If tb_drom_read() fails, sw->drom is freed but not set to NULL. sw->drom
is then freed again in the error path of tb_switch_alloc().
The bug can be triggered by unplugging a thunderbolt device shortly after
it is detected by the thunderbolt driver.
Clear sw->drom if tb_drom_read() fails.
[bhelgaas: add Fixes:, stable versions of interest]
Fixes: 343fcb8c70d7 ("thunderbolt: Fix nontrivial endpoint devices.")
Signed-off-by: Andreas Noever <andreas.noever@gmail.com>
Signed-off-by: Bjorn Helgaas <bhelgaas@google.com>
CC: stable@vger.kernel.org # v3.17+
CC: Lukas Wunner <lukas@wunner.de>
Add support for the 1st gen Light Ridge controller, which is built into
these systems:
iMac12,1 2011 21.5"
iMac12,2 2011 27"
Macmini5,1 2011 i5 2.3 GHz
Macmini5,2 2011 i5 2.5 GHz
Macmini5,3 2011 i7 2.0 GHz
MacBookPro8,1 2011 13"
MacBookPro8,2 2011 15"
MacBookPro8,3 2011 17"
MacBookPro9,1 2012 15"
MacBookPro9,2 2012 13"
Light Ridge (CV82524) was the very first copper Thunderbolt controller,
introduced 2010 alongside its fiber-optic cousin Light Peak (CVL2510).
Consequently the chip suffers from some teething troubles:
- MSI is broken for hotplug signaling on the downstream bridges: The chip
just never sends an interrupt. It requests 32 MSIs for each of its six
bridges and the pcieport driver only allocates one per bridge. However
I've verified that even if 32 MSIs are allocated there's no interrupt
on hotplug. The only option is thus to disable MSI, which is also what
OS X does. Apparently all Thunderbolt chips up to revision 1 of Cactus
Ridge 4C are plagued by this issue so quirk those as well.
- The chip supports a maximum hop_count of 32, unlike its successors
which support only 12. Fixup ring_interrupt_active() to cope with
values >= 32.
- Another peculiarity is that the chip supports a maximum of 13 ports
whereas its successors support 12. However the additional port (#5)
seems to be unusable as reading its TB_CFG_PORT config space results in
TB_CFG_ERROR_INVALID_CONFIG_SPACE. Add a quirk to mark the port
disabled on the root switch, assuming that's necessary on all Macs
using this chip.
Tested-by: Lukas Wunner <lukas@wunner.de> [MacBookPro9,1]
Tested-by: William Brown <william@blackhats.net.au> [MacBookPro8,2]
Signed-off-by: Lukas Wunner <lukas@wunner.de>
Acked-by: Andreas Noever <andreas.noever@gmail.com>
Fix typo in tb_cfg_print_error() message. Fix bytecount in struct
tb_drom_entry_port comment. Replace magic number in tb_switch_alloc().
Rename tb_sw_set_unpplugged() and TB_CAL_IECS to fix typos.
[bhelgaas: no functional change intended]
tb_eeprom_get_drom_offset is local to this file.
Force enum tb_drom_entry_type to unsigned to fix the following error:
drivers/thunderbolt/eeprom.c:202:39: error: dubious one-bit signed bitfield
The result of "sizeof(struct tb_drom_entry_port)" is a size_t, which
is not necessarily the same as 'long', so we should use the appropriate
%z format string instead of %l.
Fixes the below error:
drivers/thunderbolt/eeprom.c:407:2: error: implicit declaration of function ‘kzalloc’ [-Werror=implicit-function-declaration]
drivers/thunderbolt/eeprom.c:444:2: error: implicit declaration of function ‘kfree’ [-Werror=implicit-function-declaration]
Signed-off-by: Sachin Kamat <sachin.kamat@samsung.com>
All Thunderbolt switches (except the root switch) contain a drom which
contains information about the device. Right now we only read the UID.
Add code to read and parse this drom. For now we are only interested in
which ports are disabled and which ports are "dual link ports" (a
physical thunderbolt port/socket contains two such ports).
Add eeprom access code and read the uid during switch initialization.
The UID will be used to check device identity after suspend.
