as reported by: kbuild test robot <fengguang.wu@intel.com>:
[linuxtv-media:master 459/499] sdr-msi3101.c:undefined reference to `__umoddi3'
Reported-by: kbuild test robot <fengguang.wu@intel.com>
Signed-off-by: Mauro Carvalho Chehab <m.chehab@samsung.com>
* Fix AM_MODE. Now it could work at least in theory, cannot test.
* Use greatest common divisor algo to divide PLL fractional parts.
* Fix IF frequency mode.
* + some very minor "style" issues
Signed-off-by: Antti Palosaari <crope@iki.fi>
After feeding different signal levels using RF generator and looking
GNU Radio FFT sink I made decision to change bit shift 3 to bit shift
2 as there was very (too) huge visible leap in FFT sink GUI. Now it
looks more natural.
That stream format carries 504 x I+Q samples per 1024 USB frame.
Sample resolution is 8-bit signed. Default it when sampling rate
is 9Msps or over.
Add comments, remove useless code and so. House cleaning party.
I made some tuner freq limit tests against RF signal generator.
Adjust some PLL limits according to these test results.
Here are the results, taken from two different devices.
Ranges are measured RF limits + calculated VCO limits.
Mirics MSi3101 SDR Dongle:
VHF_MODE 52 - 132 1664 - 4224
B3_MODE 103 - 263 1648 - 4208
B45_MODE 413 - 960 1652 - 3840
Hauppauge WinTV 133559 LF:
VHF_MODE 49 - 130 1568 - 4160
B3_MODE 98 - 259 1568 - 4144
B45_MODE 391 - 960 1564 - 3840
That one seem to have 12-bit resolution. Use it for streams that
has sampling rate 6 <= rate (Msps) < 8, between 6 and 8Msps.
Higher frequencies were not possible to set correctly as that value
overflows.
It is not sure what is meaning of that number, but it is better
to try do as Windows driver. It seems to have small effect for
signal when looking FM FFT.
That one seems to have 14-bit ADC resolution, wow!
It is now used when sampling rate is below 6 Msps.
Allow stepless synthesizer configuration. With that change we lose
precision a little bit, as it is now between +-500Hz from the target.
It could be better but on that case calculation algorithm goes more
complex and atm there is more important things to do.
Two approach to improve which comes to my mind are:
1) select and use biggest suitable step
2) use greatest common divisor algo to find divisor for thresh & frac
when possible to avoid rounding errors, which is root of cause of
current +-500Hz inaccuracy.
No need to compare numbers, we could just store that fractional
value MSB directly.
Dump all unknown 'garbage' data - maybe we will discover someday if there
is something rational...
Also fix comment in USB frame description.
It is based Mirics MSi3101 reference design and will just work
without any changes.
Restarting stream fails quite often. Small delay is between urb killing
and stream stop command - likely to give harware some time to process
killed urbs.
It looks like there is some extra data carried to enhance sampling
results. When you tune to some some weak/empty channel those bits
are always zeroes. When you tune to some channel where is very
strong signals those bits are all zeroes.
Examining those 32-bits reveals shortly there is 16 pieces of 2-bit
numbers. Number seen are 0, 1 and 3 - for some reason 2 is not used.
I used that number to shift bits given amount to left, "increasing"
sampling resolution by 3-bits. It may be wrong, but after some testing
it still provides better signal.
Whilst Quadrature Sampling is most common sampling technique used in
radio technology there is others too. Add control user could select
sampling mode. We currently support only quadrature sampling.
These calculations seem to give 100% correct results. Calculation
formulas could be still a little bit wrong as I have no knowledge
what kind of dividers, multipliers and VCO limits there really is.
Just fix wrong term name. No functional changes.
It is first Kernel software defined radio receiver driver.
That device is sold as a digital television solution.
MSi3101 is reference design which consists of two chips:
1) MSi2500 USB ADC
2) MSi001 RF-tuner
Driver is put to staging as API is not ready.
We have reorganized the error handling into a simpler and more canonical
format.
Additionally we removed extra empty lines, switched to devm_kzalloc(), and
substitute 'minor' by 'ret' in the igorplugusb_remote_probe() function.
Acked-by: Dan Carpenter <dan.carpenter@oracle.com>
git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-media
Pull media updates from Mauro Carvalho Chehab:
"This series contain:
- new i2c video drivers: ml86v7667 (video decoder),
ths8200 (video encoder)
- a new video driver for EasyCap cards based on Fushicai USBTV007
- Improved support for OF and embedded systems, with V4L2 async
initialization and a better support for clocks
- API cleanups on the ioctls used by the v4l2 debug tool
- Lots of cleanups
- As usual, several driver improvements and new cards additions
- Revert two changesets that change the minimal symbol rate for
stv0399, as request by Manu
- Update MAINTAINERS and other files to point to my new e-mail"
* 'v4l_for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-media: (378 commits)
MAINTAINERS & ABI: Update to point to my new email
[media] stb0899: restore minimal rate to 5Mbauds
[media] exynos4-is: Correct colorspace handling at FIMC-LITE
[media] exynos4-is: Set valid initial format on FIMC.n subdevs
[media] exynos4-is: Set valid initial format on FIMC-IS-ISP subdev pads
[media] exynos4-is: Fix format propagation on FIMC-IS-ISP subdev
[media] exynos4-is: Set valid initial format at FIMC-LITE
[media] exynos4-is: Fix format propagation on FIMC-LITE.n subdevs
[media] MAINTAINERS: Update S5P/Exynos FIMC driver entry
[media] Documentation: Update driver's directory in video4linux/fimc.txt
[media] exynos4-is: Change fimc-is firmware file names
[media] exynos4-is: Add support for Exynos5250 MIPI-CSIS
[media] exynos4-is: Add Exynos5250 SoC support to fimc-lite driver
[media] exynos4-is: Drop drvdata handling in fimc-lite for non-dt platforms
[media] media: i2c: tvp514x: remove manual setting of subdev name
[media] media: i2c: tvp7002: remove manual setting of subdev name
[media] mem2mem: set missing v4l2_dev pointer
[media] wl128x: add missing struct v4l2_device
[media] tvp514x: Fix init seqeunce
[media] saa7134: Fix sparse warnings by adding __user annotation
git://git.kernel.org/pub/scm/linux/kernel/git/geert/linux-m68k
Pull "exotic" arch fixes from Geert Uytterhoeven:
"This is a collection of several exotic architecture fixes, and a few
other fixes for issues that were detected while doing the former"
* 'exotic-arch-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/geert/linux-m68k: (35 commits)
lib: Move fonts from drivers/video/console/ to lib/fonts/
console/font: Refactor font support code selection logic
Revert "staging/solo6x10: depend on CONFIG_FONTS"
input: cros_ec_keyb_clear_keyboard() depends on CONFIG_PM_SLEEP
score: Wire up asm-generic/xor.h
score: Remove unneeded <asm/dma-mapping.h>
openrisc: Wire up asm-generic/xor.h
h8300/boot: Use POSIX "$((..))" instead of bashism "$[...]"
h8300: Mark H83002 and H83048 CPU support broken
h8300: Switch h8300 to drivers/Kconfig
h8300: Limit timer channel ranges in Kconfig
h8300: Wire up asm-generic/xor.h
h8300: Fill the system call table using a CALL() macro
h8300: Fix <asm/tlb.h>
h8300: Hardcode symbol prefixes in asm sources
h8300: add missing definition for read_barries_depends()
frv: head.S - Remove commented-out initialization code
cris: Wire up asm-generic/vga.h
parport: disable PC-style parallel port support on cris
console: Disable VGA text console support on cris
We want the firmware merge fixes, and other bits, in here now.
The current Makefile rules to build font support are messy and buggy.
Replace them by Kconfig rules:
- Introduce CONFIG_FONT_SUPPORT, which controls the building of all font
code,
- Select CONFIG_FONT_SUPPORT for all drivers that use fonts,
- Select CONFIG_FONT_8x16 for all drivers that default to the VGA8x16
font,
- Drop the bogus console dependency for CONFIG_VIDEO_VIVI,
- Always process drivers/video/console/Makefile, as some drivers need
fonts even if CONFIG_VT is not set.
This fixes (if CONFIG_SOLO6X10=y and there are no built-in console
drivers):
drivers/built-in.o: In function `solo_osd_print':
drivers/staging/media/solo6x10/solo6x10-enc.c:144: undefined reference to `.find_font'
This fixes (if CONFIG_VT=n):
drivers/built-in.o: In function `vivi_init':
vivi.c:(.init.text+0x1a3da): undefined reference to `find_font'
Acked-by: Hans Verkuil <hans.verkuil@cisco.com> [original part]
Acked-by: Randy Dunlap <rdunlap@infradead.org> [drivers/video/Makefile]
This reverts commit 8c090cfbf980581454ae4caae731574fedd7dce8.
CONFIG_FONTS is not about enabling font support, but about enabling
manual selection of built-in fonts.
probe() should not return 0 for unsupported devices, but go7007_usb_probe() does.
The patch fixes it to return -ENODEV.
Found by Linux Driver Verification project (linuxtesting.org).
Signed-off-by: Alexey Khoroshilov <khoroshilov@ispras.ru>
Signed-off-by: Hans Verkuil <hans.verkuil@cisco.com>
* linus: (1465 commits)
ARM: tegra30: clocks: Fix pciex clock registration
lseek(fd, n, SEEK_END) does *not* go to eof - n
Linux 3.10-rc6
smp.h: Use local_irq_{save,restore}() in !SMP version of on_each_cpu().
powerpc: Fix missing/delayed calls to irq_work
powerpc: Fix emulation of illegal instructions on PowerNV platform
powerpc: Fix stack overflow crash in resume_kernel when ftracing
snd_pcm_link(): fix a leak...
use can_lookup() instead of direct checks of ->i_op->lookup
move exit_task_namespaces() outside of exit_notify()
fput: task_work_add() can fail if the caller has passed exit_task_work()
xfs: don't shutdown log recovery on validation errors
xfs: ensure btree root split sets blkno correctly
xfs: fix implicit padding in directory and attr CRC formats
xfs: don't emit v5 superblock warnings on write
mei: me: clear interrupts on the resume path
mei: nfc: fix nfc device freeing
mei: init: Flush scheduled work before resetting the device
sctp: fully initialize sctp_outq in sctp_outq_init
netiucv: Hold rtnl between name allocation and device registration.
media_entity_cleanup() frees the links array which will be accessed by
media_entity_remove_links() called by v4l2_device_unregister_subdev().
Signed-off-by: Sakari Ailus <sakari.ailus@iki.fi>
Reviewed-by: Sylwester Nawrocki <s.nawrocki@samsung.com>
Acked-by: Lad, Prabhakar <prabhakar.csengg@gmail.com>
Acked-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com>
Signed-off-by: Sylwester Nawrocki <s.nawrocki@samsung.com>
Pull media fixes from Mauro Carvalho Chehab:
"Series of fixes for 3.10. There are some usual driver fixes (mostly
on s5p/exynos playform drivers), plus some fixes at V4L2 core"
* 'v4l_for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-media: (40 commits)
[media] soc_camera: error dev remove and v4l2 call
[media] sh_veu: fix the buffer size calculation
[media] sh_veu: keep power supply until the m2m context is released
[media] sh_veu: invoke v4l2_m2m_job_finish() even if a job has been aborted
[media] v4l2-ioctl: don't print the clips list
[media] v4l2-ctrls: V4L2_CTRL_CLASS_FM_RX controls are also valid radio controls
[media] cx88: fix NULL pointer dereference
[media] DocBook/media/v4l: update version number
[media] exynos4-is: Remove "sysreg" clock handling
[media] exynos4-is: Fix reported colorspace at FIMC-IS-ISP subdev
[media] exynos4-is: Ensure fimc-is clocks are not enabled until properly configured
[media] exynos4-is: Prevent NULL pointer dereference when firmware isn't loaded
[media] s5p-mfc: Add NULL check for allocated buffer
[media] s5p-mfc: added missing end-of-lines in debug messages
[media] s5p-mfc: v4l2 controls setup routine moved to initialization code
[media] s5p-mfc: separate encoder parameters for h264 and mpeg4
[media] s5p-mfc: Remove special clock usage in driver
[media] s5p-mfc: Remove unused s5p_mfc_get_decoded_status_v6() function
[media] v4l2: mem2mem: save irq flags correctly
[media] coda: v4l2-compliance fix: add VIDIOC_CREATE_BUFS support
Error handling of usb_submit_urb() is not as all others in imon_probe().
It just unlocks mutexes and returns nonzero leaving all already
allocated resources unfreed.
The patch makes sure all the resources are deallocated.
This cleans up the saa712x setup code and there are no functional changes.
Signed-off-by: Ismael Luceno <ismael.luceno@corp.bluecherry.net>
[hans.verkuil@cisco.com: add clarification that this is cleanup only]
Since this driver provides a g_std op the current_norm field isn't used
anyway, so just drop it.
Function media_entity_remote_source actually returns the remote pad to
the given one, regardless if this is the source or the sink pad.
Name media_entity_remote_pad is more adequate for this function.
Signed-off-by: Andrzej Hajda <a.hajda@samsung.com>
Acked-by: Sakari Ailus <sakari.ailus@iki.fi>
Acked-by: Sylwester Nawrocki <s.nawrocki@samsung.com>
Signed-off-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com>
Ever since commit 45f035ab9b8f ("CONFIG_HOTPLUG should be always on"),
it has been basically impossible to build a kernel with CONFIG_HOTPLUG
turned off. Remove all the remaining references to it.
Cc: Doug Thompson <dougthompson@xmission.com>
Cc: Bjorn Helgaas <bhelgaas@google.com>
Cc: Steven Whitehouse <swhiteho@redhat.com>
Cc: Pavel Machek <pavel@ucw.cz>
Cc: "Rafael J. Wysocki" <rjw@sisk.pl>
Acked-by: Mauro Carvalho Chehab <mchehab@redhat.com>
Make sure FONT_8x16 can be found by find_font().
Signed-off-by: Xiong Zhou <jencce.kernel@gmail.com>
from commit 3778d05036cc7ddd983ae2451da579af00acdac2
[media: davinci: kconfig: fix incorrect selects]
VIDEO_VPFE_CAPTURE was removed but there was a negative
dependancy for building the DM365 VPFE MC based capture driver
(VIDEO_DM365_VPFE), This patch fixes this dependency by replacing
the VIDEO_VPFE_CAPTURE with VIDEO_DM365_ISIF, so as when older DM365
ISIF v4l driver is selected the newer media controller driver for
DM365 isnt visible.
Reported-by: Paul Bolle <pebolle@tiscali.nl>
Signed-off-by: Lad, Prabhakar <prabhakar.csengg@gmail.com>
Instead of falling back to 1/25 (PAL) or 1/30 (NTSC).
Fix to return a negative error code from the error handling
case instead of 0, as done elsewhere in this function.
Signed-off-by: Wei Yongjun <yongjun_wei@trendmicro.com.cn>
The new SOLO6X10 driver needs the built-in console fonts, specifically
the VGA8x16 font and building it without console support results in
a link error error.
:(.text+0x7d3424): undefined reference to `find_font'
This adds a dependency on the CONFIG_FONTS symbol and changes the
console code to always build the base driver even if there are
no specific fonts built-in.
Cc: Hans Verkuil <hans.verkuil@cisco.com>
Cc: Mauro Carvalho Chehab <mchehab@infradead.org>
git://git.kernel.org/pub/scm/linux/kernel/git/wsa/linux
Pull i2c changes from Wolfram Sang:
- an arbitration driver. While the driver is quite simple, it caused
discussion if we need additional arbitration on top of the one
specified in the I2C standard. Conclusion is that I accept a few
generic mechanisms, but not very specific ones.
- the core lost the detach_adapter() call. It has no users anymore and
was in the way for other cleanups. attach_adapter() is sadly still
there since there are users waiting to be converted.
- the core gained a bus recovery infrastructure. I2C defines a way to
recover if the data line is stalled. This mechanism is now in the
core and drivers can now pass some data to make use of it.
- bigger driver cleanups for designware, s3c2410
- removing superfluous refcounting from drivers
- removing Ben Dooks as second maintainer due to inactivity. Thanks
for all your work so far, Ben!
- bugfixes, feature additions, devicetree fixups, simplifications...
* 'i2c/for-next' of git://git.kernel.org/pub/scm/linux/kernel/git/wsa/linux: (38 commits)
i2c: xiic: must always write 16-bit words to TX_FIFO
i2c: octeon: use HZ in timeout value
i2c: octeon: Fix i2c fail problem when a process is terminated by a signal
i2c: designware-pci: drop superfluous {get|put}_device
i2c: designware-plat: drop superfluous {get|put}_device
i2c: davinci: drop superfluous {get|put}_device
MAINTAINERS: Ben Dooks is inactive regarding I2C
i2c: mux: Add i2c-arb-gpio-challenge 'mux' driver
i2c: at91: convert to dma_request_slave_channel_compat()
i2c: mxs: do error checking and handling in PIO mode
i2c: mxs: remove races in PIO code
i2c-designware: switch to use runtime PM autosuspend
i2c-designware: use usleep_range() in the busy-loop
i2c-designware: enable/disable the controller properly
i2c-designware: use dynamic adapter numbering on Lynxpoint
i2c-designware-pci: use managed functions pcim_* and devm_*
i2c-designware-pci: use dev_err() instead of printk()
i2c-designware: move to managed functions (devm_*)
i2c: remove CONFIG_HOTPLUG ifdefs
i2c: s3c2410: Add SMBus emulation for block read
The 6010 produces MPEG-4 part 2, while 6110 produces H.264.
Because they're signed, "is_video" and "is_audio" can be 0 and -1
instead of 0 and 1 as intended. It doesn't cause a bug, but it makes
Sparse complain:
drivers/staging/media/go7007/go7007-priv.h:94:31: error: dubious one-bit signed bitfield
drivers/staging/media/go7007/go7007-priv.h:95:31: error: dubious one-bit signed bitfield
VIDEO_GO7007 uses usb interfaces so it should depend on USB.
It also selects CYPRESS_FIRMWARE, which depends on USB.
Fixes build errors and a kconfig warning:
go7007-loader.c:(.text+0xcc7d0): undefined reference to `usb_get_dev'
go7007-loader.c:(.init.text+0x49f0): undefined reference to `usb_register_driver'
go7007-loader.c:(.exit.text+0x17ce): undefined reference to `usb_deregister'
warning: (DVB_USB_AZ6007 && VIDEO_GO7007) selects CYPRESS_FIRMWARE which has unmet direct dependencies (MEDIA_SUPPORT && USB)
Use the monotonic clock and set the timestamp_type that vb2 expects.
A mutex_unlock was missing in the 'success' path of the open() call,
and also at one error path in the same function.
i2c_del_adapter() always returns 0. So all checks testing whether it will be
non zero will always evaluate to false and the conditional code is dead code.
This patch updates all callers of i2c_del_mux_adapter() to ignore the return
value and assume that it will always succeed (which it will). In a subsequent
patch the return type of i2c_del_adapter() will be made void.
Acked-by: Ben Hutchings <bhutchings@solarflare.com>
Reviewed-by: Jean Delvare <khali@linux-fr.org>
Acked-by: Shawn Guo <shawn.guo@linaro.org>
Signed-off-by: Wolfram Sang <wsa@the-dreams.de>
Loading the cypress firmware is not dvb specific and should be common
functionality. Move the source to media/common and make it a standalone
module.
As a result we can remove the dependency on dvb-usb in go7007, which has
nothing to do with dvb.
On powerpc the maximum size for the ioctl argument is 8191, and it was
8192. However, the 64x64 array of threshold values is more than is actually
needed in practice for PAL and NTSC formats. A 45x45 array will do just fine.
So change the size accordingly to fix this problem.
