path: root/drivers/ssb/scan.c
2011-07-25Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (43 commits) fs: Merge split strings treewide: fix potentially dangerous trailing ';' in #defined values/expressions uwb: Fix misspelling of neighbourhood in comment net, netfilter: Remove redundant goto in ebt_ulog_packet trivial: don't touch files that are removed in the staging tree lib/vsprintf: replace link to Draft by final RFC number doc: Kconfig: `to be' -> `be' doc: Kconfig: Typo: square -> squared doc: Konfig: Documentation/power/{pm => apm-acpi}.txt drivers/net: static should be at beginning of declaration drivers/media: static should be at beginning of declaration drivers/i2c: static should be at beginning of declaration XTENSA: static should be at beginning of declaration SH: static should be at beginning of declaration MIPS: static should be at beginning of declaration ARM: static should be at beginning of declaration rcu: treewide: Do not use rcu_read_lock_held when calling rcu_dereference_check Update my e-mail address PCIe ASPM: forcedly -> forcibly gma500: push through device driver tree ... Fix up trivial conflicts: - arch/arm/mach-ep93xx/dma-m2p.c (deleted) - drivers/gpio/gpio-ep93xx.c (renamed and context nearby) - drivers/net/r8169.c (just context changes)
2011-07-07Update my e-mail addressMichael Büsch
Signed-off-by: Michael Buesch <m@bues.ch> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2011-06-27ssb: use pci_dev->revisionSergei Shtylyov
The bus scan code reads PCI revision ID from the PCI configuration register while it's already stored by PCI subsystem in the 'revision' field of 'struct pci_dev'... Signed-off-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-05-11ssb: update list of devices supporting multiple 80211 coresRafał Miłecki
Some of the BCM43xx chips contain cores that are attached to the SSB, but are inactive as they do not connect to the external environment. These must not be registered. Several of these types are handled in driver ssb; however, the specific case of an inactive 802.11 cores is now treated in b43 and b43legacy. Although the current setup works, this minor change will place all such workarounds in ssb, and simplify the code in drivers b43 and b43legacy. Signed-off-by: Rafał Miłecki <zajec5@gmail.com> Tested-by: Larry Finger <Larry.Finger@lwfinger.net> Acked-by: Larry Finger <Larry.Finger@lwfinger.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-04-04ssb: trivial: use u8 for chip_rev (it's mask is 0xF)Rafał Miłecki
Signed-off-by: Rafał Miłecki <zajec5@gmail.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-01-10ssb: Ignore dangling ethernet cores on wireless devicesMichael Büsch
Some Broadcom based wireless devices contain dangling ethernet cores. This triggers the ssb probing mechanism and tries to load the b44 driver on this core. Ignore the dangling core in the ssb core scanning code to avoid access to the core and failure of b44 probing. Signed-off-by: Michael Buesch <mb@bu3sch.de> Tested-by: Larry Finger <Larry.Finger@lwfinger.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-12-22ssb: Use pci_is_pcie()Hauke Mehrtens
Use function pci_is_pcie() instead of accessing struct member directly. CC: Michael Buesch <mb@bu3sch.de> Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-09-29pcmcia: convert pcmcia_request_configuration to pcmcia_enable_deviceDominik Brodowski
pcmcia_enable_device() now replaces pcmcia_request_configuration(). Instead of config_req_t, all necessary flags are either passed as a parameter to pcmcia_enable_device(), or (in rare circumstances) set in struct pcmcia_device -> flags. With the last remaining user of include/pcmcia/cs.h gone, remove all references. CC: netdev@vger.kernel.org CC: linux-wireless@vger.kernel.org CC: linux-ide@vger.kernel.org CC: linux-usb@vger.kernel.org CC: laforge@gnumonks.org CC: linux-mtd@lists.infradead.org CC: alsa-devel@alsa-project.org CC: linux-serial@vger.kernel.org CC: Jiri Kosina <jkosina@suse.cz> CC: linux-scsi@vger.kernel.org Acked-by: Gustavo F. Padovan <padovan@profusion.mobi> (for drivers/bluetooth) Tested-by: Wolfram Sang <w.sang@pengutronix.de> Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
2010-07-30pcmcia: remove cs_types.hDominik Brodowski
Remove cs_types.h which is no longer needed: Most definitions aren't used at all, a few can be made away with, and two remaining definitions (typedefs, unfortunatley) may be moved to more specific places. CC: linux-ide@vger.kernel.org CC: linux-usb@vger.kernel.org CC: laforge@gnumonks.org CC: linux-mtd@lists.infradead.org CC: alsa-devel@alsa-project.org CC: linux-serial@vger.kernel.org Acked-by: Marcel Holtmann <marcel@holtmann.org> (for drivers/bluetooth/) Acked-by: David S. Miller <davem@davemloft.net> Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
2009-11-23ssb: Unconditionally log results of core scansLarry Finger
At present, the results of an SSB core scan are only logged when CONFIG_SSB_DEBUG is "y". As this may not be set in a distro kernel, it is difficult interpret many problems posted in bug reports or in help forums. Signed-off-by: Larry Finger <Larry.Finger@lwfinger.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-11-10ssb-pcmcia: Fix 32bit register access in early bus scanningMartin Fuzzey
The scan function was using 32 bit access which does not work on 16bit CF cards. This patch corrects this by doing two 16 bit reads like ssb_pcmcia_read32 already does. mb -- Removed locking. That early in init there's no need for locking. Signed-off-by: Martin Fuzzey <mfuzzey@gmail.com> Signed-off-by: Michael Buesch <mb@bu3sch.de> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-09-09ssb: Implement SDIO host bus supportAlbert Herranz
Add support for communicating with a Sonics Silicon Backplane through a SDIO interface, as found in the Nintendo Wii WLAN daughter card. The Nintendo Wii WLAN card includes a custom Broadcom 4318 chip with a SDIO host interface. Signed-off-by: Albert Herranz <albert_herranz@yahoo.es> Signed-off-by: Michael Buesch <mb@bu3sch.de> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-01-08ssb: Fix probing of PCI cores if PCI and PCIE core is availableMichael Buesch
This will make sure that always the correct core is selected, even if there are both a PCI and PCI-E core on a PCI or PCI-E card. Signed-off-by: Michael Buesch <mb@bu3sch.de> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2007-10-10[SSB]: add Sonics Silicon Backplane bus supportMichael Buesch
SSB is an SoC bus used in a number of embedded devices. The most well-known of these devices is probably the Linksys WRT54G, but there are others as well. The bus is also used internally on the BCM43xx and BCM44xx devices from Broadcom. This patch also includes support for SSB ID tables in modules, so that SSB drivers can be loaded automatically. Signed-off-by: Michael Buesch <mb@bu3sch.de> Signed-off-by: John W. Linville <linville@tuxdriver.com> Signed-off-by: David S. Miller <davem@davemloft.net>
