commit b53b0d99d6fbf7d44330395349a895521cfdbc96 upstream.
This patch fixes a bug in iscsit_logout_post_handler_diffcid() where
a pointer used as storage for list_for_each_entry() was incorrectly
being used to determine if no matching entry had been found.
This patch changes iscsit_logout_post_handler_diffcid() to key off
bool conn_found to determine if the function needs to exit early.
Reported-by: Joern Engel <joern@logfs.org>
commit 8ae757d09c45102b347a1bc2867f54ffc1ab8fda upstream.
In iscsi_copy_param_list() a failed iscsi_param_list memory allocation
currently invokes iscsi_release_param_list() to cleanup, and will promptly
trigger a NULL pointer dereference.
Instead, go ahead and return for the first iscsi_copy_param_list()
failure case.
Found by coverity.
Signed-off-by: Joern Engel <joern@logfs.org>
commit 1f0b030c45c781f9fe568e5e2a813d6c8567a051 upstream.
Fix inverted logic in SE_DEV_ALUA_SUPPORT_STATE_STORE for setting
the supported ALUA access states via configfs, originally introduced
in commit b0a382c5.
A value of 1 should enable the support, not disable it.
Signed-off-by: Sebastian Herbszt <herbszt@gmx.de>
commit 81a9c5e72bdf7109a65102ca61d8cbd722cf4021 upstream.
On uniprocessor preemptible kernel, target core deadlocks on unload. The
following events happen:
* iscsit_del_np is called
* it calls send_sig(SIGINT, np->np_thread, 1);
* the scheduler switches to the np_thread
* the np_thread is woken up, it sees that kthread_should_stop() returns
false, so it doesn't terminate
* the np_thread clears signals with flush_signals(current); and goes back
to sleep in iscsit_accept_np
* the scheduler switches back to iscsit_del_np
* iscsit_del_np calls kthread_stop(np->np_thread);
* the np_thread is waiting in iscsit_accept_np and it doesn't respond to
kthread_stop
The deadlock could be resolved if the administrator sends SIGINT signal to
the np_thread with killall -INT iscsi_np
The reproducible deadlock was introduced in commit
db6077fd0b7dd41dc6ff18329cec979379071f87, but the thread-stopping code was
racy even before.
This patch fixes the problem. Using kthread_should_stop to stop the
np_thread is unreliable, so we test np_thread_state instead. If
np_thread_state equals ISCSI_NP_THREAD_SHUTDOWN, the thread exits.
Signed-off-by: Mikulas Patocka <mpatocka@redhat.com>
commit 683497566d48f86e04d026de1ee658dd74fc1077 upstream.
This patch adds a explicit memset to the login response PDU
exception path in iscsit_tx_login_rsp().
This addresses a regression bug introduced in commit baa4d64b
where the initiator would end up not receiving the login
response and associated status class + detail, before closing
the login connection.
Reported-by: Christophe Vu-Brugier <cvubrugier@yahoo.fr>
Tested-by: Christophe Vu-Brugier <cvubrugier@yahoo.fr>
commit 97c99b47ac58bacb7c09e1f47d5d184434f6b06a upstream.
This patch changes iscsit_check_dataout_hdr() to dump the incoming
Data-Out payload when the received ITT is not associated with a
WRITE, instead of calling iscsit_reject_cmd() for the non WRITE
ITT descriptor.
This addresses a bug where an initiator sending an Data-Out for
an ITT associated with a READ would end up generating a reject
for the READ, eventually resulting in list corruption.
Reported-by: Santosh Kulkarni <santosh.kulkarni@calsoftinc.com>
Reported-by: Arshad Hussain <arshad.hussain@calsoftinc.com>
commit 83ff42fcce070801a3aa1cd6a3269d7426271a8d upstream.
This patch fixes a left-over se_lun->lun_sep pointer OOPs when one
of the /sys/kernel/config/target/$FABRIC/$WWPN/$TPGT/lun/$LUN/alua*
attributes is accessed after the $DEVICE symlink has been removed.
To address this bug, go ahead and clear se_lun->lun_sep memory in
core_dev_unexport(), so that the existing checks for show/store
ALUA attributes in target_core_fabric_configfs.c work as expected.
Reported-by: Sebastian Herbszt <herbszt@gmx.de>
Tested-by: Sebastian Herbszt <herbszt@gmx.de>
[Note that a different patch to address the same issue went in during
v3.15-rc1 (commit 4442dc8a), but includes a bunch of other changes that
don't strictly apply to fixing the bug]
This patch changes rd_allocate_sgl_table() to explicitly clear
ramdisk_mcp backend memory pages by passing __GFP_ZERO into
alloc_pages().
This addresses a potential security issue where reading from a
ramdisk_mcp could return sensitive information, and follows what
>= v3.15 does to explicitly clear ramdisk_mcp memory at backend
device initialization time.
Reported-by: Jorge Daniel Sequeira Matias <jdsm@tecnico.ulisboa.pt>
Cc: Jorge Daniel Sequeira Matias <jdsm@tecnico.ulisboa.pt>
commit 2426bd456a61407388b6e61fc5f98dbcbebc50e2 upstream.
When an initiator sends an allocation length bigger than what its
command consumes, the target should only return the actual response data
and set the residual length to the unused part of the allocation length.
Add a helper function that command handlers (INQUIRY, READ CAPACITY,
etc) can use to do this correctly, and use this code to get the correct
residual for commands that don't use the full initiator allocation in the
handlers for READ CAPACITY, READ CAPACITY(16), INQUIRY, MODE SENSE and
REPORT LUNS.
This addresses a handful of failures as reported by Christophe with
the Windows Certification Kit:
http://permalink.gmane.org/gmane.linux.scsi.target.devel/6515
Signed-off-by: Roland Dreier <roland@purestorage.com>
commit 22c7aaa57e80853b4904a46c18f97db0036a3b97 upstream.
In case the transport is iser we should not include the
iscsi target info in the sendtargets text response pdu.
This causes sendtargets response to include the target
info twice.
Modify iscsit_build_sendtargets_response to filter
transport types that don't match.
Signed-off-by: Sagi Grimberg <sagig@mellanox.com>
Reported-by: Slava Shwartsman <valyushash@gmail.com>
commit bbc050488525e1ab1194c27355f63c66814385b8 upstream.
This patch fixes a iscsi_queue_req memory leak when ABORT_TASK response
has been queued by TFO->queue_tm_rsp() -> lio_queue_tm_rsp() after a
long standing I/O completes, but the connection has already reset and
waiting for cleanup to complete in iscsit_release_commands_from_conn()
-> transport_generic_free_cmd() -> transport_wait_for_tasks() code.
It moves iscsit_free_queue_reqs_for_conn() after the per-connection command
list has been released, so that the associated se_cmd tag can be completed +
released by target-core before freeing any remaining iscsi_queue_req memory
for the connection generated by lio_queue_tm_rsp().
Cc: Thomas Glanzmann <thomas@glanzmann.de>
Cc: Charalampos Pournaris <charpour@gmail.com>
commit a95d6511303b848da45ee27b35018bb58087bdc6 upstream.
This patch fixes a bug where multiple waiters on ->t_transport_stop_comp
occurs due to a concurrent ABORT_TASK and session reset both invoking
transport_wait_for_tasks(), while waiting for the associated se_cmd
descriptor backend processing to complete.
For this case, complete_all() should be invoked in order to wake up
both waiters in core_tmr_abort_task() + transport_generic_free_cmd()
process contexts.
commit f15e9cd910c4d9da7de43f2181f362082fc45f0f upstream.
This patch fixes a bug where se_cmd descriptors associated with a
Task Management Request (TMR) where not setting CMD_T_ACTIVE before
being dispatched into target_tmr_work() process context.
This is required in order for transport_generic_free_cmd() ->
transport_wait_for_tasks() to wait on se_cmd->t_transport_stop_comp
if a session reset event occurs while an ABORT_TASK is outstanding
waiting for another I/O to complete.
commit 1d2b60a5545942b1376cb48c1d55843d71e3a08f upstream.
This patch adds an explicit check in chap_server_compute_md5() to ensure
the CHAP_C value received from the initiator during mutual authentication
does not match the original CHAP_C provided by the target.
This is in line with RFC-3720, section 8.2.1:
Originators MUST NOT reuse the CHAP challenge sent by the Responder
for the other direction of a bidirectional authentication.
Responders MUST check for this condition and close the iSCSI TCP
connection if it occurs.
Reported-by: Tejas Vaykole <tejas.vaykole@calsoftinc.com>
commit 0ed6e189e3f6ac3a25383ed5cc8b0ac24c9b97b7 upstream.
This patch fixes a NULL pointer dereference regression bug that was
introduced with:
commit 1e1110c43b1cda9fe77fc4a04835e460550e6b3c
Author: Mikulas Patocka <mpatocka@redhat.com>
Date: Sat May 17 06:49:22 2014 -0400
target: fix memory leak on XCOPY
Now that target_put_sess_cmd() -> kref_put_spinlock_irqsave() is
called with a valid se_cmd->cmd_kref, a NULL pointer dereference
is triggered because the XCOPY passthrough commands don't have
an associated se_session pointer.
To address this bug, go ahead and checking for a NULL se_sess pointer
within target_put_sess_cmd(), and call se_cmd->se_tfo->release_cmd()
to release the XCOPY's xcopy_pt_cmd memory.
Reported-by: Thomas Glanzmann <thomas@glanzmann.de>
Cc: Mikulas Patocka <mpatocka@redhat.com>
commit e7810c2d2c37fa8e58dda74b00790dab60fe6fba upstream.
This patch allows READ_CAPACITY + SAI_READ_CAPACITY_16 opcode
processing to occur while the associated ALUA group is in Standby
access state.
This is required to avoid host side LUN probe failures during the
initial scan if an ALUA group has already implicitly changed into
Standby access state.
This addresses a bug reported by Chris + Philip using dm-multipath
+ ESX hosts configured with ALUA multipath.
(Drop v3.15 specific set_ascq usage - nab)
Reported-by: Chris Boot <crb@tiger-computing.co.uk>
Reported-by: Philip Gaw <pgaw@darktech.org.uk>
Cc: Chris Boot <crb@tiger-computing.co.uk>
Cc: Philip Gaw <pgaw@darktech.org.uk>
Cc: Hannes Reinecke <hare@suse.de>
commit 2363d196686e44c0158929e7cf96c8589a24a81b upstream.
This patch fixes a iser-target specific regression introduced in
v3.15-rc6 with:
commit 14f4b54fe38f3a8f8392a50b951c8aa43b63687a
Author: Sagi Grimberg <sagig@mellanox.com>
Date: Tue Apr 29 13:13:47 2014 +0300
Target/iscsi,iser: Avoid accepting transport connections during stop stage
where the change to set iscsi_np->enabled = false within
iscsit_clear_tpg_np_login_thread() meant that a iscsi_np with
two iscsi_tpg_np exports would have it's parent iscsi_np set
to a disabled state, even if other iscsi_tpg_np exports still
existed.
This patch changes iscsit_clear_tpg_np_login_thread() to only
set iscsi_np->enabled = false when shutdown = true, and also
changes iscsit_del_np() to set iscsi_np->enabled = true when
iscsi_np->np_exports is non zero.
Cc: Sagi Grimberg <sagig@dev.mellanox.co.il>
commit 14f4b54fe38f3a8f8392a50b951c8aa43b63687a upstream.
When the target is in stop stage, iSER transport initiates RDMA disconnects.
The iSER initiator may wish to establish a new connection over the
still existing network portal. In this case iSER transport should not
accept and resume new RDMA connections. In order to learn that, iscsi_np
is added with enabled flag so the iSER transport can check when deciding
weather to accept and resume a new connection request.
The iscsi_np is enabled after successful transport setup, and disabled
before iscsi_np login threads are cleaned up.
commit f1453773514bb8b0bba0716301e8c8f17f8d39c7 upstream.
This patch fixes a OOPs where an attempt to write to the per-device
alua_access_state configfs attribute at:
/sys/kernel/config/target/core/$HBA/$DEV/alua/$TG_PT_GP/alua_access_state
results in an NULL pointer dereference when the backend device has not
yet been configured.
This patch adds an explicit check for DF_CONFIGURED, and fails with
-ENODEV to avoid this case.
commit 79d59d08082dd0a0a18f8ceb78c99f9f321d72aa upstream.
In non-leading connection login, iscsi_login_non_zero_tsih_s1() calls
iscsi_change_param_value() with the buffer it uses to hold the login
PDU, not a temporary buffer. This leads to the login header getting
corrupted and login failing for non-leading connections in MC/S.
Fix this by adding a wrapper iscsi_change_param_sprintf() that handles
the temporary buffer itself to avoid confusion. Also handle sending a
reject in case of failure in the wrapper, which lets the calling code
get quite a bit smaller and easier to read.
Finally, bump the size of the temporary buffer from 32 to 64 bytes to be
safe, since "MaxRecvDataSegmentLength=" by itself is 25 bytes; with a
trailing NUL, a value >= 1M will lead to a buffer overrun. (This isn't
the default but we don't need to run right at the ragged edge here)
commit ed8ec8f707ed4760c124d47b27c93df8ec5b1eba upstream.
This patch fixes a free-after-use regression in ft_free_cmd(), where
ft_sess_put() is called with cmd->sess after percpu_ida_free() has
already released the tag.
Fix this bug by saving the ft_sess pointer ahead of percpu_ida_free(),
and pass it directly to ft_sess_put().
The regression was originally introduced in v3.13-rc1 commit:
commit 5f544cfac956971099e906f94568bc3fd1a7108a
Author: Nicholas Bellinger <nab@daterainc.com>
Date: Mon Sep 23 12:12:42 2013 -0700
tcm_fc: Convert to per-cpu command map pre-allocation of ft_cmd
Reported-by: Jun Wu <jwu@stormojo.com>
Cc: Mark Rustad <mark.d.rustad@intel.com>
Cc: Robert Love <robert.w.love@intel.com>
commit 1e1110c43b1cda9fe77fc4a04835e460550e6b3c upstream.
On each processed XCOPY command, two "kmalloc-512" memory objects are
leaked. These represent two allocations of struct xcopy_pt_cmd in
target_core_xcopy.c.
The reason for the memory leak is that the cmd_kref field is not
initialized (thus, it is zero because the allocations were done with
kzalloc). When we decrement zero kref in target_put_sess_cmd, the result
is not zero, thus target_release_cmd_kref is not called.
This patch fixes the bug by moving kref initialization from
target_get_sess_cmd to transport_init_se_cmd (this function is called from
target_core_xcopy.c, so it will correctly initialize cmd_kref). It can be
easily verified that all code that calls target_get_sess_cmd also calls
transport_init_se_cmd earlier, thus moving kref_init shouldn't introduce
any new problems.
commit 07b8dae38b09bcfede7e726f172e39b5ce8390d9 upstream.
Just like for pSCSI, if the transport sets get_write_cache, then it is
not valid to enable write cache emulation for it. Return an error.
see https://bugzilla.redhat.com/show_bug.cgi?id=1082675
Reviewed-by: Chris Leech <cleech@redhat.com>
Signed-off-by: Andy Grover <agrover@redhat.com>
commit 7cbfcc953789ff864c2bf8365a82a3fba4869649 upstream.
This patch changes an incorrect use of BUG_ON to instead generate a
REJECT + PROTOCOL_ERROR in iscsit_process_nop_out() code. This case
can occur with traditional TCP where a flood of zeros in the data
stream can reach this block for what is presumed to be a NOP-OUT with
a solicited reply, but without a valid iscsi_cmd pointer.
This incorrect BUG_ON was introduced during the v3.11-rc timeframe
with the following commit:
commit 778de368964c5b7e8100cde9f549992d521e9c89
Author: Nicholas Bellinger <nab@linux-iscsi.org>
Date: Fri Jun 14 16:07:47 2013 -0700
iscsi/isert-target: Refactor ISCSI_OP_NOOP RX handling
commit 448ba904160f9d8f69217c28a1692cee5afbff88 upstream.
Userspace tools assume if a value is read from configfs, it is valid
and will not cause an error if the same value is written back. The only
valid value for pi_prot_type for backends not supporting DIF is 0, so allow
this particular value to be set without returning an error.
Reported-by: Krzysztof Chojnowski <frirajder@gmail.com>
Reviewed-by: Sagi Grimberg <sagig@mellanox.com>
commit 2c42be2dd4f6586728dba5c4e197afd5cfaded78 upstream.
ft_del_tpg checks tpg->tport is set before unlinking the tpg from the
tport when the tpg is being removed. Set this pointer in ft_tport_create,
or the unlinking won't happen in ft_del_tpg and tport->tpg will reference
a deleted object.
This patch sets tpg->tport in ft_tport_create, because that's what
ft_del_tpg checks, and is the only way to get back to the tport to
clear tport->tpg.
The bug was occuring when:
- lport created, tport (our per-lport, per-provider context) is
allocated.
tport->tpg = NULL
- tpg created
- a PRLI is received. ft_tport_create is called, tpg is found and
tport->tpg is set
- tpg removed. ft_tpg is freed in ft_del_tpg. Since tpg->tport was not
set, tport->tpg is not cleared and points at freed memory
- Future calls to ft_tport_create return tport via first conditional,
instead of searching for new tpg by calling ft_lport_find_tpg.
tport->tpg is still invalid, and will access freed memory.
see https://bugzilla.redhat.com/show_bug.cgi?id=1071340
commit d84287bcfe624697cd4f3c1df746beb53b86d9c4 upstream.
This patch fixes a double free bug during IBLOCK backend shutdown
where bioset_integrity_free() was incorrectly called ahead of
bioset_free(), who is already making the same call directly.
This bug was introduced with commit ecebbf6cc, and will end up
triggering a general protection fault in iblock_free_device()
Cc: Martin K. Petersen <martin.petersen@oracle.com>
Cc: Or Gerlitz <ogerlitz@mellanox.com>
Cc: Quinn Tran <quinn.tran@qlogic.com>
Cc: Giridhar Malavali <giridhar.malavali@qlogic.com>
commit a1e1774c6dfa3a524dd8df51ca95185fe5ef3247 upstream.
When compiled with CONFIG_DEBUG_SG set, uninitialized SGL leads
to BUG() in compare_and_write_callback().
Signed-off-by: Martin Svec <martin.svec@zoner.cz>
commit 9d2e59f2a778328a41771fe9a0098dadbc4314ba upstream.
Ram disk is allocating 8x more space than required for diff data.
For large RAM disk test, there is small potential for memory
starvation.
(Use block_size when calculating total_sg_needed - sagi + nab)
Signed-off-by: Giridhar Malavali <giridhar.malavali@qlogic.com>
Signed-off-by: Quinn Tran <quinn.tran@qlogic.com>
commit d444edc679e7713412f243b792b1f964e5cff1e1 upstream.
This patch fixes a long-standing bug in iscsit_build_conn_drop_async_message()
where during ERL=2 connection recovery, a bogus conn_p pointer could
end up being used to send the ISCSI_OP_ASYNC_EVENT + DROPPING_CONNECTION
notifying the initiator that cmd->logout_cid has failed.
The bug was manifesting itself as an OOPs in iscsit_allocate_cmd() with
a bogus conn_p pointer in iscsit_build_conn_drop_async_message().
Reported-by: santosh kulkarni <santosh.kulkarni@calsoftinc.com>
When copying between device and command protection scatters
we must take into account that device scatters might be offset
and we might copy outside scatter range. Thus for each cmd prot
scatter we must take the min between cmd prot scatter, dev prot
scatter, and whats left (and loop in case we havn't copied enough
from/to cmd prot scatter).
Example (single t_prot_sg of len 2048):
kernel: sbc_dif_copy_prot: se_cmd=ffff880380aaf970, left=2048, len=2048, dev_prot_sg_offset=3072, dev_prot_sg_len=4096
kernel: isert: se_cmd=ffff880380aaf970 PI error found type 0 at sector 0x2600 expected 0x0 vs actual 0x725f, lba=2580
Instead of copying 2048 from offset 3072 (copying junk outside sg
limit 4096), we must to copy 1024 and continue to next sg until
we complete cmd prot scatter.
This issue was found using iSER T10-PI offload over rd_mcp (wasn't
discovered with fileio since file_dev prot sglists are never offset).
Changes from v1:
- Fix sbc_copy_prot copy length miss-calculation
Changes from v0:
- Removed psg->offset consideration for psg_len computation
- Removed sg->offset consideration for offset condition
- Added copied consideraiton for len computation
- Added copied offset to paddr when doing memcpy
This patch addresses a couple of different hug shutdown issues
related to wait_event() + isert_conn->state. First, it changes
isert_conn->conn_wait + isert_conn->conn_wait_comp_err from
waitqueues to completions, and sets ISER_CONN_TERMINATING from
within isert_disconnect_work().
Second, it splits isert_free_conn() into isert_wait_conn() that
is called earlier in iscsit_close_connection() to ensure that
all outstanding commands have completed before continuing.
Finally, it breaks isert_cq_comp_err() into seperate TX / RX
related code, and adds logic in isert_cq_rx_comp_err() to wait
for outstanding commands to complete before setting ISER_CONN_DOWN
and calling complete(&isert_conn->conn_wait_comp_err).
Acked-by: Sagi Grimberg <sagig@mellanox.com>
Cc: <stable@vger.kernel.org> #3.10+
There are a handful of uses of list_empty() for cmd->i_conn_node
within iser-target code that expect to return false once a cmd
has been removed from the per connect list.
This patch changes all uses of list_del -> list_del_init in order
to ensure that list_empty() returns false as expected.
This patch fixes a bug in iscsit_get_tpg_from_np() where the
tpg->tpg_state sanity check was looking for TPG_STATE_FREE,
instead of != TPG_STATE_ACTIVE.
The latter is expected during a normal TPG shutdown once the
tpg_state goes into TPG_STATE_INACTIVE in order to reject any
new incoming login attempts.
Because then this sg is passed to sbc_copy_prot which will
hit a protection fault in cases we have more than a single sg.
This patch adds the three missing DIF related sense codes within
transport_generic_request_failure(), which are required to ensure
that the correct ASC/ASQC is generated by the subsequent call to
transport_send_check_condition_and_sense().
Cc: Sagi Grimberg <sagig@mellanox.com>
This patch fixes a bug in sbc_dif_copy_prot() where the updated addr
offset did not take into account the case where the associated
scatterlist had not been incremented.
This addresses the case where incoming protection scatterlists may
contain a length smaller than PAGE_SIZE across multiple entires,
when the target protection scatterlists are always being explicitly
filled up to PAGE_SIZE before adding another entry.
Need to take into account that protection sg_list
(copy-buffer) may consist of multiple entries.
Changes from v0:
- Changed commit description
The CMD_T_FAILED flag is set used in one place to record the result of a
trivial test, and it is only tested once, few lines later. We might as
well make the code simpler and easier to read by directly doing the test
of "success" where we want to use it.
This patch fixes Status SNACK handling of BegRun=0 to allow
for all unacknowledged respones to be resent, instead of
always assuming that BegRun would be an explicit value less
than the current ExpStatSN.
Commit fbfe858fea2a ("target_core_spc: Include target device
descriptor in VPD page 83") added a new length variable, but (due to a
cut and paste mistake?) just checks scsi_name_len against 256 twice.
Fix this to check scsi_target_len for overflow too.
This patch changes core_alua_state_lba_dependent() to use do_div()
instead sector_div() to avoid the following link error on 32-bit
with CONFIG_LBDAF=n as reported by Jim:
buildlog-1391099072.txt-drivers/built-in.o: In function `target_alua_state_check':
buildlog-1391099072.txt-(.text+0x928d93): undefined reference to `__umoddi3'
buildlog-1391099072.txt:make: *** [vmlinux] Error 1 --
buildlog-1391101753.txt- CC init/version.o
buildlog-1391101753.txt- LD init/built-in.o
buildlog-1391101753.txt-drivers/built-in.o: In function `core_alua_state_lba_dependent':
buildlog-1391101753.txt-/home/jim/linux/drivers/target/target_core_alua.c:503: undefined reference to `__umoddi3'
buildlog-1391101753.txt:make: *** [vmlinux] Error 1
Reported-by: Jim Davis <jim.epost@gmail.com>
This patch addresses a >= v3.11 free-after-use regression
in core_scsi3_emulate_pro_register() that was introduced
in the following commit:
commit bc118fe4c4a8cfa453491ba77c0a146a6d0e73e0
Author: Andy Grover <agrover@redhat.com>
Date: Thu May 16 10:41:04 2013 -0700
target: Further refactoring of core_scsi3_emulate_pro_register()
To avoid the free-after-use, save an type value before hand, and
only call core_scsi3_put_pr_reg() with a valid *pr_reg.
Reported-by: Dan Carpenter <dan.carpenter@oracle.com>
Cc: Andy Grover <agrover@redhat.com>
Cc: <stable@vger.kernel.org> #3.11+
git://git.kernel.org/pub/scm/linux/kernel/git/nab/target-pending
Pull SCSI target updates from Nicholas Bellinger:
"The highlights this round include:
- add support for SCSI Referrals (Hannes)
- add support for T10 DIF into target core (nab + mkp)
- add support for T10 DIF emulation in FILEIO + RAMDISK backends (Sagi + nab)
- add support for T10 DIF -> bio_integrity passthrough in IBLOCK backend (nab)
- prep changes to iser-target for >= v3.15 T10 DIF support (Sagi)
- add support for qla2xxx N_Port ID Virtualization - NPIV (Saurav + Quinn)
- allow percpu_ida_alloc() to receive task state bitmask (Kent)
- fix >= v3.12 iscsi-target session reset hung task regression (nab)
- fix >= v3.13 percpu_ref se_lun->lun_ref_active race (nab)
- fix a long-standing network portal creation race (Andy)"
* 'for-next' of git://git.kernel.org/pub/scm/linux/kernel/git/nab/target-pending: (51 commits)
target: Fix percpu_ref_put race in transport_lun_remove_cmd
target/iscsi: Fix network portal creation race
target: Report bad sector in sense data for DIF errors
iscsi-target: Convert gfp_t parameter to task state bitmask
iscsi-target: Fix connection reset hang with percpu_ida_alloc
percpu_ida: Make percpu_ida_alloc + callers accept task state bitmask
iscsi-target: Pre-allocate more tags to avoid ack starvation
qla2xxx: Configure NPIV fc_vport via tcm_qla2xxx_npiv_make_lport
qla2xxx: Enhancements to enable NPIV support for QLOGIC ISPs with TCM/LIO.
qla2xxx: Fix scsi_host leak on qlt_lport_register callback failure
IB/isert: pass scatterlist instead of cmd to fast_reg_mr routine
IB/isert: Move fastreg descriptor creation to a function
IB/isert: Avoid frwr notation, user fastreg
IB/isert: seperate connection protection domains and dma MRs
tcm_loop: Enable DIF/DIX modes in SCSI host LLD
target/rd: Add DIF protection into rd_execute_rw
target/rd: Add support for protection SGL setup + release
target/rd: Refactor rd_build_device_space + rd_release_device_space
target/file: Add DIF protection support to fd_execute_rw
target/file: Add DIF protection init/format support
This patch fixes a percpu_ref_put race for se_lun->lun_ref in
transport_lun_remove_cmd() where ->lun_ref could end up being
put more than once per command via different target completion
and fabric release contexts.
It adds a cmpxchg() for se_cmd->lun_ref_active to ensure that
percpu_ref_put() is only ever called once per se_cmd.
This bug was manifesting itself as a LUN shutdown regression
bug in >= v3.13 code, where percpu_ref_kill() would end up
hanging indefinately due to the incorrect percpu_ref count.
(Change se_cmd->lun_ref_active from bool -> int to force at
least a 4-byte cmpxchg with MIPS ll/sc ins. - Fengguang)
Reported-by: Tommy Apel <tommyapeldk@gmail.com>
Cc: Tommy Apel <tommyapeldk@gmail.com>
Cc: <stable@vger.kernel.org> #3.13+
When creating network portals rapidly, such as when restoring a
configuration, LIO's code to reuse existing portals can return a false
negative if the thread hasn't run yet and set np_thread_state to
ISCSI_NP_THREAD_ACTIVE. This causes an error in the network stack
when attempting to bind to the same address/port.
This patch sets NP_THREAD_ACTIVE before the np is placed on g_np_list,
so even if the thread hasn't run yet, iscsit_get_np will return the
existing np.
Also, convert np_lock -> np_mutex + hold across adding new net portal
to g_np_list to prevent a race where two threads may attempt to create
the same network portal, resulting in one of them failing.
(nab: Add missing mutex_unlocks in iscsit_add_np failure paths)
(DanC: Fix incorrect spin_unlock -> spin_unlock_bh)
Cc: <stable@vger.kernel.org> #3.1+
SPC-4 states that data-integrity errors shall also report
the failed sector in CHECK_CONDITION response sense data
information field.
This patch propigates the use of task state bitmask now used by
percpu_ida_alloc() up the iscsi-target callchain, replacing the
use of GFP_ATOMIC for TASK_RUNNING, and GFP_KERNEL for
TASK_INTERRUPTIBLE.
Also, drop the unnecessary gfp_t parameter to isert_allocate_cmd(),
and just pass TASK_INTERRUPTIBLE into iscsit_allocate_cmd().
This patch addresses a bug where connection reset would hang
indefinately once percpu_ida_alloc() was starved for tags, due
to the fact that it always assumed uninterruptible sleep mode.
So now make percpu_ida_alloc() check for signal_pending_state() for
making interruptible sleep optional, and convert iscsit_allocate_cmd()
to set TASK_INTERRUPTIBLE for GFP_KERNEL, or TASK_RUNNING for
GFP_ATOMIC.
Reported-by: Linus Torvalds <torvalds@linux-foundation.org>
Cc: Kent Overstreet <kmo@daterainc.com>
Cc: <stable@vger.kernel.org> #3.12+
This patch changes percpu_ida_alloc() + callers to accept task state
bitmask for prepare_to_wait() for code like target/iscsi that needs
it for interruptible sleep, that is provided in a subsequent patch.
It now expects TASK_UNINTERRUPTIBLE when the caller is able to sleep
waiting for a new tag, or TASK_RUNNING when the caller cannot sleep,
and is forced to return a negative value when no tags are available.
v2 changes:
- Include blk-mq + tcm_fc + vhost/scsi + target/iscsi changes
- Drop signal_pending_state() call
v3 changes:
- Only call prepare_to_wait() + finish_wait() when != TASK_RUNNING
(PeterZ)
Signed-off-by: Kent Overstreet <kmo@daterainc.com>
