commit fc1e2c8ea85e109acf09e74789e9b852f6eed251 upstream.
Commit 367e8560e8d7a62d96e9b1d644028a3816e04206 introduced a bug
in fbtft-core where fps is always 0, this is because variable
update_time is not assigned correctly.
Signed-off-by: Ksenija Stanojevic <ksenija.stanojevic@gmail.com>
Fixes: 367e8560e8d7 ("Staging: fbtbt: Replace timespec with ktime_t")
git://git.kernel.org/pub/scm/linux/kernel/git/broonie/spi
Pull spi updates from Mark Brown:
"Quite a lot of activity in SPI this cycle, almost all of it in drivers
with a few minor improvements and tweaks in the core.
- Updates to pxa2xx to support Intel Broxton and multiple chip selects.
- Support for big endian in the bcm63xx driver.
- Multiple slave support for the mt8173
- New driver for the auxiliary SPI controller in bcm2835 SoCs.
- Support for Layerscale SoCs in the Freescale DSPI driver"
* tag 'spi-v4.4' of git://git.kernel.org/pub/scm/linux/kernel/git/broonie/spi: (87 commits)
spi: pxa2xx: Rework self-initiated platform data creation for non-ACPI
spi: pxa2xx: Add support for Intel Broxton
spi: pxa2xx: Detect number of enabled Intel LPSS SPI chip select signals
spi: pxa2xx: Add output control for multiple Intel LPSS chip selects
spi: pxa2xx: Use LPSS prefix for defines that are Intel LPSS specific
spi: Add DSPI support for layerscape family
spi: ti-qspi: improve ->remove() callback
spi/spi-xilinx: Fix race condition on last word read
spi: Drop owner assignment from spi_drivers
spi: Add THIS_MODULE to spi_driver in SPI core
spi: Setup the master controller driver before setting the chipselect
spi: dw: replace magic constant by DW_SPI_DR
spi: mediatek: mt8173 spi multiple devices support
spi: mediatek: handle controller_data in mtk_spi_setup
spi: mediatek: remove mtk_spi_config
spi: mediatek: Update document devicetree bindings to support multiple devices
spi: fix kernel-doc warnings about missing return desc in spi.c
spi: fix kernel-doc warnings about missing return desc in spi.h
spi: pxa2xx: Align a few defines
spi: pxa2xx: Save other reg_cs_ctrl bits when configuring chip select
'spi/topic/omap-uwire', 'spi/topic/owner', 'spi/topic/pxa' and 'spi/topic/pxa2xx' into spi-next
An spi_driver does not need to set an owner, it will be populated by the
driver core.
Signed-off-by: Andrew F. Davis <afd@ti.com>
Acked-by: Jonathan Cameron <jic23@kernel.org>
Signed-off-by: Mark Brown <broonie@kernel.org>
This patch fixes some internal voltage settings for the C-Berry28 display.
The original example source files for the C-Berry28 as provided by
its vendor admatec contained six issues where a command parameter's value
didn't match its corresponding comment.
I've informed admatec about these discrepancies on 2015-08-25. In the
meantime, I've assumed the comments to be more reliable than the code,
and thus have used these values to write the initial C-Berry28 driver.
After having received a reply from admatec on 2015-10-16 that the issues
have been fixed in their example code, it has turned out that for the
voltages VCOM and AVDD, the code was indeed correct, but the comments
were wrong. This patch is meant to fix these two pending mistakes.
Signed-off-by: Dennis Menschel <menschel-d@posteo.de>
This patch converts the default init sequence of the ST7789V
display controller into an init function, as init sequences
are considered deprecated by the maintainers of fbtft.
This patch removes the function set_addr_win() from fb_st7789v.c, as its
definition is redundant to the default implementation fbtft_set_addr_win()
which can be found in fbtft-core.c.
This patch makes use of the standard MIPI Display Command Set to remove
redundant entries from the command enum of the ST7789V display controller
and also some of the magic constants found in the init sequence of the
C-Berry28 display.
Compiler can typecast variables implicitly so, explicit type cast is not
required and should be removed.
Semantic patch used:
type T;
T e;
identifier x;
* T x = (T)e;
Signed-off-by: Shivani Bhardwaj <shivanib134@gmail.com>
Remove explicit type conversion as it is not required.
type T;
T e;
identifier x;
* T x = (T)e;
Remove explicit typecast from variables as compiler can typecast
implicitly.
type T;
T e;
identifier x;
* T x = (T)e;
Thus use the preferred style for multi-line coments as
mentioned in Documentation/CodingStyle.
It also silences 'Block comments use * on subsequent lines'
checkpatch.pl warnings.
Signed-off-by: Cristina Moraru <cristina.moraru09@gmail.com>
In fbtft-bus.c:fbtft_write_vmem16_bus9(), ioread8() is used for
accessing the provided screen array. Since screen_buffer actually
points to an ordinary buffer, instead access it directly.
Signed-off-by: Lars Svensson <lars1.svensson@sonymobile.com>
Member screen_base in struct fb_info is declared with __iomem
qualifier causing sparse warnings when used as a regular ponter.
To avoid the warnings, instead use alternate non-__iomem pointer,
screen_buffer, troughout the driver.
This patch adds support for the C-Berry28, a small 2.8" color display
with a resolution of 320x240 pixels from admatec for the Raspberry Pi.
It uses the Sitronix ST7789V display controller along with a custom
init sequence and custom gamma curves.
This patch adds support for the Sitronix ST7789V display controller.
The controller is intended for small color displays with a resolution
of up to 320x240 pixels.
struct timespec will overflow in year 2038, so replace it with
ktime_t. And replace functions that use struct timespec,
timespec_sub with ktime_sub. Also use monotonic time instead of real
time, by replacing getnstimeofday with ktime_get, to be more robust
against leap seconds and settimeofday() calls.
Reviewed-by: Arnd Bergmann <arnd@arndb.de>
Remove debug messages related to fbtft_par_dbg(DEBUG_BACKLIGHT.. )
as this info can be obtained using kernel function tracer
Signed-off-by: Shraddha Barke <shraddha.6596@gmail.com>
Remove debug messages related to fbtft_par_dbg(DEBUG_WRITE_VMEM.. )
We want the staging fixes in here as well.
Remove debug messages related to fbtft_par_dbg(DEBUG_INIT_DISPLAY.. )
Calling the setup of the SPI master directly causes a NULL pointer
dereference with master drivers without a separate setup function.
This problem is reproduceable on ARM MXS platform.
So fix this issue by using spi_setup() instead.
Signed-off-by: Stefan Wahren <stefan.wahren@i2se.com>
Acked-by: Noralf Trønnes <noralf@tronnes.org>
Since the result of the setup function isn't adequate to check
9-bit SPI support, we better check bits_per_word_mask. Btw this
change avoids a NULL pointer dereference with master drivers
Reduce the log level of some of the pr_* calls and remove 2 pr_debug
calls which just prints "init" and "exit".
Signed-off-by: Sudip Mukherjee <sudip@vectorindia.org>
Instead of defining DRVNAME and using it in all calls to pr_* family of
macros lets start using pr_fmt.
Use dev_* family of macros where we have a reference of a device.
Using magic numbers are not good coding practise. Use
FBTFT_GPIO_NAME_SIZE as defined in the header files.
Using strcpy() is a security risk as the destination buffer size is not
checked and we may over-run the buffer. Use strncpy() instead, while
mentioning the buffer size leaving place for the NULL termination.
Add blank spaces around operators where recommended
by checkpatch.pl
Signed-off-by: Anish Bhatt <anish@chelsio.com>
Remove or add blank lines as recommended by checkpatch.pl
Remove stray unicode quotes around name
fbtft_par_dbg(DEBUG_SET_ADDR_WIN.. ) is repeated in every
set_addr_win() handler, this could be replicated by using the kernel
function tracer instead.
Suggested-by: Greg KH <gregkh@linuxfoundation.org>
Based on checkpatch.pl recommendations, (1 << x)
is replaced by BIT(x)
instead of devm_kzalloc'ing them
Signed-off-by: Mike Rapoport <mike.rapoport@gmail.com>
Returning immediately if no platform_data or platform_data->gpios is
specified reduceis code nesting
The only usage of bl_ops variable in fbtft_unregister_backlight function
was assigment of a value to that variable, therefore the assignment and
the variable itself can be safely removed
checkpatch.pl recommends that this is no longer required.
Also replaces ASCII-art copyright notice with simple text
Using 'extern' is not necessary for function prototypes.
Miscellanea:
o Reflow alignments
Use a struct flexfb_lcd_controller to holds chip properties, instead of
relying on a long 'if - else if' chain.
This allows to:
- use a simple linear search to verify if a certain LCD controller
model is supported or not.
- add support for a new LCD chip controller simply defining a new
flexfb_lcd_controller struct.
Signed-off-by: Fabio Falzoi <fabio.falzoi84@gmail.com>
The GPIO subsystem provides dummy GPIO consumer functions if GPIOLIB is
not enabled. Hence drivers that depend on GPIOLIB, but use GPIO consumer
functionality only, can still be compiled if GPIOLIB is not enabled.
Relax the dependency on GPIOLIB if COMPILE_TEST is enabled, where
appropriate.
Pass platform_data as an argument to fbtft_framebuffer_alloc()
instead of using dev->platform_data.
This fixes an issue where the device comes from Device Tree
and fbtft_probe_common() sets dev->platform_data to allocated
memory. When the module is reloaded, dev->platform_data points
to freed memory.
Signed-off-by: Noralf Trønnes <noralf@tronnes.org>
This is a driver chip for 240x160 4-bit greyscale LCDs.
It is capable of 4-wire (8 bit) or 3-wire (9 bit) SPI that have both been
tested. (It also has a 6800 or 8080-style parallel interface, but I have
not included support for it.)
Signed-off-by: Henri Chain <henri.chain@eleves.ec-nantes.fr>
When an init sequence is present in the Device Tree,
fbtft_init_display_dt() is used to initialize the display.
Add missing reset function call and activation of
chip select for parallel bus.
This patch fixes the following checkpatch.pl error:
CHECK:SPACING at line 318.
CHECK:PARENTHESIS_ALIGNMENT at line 217.
This patch removes some unnecessary multiple blank lines to fix the
following checkpatch errors:
CHECK:LINE_SPACING at lines 29, 67, 131, 287, 299, 312, 326, 351 and
364.
Remove paragraph about writing to the Free Software Foundation's
mailing address from GPL notice.
This patch fixes the following checkpatch error:
CHECK:FSF_MAILING_ADDRESS at line 17.
Typo in a comment to register write corrected.
Signed-off-by: Anton Gerasimov <anton.gerasimov@openmailbox.org>
