path: root/drivers/thermal
2011-02-28ACPI: Fix build for CONFIG_NET unsetRafael J. Wysocki
Several ACPI drivers fail to build if CONFIG_NET is unset, because they refer to things depending on CONFIG_THERMAL that in turn depends on CONFIG_NET. However, CONFIG_THERMAL doesn't really need to depend on CONFIG_NET, because the only part of it requiring CONFIG_NET is the netlink interface in thermal_sys.c. Put the netlink interface in thermal_sys.c under #ifdef CONFIG_NET and remove the dependency of CONFIG_THERMAL on CONFIG_NET from drivers/thermal/Kconfig. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Acked-by: Randy Dunlap <randy.dunlap@oracle.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Len Brown <lenb@kernel.org> Cc: Stephen Rothwell <sfr@canb.auug.org.au> Cc: Luming Yu <luming.yu@intel.com> Cc: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-01-12Merge branch 'misc' into releaseLen Brown
2011-01-12thermal: Add event notification to thermal frameworkR.Durgadoss
This patch adds event notification support to the generic thermal sysfs framework in the kernel. The notification is in the form of a netlink event. Signed-off-by: R.Durgadoss <durgadoss.r@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2010-11-30thermal: make ops constantAlan Cox
And while touching that function definition do something about the disaster of formatting there. Signed-off-by: Alan Cox <alan@linux.intel.com> Acked-by: Zhang Rui <rui.zhang@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2010-04-07drivers/thermal/thermal_sys.c: fix 'key f70f4b50 not in .data' in thermal_sysSergey Senozhatsky
Initialize sysfs attributes before device_create_file call. Addresses https://bugzilla.kernel.org/show_bug.cgi?id=15548 Signed-off-by: Wolfram Sang <w.sang@pengutronix.de> Signed-off-by: Sergey Senozhatsky <sergey.senozhatsky@gmail.com> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Cc: Greg KH <gregkh@suse.de> Cc: Zhang Rui <rui.zhang@intel.com> Cc: Len Brown <len.brown@intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2009-12-16Merge branch 'misc-2.6.33' into releaseLen Brown
2009-12-16thermal: Fix test of unsigned in thermal_cooling_device_cur_state_store()Roel Kluin
state is unsigned long so the test did not work. Signed-off-by: Roel Kluin <roel.kluin@gmail.com> Acked-by: Zhang Rui <rui.zhang@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2009-11-05thermal: disable polling if passive_delay and polling_delay are both unsetFrans Pop
Otherwise polling will continue for the thermal zone even when it is no longer needed, for example because forced passive cooling was disabled. Signed-off-by: Frans Pop <elendil@planet.nl> Acked-by: Matthew Garrett <mjg@redhat.com> Acked-by: Zhang Rui <rui.zhang@intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Len Brown <len.brown@intel.com>
2009-11-05thermal: Only set passive_delay for forced_passive coolingFrans Pop
Setting polling_delay is useless as passive_delay has priority, so the value shown in proc isn't the actual polling delay. It also gives the impression to the user that he can change the polling interval through proc, while in fact he can't. Also, unset passive_delay when the forced passive trip point is unbound to allow polling to be disabled. Signed-off-by: Frans Pop <elendil@planet.nl> Acked-by: Matthew Garrett <mjg@redhat.com> Acked-by: Zhang Rui <rui.zhang@intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Len Brown <len.brown@intel.com>
2009-11-05thermal: add sanity check for the passive attributeFrans Pop
Values below 1000 milli-celsius don't make sense and can cause the system to go into a thermal heart attack: the actual temperature will always be lower and thus the system will be throttled down to its lowest setting. An additional problem is that values below 1000 will show as 0 in /proc/acpi/thermal/TZx/trip_points:passive. cat passive 0 echo -n 90 >passive bash: echo: write error: Invalid argument echo -n 90000 >passive cat passive 90000 Signed-off-by: Frans Pop <elendil@planet.nl> Acked-by: Zhang Rui <rui.zhang@intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Len Brown <len.brown@intel.com>
2009-11-05acpi: thermal: Add EOL to the trip_point_N_type stringsAmit Kucheria
Make the trip_point_N_type sysfs files return a string ending in EOL for consistency with other sysfs files. Signed-off-by: Amit Kucheria <amit.kucheria@canonical.com> Acked-by: Zhang Rui <rui.zhang@intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Len Brown <len.brown@intel.com>
2009-09-19thermal: add missing Kconfig dependencyJan Beulich
Otherwise THERMAL_HWMON can be selected when HWMON=n and THERMAL=n, which fails to build. Signed-off-by: Jan Beulich <jbeulich@novell.com> Cc: Zhang Rui <rui.zhang@intel.com> Cc: Matthew Garrett <mjg@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Len Brown <len.brown@intel.com>
2009-08-26thermal_sys: check get_temp return valueMichael Brunner
The return value of the get_temp function is not checked when doing a thermal zone update. This may lead to a critical shutdown if get_temp fails and the content of the temp variable is incorrectly set higher than the critical trip point. This has been observed on a system with incorrect ACPI implementation where the corresponding methods were not serialized and therefore sometimes triggered ACPI errors (AE_ALREADY_EXISTS). The following critical shutdowns indicated a temperature of 2097 C, which was obviously wrong. The patch adds a return value check that jumps over all trip point evaluations printing a warning if get_temp fails. The trip points are evaluated again on the next polling interval with successful get_temp execution. Signed-off-by: Michael Brunner <mibru@gmx.de> Acked-by: Zhang Rui <rui.zhang@intel.com> Cc: Len Brown <lenb@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-06-15thermal: remove driver_data direct access of struct deviceGreg Kroah-Hartman
In the near future, the driver core is going to not allow direct access to the driver_data pointer in struct device. Instead, the functions dev_get_drvdata() and dev_set_drvdata() should be used. These functions have been around since the beginning, so are backwards compatible with all older kernel versions. Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-05-14thermal: fix off-by-1 error in trip point trigger conditionVladimir Zajac
This patch fixes a regression caused by commit b1569e99c795bf83b4ddf41c4f1c42761ab7f75e "ACPI: move thermal trip handling to generic thermal layer" which accidentally changed trip point trigger condition to temp > trip_temp This patch changes the trigger condition back to temp >= trip_temp Signed-off-by: Vladimir Zajac <eightgraph@gmail.com> Acked-by: Zhang Rui <rui.zhang@intel.com> Acked-by: Matthew Garrett <mjg@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Len Brown <len.brown@intel.com>
2009-03-27thermal: support forcing support for passive coolingMatthew Garrett
Due to poor thermal design or Linux driving hardware outside its thermal envelope, some systems will reach critical temperature and shut down under high load. This patch adds support for forcing a polling-based passive trip point if the firmware doesn't provide one. The assumption is made that the processor is the most practical means to reduce the dynamic heat generation, so hitting the passive thermal limit will cause the CPU to be throttled until the temperature stabalises around the defined value. UI is provided via a "passive" sysfs entry in the thermal zone directory. It accepts a decimal value in millidegrees celsius, or "0" to disable the functionality. Default behaviour is for this functionality to be disabled. Signed-off-by: Matthew Garrett <mjg@redhat.com> Signed-off-by: Len Brown <len.brown@intel.com>
2009-02-20ACPI: move thermal trip handling to generic thermal layerMatthew Garrett
The ACPI code currently carries its own thermal trip handling, meaning that any other thermal implementation will need to reimplement it. Move the code to the generic thermal layer. Signed-off-by: Matthew Garrett <mjg@redhat.com> Signed-off-by: Len Brown <len.brown@intel.com>
2009-02-20thermal: use integers rather than strings for thermal valuesMatthew Garrett
The thermal API currently uses strings to pass values to userspace. This makes it difficult to use from within the kernel. Change the interface to use integers and fix up the consumers. Signed-off-by: Matthew Garrett <mjg@redhat.com> Acked-by: Zhang Rui <rui.zhang@intel.com> Acked-by: Thomas Renninger <trenn@suse.de> Signed-off-by: Len Brown <len.brown@intel.com>
2009-01-06thermal: struct device - replace bus_id with dev_name(), dev_set_name()Kay Sievers
Signed-off-by: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-06-25thermal: Create CONFIG_THERMAL_HWMON=nRene Herman
A bug in libsensors <= 2.10.6 is exposed when this new hwmon I/F is enabled. Create CONFIG_THERMAL_HWMON=n until some time after libsensors 2.10.7 ships so those users can run the latest kernel. libsensors 3.x is already fixed -- those users can use CONFIG_THERMAL_HWMON=y now. Signed-off-by: Rene Herman <rene.herman@gmail.com> Acked-by: Mark M. Hoffman <mhoffman@lightlink.com> Signed-off-by: Len Brown <len.brown@intel.com>
2008-04-29thermal: re-name thermal.c to thermal_sys.cLen Brown
thermal_sys was already the name of the resulting module, and it is built from this one source file. Signed-off-by: Len Brown <len.brown@intel.com>
2008-04-29thermal: add hwmon sysfs I/FZhang Rui
Add hwmon sys I/F for generic thermal driver. Note: we have one hwmon class device for EACH TYPE of the thermal zone device. Signed-off-by: Zhang Rui <rui.zhang@intel.com> Acked-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Len Brown <len.brown@intel.com>
2008-04-29thermal: add the support for building the generic thermal as a moduleZhang Rui
Build the generic thermal driver as module "thermal_sys". Make ACPI thermal, video, processor and fan SELECT the generic thermal driver, as these drivers rely on it to build the sysfs I/F. Signed-off-by: Zhang Rui <rui.zhang@intel.com> Acked-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Len Brown <len.brown@intel.com>
2008-04-15acpi thermal trip points increased to 12Krzysztof Helt
The THERMAL_MAX_TRIPS value is set to 10. It is too few for the Compaq AP550 machine which has 12 trip points. Signed-off-by: Krzysztof Helt <krzysztof.h1@wp.pl> Cc: Len Brown <lenb@kernel.org> Cc: Zhang Rui <rui.zhang@intel.com> Cc: "Rafael J. Wysocki" <rjw@sisk.pl> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-03-18thermal: delete "default y"Len Brown
The generic thermal I/F gets selected by ACPI_THERMAL -- its only current customer. it doesn't need to clutter other configs by default. Signed-off-by: Len Brown <len.brown@intel.com>
2008-03-18Revert "thermal: fix generic thermal I/F for hwmon"Len Brown
This reverts commit 3152fb9f11cdd2fd8688c2c5cb805e5c09b53dd9. This broke libsensors. Acked-by: Zhang Rui <rui.zhang@intel.com> Acked-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Len Brown <len.brown@intel.com>
2008-03-13thermal: fix generic thermal I/F for hwmonZhang, Rui
Signed-off-by: Zhang Rui <rui.zhang@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2008-02-15thermal: use ERR_PTR for returning errorThomas Sujith
Need to return using ERR_PTR instead of NULL in case of errors. Signed-off-by: Thomas Sujith <sujith.thomas@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2008-02-15thermal: validate input parametersThomas Sujith
Added sanity check to make sure that thermal zone and cooling device exists. Signed-off-by: Thomas Sujith <sujith.thomas@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2008-02-07ACPI: thermal: syntax, spelling, kernel-docLen Brown
Reviewed-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Len Brown <len.brown@intel.com>
2008-02-01the generic thermal sysfs driverZhang Rui
The Generic Thermal sysfs driver for thermal management. Signed-off-by: Zhang Rui <rui.zhang@intel.com> Signed-off-by: Thomas Sujith <sujith.thomas@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
