The Beceem WiMAX driver was barely function in its current state
and was non-functional on 64 bit systems. Based on repeated
statements from Greg KH that he wanted the driver removed, I am
removing the driver.
CC: Matthias Beyer <mail@beyermatthias.de>
CC: Kevin McKinney <klmckinney1@gmail.com>
Signed-off-by: Matthias Beyer <mail@beyermatthias.de>
Removes whitespace before semicolons and add blank line after
declaration.
This patch simplifies
if (a) {
x = false;
} else {
if (b) {
x = false;
to
if (a || b) {
x = false;
This patch removes the unneccessary blocks inside the case statements
and fixes the indentation of their content.
Fix "Missing blank line after declaration" warnings reported by
checkpatch.pl.
Signed-off-by: Pawel Lebioda <pawel.lebioda89@gmail.com>
Some void pointers can be assigned to other
pointer variables in functions without casting.
Signed-off-by: Lisa Nguyen <lisa@xenapiadmin.com>
Replace user-defined type FALSE with C defined false keyword.
Remove user-defined BOOLEAN data type with C bool data
type.
This patch removes typedef IPV6HeaderFormatTag,
and changes the name of the struct to bcm_ipv6_hdr.
In addition, any calls to typedef IPV6Header
are changed to call the struct directly.
Signed-off-by: Kevin McKinney <klmckinney1@gmail.com>
This patch removes typedef IPV6RoutingHeaderFormatTag,
and changes the name of the struct to bcm_ipv6_routing_hdr.
In addition, any calls to typedef IPV6RoutingHeader
This patch removes typedef IPV6FragmentHeaderFormatTag,
and changes the name of the struct to bcm_ipv6_fragment_hdr.
In addition, any calls to typedef IPV6FragmentHeader
directly.
This patch removes typedef IPV6DestOptionsHeaderFormatTag,
and changes the name of the struct to bcm_ipv6_dest_options_hdr.
In addition, any calls to typedef IPV6DestOptionsHeader
directly.
This patch removes typedef IPV6HopByHopOptionsHeaderFormatTag,
and changes the name of the struct to bcm_ipv6_options_hdr.
In addition, any calls to typedef IPV6HopByHopOptionsHeader
directly.
This patch removes typedef for IPV6AuthenticationHeaderFormatTag,
and changes the name of the struct to bcm_ipv6_authentication_hdr
In addition, any calls to typedef IPV6AuthenticationHeader, are
This patch removes typedef for _MINI_ADAPTER, changes the
name of the struct from _MINI_ADAPTER to bcm_mini_adapter.
In addition, any calls to the following typedefs
"MINI_ADAPTER, *PMINI_ADAPTER" are changed to call
This patch removes typedef for _S_CLASSIFIER_RULE,
changes the name of the struct from
_S_CLASSIFIER_RULE to bcm_classifier_rule.
"S_CLASSIFIER_RULE" are changed to call the
struct directly.
Eighth patch in a series to fix coding style in IPv6Protocol.c
This patch removes some uneeded braces around single line if/for statements
Signed-off-by: Max Tottenham <mtottenh@gmail.com>
Acked-by: Kevin McKinney <klmckinney1@gmail.com>
Seventh patch in a series of patches to fix coding style in IPv6Protocol.c
this patch makes the file mostly conform to the 80 char line limit
there are some exceptions to this rule I have left in to aid readability
Sixth in a series of patche to fix coding style in IPv6Protocol.c
This patch changes the format of if statments from:
if (#VALUE == variable)
to:
if (variable == #VALUE)
Fith in a series of patche to fi coding syle in IPv6Protocol.c
Fixed trailing whitespaces and replaced spaces with tabs
in code indents
Fourth patch in a series of patches to fix coding style in IPv6Protocol.c
Continuation of fixing spacing arount ','
Third in a series of patches to fix coding style in Ipv6Protocol.c
This patch fixes the spacing around ',' in function calls.
Second in a set of patches to fix coding style in IPv6Protocol.c
This patch changes the commenting style
The first in a series of 8 patches to fix IPv6Protocol.c
This first patch fixes formatting issues for braced statements
(e.g. if/for/while)
Use namespace tool from kernel scripts to identify dead code and
functions that should be static.
This marks up the code where sparse complains in most cases.
Most of the changes are in the ioctl handling code, which
gets __user annotations, finding one unchecked user access.
The rest is mostly about marking functions static when they
are only used in one file.
The Sprint 4G network uses a Wimax dongle with Beecem
chipset. The driver is typical of out of tree drivers, but
maybe useful for people, and the hardware is readily available.
Here is a staging ready version (i.e warts and all)
0. Started with Rel_5.2.7.3P1_USB from Sprint4GDeveloperPack-1.1
1. Consolidated files in staging
2. Remove Dos cr/lf
3. Remove unnecessary ioctl from usbbcm_fops
Applied patches that were in the developer pack, surprising
there were ones for 2.6.35 already.
This is compile tested only, see TODO for what still needs
to be done.
