path: root/drivers/staging/generic_serial
2011-07-06Staging: delete generic_serial driversGreg Kroah-Hartman
No one has steped up to claim them, so as described in commit 4c37705877e74c02c968735c2eee0f84914cf557 (tty: move obsolete and broken generic_serial drivers to drivers/staging/generic_serial/), they are now deleted from the system. Cc: Arnd Bergmann <arnd@arndb.de> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Cc: Jiri Slaby <jslaby@suse.cz> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-05-26Merge branch 'trivial' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild-2.6 * 'trivial' of git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild-2.6: gfs2: Drop __TIME__ usage isdn/diva: Drop __TIME__ usage atm: Drop __TIME__ usage dlm: Drop __TIME__ usage wan/pc300: Drop __TIME__ usage parport: Drop __TIME__ usage hdlcdrv: Drop __TIME__ usage baycom: Drop __TIME__ usage pmcraid: Drop __DATE__ usage edac: Drop __DATE__ usage rio: Drop __DATE__ usage scsi/wd33c93: Drop __TIME__ usage scsi/in2000: Drop __TIME__ usage aacraid: Drop __TIME__ usage media/cx231xx: Drop __TIME__ usage media/radio-maxiradio: Drop __TIME__ usage nozomi: Drop __TIME__ usage cyclades: Drop __TIME__ usage
2011-04-19rio: Drop __DATE__ usageMichal Marek
The kernel already prints its build timestamp during boot, no need to repeat it in random drivers and produce different object files each time. As the buildDate field is part of the userspace API, I replaced it with the date of the last code change. Acked-by: Greg Kroah-Hartman <gregkh@suse.de> Signed-off-by: Michal Marek <mmarek@suse.cz>
2011-02-28Staging: generic_serial: fix double locking bugDan Carpenter
spin_lock_irqsave() is not nestable. The second time that it gets called it overwrites the "flags" variable and so IRQs can't be restored properly. Signed-off-by: Dan Carpenter <error27@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-02-22tty: move obsolete and broken generic_serial drivers to ↵Greg Kroah-Hartman
drivers/staging/generic_serial/ As planned by Arnd Bergmann, this moves the following drivers to the drivers/staging/generic_serial directory where they will be removed after 2.6.41 if no one steps up to claim them. generic_serial rio ser_a2232 sx vme_scc Cc: Arnd Bergmann <arnd@arndb.de> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Cc: Jiri Slaby <jslaby@suse.cz> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
