path: root/drivers/spi/spi_bitbang.c
2006-01-13[PATCH] spi: use linked lists rather than an arrayVitaly Wool
This makes the SPI core and its users access transfers in the SPI message structure as linked list not as an array, as discussed on LKML. From: David Brownell <dbrownell@users.sourceforge.net> Updates including doc, bugfixes to the list code, add spi_message_add_tail(). Plus, initialize things _before_ grabbing the locks in some cases (in case it grows more expensive). This also merges some bitbang updates of mine that didn't yet make it into the mm tree. Signed-off-by: Vitaly Wool <vwool@ru.mvista.com> Signed-off-by: Dmitry Pervushin <dpervushin@gmail.com> Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-01-13[PATCH] spi: add spi_bitbang driverDavid Brownell
This adds a bitbanging spi master, hooking up to board/adapter-specific glue code which knows how to set and read the signals (gpios etc). This code kicks in after the glue code creates a platform_device with the right platform_data. That data includes I/O loops, which will usually come from expanding an inline function (provided in the header). One goal is that the I/O loops should be easily optimized down to a few GPIO register accesses, in common cases, for speed and minimized overhead. This understands all the currently defined protocol tweaking options in the SPI framework, and might eventually serve as as reference implementation. - different word sizes (1..32 bits) - differing clock rates - SPI modes differing by CPOL (affecting chip select and I/O loops) - SPI modes differing by CPHA (affecting I/O loops) - delays (usecs) after transfers - temporarily deselecting chips in mid-transfer A lot of hardware could work with this framework, though common types of controller can't reach peak performance without switching to a driver structure that supports pipelining of transfers (e.g. DMA queues) and maybe controllers (e.g. IRQ driven). Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
