The inline functions for accessing a memory mapped 8254 device
are using a void * for the 'base_address' of the device. Memory
mapped io using the read/write functions should be using a
void __iomem * for the address.
Fixing these exposed a couple other void * / void __iomem *
issues in the ni_labpc driver.
This fixes a number of sparse warnings like:
warning: incorrect type in argument 2 (different address spaces)
expected void volatile [noderef] <asn:2>*addr
got void *
warning: incorrect type in argument 1 (different address spaces)
expected void const volatile [noderef] <asn:2>*addr
got void *<noident>
Cc: Ian Abbott <abbotti@mev.co.uk>
This is a patch to the 8253.h file to fix 80 character line warning
found by checkpatch.pl tool
Signed-off-by: Graham M Howe <gman.1352@googlemail.com>
The line was too long.
Lindent changes to comdi driver in staging tree.
This patch is followed by the checkpatch.pl error fixes.
Did not make them part of this patch as the patch size is already huge.
Signed-off-by: Mithlesh Thukral <mithlesh@linsyssoft.com>
Remove dupilcated #include in drivers/staging/comedi/drivers/8253.h.
Signed-off-by: Huang Weiyi <weiyi.huang@gmail.com>
Signed-off-by: Bill Pemberton <wfp5p@virginia.edu>
This is needed by a bunch of different comedi drivers.
Cc: Frank Mori Hess <fmhess@users.sourceforge.net>
