Signed-off-by: Charles Clément <caratorn@gmail.com>
Replace all occurrences with unsigned char type.
Replace all occurrences with unsigned short type.
Use unsigned short * instead.
Use unsigned char * instead.
Remove empty OUT definition used to specify output parameters.
Remove empty IN definition used to specify input parameters.
Remove cplusplus lines from include files
Remove needless ifdefs on includes to conform with C
conventions. Remove misc commented code/includes
Update TODO
Signed-off-by: Jim Lieb <lieb@canonical.com>
Text only changes to remove textual differences between the vt6655
and vt6656 trees in prep for driver merge.
Add pristine upstream vt6655 driver sources to drivers/staging/vt6655. These
files were literally copied from the driver directory in the upstream source
archive, available here:
http://www.viaarena.com/Driver/vt6655_linux_src_v1.19.12_x86.zip
Signed-off-by: Forest Bond <forest@alittletooquiet.net>
