path: root/drivers/tty/amiserial.c
2014-01-07tty/amiserial: avoid interruptible_sleep_onArnd Bergmann
interruptible_sleep_on is generally problematic and we want to get rid of it. In case of TIOCMIWAIT, that race is actually in user space and does not get fixed since we can only detect changes after entering the ioctl handler, but it removes one more caller. This instance can not be trivially replaced with wait_event, so I chose to open-code the wait loop using prepare_to_wait/finish_wait. Signed-off-by: Arnd Bergmann <arnd@arndb.de> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-11-25TTY: amiserial, add missing platform checkGeert Uytterhoeven
When booting a multi-platform m68k kernel on a non-Amiga with "console=ttyS0" on the kernel command line, it crashes with: Unable to handle kernel access at virtual address 81dff01c Oops: 00000000 PC: [<001e09a8>] serial_console_write+0xc/0x70 Add the missing platform check to amiserial_console_init() to fix this. Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-08-27TTY: amiserial, remove unnecessary platform_set_drvdata()Jingoo Han
The driver core clears the driver data to NULL after device_release or on probe failure. Thus, it is not needed to manually clear the device driver data to NULL. Signed-off-by: Jingoo Han <jg1.han@samsung.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-03-15TTY: amiserial, use module_platform_driver_probe()Jingoo Han
This patch uses module_platform_driver_probe() macro which makes the code smaller and simpler. Signed-off-by: Jingoo Han <jg1.han@samsung.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-02-13tty: Remove ancient hardpps()Peter Hurley
hardpps() functionality is provided through the N_PPS line discipline now. The new function signature was added in commit 025b40ab (2011-01-12). There was no previous macro or function hardpps(), at least since before the initial commit of v2.6.12 in 2005. It's unlikely this code has been compiled since. Signed-off-by: Peter Hurley <peter@hurleysoftware.com> Signed-off-by: George Spelvin <linux@horizon.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-01-15TTY: switch tty_flip_buffer_pushJiri Slaby
Now, we start converting tty buffer functions to actually use tty_port. This will allow us to get rid of the need of tty in many call sites. Only tty_port will needed and hence no more tty_port_tty_get in those paths. Now, the one where most of tty_port_tty_get gets removed: tty_flip_buffer_push. IOW we also closed all the races in drivers not using tty_port_tty_get at all yet. Also we move tty_flip_buffer_push declaration from include/linux/tty.h to include/linux/tty_flip.h to all others while we are changing it anyway. Signed-off-by: Jiri Slaby <jslaby@suse.cz> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-01-15TTY: move low_latency to tty_portJiri Slaby
One point is to have less places where we actually need tty pointer. The other is that low_latency is bound to buffer processing and buffers are now in tty_port. So it makes sense to move low_latency to tty_port too. Signed-off-by: Jiri Slaby <jslaby@suse.cz> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-01-15TTY: switch tty_insert_flip_charJiri Slaby
Now, we start converting tty buffer functions to actually use tty_port. This will allow us to get rid of the need of tty in many call sites. Only tty_port will needed and hence no more tty_port_tty_get in those paths. tty_insert_flip_char is the next one to proceed. This one is used all over the code, so the patch is huge. Signed-off-by: Jiri Slaby <jslaby@suse.cz> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-11-15TTY: call tty_port_destroy in the rest of driversJiri Slaby
After commit "TTY: move tty buffers to tty_port", the tty buffers are not freed in some drivers. This is because tty_port_destructor is not called whenever a tty_port is freed. This was an assumption I counted with but was unfortunately untrue. So fix the drivers to fulfil this assumption. To be sure, the TTY buffers (and later some stuff) are gone along with the tty_port, we have to call tty_port_destroy at tear-down places. This is mostly where the structure containing a tty_port is freed. This patch does exactly that -- put tty_port_destroy at those places. Signed-off-by: Jiri Slaby <jslaby@suse.cz> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-09-05serial: add a new helper functionHuang Shijie
In most of the time, the driver needs to check if the cts flow control is enabled. But now, the driver checks the ASYNC_CTS_FLOW flag manually, which is not a grace way. So add a new wraper function to make the code tidy and clean. Signed-off-by: Huang Shijie <shijie8@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-08-13TTY: use tty_port_link_deviceJiri Slaby
So now for those drivers that can use neither tty_port_install nor tty_port_register_driver but still have tty_port available before tty_register_driver we use newly added tty_port_link_device. The rest of the drivers that still do not provide tty_struct <-> tty_port link will have to be converted to implement tty->ops->install. Signed-off-by: Jiri Slaby <jslaby@suse.cz> Acked-by: Alan Cox <alan@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-08-10tty: localise the lockAlan Cox
The termios and other changes mean the other protections needed on the driver tty arrays should be adequate. Turn it all back on. This contains pieces folded in from the fixes made to the original patches | From: Geert Uytterhoeven <geert@linux-m68k.org> (fix m68k) | From: Paul Gortmaker <paul.gortmaker@windriver.com> (fix cris) | From: Jiri Kosina <jkosina@suze.cz> (lockdep) | From: Eric Dumazet <eric.dumazet@gmail.com> (lockdep) Signed-off-by: Alan Cox <alan@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-07-16tty: move the termios object into the ttyAlan Cox
This will let us sort out a whole pile of tty related races. The alternative would be to keep points and refcount the termios objects. However 1. They are tiny anyway 2. Many devices don't use the stored copies 3. We can remove a pty special case Signed-off-by: Alan Cox <alan@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-07-16tty: revert incorrectly applied lock patchAlan Cox
I sent GregKH this after the pre-requisites. He dropped the pre-requesites for good reason and unfortunately then applied this patch. Without this reverted you get random kernel memory corruption which will make bisecting anything between it and the properly applied patches a complete sod. Signed-off-by: Alan Cox <alan@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-07-06tty: localise the lockAlan Cox
2012-06-02tty: Revert the tty locking series, it needs more workLinus Torvalds
This reverts the tty layer change to use per-tty locking, because it's not correct yet, and fixing it will require some more deep surgery. The main revert is d29f3ef39be4 ("tty_lock: Localise the lock"), but there are several smaller commits that built upon it, they also get reverted here. The list of reverted commits is: fde86d310886 - tty: add lockdep annotations 8f6576ad476b - tty: fix ldisc lock inversion trace d3ca8b64b97e - pty: Fix lock inversion b1d679afd766 - tty: drop the pty lock during hangup abcefe5fc357 - tty/amiserial: Add missing argument for tty_unlock() fd11b42e3598 - cris: fix missing tty arg in wait_event_interruptible_tty call d29f3ef39be4 - tty_lock: Localise the lock The revert had a trivial conflict in the 68360serial.c staging driver that got removed in the meantime. Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-05-07tty/amiserial: Add missing argument for tty_unlock()Geert Uytterhoeven
commit d29f3ef39be4eec0362b985305fc526d9be318cf ("tty_lock: Localise the lock") missed that d3a7b83f865b46bb7b5e1ed18a129ce1af349db4 ("drivers/tty/amiserial.c: add missing tty_unlock") just added a new caller of tty_unlock(): drivers/tty/amiserial.c: In function ‘set_serial_info’: drivers/tty/amiserial.c:1077: error: too few arguments to function ‘tty_unlock’ Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Alan Cox <alan@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-05-04tty_lock: Localise the lockAlan Cox
In each remaining case the tty_lock is associated with a specific tty. This means we can now lock on a per tty basis. We do need tty_lock_pair() for the pty case. Uglier but still a step in the right direction. [fixed up calls in 3 missing drivers - gregkh] Signed-off-by: Alan Cox <alan@linux.intel.com> Acked-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-04-19drivers/tty/amiserial.c: add missing tty_unlockJulia Lawall
tty_unlock is used on all other exits from the function. Signed-off-by: Julia Lawall <Julia.Lawall@lip6.fr> Acked-by: Jiri Slaby <jslaby@suse.cz> Cc: stable <stable@vger.kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-03-28Remove all #inclusions of asm/system.hDavid Howells
Remove all #inclusions of asm/system.h preparatory to splitting and killing it. Performed with the following command: perl -p -i -e 's!^#\s*include\s*<asm/system[.]h>.*\n!!' `grep -Irl '^#\s*include\s*<asm/system[.]h>' *` Signed-off-by: David Howells <dhowells@redhat.com>
2012-03-08TTY: amiserial, use tty_port_close_startJiri Slaby
Again, no need to duplicate the code. Let's use the helper. Amiserial changes are only free of compilation errors. I have no access to the hardware. Signed-off-by: Jiri Slaby <jslaby@suse.cz> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-03-08TTY: amiserial, use tty_port_close_endJiri Slaby
Hmm, the code was sleeping with interrupts disabled. This was not good. Fix this by turning interrupts at an appropriate place. (The race is protected by CLOSING flag.) After the move, the code is identical to tty_port_close_end, so use it! Signed-off-by: Jiri Slaby <jslaby@suse.cz> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-03-08TTY: amiserial, use tty_port_block_til_readyJiri Slaby
Hmm, 150 lines of duplicated stuff is gone now. Signed-off-by: Jiri Slaby <jslaby@suse.cz> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-03-08TTY: amiserial, provide carrier helpersJiri Slaby
This is a preparation for a switch to tty_port_block_til_ready. We need amiga_carrier_raised and amiga_dtr_rts. The implementation is taken from startup, shutdown and current block_til_ready. Signed-off-by: Jiri Slaby <jslaby@suse.cz> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-03-08TTY: amiserial no longer needs serialPJiri Slaby
amiserial is the last user of serialP.h. Let's move struct serial_state directly to amiserial and remove serialP crap from includes. Finally, remove the header from the tree completely. Signed-off-by: Jiri Slaby <jslaby@suse.cz> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-03-08TTY: amiserial, stop using serial_state->{irq,type,line}Jiri Slaby
* instead of line, use tty->index or iterator... * irq and type are left unset. So get rid of them. Signed-off-by: Jiri Slaby <jslaby@suse.cz> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-03-08TTY: amiserial, define local tty_port pointerJiri Slaby
And use it to make the code more readable. Signed-off-by: Jiri Slaby <jslaby@suse.cz> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-03-08TTY: amiserial/simserial, use flags from tty_portJiri Slaby
This changes flags' type to ulong which is appropriate for all the set/clear_bits performed in the drivers.. Signed-off-by: Jiri Slaby <jslaby@suse.cz> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Tony Luck <tony.luck@intel.com> Cc: Fenghua Yu <fenghua.yu@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-03-08TTY: amiserial/simserial, use count from tty_portJiri Slaby
Nothing special. Just remove count from serial_state and change all users to use tty_port. Signed-off-by: Jiri Slaby <jslaby@suse.cz> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Tony Luck <tony.luck@intel.com> Cc: Fenghua Yu <fenghua.yu@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-03-08TTY: amiserial/simserial, use close delays from tty_portJiri Slaby
Note that previously simserial set the delay to 0. So we preserve that. BUT, is it correct? Signed-off-by: Jiri Slaby <jslaby@suse.cz> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Tony Luck <tony.luck@intel.com> Cc: Fenghua Yu <fenghua.yu@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-03-08TTY: amiserial/simserial, use tty_portJiri Slaby
Add tty_port to serial_state and start using common tty port members from tty_port in amiserial and simserial. The rest will follow one by one. Signed-off-by: Jiri Slaby <jslaby@suse.cz> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Tony Luck <tony.luck@intel.com> Cc: Fenghua Yu <fenghua.yu@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-03-08TTY: amiserial, pass tty down to functionsJiri Slaby
This avoids pain with tty refcounting and touching tty_port in the future. It allows us to remove some info->tty tests because the tty passed down to them can never be NULL. Signed-off-by: Jiri Slaby <jslaby@suse.cz> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-03-08TTY: amiserial, simplify set_serial_infoJiri Slaby
Do not copy whole serial_state. We only need to know whether the speed is to be changed. Hence store the info in advance and use it later. A simple bool is enough. Also remove reduntant assignments and move the tests directly to the 'if'. Signed-off-by: Jiri Slaby <jslaby@suse.cz> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-03-08TTY: serialP, merge serial_state and async_structJiri Slaby
This is the final step to get rid of the one of the structures. A further cleanup will follow. And I struct serial_state deserves cease to exist after a switch to tty_port too. While changing the lines, it removes also pointless tty->driver_data casts. Signed-off-by: Jiri Slaby <jslaby@suse.cz> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Tony Luck <tony.luck@intel.com> Cc: Fenghua Yu <fenghua.yu@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-03-08TTY: amiserial, remove IRQ_portsJiri Slaby
They used to work as a storage for 'info' pointer used in ISRs. They are not really needed. Just pass the pointer through request_irq to the handlers. It was set to NULL and tested in the ISRs, but we do not need the tests as we disable all the interrupts at the same places where NULL sets were. Signed-off-by: Jiri Slaby <jslaby@suse.cz> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-03-08TTY: simserial/amiserial, use one instance of other membersJiri Slaby
This means: * close_delay * closing_wait * line * port * xmit_fifo_size This actually fixes a bug in amiserial. It initializes one and uses the other of the close delays. Yes, duplicating structure members is evil. Signed-off-by: Jiri Slaby <jslaby@suse.cz> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Tony Luck <tony.luck@intel.com> Cc: Fenghua Yu <fenghua.yu@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-03-08TTY: amiserial, use only one copy of async flagsJiri Slaby
Huh, why would one want to store two copies of them? Get rid of the one from async_struct. That structure is going away as a whole soon. Signed-off-by: Jiri Slaby <jslaby@suse.cz> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-03-08TTY: amiserial, remove tasklet for tty_wakeupJiri Slaby
tty_wakeup is safe to be called from all contexts. No need to schedule a tasklet for that. Let's call it directly like in other drivers. This allows us to kill another member of async_struct structure. (If we remove the dummy uses in simserial.) Signed-off-by: Jiri Slaby <jslaby@suse.cz> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Tony Luck <tony.luck@intel.com> Cc: Fenghua Yu <fenghua.yu@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-03-08TTY: serialP, remove unused materialJiri Slaby
First, remove unused macro and rs_multiport_struct structure. Nobody uses them at all. Further, the 2 drivers (they are below) which use the rest of structures from serialP.h (async_struct and serial_state) do not use all the members. Remove the members: * which are unused or * which are only initialized and never used for something real. Everybody should avoid the structures with a looong distance. Finally, remove the ALPHA kludge MCR quirks. They are 1:1 copy from 8250.h. No need to redefine them here. The 2 promised users of the structures: arch/ia64/hp/sim/simserial.c drivers/tty/amiserial.c Signed-off-by: Jiri Slaby <jslaby@suse.cz> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Tony Luck <tony.luck@intel.com> Cc: Fenghua Yu <fenghua.yu@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-03-08TTY: remove unneeded tty->index checksJiri Slaby
Checking if tty->index is in bounds is not needed. The tty has the index set in the initial open. This is done in get_tty_driver. And it can be only in interval <0,driver->num). So remove the tests which check exactly this interval. Some are left untouched as they check against the current backing device count. (Leaving apart that the check is racy in most of the cases.) Signed-off-by: Jiri Slaby <jslaby@suse.cz> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-03-08TTY: remove re-assignments to tty_driver membersJiri Slaby
All num, magic and owner are set by alloc_tty_driver. No need to re-set them on each allocation site. pti driver sets something different to what it passes to alloc_tty_driver. It is not a bug, since we don't use the lines parameter in any way. Anyway this is fixed, and now we do the right thing. Signed-off-by: Jiri Slaby <jslaby@suse.cz> Acked-by: Tilman Schmidt <tilman@imap.cc> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2011-09-22TTY: irq: Remove IRQF_DISABLEDYong Zhang
Since commit [e58aa3d2: genirq: Run irq handlers with interrupts disabled], We run all interrupt handlers with interrupts disabled and we even check and yell when an interrupt handler returns with interrupts enabled (see commit [b738a50a: genirq: Warn when handler enables interrupts]). So now this flag is a NOOP and can be removed. Signed-off-by: Yong Zhang <yong.zhang0@gmail.com> Acked-by: Tobias Klauser <tklauser@distanz.ch> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-08-23TTY: ami_serial, remove BTM from wait_until_sentJiri Slaby
The same as in "TTY: serial, remove BTM from wait_until_sent" we don't need to take BTM in wait_until_sent of ami_serial. Exactly the same as serial, ami_serial accesses some "info" members (xmit_fifo_size, timeout), but their assignment on other places in the code is not protected by BTM anyway. So the BTM protects nothing here. This removal helps us to get rid of tty_locked() and __big_tty_mutex_owner in the following patch. This was suggested by Arnd. Signed-off-by: Jiri Slaby <jslaby@suse.cz> Acked-by: Arnd Bergmann <arnd@arndb.de> Cc: Alan Cox <alan@linux.intel.com> Cc: Andreas Bombe <aeb@debian.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-04-19tty: remove invalid location line in file headerJovi Zhang
remove invalid location line in each file header after location moved from driver/char to driver/tty Signed-off-by: Jovi Zhang <bookjovi@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-02-22tty: move a number of tty drivers from drivers/char/ to drivers/tty/Greg Kroah-Hartman
As planned by Arnd Bergmann, this moves the following drivers from drivers/char/ to drivers/tty/ as that's where they really belong: amiserial nozomi synclink rocket cyclades moxa mxser isicom bfin_jtag_comm Cc: Arnd Bergmann <arnd@arndb.de> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Cc: Jiri Slaby <jslaby@suse.cz> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
