path: root/drivers/target
2016-09-19chcr/cxgb4i/cxgbit/RDMA/cxgb4: Allocate resources dynamically for all cxgb4 ↵Hariprasad Shenai
ULD's Allocate resources dynamically to cxgb4's Upper layer driver's(ULD) like cxgbit, iw_cxgb4 and cxgb4i. Allocate resources when they register with cxgb4 driver and free them while unregistering. All the queues and the interrupts for them will be allocated during ULD probe only and freed during remove. Signed-off-by: Hariprasad Shenai <hariprasad@chelsio.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2016-09-15libcxgb,iw_cxgb4,cxgbit: add cxgb_mk_rx_data_ack()Varun Prakash
Add cxgb_mk_rx_data_ack() to remove duplicate code to form CPL_RX_DATA_ACK hardware command. Signed-off-by: Varun Prakash <varun@chelsio.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2016-09-15libcxgb,iw_cxgb4,cxgbit: add cxgb_mk_abort_rpl()Varun Prakash
Add cxgb_mk_abort_rpl() to remove duplicate code to form CPL_ABORT_RPL hardware command. Signed-off-by: Varun Prakash <varun@chelsio.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2016-09-15libcxgb,iw_cxgb4,cxgbit: add cxgb_mk_abort_req()Varun Prakash
Add cxgb_mk_abort_req() to remove duplicate code to form CPL_ABORT_REQ hardware command. Signed-off-by: Varun Prakash <varun@chelsio.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2016-09-15libcxgb, iw_cxgb4, cxgbit: add cxgb_mk_close_con_req()Varun Prakash
Add cxgb_mk_close_con_req() to remove duplicate code to form CPL_CLOSE_CON_REQ hardware command. Signed-off-by: Varun Prakash <varun@chelsio.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2016-09-15libcxgb,iw_cxgb4,cxgbit: add cxgb_mk_tid_release()Varun Prakash
Add cxgb_mk_tid_release() to remove duplicate code to form CPL_TID_RELEASE hardware command. Signed-off-by: Varun Prakash <varun@chelsio.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2016-09-15libcxgb,iw_cxgb4,cxgbit: add cxgb_compute_wscale()Varun Prakash
Add cxgb_compute_wscale() in libcxgb_cm.h to remove it's duplicate definitions from cxgb4/cm.c and cxgbit/cxgbit_cm.c. Signed-off-by: Varun Prakash <varun@chelsio.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2016-09-15libcxgb,iw_cxgb4,cxgbit: add cxgb_best_mtu()Varun Prakash
Add cxgb_best_mtu() in libcxgb_cm.h to remove it's duplicate definitions from cxgb4/cm.c and cxgbit/cxgbit_cm.c Signed-off-by: Varun Prakash <varun@chelsio.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2016-09-15libcxgb,iw_cxgb4,cxgbit: add cxgb_is_neg_adv()Varun Prakash
Add cxgb_is_neg_adv() in libcxgb_cm.h to remove it's duplicate definitions from cxgb4/cm.c and cxgbit/cxgbit_cm.c. Signed-off-by: Varun Prakash <varun@chelsio.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2016-09-15libcxgb,iw_cxgb4,cxgbit: add cxgb_find_route6()Varun Prakash
Add cxgb_find_route6() in libcxgb_cm.c to remove it's duplicate definitions from cxgb4/cm.c and cxgbit/cxgbit_cm.c. Signed-off-by: Varun Prakash <varun@chelsio.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2016-09-15libcxgb,iw_cxgb4,cxgbit: add cxgb_find_route()Varun Prakash
Add cxgb_find_route() in libcxgb_cm.c to remove it's duplicate definitions from cxgb4/cm.c and cxgbit/cxgbit_cm.c. Signed-off-by: Varun Prakash <varun@chelsio.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2016-09-15libcxgb,iw_cxgb4,cxgbit: add cxgb_get_4tuple()Varun Prakash
Add cxgb_get_4tuple() in libcxgb_cm.c to remove it's duplicate definitions from cxgb4/cm.c and cxgbit/cxgbit_cm.c. Signed-off-by: Varun Prakash <varun@chelsio.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2016-08-07target: iblock_execute_sync_cache() should use bio_set_op_attrs()Jens Axboe
The original commit missed this function, it needs to mark it a write flush. Cc: Mike Christie <mchristi@redhat.com> Fixes: e742fc32fcb4 ("target: use bio op accessors") Signed-off-by: Jens Axboe <axboe@fb.com>
2016-08-04Merge branch 'for-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/nab/target-pending Pull SCSI target updates from Nicholas Bellinger: "The most notable item is IBM virtual SCSI target driver, that was originally ported to target-core back in 2010 by Tomo-san, and has been brought forward to v4.x code by Bryant Ly, Michael Cyr and co over the last months. Also included are two ORDERED task related bug-fixes Bryant + Michael found along the way using ibmvscsis with AIX guests, plus a few miscellaneous target-core + iscsi-target bug-fixes with associated stable tags" * 'for-next' of git://git.kernel.org/pub/scm/linux/kernel/git/nab/target-pending: target: fix spelling mistake: "limitiation" -> "limitation" target: Fix residual overflow handling in target_complete_cmd_with_length tcm_fc: set and unset FCP_SPPF_TARG_FCN iscsi-target: Fix panic when adding second TCP connection to iSCSI session ibmvscsis: Initial commit of IBM VSCSI Tgt Driver target: Fix ordered task CHECK_CONDITION early exception handling target: Fix ordered task target_setup_cmd_from_cdb exception hang target: Fix max_unmap_lba_count calc overflow target: Fix race between iscsi-target connection shutdown + ABORT_TASK target: Fix missing complete during ABORT_TASK + CMD_T_FABRIC_STOP
2016-07-27Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-nextLinus Torvalds
Pull networking updates from David Miller: 1) Unified UDP encapsulation offload methods for drivers, from Alexander Duyck. 2) Make DSA binding more sane, from Andrew Lunn. 3) Support QCA9888 chips in ath10k, from Anilkumar Kolli. 4) Several workqueue usage cleanups, from Bhaktipriya Shridhar. 5) Add XDP (eXpress Data Path), essentially running BPF programs on RX packets as soon as the device sees them, with the option to mirror the packet on TX via the same interface. From Brenden Blanco and others. 6) Allow qdisc/class stats dumps to run lockless, from Eric Dumazet. 7) Add VLAN support to b53 and bcm_sf2, from Florian Fainelli. 8) Simplify netlink conntrack entry layout, from Florian Westphal. 9) Add ipv4 forwarding support to mlxsw spectrum driver, from Ido Schimmel, Yotam Gigi, and Jiri Pirko. 10) Add SKB array infrastructure and convert tun and macvtap over to it. From Michael S Tsirkin and Jason Wang. 11) Support qdisc packet injection in pktgen, from John Fastabend. 12) Add neighbour monitoring framework to TIPC, from Jon Paul Maloy. 13) Add NV congestion control support to TCP, from Lawrence Brakmo. 14) Add GSO support to SCTP, from Marcelo Ricardo Leitner. 15) Allow GRO and RPS to function on macsec devices, from Paolo Abeni. 16) Support MPLS over IPV4, from Simon Horman. * git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next: (1622 commits) xgene: Fix build warning with ACPI disabled. be2net: perform temperature query in adapter regardless of its interface state l2tp: Correctly return -EBADF from pppol2tp_getname. net/mlx5_core/health: Remove deprecated create_singlethread_workqueue net: ipmr/ip6mr: update lastuse on entry change macsec: ensure rx_sa is set when validation is disabled tipc: dump monitor attributes tipc: add a function to get the bearer name tipc: get monitor threshold for the cluster tipc: make cluster size threshold for monitoring configurable tipc: introduce constants for tipc address validation net: neigh: disallow transition to NUD_STALE if lladdr is unchanged in neigh_update() MAINTAINERS: xgene: Add driver and documentation path Documentation: dtb: xgene: Add MDIO node dtb: xgene: Add MDIO node drivers: net: xgene: ethtool: Use phy_ethtool_gset and sset drivers: net: xgene: Use exported functions drivers: net: xgene: Enable MDIO driver drivers: net: xgene: Add backward compatibility drivers: net: phy: xgene: Add MDIO driver ...
2016-07-25libcxgb: export ppm release and tagmask set apiVarun Prakash
Export cxgbi_ppm_release() to release ppod manager and cxgbi_tagmask_set() to set tag mask, they are used by cxgb3i, cxgb4i and cxgbit. Signed-off-by: Varun Prakash <varun@chelsio.com> Reviewed-by: Steve Wise <swise@opengridcomputing.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2016-07-25libcxgb: add library module for Chelsio driversVarun Prakash
Add common library module(libcxgb.ko) for Chelsio drivers to remove duplicate code. Code for iSCSI DDP Page Pod Manager is moved from cxgb4.ko to libcxgb.ko. Earlier only cxgbit.ko was using this code, now cxgb3i and cxgb4i will also use common Page Pod manager code. In future this module will have common connection management and hardware specific code that can be shared by multiple Chelsio drivers. Signed-off-by: Varun Prakash <varun@chelsio.com> Reviewed-by: Steve Wise <swise@opengridcomputing.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2016-07-23target: fix spelling mistake: "limitiation" -> "limitation"Colin Ian King
trivial fix to spelling mistake Signed-off-by: Colin Ian King <colin.king@canonical.com> Signed-off-by: Nicholas Bellinger <nab@linux-iscsi.org>
2016-07-23target: Fix residual overflow handling in target_complete_cmd_with_lengthSumit Rai
This patch fixes residual overflow handling to correctly set the residual_count using SPDTL, instead of SCSI Allocation Length. Allocation Length is the maximum value of the SPDTL and not substitute for it, hence it shouldn’t be used to calculate ResidualCount except for cases where SPDTL > Allocation Length and Data is truncated (in that case both Alloc Len and SPDTL are same). (SPC 5r01 Section 4.2.5.6). Thanks to Ajay Nair in assisting with this patch. Signed-off-by: Sumit Rai <sumitrai96@gmail.com> Signed-off-by: Nicholas Bellinger <nab@linux-iscsi.org>
2016-07-20target: stop using blk_make_requestChristoph Hellwig
Using blk_rq_append_bio allows to append the bios to the request directly instead of having to build up a list first, and also allows to have a single code path for requests with or without data attached to them. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Jens Axboe <axboe@fb.com>
2016-07-20tcm_fc: set and unset FCP_SPPF_TARG_FCNHannes Reinecke
When registering and unregistering as an target port we should be setting the FC-4 service params correctly. Signed-off-by: Hannes Reinecke <hare@suse.com> Signed-off-by: Nicholas Bellinger <nab@linux-iscsi.org>
2016-07-20iscsi-target: Fix panic when adding second TCP connection to iSCSI sessionFeng Li
In MC/S scenario, the conn->sess has been set NULL in iscsi_login_non_zero_tsih_s1 when the second connection comes here, then kernel panic. The conn->sess will be assigned in iscsi_login_non_zero_tsih_s2. So we should check whether it's NULL before calling. Signed-off-by: Feng Li <lifeng1519@gmail.com> Tested-by: Sumit Rai <sumit.rai@calsoftinc.com> Cc: stable@vger.kernel.org # 3.14+ Signed-off-by: Nicholas Bellinger <nab@linux-iscsi.org>
2016-07-20target: Fix ordered task CHECK_CONDITION early exception handlingNicholas Bellinger
If a Simple command is sent with a failure, target_setup_cmd_from_cdb returns with TCM_UNSUPPORTED_SCSI_OPCODE or TCM_INVALID_CDB_FIELD. So in the cases where target_setup_cmd_from_cdb returns an error, we never get far enough to call target_execute_cmd to increment simple_cmds. Since simple_cmds isn't incremented, the result of the failure from target_setup_cmd_from_cdb causes transport_generic_request_failure to decrement simple_cmds, due to call to transport_complete_task_attr. With this dev->simple_cmds or dev->dev_ordered_sync is now -1, not 0. So when a subsequent command with an Ordered Task is sent, it causes a hang, since dev->simple_cmds is at -1. Tested-by: Bryant G. Ly <bryantly@linux.vnet.ibm.com> Signed-off-by: Bryant G. Ly <bryantly@linux.vnet.ibm.com> Tested-by: Michael Cyr <mikecyr@linux.vnet.ibm.com> Signed-off-by: Michael Cyr <mikecyr@linux.vnet.ibm.com> Cc: stable@vger.kernel.org # 4.4+ Signed-off-by: Nicholas Bellinger <nab@linux-iscsi.org>
2016-07-20target: Fix ordered task target_setup_cmd_from_cdb exception hangNicholas Bellinger
If a command with a Simple task attribute is failed due to a Unit Attention, then a subsequent command with an Ordered task attribute will hang forever. The reason for this is that the Unit Attention status is checked for in target_setup_cmd_from_cdb, before the call to target_execute_cmd, which calls target_handle_task_attr, which in turn increments dev->simple_cmds. However, transport_generic_request_failure still calls transport_complete_task_attr, which will decrement dev->simple_cmds. In this case, simple_cmds is now -1. So when a command with the Ordered task attribute is sent, target_handle_task_attr sees that dev->simple_cmds is not 0, so it decides it can't execute the command until all the (nonexistent) Simple commands have completed. Reported-by: Michael Cyr <mikecyr@linux.vnet.ibm.com> Tested-by: Michael Cyr <mikecyr@linux.vnet.ibm.com> Reported-by: Bryant G. Ly <bryantly@linux.vnet.ibm.com> Tested-by: Bryant G. Ly <bryantly@linux.vnet.ibm.com> Cc: stable@vger.kernel.org # 4.4+ Signed-off-by: Nicholas Bellinger <nab@linux-iscsi.org>
2016-07-20target: Fix max_unmap_lba_count calc overflowMike Christie
max_discard_sectors only 32bits, and some non scsi backend devices will set this to the max 0xffffffff, so we can end up overflowing during the max_unmap_lba_count calculation. This fixes a regression caused by my patch: commit 8a9ebe717a133ba7bc90b06047f43cc6b8bcb8b3 Author: Mike Christie <mchristi@redhat.com> Date: Mon Jan 18 14:09:27 2016 -0600 target: Fix WRITE_SAME/DISCARD conversion to linux 512b sectors which can result in extra discards being sent to due the overflow causing max_unmap_lba_count to be smaller than what the backing device can actually support. Signed-off-by: Mike Christie <mchristi@redhat.com> Reviewed-by: Bart Van Assche <bart.vanassche@sandisk.com> Cc: stable@vger.kernel.org Signed-off-by: Nicholas Bellinger <nab@linux-iscsi.org>
2016-07-20target: Fix race between iscsi-target connection shutdown + ABORT_TASKNicholas Bellinger
This patch fixes a race in iscsit_release_commands_from_conn() -> iscsit_free_cmd() -> transport_generic_free_cmd() + wait_for_tasks=1, where CMD_T_FABRIC_STOP could end up being set after the final kref_put() is called from core_tmr_abort_task() context. This results in transport_generic_free_cmd() blocking indefinately on se_cmd->cmd_wait_comp, because the target_release_cmd_kref() check for CMD_T_FABRIC_STOP returns false. To address this bug, make iscsit_release_commands_from_conn() do list_splice and set CMD_T_FABRIC_STOP early while holding iscsi_conn->cmd_lock. Also make iscsit_aborted_task() only remove iscsi_cmd_t if CMD_T_FABRIC_STOP has not already been set. Finally in target_release_cmd_kref(), only honor fabric_stop if CMD_T_ABORTED has been set. Cc: Mike Christie <mchristi@redhat.com> Cc: Quinn Tran <quinn.tran@qlogic.com> Cc: Himanshu Madhani <himanshu.madhani@qlogic.com> Cc: Christoph Hellwig <hch@lst.de> Cc: Hannes Reinecke <hare@suse.de> Cc: stable@vger.kernel.org # 3.14+ Tested-by: Nicholas Bellinger <nab@linux-iscsi.org> Signed-off-by: Nicholas Bellinger <nab@linux-iscsi.org>
2016-07-20target: Fix missing complete during ABORT_TASK + CMD_T_FABRIC_STOPNicholas Bellinger
During transport_generic_free_cmd() with a concurrent TMR ABORT_TASK and shutdown CMD_T_FABRIC_STOP bit set, the caller will be blocked on se_cmd->cmd_wait_stop completion until the final kref_put() -> target_release_cmd_kref() has been invoked to call complete(). However, when ABORT_TASK is completed with FUNCTION_COMPLETE in core_tmr_abort_task(), the aborted se_cmd will have already been removed from se_sess->sess_cmd_list via list_del_init(). This results in target_release_cmd_kref() hitting the legacy list_empty() == true check, invoking ->release_cmd() but skipping complete() to wakeup se_cmd->cmd_wait_stop blocked earlier in transport_generic_free_cmd() code. To address this bug, it's safe to go ahead and drop the original list_empty() check so that fabric_stop invokes the complete() as expected, since list_del_init() can safely be used on a empty list. Cc: Mike Christie <mchristi@redhat.com> Cc: Quinn Tran <quinn.tran@qlogic.com> Cc: Himanshu Madhani <himanshu.madhani@qlogic.com> Cc: Christoph Hellwig <hch@lst.de> Cc: Hannes Reinecke <hare@suse.de> Cc: stable@vger.kernel.org # 3.14+ Tested-by: Nicholas Bellinger <nab@linux-iscsi.org> Signed-off-by: Nicholas Bellinger <nab@linux-iscsi.org>
2016-06-07target: use bio op accessorsMike Christie
Separate the op from the rq_flag_bits and have the target layer set/get the bio using bio_set_op_attrs/bio_op. Signed-off-by: Mike Christie <mchristi@redhat.com> Reviewed-by: Hannes Reinecke <hare@suse.com> Signed-off-by: Jens Axboe <axboe@fb.com>
2016-06-07block/fs/drivers: remove rw argument from submit_bioMike Christie
This has callers of submit_bio/submit_bio_wait set the bio->bi_rw instead of passing it in. This makes that use the same as generic_make_request and how we set the other bio fields. Signed-off-by: Mike Christie <mchristi@redhat.com> Fixed up fs/ext4/crypto.c Signed-off-by: Jens Axboe <axboe@fb.com>
2016-05-28Merge branch 'for-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/nab/target-pending Pull SCSI target updates from Nicholas Bellinger: "Here are the outstanding target pending updates for v4.7-rc1. The highlights this round include: - Allow external PR/ALUA metadata path be defined at runtime via top level configfs attribute (Lee) - Fix target session shutdown bug for ib_srpt multi-channel (hch) - Make TFO close_session() and shutdown_session() optional (hch) - Drop se_sess->sess_kref + convert tcm_qla2xxx to internal kref (hch) - Add tcm_qla2xxx endpoint attribute for basic FC jammer (Laurence) - Refactor iscsi-target RX/TX PDU encode/decode into common code (Varun) - Extend iscsit_transport with xmit_pdu, release_cmd, get_rx_pdu, validate_parameters, and get_r2t_ttt for generic ISO offload (Varun) - Initial merge of cxgb iscsi-segment offload target driver (Varun) The bulk of the changes are Chelsio's new driver, along with a number of iscsi-target common code improvements made by Varun + Co along the way" * 'for-next' of git://git.kernel.org/pub/scm/linux/kernel/git/nab/target-pending: (29 commits) iscsi-target: Fix early sk_data_ready LOGIN_FLAGS_READY race cxgbit: Use type ISCSI_CXGBIT + cxgbit tpg_np attribute iscsi-target: Convert transport drivers to signal rdma_shutdown iscsi-target: Make iscsi_tpg_np driver show/store use generic code tcm_qla2xxx Add SCSI command jammer/discard capability iscsi-target: graceful disconnect on invalid mapping to iovec target: need_to_release is always false, remove redundant check and kfree target: remove sess_kref and ->shutdown_session iscsi-target: remove usage of ->shutdown_session tcm_qla2xxx: introduce a private sess_kref target: make close_session optional target: make ->shutdown_session optional target: remove acl_stop target: consolidate and fix session shutdown cxgbit: add files for cxgbit.ko iscsi-target: export symbols iscsi-target: call complete on conn_logout_comp iscsi-target: clear tx_thread_active iscsi-target: add new offload transport type iscsi-target: use conn_transport->transport_type in text rsp ...
2016-05-20Merge tag 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/dledford/rdma Pull rdma updates from Doug Ledford: "Primary 4.7 merge window changes - Updates to the new Intel X722 iWARP driver - Updates to the hfi1 driver - Fixes for the iw_cxgb4 driver - Misc core fixes - Generic RDMA READ/WRITE API addition - SRP updates - Misc ipoib updates - Minor mlx5 updates" * tag 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/dledford/rdma: (148 commits) IB/mlx5: Fire the CQ completion handler from tasklet net/mlx5_core: Use tasklet for user-space CQ completion events IB/core: Do not require CAP_NET_ADMIN for packet sniffing IB/mlx4: Fix unaligned access in send_reply_to_slave IB/mlx5: Report Scatter FCS device capability when supported IB/mlx5: Add Scatter FCS support for Raw Packet QP IB/core: Add Scatter FCS create flag IB/core: Add Raw Scatter FCS device capability IB/core: Add extended device capability flags i40iw: pass hw_stats by reference rather than by value i40iw: Remove unnecessary synchronize_irq() before free_irq() i40iw: constify i40iw_vf_cqp_ops structure IB/mlx5: Add UARs write-combining and non-cached mapping IB/mlx5: Allow mapping the free running counter on PROT_EXEC IB/mlx4: Use list_for_each_entry_safe IB/SA: Use correct free function IB/core: Fix a potential array overrun in CMA and SA agent IB/core: Remove unnecessary check in ibnl_rcv_msg IB/IWPM: Fix a potential skb leak RDMA/nes: replace custom print_hex_dump() ...
2016-05-17Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial Pull trivial tree updates from Jiri Kosina. * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (21 commits) gitignore: fix wording mfd: ab8500-debugfs: fix "between" in printk memstick: trivial fix of spelling mistake on management cpupowerutils: bench: fix "average" treewide: Fix typos in printk IB/mlx4: printk fix pinctrl: sirf/atlas7: fix printk spelling serial: mctrl_gpio: Grammar s/lines GPIOs/line GPIOs/, /sets/set/ w1: comment spelling s/minmum/minimum/ Blackfin: comment spelling s/divsor/divisor/ metag: Fix misspellings in comments. ia64: Fix misspellings in comments. hexagon: Fix misspellings in comments. tools/perf: Fix misspellings in comments. cris: Fix misspellings in comments. c6x: Fix misspellings in comments. blackfin: Fix misspelling of 'register' in comment. avr32: Fix misspelling of 'definitions' in comment. treewide: Fix typos in printk Doc: treewide : Fix typos in DocBook/filesystem.xml ...
2016-05-17Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-nextLinus Torvalds
Pull networking updates from David Miller: "Highlights: 1) Support SPI based w5100 devices, from Akinobu Mita. 2) Partial Segmentation Offload, from Alexander Duyck. 3) Add GMAC4 support to stmmac driver, from Alexandre TORGUE. 4) Allow cls_flower stats offload, from Amir Vadai. 5) Implement bpf blinding, from Daniel Borkmann. 6) Optimize _ASYNC_ bit twiddling on sockets, unless the socket is actually using FASYNC these atomics are superfluous. From Eric Dumazet. 7) Run TCP more preemptibly, also from Eric Dumazet. 8) Support LED blinking, EEPROM dumps, and rxvlan offloading in mlx5e driver, from Gal Pressman. 9) Allow creating ppp devices via rtnetlink, from Guillaume Nault. 10) Improve BPF usage documentation, from Jesper Dangaard Brouer. 11) Support tunneling offloads in qed, from Manish Chopra. 12) aRFS offloading in mlx5e, from Maor Gottlieb. 13) Add RFS and RPS support to SCTP protocol, from Marcelo Ricardo Leitner. 14) Add MSG_EOR support to TCP, this allows controlling packet coalescing on application record boundaries for more accurate socket timestamp sampling. From Martin KaFai Lau. 15) Fix alignment of 64-bit netlink attributes across the board, from Nicolas Dichtel. 16) Per-vlan stats in bridging, from Nikolay Aleksandrov. 17) Several conversions of drivers to ethtool ksettings, from Philippe Reynes. 18) Checksum neutral ILA in ipv6, from Tom Herbert. 19) Factorize all of the various marvell dsa drivers into one, from Vivien Didelot 20) Add VF support to qed driver, from Yuval Mintz" * git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next: (1649 commits) Revert "phy dp83867: Fix compilation with CONFIG_OF_MDIO=m" Revert "phy dp83867: Make rgmii parameters optional" r8169: default to 64-bit DMA on recent PCIe chips phy dp83867: Make rgmii parameters optional phy dp83867: Fix compilation with CONFIG_OF_MDIO=m bpf: arm64: remove callee-save registers use for tmp registers asix: Fix offset calculation in asix_rx_fixup() causing slow transmissions switchdev: pass pointer to fib_info instead of copy net_sched: close another race condition in tcf_mirred_release() tipc: fix nametable publication field in nl compat drivers: net: Don't print unpopulated net_device name qed: add support for dcbx. ravb: Add missing free_irq() calls to ravb_close() qed: Remove a stray tab net: ethernet: fec-mpc52xx: use phy_ethtool_{get|set}_link_ksettings net: ethernet: fec-mpc52xx: use phydev from struct net_device bpf, doc: fix typo on bpf_asm descriptions stmmac: hardware TX COE doesn't work when force_thresh_dma_mode is set net: ethernet: fs-enet: use phy_ethtool_{get|set}_link_ksettings net: ethernet: fs-enet: use phydev from struct net_device ...
2016-05-17iscsi-target: Fix early sk_data_ready LOGIN_FLAGS_READY raceNicholas Bellinger
There is a iscsi-target/tcp login race in LOGIN_FLAGS_READY state assignment that can result in frequent errors during iscsi discovery: "iSCSI Login negotiation failed." To address this bug, move the initial LOGIN_FLAGS_READY assignment ahead of iscsi_target_do_login() when handling the initial iscsi_target_start_negotiation() request PDU during connection login. As iscsi_target_do_login_rx() work_struct callback is clearing LOGIN_FLAGS_READ_ACTIVE after subsequent calls to iscsi_target_do_login(), the early sk_data_ready ahead of the first iscsi_target_do_login() expects LOGIN_FLAGS_READY to also be set for the initial login request PDU. As reported by Maged, this was first obsered using an MSFT initiator running across multiple VMWare host virtual machines with iscsi-target/tcp. Reported-by: Maged Mokhtar <mmokhtar@binarykinetics.com> Tested-by: Maged Mokhtar <mmokhtar@binarykinetics.com> Signed-off-by: Nicholas Bellinger <nab@linux-iscsi.org>
2016-05-16cxgbit: Use type ISCSI_CXGBIT + cxgbit tpg_np attributeNicholas Bellinger
Instead of having cxgbit use type ISCSI_HW_OFFLOAD + 'hw_offload' tpg_np attribute, it should be using it's own driver specific type + attribute Cc: Varun Prakash <varun@chelsio.com> Cc: Hariprasad Shenai <hariprasad@chelsio.com> Cc: Christoph Hellwig <hch@lst.de> Cc: Sagi Grimberg <sagi@grimberg.me> Signed-off-by: Nicholas Bellinger <nab@linux-iscsi.org>
2016-05-16iscsi-target: Convert transport drivers to signal rdma_shutdownNicholas Bellinger
Instead of special casing the handful of callers that check for iser-target rdma verbs specific shutdown, use a simple flag at iscsit_transport->rdma_shutdown so each driver can signal this. Also, update iscsi-target/tcp + cxgbit to rdma_shutdown = false. Cc: Varun Prakash <varun@chelsio.com> Cc: Hariprasad Shenai <hariprasad@chelsio.com> Cc: Christoph Hellwig <hch@lst.de> Cc: Sagi Grimberg <sagi@grimberg.me> Signed-off-by: Nicholas Bellinger <nab@linux-iscsi.org>
2016-05-16iscsi-target: Make iscsi_tpg_np driver show/store use generic codeNicholas Bellinger
Go ahead and fold the duplicate iscsi_tpg_np driver attribute show/store functions into generic callers, invoked by current driver specific functions. This allows for future v4.8+ changes to have iscsi_target_mod use tpg_np driver attributes at runtime, instead of having the defaults hardcoded in iscsi_target_configfs.c. Also, drop the unused/legacy 'sctp' attribute for non standard RFC-3720 operation with IPPROTO_SCTP. Cc: Varun Prakash <varun@chelsio.com> Cc: Hariprasad Shenai <hariprasad@chelsio.com> Cc: Christoph Hellwig <hch@lst.de> Cc: Sagi Grimberg <sagi@grimberg.me> Signed-off-by: Nicholas Bellinger <nab@linux-iscsi.org>
2016-05-13target: enhance and export target_alloc_sgl/target_free_sglChristoph Hellwig
The SRP target driver will need to allocate and chain it's own SGLs soon. For this export target_alloc_sgl, and add a new argument to it so that it can allocate an additional chain entry that doesn't point to a page. Also export transport_free_sgl after renaming it to target_free_sgl to free these SGLs again. Signed-off-by: Christoph Hellwig <hch@lst.de> Reviewed-by: Bart Van Assche <bart.vanassche@sandisk.com> Signed-off-by: Doug Ledford <dledford@redhat.com>
2016-05-10iscsi-target: graceful disconnect on invalid mapping to iovecImran Haider
Ensures the first page entry is within bounds. A failed check would terminate the iSCSI connection instead of causing a NULL-dereference. This violation seems to happen with certain iSCSI commands where the computed CDB length is zero but the expected transfer length is non-zero. The real problem is probably on the iSCSI initiator side since there is a discrepancy between the iSCSI header and the encapsulated CDB Opcode. Signed-off-by: Imran Haider <imran1008@gmail.com> Signed-off-by: Nicholas Bellinger <nab@linux-iscsi.org>
2016-05-10target: need_to_release is always false, remove redundant check and kfreeColin Ian King
The removal the #ifdef'd code on CONFIG_ARCH_HAS_SG_CHAIN in commit 02c4de53add1b79 ("target/rd: always chain S/G list") removed the setting of need_to_release to true, so we are now left with need_to_release always being false and hence the conditional kfree is never reached. Clean up the dead code by removing need_to_release and the conditional kfree. Signed-off-by: Colin Ian King <colin.king@canonical.com> Reviewed-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Nicholas Bellinger <nab@linux-iscsi.org>
2016-05-10target: remove sess_kref and ->shutdown_sessionChristoph Hellwig
Both of them are unused now that drivers handle any delayed session shutdown internally. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Nicholas Bellinger <nab@linux-iscsi.org>
2016-05-10iscsi-target: remove usage of ->shutdown_sessionChristoph Hellwig
->shutdown session only decideѕ if the target core calls ->close_session directly, or if the fabrics drivers calls it manually later through target_put_session, which at this point will always close the session as it has been removed from the lookup list and thus no new references will be acquired from the core. So instead remove ->shutdown and have the core call ->close_session directly, and replace all calls to target_put_session in the iSCSI target with direct calls to iscsit_close_session. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Nicholas Bellinger <nab@linux-iscsi.org>
2016-05-10target: make close_session optionalChristoph Hellwig
2016-05-10target: make ->shutdown_session optionalChristoph Hellwig
Turns out the template and thus many drivers got the return value wrong: 0 means the fabrics driver needs to put a session reference, which no driver except for the iSCSI target drivers did. Fortunately none of these drivers supports explicit Node ACLs, so the bug was harmless. Even without that only qla2xxx and iscsi every did real work in shutdown_session, so get rid of the boilerplate code in all other drivers. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Nicholas Bellinger <nab@linux-iscsi.org>
2016-05-10target: remove acl_stopChristoph Hellwig
Ensure we can use list_empty on the sess_acl_list to remove the need for this flag. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Nicholas Bellinger <nab@linux-iscsi.org>
2016-05-10target: consolidate and fix session shutdownChristoph Hellwig
Factor out a helper to shutdown sessions for a Node ACL, and make it properly restart the list walk after dropping the lock. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Nicholas Bellinger <nab@linux-iscsi.org>
2016-05-09cxgbit: add files for cxgbit.koVarun Prakash
cxgbit.h - This file contains data structure definitions for cxgbit.ko. cxgbit_lro.h - This file contains data structure definitions for LRO support. cxgbit_main.c - This file contains code for registering with iscsi target transport and cxgb4 driver. cxgbit_cm.c - This file contains code for connection management. cxgbit_target.c - This file contains code for processing iSCSI PDU. cxgbit_ddp.c - This file contains code for Direct Data Placement. (added check for NULL sg in cxgbit_set_one_ppod) Reported-by: Dan Carpenter <dan.carpenter@oracle.com> (add Kconfig and Makefile v2: added dependency on INET) Reported-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Varun Prakash <varun@chelsio.com> Signed-off-by: Nicholas Bellinger <nab@linux-iscsi.org>
2016-05-09iscsi-target: export symbolsVarun Prakash
export symbols for ISCSI_HW_OFFLOAD transport drivers. Signed-off-by: Varun Prakash <varun@chelsio.com> Signed-off-by: Nicholas Bellinger <nab@linux-iscsi.org>
2016-05-09iscsi-target: call complete on conn_logout_compVarun Prakash
ISCSI_HW_OFFLOAD transport drivers waits on conn_logout_comp as ISCSI_TCP driver so call complete if transport type is ISCSI_HW_OFFLOAD. Signed-off-by: Varun Prakash <varun@chelsio.com> Signed-off-by: Nicholas Bellinger <nab@linux-iscsi.org>
2016-05-09iscsi-target: clear tx_thread_activeVarun Prakash
clear tx_thread_active for ISCSI_HW_OFFLOAD transport in logout_post_handler functions. Signed-off-by: Varun Prakash <varun@chelsio.com> Signed-off-by: Nicholas Bellinger <nab@linux-iscsi.org>
