This is a patch to the prism2fw.c file that fixes up a brace
warning found by the checkpatch.pl tool.
Signed-off-by: Joseph Salisbury <salisbury.joseph@gmail.com>
This patch was generated by the following semantic patch:
// <smpl>
@@ expression E; @@
- if (E != NULL) { kfree(E); }
+ kfree(E);
@@ expression E; @@
- if (E != NULL) { kfree(E); E = NULL; }
+ kfree(E);
+ E = NULL;
// </smpl>
Signed-off-by: Ilia Mirkin <imirkin@alum.mit.edu>
This patch removes the only typedef in p80211hdr.h.
Signed-off-by: Edgardo Hames <ehames@gmail.com>
This patch fix errors and warnings reported by checkpatch
in p80211meta.h and p80211metstruct.h.
Removed multiple typedef and fixed long lines.
Use kcalloc or kzalloc rather than the combination of kmalloc and memset.
The semantic patch that makes this change is as follows:
(http://coccinelle.lip6.fr/)
// <smpl>
expression x,y,flags;
statement S;
type T;
x =
- kmalloc
+ kcalloc
- y * sizeof(T),
+ y, sizeof(T),
flags);
if (x == NULL) S
-memset(x, 0, y * sizeof(T));
expression x,size,flags;
statement S;
-x = kmalloc(size,flags);
+x = kzalloc(size,flags);
if (x == NULL) S
-memset(x, 0, size);
// </smpl>
Fixed non static functions in prism2fw.c
Signed-off-by: Zachary Richey <zr.public@gmail.com>
file.
files.
necessary.
* ia64 SMP allmodconfig
* s390 SMP allmodconfig
* alpha SMP allmodconfig
the specific arch.
Turns out that multiple people sent pretty much the same patch
for the same staging drivers. Commit these in two different
branches and merge them together to get a more complete coverage
of the cleanup and properly credit everyone for the work that they
did.
Basic fixups in the staging/wlan-ng directory.
(First kernel patch - thanks to FOSDEM talk)
Signed-off-by: Andrew Elwell <Andrew.Elwell@gmail.com>
Fix prism2fw.c printk format warning:
drivers/staging/wlan-ng/prism2fw.c:209: warning: format '%d' expects type 'int', but argument 3 has type 'size_t'
Cleanups as suggested by checkpatch.pl utiltiy.
.o's from before and after cleanup have matching SHA1s.
Signed-off-by: Svenne Krap <svenne@krap.dk>
Memset should be given the size of the structure, not the size of the pointer.
// <smpl>
type T;
T *x;
expression E;
memset(x, E, sizeof(
x))
// </smpl>
Convert prism2_usb firmware loading to load firmware in pre-compiled
binary 'ihex' format rather than ascii 'srec' format. This moves the
srec processing and sorting of records out of kernel space into a
pre-compiler. The driver now just works with the binary image, but
still does the 'pda plugging' of that image at runtime, as required
by the prism hardware.
Some Notes:
- The firmware is now expected to be in the same 'ihex' (.fw) format
used by other drivers.
- The now driver assumes the data records are already sorted into ascending
address order.
- Plug and crc records are still recognised by special address locations
as in original srec processing.
- The srec S7 start address record is assumed to have been converted
into a data record with another special address location (0xff400000),
with the original start address being stored as a 4 byte data word
(little endian).
Signed-off-by: Karl Relton <karllinuxtest.relton@ntlworld.com>
scripts/checkpatch.pl error fixes. This is a TODO item.
This patch fixes most of the errors reported by checkpatch.pl in
wlan-ng directory of staging tree.
Signed-off-by: Mithlesh Thukral <mithlesh@linsyssoft.com>
Lindent script cleanups in wlan-ng driver in the staging tree.
This is a item in the TODO list.
Move prism2 firmware loading from userspace into driver, using linux
request_firmware(). Firmware is now loaded (if available) on device
probing, before it is registered as a netdevice and advertised to userspace.
