequate. Turn it all back on. This contains pieces folded in from the fixes made to the original patches | From: Geert Uytterhoeven <geert@linux-m68k.org> (fix m68k) | From: Paul Gortmaker <paul.gortmaker@windriver.com> (fix cris) | From: Jiri Kosina <jkosina@suze.cz> (lockdep) | From: Eric Dumazet <eric.dumazet@gmail.com> (lockdep) Signed-off-by: Alan Cox <alan@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-07-16tty: move the termios object into the ttyAlan Cox
This will let us sort out a whole pile of tty related races. The alternative would be to keep points and refcount the termios objects. However 1. They are tiny anyway 2. Many devices don't use the stored copies 3. We can remove a pty special case Signed-off-by: Alan Cox <alan@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-07-16tty: revert incorrectly applied lock patchAlan Cox
I sent GregKH this after the pre-requisites. He dropped the pre-requesites for good reason and unfortunately then applied this patch. Without this reverted you get random kernel memory corruption which will make bisecting anything between it and the properly applied patches a complete sod. Signed-off-by: Alan Cox <alan@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-07-06tty: localise the lockAlan Cox
2012-06-12TTY: cyclades, add local pointer for cardJiri Slaby
cy_pci_probe and cy_detect_isa reference cy_card[card_no] many times. It makes the code hard to read. Let us add a local variable holding a pointer to the card indexed by card_no and use that. Signed-off-by: Jiri Slaby <jslaby@suse.cz> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-06-02tty: Revert the tty locking series, it needs more workLinus Torvalds
This reverts the tty layer change to use per-tty locking, because it's not correct yet, and fixing it will require some more deep surgery. The main revert is d29f3ef39be4 ("tty_lock: Localise the lock"), but there are several smaller commits that built upon it, they also get reverted here. The list of reverted commits is: fde86d310886 - tty: add lockdep annotations 8f6576ad476b - tty: fix ldisc lock inversion trace d3ca8b64b97e - pty: Fix lock inversion b1d679afd766 - tty: drop the pty lock during hangup abcefe5fc357 - tty/amiserial: Add missing argument for tty_unlock() fd11b42e3598 - cris: fix missing tty arg in wait_event_interruptible_tty call d29f3ef39be4 - tty_lock: Localise the lock The revert had a trivial conflict in the 68360serial.c staging driver that got removed in the meantime. Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-05-04tty_lock: Localise the lockAlan Cox
In each remaining case the tty_lock is associated with a specific tty. This means we can now lock on a per tty basis. We do need tty_lock_pair() for the pty case. Uglier but still a step in the right direction. [fixed up calls in 3 missing drivers - gregkh] Signed-off-by: Alan Cox <alan@linux.intel.com> Acked-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-03-08TTY: remove unneeded tty->index checksJiri Slaby
Checking if tty->index is in bounds is not needed. The tty has the index set in the initial open. This is done in get_tty_driver. And it can be only in interval <0,driver->num). So remove the tests which check exactly this interval. Some are left untouched as they check against the current backing device count. (Leaving apart that the check is racy in most of the cases.) Signed-off-by: Jiri Slaby <jslaby@suse.cz> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-03-08TTY: remove re-assignments to tty_driver membersJiri Slaby
All num, magic and owner are set by alloc_tty_driver. No need to re-set them on each allocation site. pti driver sets something different to what it passes to alloc_tty_driver. It is not a bug, since we don't use the lines parameter in any way. Anyway this is fixed, and now we do the right thing. Signed-off-by: Jiri Slaby <jslaby@suse.cz> Acked-by: Tilman Schmidt <tilman@imap.cc> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-03-08tty: cyclades: TIOCSERGETLSR should should store to a uintDan Carpenter
TIOCSERGETLSR should be saved in a uint so the cast here to unsigned long is a bug. Reported-by: Jiri Slaby <jslaby@suse.cz> Signed-off-by: Dan Carpenter <dan.carpenter@oracle.com> Acked-by: Jiri Slaby <jslaby@suse.cz> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2011-09-22TTY: irq: Remove IRQF_DISABLEDYong Zhang
Since commit [e58aa3d2: genirq: Run irq handlers with interrupts disabled], We run all interrupt handlers with interrupts disabled and we even check and yell when an interrupt handler returns with interrupts enabled (see commit [b738a50a: genirq: Warn when handler enables interrupts]). So now this flag is a NOOP and can be removed. Signed-off-by: Yong Zhang <yong.zhang0@gmail.com> Acked-by: Tobias Klauser <tklauser@distanz.ch> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-08-23TTY: mxser+cyclades remove wait_until_sent debug codeJiri Slaby
It makes the code really ugly. And since it can be enabled only before building and only in the source files, it can be barely used by users. That said, I've not seen anybody to use it in the past few years. This crap is copied to some more drivers over the tty tree. Since I'm not their maintainer, I'm not sure if I should remove them too? Signed-off-by: Jiri Slaby <jslaby@suse.cz> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-05-26Merge branch 'trivial' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild-2.6 * 'trivial' of git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild-2.6: gfs2: Drop __TIME__ usage isdn/diva: Drop __TIME__ usage atm: Drop __TIME__ usage dlm: Drop __TIME__ usage wan/pc300: Drop __TIME__ usage parport: Drop __TIME__ usage hdlcdrv: Drop __TIME__ usage baycom: Drop __TIME__ usage pmcraid: Drop __DATE__ usage edac: Drop __DATE__ usage rio: Drop __DATE__ usage scsi/wd33c93: Drop __TIME__ usage scsi/in2000: Drop __TIME__ usage aacraid: Drop __TIME__ usage media/cx231xx: Drop __TIME__ usage media/radio-maxiradio: Drop __TIME__ usage nozomi: Drop __TIME__ usage cyclades: Drop __TIME__ usage
2011-04-19tty: remove invalid location line in file headerJovi Zhang
remove invalid location line in each file header after location moved from driver/char to driver/tty Signed-off-by: Jovi Zhang <bookjovi@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-04-19Char: cyclades, fix unused variableJiri Slaby
drivers/tty/cyclades.c:1454:2: warning: Value stored to 'channel' is never read channel = info->line - card->first_line; ^ ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ Fix it by moving it to the appropriate debug section where it is used. Signed-off-by: Jiri Slaby <jslaby@suse.cz> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-04-19cyclades: Drop __TIME__ usageMichal Marek
The kernel already prints its build timestamp during boot, no need to repeat it in random drivers and produce different object files each time. Acked-by: Greg Kroah-Hartman <gregkh@suse.de> Signed-off-by: Michal Marek <mmarek@suse.cz>
2011-02-22tty: move a number of tty drivers from drivers/char/ to drivers/tty/Greg Kroah-Hartman
As planned by Arnd Bergmann, this moves the following drivers from drivers/char/ to drivers/tty/ as that's where they really belong: amiserial nozomi synclink rocket cyclades moxa mxser isicom bfin_jtag_comm Cc: Arnd Bergmann <arnd@arndb.de> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Cc: Jiri Slaby <jslaby@suse.cz> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
