Fix doubled clock disable and unprepare during PM suspend which triggered
the warnings:
WARNING: at drivers/clk/clk.c:800 clk_disable+0x18/0x24()
Modules linked in:
CPU: 0 PID: 1745 Comm: sh Not tainted 3.10.14-01211-ge2549bb-dirty #62
[<c0015980>] (unwind_backtrace+0x0/0x138) from [<c0012a44>] (show_stack+0x10/0x14)
[<c0012a44>] (show_stack+0x10/0x14) from [<c0022818>] (warn_slowpath_common+0x4c/0x68)
[<c0022818>] (warn_slowpath_common+0x4c/0x68) from [<c0022850>] (warn_slowpath_null+0x1c/0x24)
[<c0022850>] (warn_slowpath_null+0x1c/0x24) from [<c036e274>] (clk_disable+0x18/0x24)
[<c036e274>] (clk_disable+0x18/0x24) from [<c02d5f78>] (s3c64xx_spi_suspend+0x28/0x54)
[<c02d5f78>] (s3c64xx_spi_suspend+0x28/0x54) from [<c02b3a54>] (platform_pm_suspend+0x2c/0x5c)
[<c02b3a54>] (platform_pm_suspend+0x2c/0x5c) from [<c02b8a30>] (dpm_run_callback+0x44/0x7c)
[<c02b8a30>] (dpm_run_callback+0x44/0x7c) from [<c02b8b70>] (__device_suspend+0x108/0x300)
[<c02b8b70>] (__device_suspend+0x108/0x300) from [<c02ba4e0>] (dpm_suspend+0x54/0x208)
[<c02ba4e0>] (dpm_suspend+0x54/0x208) from [<c0066bcc>] (suspend_devices_and_enter+0x98/0x458)
[<c0066bcc>] (suspend_devices_and_enter+0x98/0x458) from [<c0067150>] (pm_suspend+0x1c4/0x25c)
[<c0067150>] (pm_suspend+0x1c4/0x25c) from [<c0066044>] (state_store+0x6c/0xbc)
[<c0066044>] (state_store+0x6c/0xbc) from [<c0203290>] (kobj_attr_store+0x14/0x20)
[<c0203290>] (kobj_attr_store+0x14/0x20) from [<c0157530>] (sysfs_write_file+0xfc/0x164)
[<c0157530>] (sysfs_write_file+0xfc/0x164) from [<c00fd6b0>] (vfs_write+0xbc/0x1bc)
[<c00fd6b0>] (vfs_write+0xbc/0x1bc) from [<c00fdaf0>] (SyS_write+0x40/0x68)
[<c00fdaf0>] (SyS_write+0x40/0x68) from [<c000ea80>] (ret_fast_syscall+0x0/0x3c)
The clocks may be already disabled before suspending. Check PM runtime
suspend status and disable clocks only if device is not suspended.
During resume do not enable the clocks if device is runtime suspended.
Signed-off-by: Krzysztof Kozlowski <k.kozlowski@samsung.com>
Reviewed-by: Sylwester Nawrocki <s.nawrocki@samsung.com>
Signed-off-by: Mark Brown <broonie@linaro.org>
During PM resume and suspend do not ignore the return value of
spi_master_suspend() or spi_master_resume(). Instead pass it further.
pm_runtime_put() wasn't called if clock rate could not be set up in
s3c64xx_spi_setup() leading to invalid count of device pm_runtime usage.
Mark device as PM runtime active during initialization to reflect
actual device power/clocks state. This reduces the enable count for SPI
bus controller gate clock so it can be disabled when the bus controller
is not used.
This is of very little value in itself but will be useful once the loop
iterating over the transfers is also factored out into the core.
The hardware level /CS handling is tied to the start of the data path so
is rolled into the same function as we use to manipulate GPIO /CS. In
order to support factoring out the /CS handling into the core separate the
two and explicitly start transfers separately to the /CS handling.
To help with bisection of future refactoring to share more of the code for
handling a spi_message pull the enabling of GPIO based /CS prior to all
the hardware setup for starting a transfer.
Rather than using the driver custom platform data to store the chip select
GPIO use the cs_gpio field provided by the SPI core, supporting future
refectoring.
Ensure that the FIFOs are fully drained before we deassert /CS or do any
delays that have been requested in order to ensure that the behaviour
visible on the bus matches that which was requested by the caller.
drivers/spi/spi-s3c64xx.c
Otherwise we may try to start transfers immediately and then fail to
runtime resume the device causing us not to have clocks enabled.
Add compatibles for s3c6410, s5pc100 and s5pc110/s5pv210 boards.
Signed-off-by: Mateusz Krawczuk <m.krawczuk@partner.samsung.com>
Also improve the error reporting on failure and remove a duplicate put.
This provides a small code saving.
subsys_init_call() initializes driver too early.
It's preventing to move DMA channel allocation at the begining
(driver probe).
This patch reduces and simplifies initalization code by
using module_platform_driver() macro.
It's also efficiently delaying driver startup.
Signed-off-by: Lukasz Czerwinski <l.czerwinski@samsung.com>
drivers/spi/spi-rspi.c
Use the wrapper function for retrieving the platform data instead of
accessing dev->platform_data directly.
Signed-off-by: Jingoo Han <jg1.han@samsung.com>
We always need the device to be runtime PM enabled to use it so just skip
the DMA initialisation not the entire prepare when polling.
Since the driver supports only contiguous buffers, there is no need to
manually construct a scatterlist with just a single entry, when there is
a dedicated helper for this purpose.
This patch modifies prepare_dma() function to use available helper instead
of manually creating a scatterlist.
Signed-off-by: Tomasz Figa <tomasz.figa@gmail.com>
Comments in linux/spi/spi.h and observed behavior show that .setup()
callback can be called multiple times without corresponding calls to
.cleanup(), what was incorrectly assumed by spi-s3c64xx driver, leading
to failures trying to request CS GPIO multiple times.
This patch modifies the behavior of spi-s3c64xx driver to request CS
GPIO only on first call to .setup() after last .cleanup().
Not all fields of dma_slave_config struct are being initialized by
prepare_dma() function, leaving those which are not in undefined state,
which can confuse DMA drivers using them.
This patch adds call to memset() to zero the struct before initializing
a subset of its fields.
sdd->ops->request is unsigned int, not unsigned long.
Also, sdd->rx_dma.ch is a 'struct dma_chan *'.
Thus, (void *) is converted to (struct dma_chan *)(unsigned long),
in order to fix possible sparse warnings.
Fix the following build warnings when LPAE is enabled:
drivers/spi/spi-s3c64xx.c:1466:2: warning: format '%x' expects argument of type 'unsigned int', but argument 4 has type
'resource_size_t' [-Wformat]
drivers/spi/spi-s3c64xx.c:1466:2: warning: format '%x' expects argument of type 'unsigned int', but argument 5 has type
Use vsprintf extension %pR to format resource.
Fix the following checkpatch error and warnings:
ERROR: "(foo*)" should be "(foo *)"
WARNING: line over 80 characters
WARNING: quoted string split across lines
Since the driver has been converted to use the core message pump code
the only use of the messsage queue in the driver is a check to see if
it is empty which will always succeed since nothing ever adds to the
queue. Just remove the queue.
Acked-by: Kukjin Kim <kgene.kim@samsung.com>
Due to changes in mainline prior to submission the spi device detection
in polling mode breaks. This revealed the missing check for polling
during dma prepare. This patch adds the missing check.
Signed-off-by: Girish K S <ks.giri@samsung.com>
After the patch "spi/s3c64xx: Fix non-dmaengine usage"
with commit id 563b444e33810f3120838620c990480304e24e63
submitted by Mark Brown, the spi device detection in polling
mode breaks. This revealed the missing check for polling during
This should work with modern compilers, isn't that much of an issue if
it goes wrong and it ensures that the DT-only hardware variants don't
leave unreferenced parameters structures lying around.
This patch adds support for the exynos5440 spi controller.
The integration of the spi IP in exynos5440 is different from
other SoC's. The I/O pins are no more configured via gpio, they
have dedicated pins.
The existing driver supports gpio based /cs signal.
For controller's that have one device per controller,
the slave device's /cs signal might be internally controlled
by the chip select bit of slave select register. They are not
externally asserted/deasserted using gpio pin.
This patch adds support for controllers with dedicated /cs pin.
if "cs-gpio" property doesnt exist in a spi dts node, the controller
would treat the /cs pin as dedicated.
The 64xx spi driver supports partial polling mode.
Only the last chunk of the transfer length is transferred
or recieved in polling mode.
Some SoC's that adopt this controller might not have have dma
interface. This patch adds support for complete polling mode
and gives flexibity for the user to select poll/dma mode.
If the device is already in a runtime PM enabled state
pm_runtime_get_sync() will return 1, so a test for negative
value should be used to check for errors.
Without this patch there are seen errors like:
[ 8.540000] s3c64xx-spi 13930000.spi: Failed to enable device: 1
[ 8.545000] spi_master spi1: failed to prepare transfer hardware
Likely because the driver uses synchronous API to runtime enable
the device and asynchronous one to disable it.
Signed-off-by: Sylwester Nawrocki <s.nawrocki@samsung.com>
Signed-off-by: Mark Brown <broonielinaro.org>
Cc: stable@vger.kernel.org
Fill in the recently added spi_master.bits_per_word_mask field in as
many drivers as possible. Make related cleanups, such as removing any
redundant error-checking, or empty setup callbacks.
Signed-off-by: Stephen Warren <swarren@wwwdotorg.org>
Acked-by: H Hartley Sweeten <hsweeten@visionengravers.com>
The driver core clears the driver data to NULL after device_release
or on probe failure, since commit 0998d0631001288a5974afc0b2a5f568bcdecb4d
(device-core: Ensure drvdata = NULL when no driver is bound).
Thus, it is not needed to manually clear the device driver data to NULL.
Acked-by: Grant Likely <grant.likely@linaro.org>
Don't silently ignore errors, report them.
The multiplatform conversion in commit 788437 (spi: s3c64xx: move to
generic dmaengine API) tested for the use of the Samsung-specific DMA
API with SAMSUNG_DMADEV when in fact S3C_DMA should be used. This
renderd DMA based transfers non-functional on platforms not using
dmaengine.
With device core now able to setup the default pin configuration,
the pin configuration code based on the deprecated Samsung specific
gpio bindings is removed.
Signed-off-by: Thomas Abraham <thomas.abraham@linaro.org>
Signed-off-by: Doug Anderson <dianders@chromium.org>
Reviewed-by: Doug Anderson <dianders@chromium.org>
Tested-by: Doug Anderson <dianders@chromium.org>
Signed-off-by: Grant Likely <grant.likely@linaro.org>
