CONFIG_HOTPLUG is going away as an option so __devexit is no
longer needed.
Signed-off-by: Bill Pemberton <wfp5p@virginia.edu>
CONFIG_HOTPLUG is going away as an option so __devinit is no longer
needed.
CONFIG_HOTPLUG is going away as an option so __devexit_p is no longer
needed.
Remaining vb_table.h data can be trivially made const.
Signed-off-by: Aaro Koskinen <aaro.koskinen@iki.fi>
Make Tap4 data const and adjust functions accordingly.
Access XGI340_AGPReg directly and make it const.
Inline constant values that are used only once.
Access XGI340_CR6B directly and make it const.
In-line constants that are used only once.
Delete unused data.
Access XGI330_ModeResInfo directly and make it const.
Access XGI330_ScreenOffset directly and make it const.
Access XGI_VCLKData and XGI_VBVCLKData directly and make them const.
Access XGI340_ECLKData directly and make it const.
Eliminate dummy zero read-only global data.
Access XGI_UpdateCRT1Table directly and make it const.
Access XGI_CRT1Table directly and make it const.
Access XGI330_RefIndex directly and make it const.
Access XGI330_EModeIDTable directly and make it const.
Access XGI330_StandTable directly and make it const.
Use private data instead of global variables for timing data. Also,
get rid of the single element arrays.
Refactor XGI_GetLVDSData() to avoid nesting and redundant ifs.
XGI21_LCDCapList does not exist.
Make read-only LCD data tables const.
Let the caller pass the table pointer directly instead of using a magic
number to indicate which table to use.
tempal is a write-only stack variable, and code touching it can be
deleted.
Use real pointers for LCD data tables to simplify the code.
Replace xgifb_epllcd_crt1 with two different tables to make further
cleanups easier.
Add a separate data table for VB_SIS301LV/VB_SIS302LV to avoid branching
and to make further cleanups easier.
The driver reconfigures DRAM size register to 8M (regardless what the
actual size was) once the init has been completed, overwriting the
correct value written during the early init. As a result if the driver
is unloaded and reloaded, the user will be limited to 8M video memory
and may lose some of the available video modes.
On embedded systems without a BIOS, the DRAM sizing register is 0 after
the boot, and the driver thinks we have only 1 MB video memory. On such
cases, use the PCI window size for the initial size. This information
is needed only to create the I/O mapping - the driver will later detect
and configure the memory size correctly. Limit the size to 16 MB as it
should be sufficient for all supported video modes.
Add a sanity check for the video RAM size. It should fit into the
PCI window.
It's possible to select video mode that exceeds the available video
memory. This is potentially dangerous, fix by adding a check.
The patch fixes system hangs seen occasionally when playing random videos
with mplayer.
Delete some redundant casts.
Use correct type to eliminate casting.
Delete unneeded flag.
Mark some data tables as const.
Access some data tables directly instead of using pointers.
Use "else if" when possible to reduce nesting.
Delete an unused structure.
LCDLenList is redundant. It's only used for modifying a write-only stack
variable. Delete also related #defines.
Only table values 0..5 are ever used.
Delete unused Chrontel 7017 LCD data.
Replace DATAPTR numbers with a real pointer to make code simpler.
There's a dangerous cast from XGI330_TVDataStruct to SiS_TVData. Use
SiS_TVData everywhere, also the data can be made const.
Delete unused Chrontel TV data.
Only one TV data table is used by the driver, delete unneeded complexity.
Share the common data tables instead of having the same data in multiple
tables.
All chip type values are covered by (chip >= XG20 || chip >= XG40).
