Signed-off-by: Michael Buesch <m@bues.ch>
Add new vendor for Broadcom 4318.
Signed-off-by: Daniel Klaffenbach <danielklaffenbach@gmail.com>
Cc: Stable <stable@kernel.org>
00:09.0 Network controller [0280]: Broadcom Corporation BCM4307 Ethernet Controller [14e4:4306] (rev 03)
Subsystem: Broadcom Corporation BCM4307 Ethernet Controller [14e4:4306]
Flags: bus master, fast devsel, latency 32, IRQ 10
Memory at d7000000 (32-bit, non-prefetchable) [size=8K]
Kernel driver in use: b43-pci-bridge
Kernel modules: ssb
Reported-by: yoann <yoann71@msn.com>
Signed-off-by: Michael Buesch <mb@bu3sch.de>
This adds detection code for the LP-PHY and SPROM
extraction code for version 8, which is needed by the LP-PHY and
newer N-PHY.
This is used on my macbook. N PHY, obviously nothing works
yet, but we can detect the chip with this patch.
Signed-off-by: Johannes Berg <johannes@sipsolutions.net>
Signed-off-by: Adrian Bunk <bunk@kernel.org>
This adds the PCI ID 0x4329 for the BCM43XG.
In disagreement with the SPROM specs, revision 3 devices appear to have
moved the MAC address.
Change ssb to handle the revision 4 SPROM, which is a different size.
This change in size is handled by adding a new variable to the ssb_sprom
struct and using it whenever possible. For those routines that do not
have access to this structure, a 'u16 size' argument is added.
The new PCI_ID for the BCM4328 is also added.
Testing of the Revision 4 SPROM, which is used on the BCM4328, was done
by Michael Gerdau <mgerdau@tiscali.de>.
This fixes all Sparse warnings in SSB.
No semantics change.
SSB is an SoC bus used in a number of embedded devices. The most
well-known of these devices is probably the Linksys WRT54G, but there
are others as well. The bus is also used internally on the BCM43xx
and BCM44xx devices from Broadcom.
This patch also includes support for SSB ID tables in modules, so
that SSB drivers can be loaded automatically.
