Signed-off-by: Malcolm Priestley <tvboxspy@gmail.com>
This patchs fixes tons of warnings such as:
WARNING: braces {} are not necessary for single statement blocks
#354: FILE: drivers/staging/vt6655/wmgr.c:354:
+ for (ii = 0; ii < WLAN_BSSID_LEN; ii++) {
+ pMgmt->abyDesireBSSID[ii] = 0xFF;
Please note: this patch only fixes bracing issues (and there is still a
lot to do); so if you run checkpatch it _will_ throw a lot of errors.
Use --test-only=braces
Signed-off-by: Guido Martínez <guido@vanguardiasur.com.ar>
Remove dead code in many places on this driver.
This patch fixes the Sparse Warning "symbol was
not declared. Should it be static?" in tkip.c
Signed-off-by: Ebru Akagunduz <ebru.akagunduz@gmail.com>
Reviewed-by: Rusty Russell <rusty@rustcorp.com.au>
Remove a bunch of useless vertical whitespace.
Convert 3 or more consecutive newlines to 2.
Remove blank lines after open brace and before close brace.
Returns aren't functions, remove the parentheses to be
more kernel style like.
Neatening only.
git diff -w shows no differences.
Replace all occurrences with unsigned char type.
Signed-off-by: Charles Clément <caratorn@gmail.com>
Replace all occurrences with unsigned short type.
Replace all occurrences with unsigned long type, except for pointer fields that
should be u32 in packed structures and 8-byte-aligned 8 byte long structure
QWORD.
Thanks to Jiri Slaby for pointing out that simply replacing by unsigned long is
wrong on x86-64 arch.
Use unsigned char * instead.
Remove use of tbit macros adn remove header file.
Signed-off-by: Jim Lieb <lieb@canonical.com>
Remove references to umem.h macros and refer directly to memcpy
functions. Delete the include file.
Remove cplusplus lines from include files
Remove needless ifdefs on includes to conform with C
conventions. Remove misc commented code/includes
Update TODO
Add pristine upstream vt6655 driver sources to drivers/staging/vt6655. These
files were literally copied from the driver directory in the upstream source
archive, available here:
http://www.viaarena.com/Driver/vt6655_linux_src_v1.19.12_x86.zip
Signed-off-by: Forest Bond <forest@alittletooquiet.net>
