[ Upstream commit 3fd269e74f2feec973f45ee11d822faeda4fe284 ]
All amba drivers return 0 in their remove callback. Together with the
driver core ignoring the return value anyhow, it doesn't make sense to
return a value here.
Change the remove prototype to return void, which makes it explicit that
returning an error value doesn't work as expected. This simplifies changing
the core remove callback to return void, too.
Reviewed-by: Ulf Hansson <ulf.hansson@linaro.org>
Reviewed-by: Arnd Bergmann <arnd@arndb.de>
Acked-by: Alexandre Belloni <alexandre.belloni@bootlin.com>
Acked-by: Dmitry Torokhov <dmitry.torokhov@gmail.com>
Acked-by: Krzysztof Kozlowski <krzk@kernel.org> # for drivers/memory
Acked-by: Mark Brown <broonie@kernel.org>
Acked-by: Suzuki K Poulose <suzuki.poulose@arm.com> # for hwtracing/coresight
Acked-By: Vinod Koul <vkoul@kernel.org> # for dmaengine
Acked-by: Guenter Roeck <linux@roeck-us.net> # for watchdog
Acked-by: Wolfram Sang <wsa@kernel.org> # for I2C
Acked-by: Takashi Iwai <tiwai@suse.de> # for sound
Acked-by: Vladimir Zapolskiy <vz@mleia.com> # for memory/pl172
Acked-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
Link: https://lore.kernel.org/r/20210126165835.687514-5-u.kleine-koenig@pengutronix.de
[ Upstream commit d81d0e41ed5fe7229a2c9a29d13bad288c7cf2d2 ]
There are missing braces in the function that verify controller parameters,
then an error is always returned when the parameter to select Microwire
frames operation is used on devices allowing it.
Signed-off-by: Thomas Perrot <thomas.perrot@bootlin.com>
Link: https://lore.kernel.org/r/20211022142104.1386379-1-thomas.perrot@bootlin.com
Signed-off-by: Mark Brown <broonie@kernel.org>
Also demote non-worthy kerneldoc headers to standard comment blocks.
Fixes the following W=1 kernel build warning(s):
drivers/spi/spi-pl022.c:304: warning: cannot understand function prototype: 'enum ssp_writing '
drivers/spi/spi-pl022.c:330: warning: Function parameter or member 'loopback' not described in 'vendor_data'
drivers/spi/spi-pl022.c:398: warning: Function parameter or member 'rx_lev_trig' not described in 'pl022'
drivers/spi/spi-pl022.c:398: warning: Function parameter or member 'tx_lev_trig' not described in 'pl022'
drivers/spi/spi-pl022.c:398: warning: Function parameter or member 'dma_running' not described in 'pl022'
drivers/spi/spi-pl022.c:670: warning: Function parameter or member 'pl022' not described in 'readwriter'
drivers/spi/spi-pl022.c:1250: warning: Function parameter or member 'irq' not described in 'pl022_interrupt_handler'
drivers/spi/spi-pl022.c:1250: warning: Function parameter or member 'dev_id' not described in 'pl022_interrupt_handler'
drivers/spi/spi-pl022.c:1343: warning: Function parameter or member 'pl022' not described in 'set_up_next_transfer'
drivers/spi/spi-pl022.c:1343: warning: Function parameter or member 'transfer' not described in 'set_up_next_transfer'
Signed-off-by: Lee Jones <lee.jones@linaro.org>
Cc: Sachin Verma <sachin.verma@st.com>
Link: https://lore.kernel.org/r/20200717135424.2442271-9-lee.jones@linaro.org
dma_request_slave_channel_reason() is:
#define dma_request_slave_channel_reason(dev, name) \
dma_request_chan(dev, name)
Signed-off-by: Peter Ujfalusi <peter.ujfalusi@ti.com>
Link: https://lore.kernel.org/r/20191113094256.1108-6-peter.ujfalusi@ti.com
For many places in the spi drivers, using the new `spi_transfer_delay`
helper is straightforward.
It's just replacing:
if (t->delay_usecs)
udelay(t->delay_usecs);
with `spi_transfer_delay(t)` which handles both `delay_usecs` and the new
`delay` field.
This change replaces in all places (in the spi drivers) where this change
is simple.
Signed-off-by: Alexandru Ardelean <alexandru.ardelean@analog.com>
Link: https://lore.kernel.org/r/20190926105147.7839-10-alexandru.ardelean@analog.com
Based on 3 normalized pattern(s):
this program is free software you can redistribute it and or modify
it under the terms of the gnu general public license as published by
the free software foundation either version 2 of the license or at
your option any later version this program is distributed in the
hope that it will be useful but without any warranty without even
the implied warranty of merchantability or fitness for a particular
purpose see the gnu general public license for more details
your option any later version [author] [kishon] [vijay] [abraham]
[i] [kishon]@[ti] [com] this program is distributed in the hope that
it will be useful but without any warranty without even the implied
warranty of merchantability or fitness for a particular purpose see
your option any later version [author] [graeme] [gregory]
[gg]@[slimlogic] [co] [uk] [author] [kishon] [vijay] [abraham] [i]
[kishon]@[ti] [com] [based] [on] [twl6030]_[usb] [c] [author] [hema]
[hk] [hemahk]@[ti] [com] this program is distributed in the hope
that it will be useful but without any warranty without even the
extracted by the scancode license scanner the SPDX license identifier
GPL-2.0-or-later
has been chosen to replace the boilerplate/reference in 1105 file(s).
Reviewed-by: Allison Randal <allison@lohutok.net>
Reviewed-by: Richard Fontana <rfontana@redhat.com>
Cc: linux-spdx@vger.kernel.org
Link: https://lkml.kernel.org/r/20190527070033.202006027@linutronix.de
When transfer timeout, give -EAGAIN to the message's status, and it can
make the spi device driver choose repeated transimation or not. And if
transfer timeout, output some useful information for tracing the issue.
Signed-off-by: Jiwei Sun <jiwei.sun@windriver.com>
Do not deselect cs when cs_change is set for the last transfer in the
message. In this case, cs_change indicates that cs should stay selected
until the next transfer.
Signed-off-by: Fredrik Ternerot <fredrikt@axis.com>
Fixes gcc '-Wunused-but-set-variable' warning:
drivers/spi/spi-pl022.c: In function 'do_polling_transfer':
drivers/spi/spi-pl022.c:1493:20: warning:
variable 'chip' set but not used [-Wunused-but-set-variable]
Signed-off-by: YueHaibing <yuehaibing@huawei.com>
spi_controller_{suspend,resume}() already prints an error message on
failure, so there is no need to repeat this in individual drivers.
Note: spi_master_{suspend,resume}() is an alias for
spi_controller_{suspend,resume}().
Signed-off-by: Geert Uytterhoeven <geert+renesas@glider.be>
Reviewed-by: Alexandre Belloni <alexandre.belloni@bootlin.com>
Reviewed-by: Daniel Mack <daniel@zonque.org>
Acked-by: Nicolas Ferre <nicolas.ferre@microchip.com>
The devm_kzalloc() function has a 2-factor argument form, devm_kcalloc().
This patch replaces cases of:
devm_kzalloc(handle, a * b, gfp)
with:
devm_kcalloc(handle, a * b, gfp)
as well as handling cases of:
devm_kzalloc(handle, a * b * c, gfp)
with:
devm_kzalloc(handle, array3_size(a, b, c), gfp)
as it's slightly less ugly than:
devm_kcalloc(handle, array_size(a, b), c, gfp)
This does, however, attempt to ignore constant size factors like:
devm_kzalloc(handle, 4 * 1024, gfp)
though any constants defined via macros get caught up in the conversion.
Any factors with a sizeof() of "unsigned char", "char", and "u8" were
dropped, since they're redundant.
Some manual whitespace fixes were needed in this patch, as Coccinelle
really liked to write "=devm_kcalloc..." instead of "= devm_kcalloc...".
The Coccinelle script used for this was:
// Fix redundant parens around sizeof().
expression HANDLE;
type TYPE;
expression THING, E;
devm_kzalloc(HANDLE,
- (sizeof(TYPE)) * E
+ sizeof(TYPE) * E
- (sizeof(THING)) * E
+ sizeof(THING) * E
// Drop single-byte sizes and redundant parens.
expression HANDLE;
expression COUNT;
typedef u8;
typedef __u8;
- sizeof(u8) * (COUNT)
+ COUNT
- sizeof(__u8) * (COUNT)
+ COUNT
- sizeof(char) * (COUNT)
+ COUNT
- sizeof(unsigned char) * (COUNT)
+ COUNT
- sizeof(u8) * COUNT
+ COUNT
- sizeof(__u8) * COUNT
+ COUNT
- sizeof(char) * COUNT
+ COUNT
- sizeof(unsigned char) * COUNT
+ COUNT
// 2-factor product with sizeof(type/expression) and identifier or constant.
expression HANDLE;
type TYPE;
expression THING;
identifier COUNT_ID;
constant COUNT_CONST;
- devm_kzalloc
+ devm_kcalloc
(HANDLE,
- sizeof(TYPE) * (COUNT_ID)
+ COUNT_ID, sizeof(TYPE)
- devm_kzalloc
+ devm_kcalloc
(HANDLE,
- sizeof(TYPE) * COUNT_ID
- devm_kzalloc
+ devm_kcalloc
(HANDLE,
- sizeof(TYPE) * (COUNT_CONST)
+ COUNT_CONST, sizeof(TYPE)
- devm_kzalloc
+ devm_kcalloc
(HANDLE,
- sizeof(TYPE) * COUNT_CONST
- devm_kzalloc
+ devm_kcalloc
(HANDLE,
- sizeof(THING) * (COUNT_ID)
+ COUNT_ID, sizeof(THING)
- devm_kzalloc
+ devm_kcalloc
(HANDLE,
- sizeof(THING) * COUNT_ID
- devm_kzalloc
+ devm_kcalloc
(HANDLE,
- sizeof(THING) * (COUNT_CONST)
+ COUNT_CONST, sizeof(THING)
- devm_kzalloc
+ devm_kcalloc
(HANDLE,
- sizeof(THING) * COUNT_CONST
// 2-factor product, only identifiers.
expression HANDLE;
identifier SIZE, COUNT;
- devm_kzalloc
+ devm_kcalloc
(HANDLE,
- SIZE * COUNT
+ COUNT, SIZE
// 3-factor product with 1 sizeof(type) or sizeof(expression), with
// redundant parens removed.
expression HANDLE;
expression THING;
identifier STRIDE, COUNT;
type TYPE;
- sizeof(TYPE) * (COUNT) * (STRIDE)
+ array3_size(COUNT, STRIDE, sizeof(TYPE))
- sizeof(TYPE) * (COUNT) * STRIDE
- sizeof(TYPE) * COUNT * (STRIDE)
- sizeof(TYPE) * COUNT * STRIDE
- sizeof(THING) * (COUNT) * (STRIDE)
+ array3_size(COUNT, STRIDE, sizeof(THING))
- sizeof(THING) * (COUNT) * STRIDE
- sizeof(THING) * COUNT * (STRIDE)
- sizeof(THING) * COUNT * STRIDE
// 3-factor product with 2 sizeof(variable), with redundant parens removed.
expression HANDLE;
expression THING1, THING2;
identifier COUNT;
type TYPE1, TYPE2;
- sizeof(TYPE1) * sizeof(TYPE2) * COUNT
+ array3_size(COUNT, sizeof(TYPE1), sizeof(TYPE2))
- sizeof(TYPE1) * sizeof(THING2) * (COUNT)
- sizeof(THING1) * sizeof(THING2) * COUNT
+ array3_size(COUNT, sizeof(THING1), sizeof(THING2))
- sizeof(THING1) * sizeof(THING2) * (COUNT)
- sizeof(TYPE1) * sizeof(THING2) * COUNT
+ array3_size(COUNT, sizeof(TYPE1), sizeof(THING2))
// 3-factor product, only identifiers, with redundant parens removed.
expression HANDLE;
identifier STRIDE, SIZE, COUNT;
- (COUNT) * STRIDE * SIZE
+ array3_size(COUNT, STRIDE, SIZE)
- COUNT * (STRIDE) * SIZE
- COUNT * STRIDE * (SIZE)
- (COUNT) * (STRIDE) * SIZE
- COUNT * (STRIDE) * (SIZE)
- (COUNT) * STRIDE * (SIZE)
- (COUNT) * (STRIDE) * (SIZE)
- COUNT * STRIDE * SIZE
// Any remaining multi-factor products, first at least 3-factor products,
// when they're not all constants...
expression HANDLE;
expression E1, E2, E3;
constant C1, C2, C3;
devm_kzalloc(HANDLE, C1 * C2 * C3, ...)
- (E1) * E2 * E3
+ array3_size(E1, E2, E3)
- (E1) * (E2) * E3
- (E1) * (E2) * (E3)
- E1 * E2 * E3
// And then all remaining 2 factors products when they're not all constants,
// keeping sizeof() as the second factor argument.
expression HANDLE;
expression THING, E1, E2;
type TYPE;
devm_kzalloc(HANDLE, sizeof(THING) * C2, ...)
devm_kzalloc(HANDLE, sizeof(TYPE) * C2, ...)
devm_kzalloc(HANDLE, C1 * C2, ...)
- devm_kzalloc
+ devm_kcalloc
(HANDLE,
- sizeof(TYPE) * (E2)
+ E2, sizeof(TYPE)
- devm_kzalloc
+ devm_kcalloc
(HANDLE,
- sizeof(TYPE) * E2
+ E2, sizeof(TYPE)
- devm_kzalloc
+ devm_kcalloc
(HANDLE,
- sizeof(THING) * (E2)
+ E2, sizeof(THING)
- devm_kzalloc
+ devm_kcalloc
(HANDLE,
- sizeof(THING) * E2
+ E2, sizeof(THING)
- devm_kzalloc
+ devm_kcalloc
(HANDLE,
- (E1) * E2
+ E1, E2
- devm_kzalloc
+ devm_kcalloc
(HANDLE,
- (E1) * (E2)
+ E1, E2
- devm_kzalloc
+ devm_kcalloc
(HANDLE,
- E1 * E2
+ E1, E2
amba_id are not supposed to change at runtime. All functions
working with const amba_id. So mark the non-const structs as const.
Signed-off-by: Arvind Yadav <arvind.yadav.cs@gmail.com>
The num-cs property is a required property according to the binding
documentation. However, if it is not present, the driver currently
simply uses random junk from the stack for the num-cs since the variable
whose pointer is passed to of_property_read_u32() is not initialized.
Signed-off-by: Rabin Vincent <rabinv@axis.com>
These structure members were removed in 2012 by the commit ffbbdd21329f
("spi: create a message queueing infrastructure").
Signed-off-by: Jarkko Nikula <jarkko.nikula@linux.intel.com>
Handle EPROBE_DEFER explicitly so that we ensure that we get the DMA
channel specified in the device tree, instead of depending on the DMA
controller getting probed before us.
Signed-off-by: Rabin Vincent <rabin.vincent@axis.com>
'spi/topic/omap-uwire', 'spi/topic/pl022', 'spi/topic/pm' and 'spi/topic/pxa2xx' into spi-next
Commit fd316941c ("spi/pl022: disable port when unused") introduced a race,
which leads to possible driver lock up (easily reproducible on SMP).
The problem happens in giveback() function where the completion of the transfer
is signalled to SPI subsystem and then the HW SPI controller is disabled. Another
transfer might be setup in between, which brings driver in locked-up state.
Exact event sequence on SMP:
core0 core1
=> pump_transfers()
/* message->state == STATE_DONE */
=> giveback()
=> spi_finalize_current_message()
=> pl022_unprepare_transfer_hardware()
=> pl022_transfer_one_message
=> flush()
=> do_interrupt_dma_transfer()
=> set_up_next_transfer()
/* Enable SSP, turn on interrupts */
writew((readw(SSP_CR1(pl022->virtbase)) |
SSP_CR1_MASK_SSE), SSP_CR1(pl022->virtbase));
=> pl022_interrupt_handler()
=> readwriter()
/* disable the SPI/SSP operation */
=> writew((readw(SSP_CR1(pl022->virtbase)) &
(~SSP_CR1_MASK_SSE)), SSP_CR1(pl022->virtbase));
Lockup! SPI controller is disabled and the data will never be received. Whole
SPI subsystem is waiting for transfer ACK and blocked.
So, only signal transfer completion after disabling the controller.
Fixes: fd316941c (spi/pl022: disable port when unused)
Signed-off-by: Alexander Sverdlin <alexander.sverdlin@nokia.com>
Cc: stable@vger.kernel.org
"flag" variable does nothing, remove it.
PL022 Programmers model explicitely states "do not modify undefined register
bits". Correct the "all enable" interrupt mask so that it only enables defined
ones.
According to PL022 specification, TNF bit states for "Transmit FIFO Not full".
So the logic here is inverted. But "Receive Overrun Interrupt", which is handled
here, is only triggered on Rx errors. So instead of fixing the if statement,
remove the whole message.
The SET_PM_RUNTIME_PM_OPS() and SET_RUNTIME_PM_OPS() macros are
identical except that one of them is not empty for CONFIG_PM set,
while the other one is not empty for CONFIG_PM_RUNTIME set,
respectively.
However, after commit b2b49ccbdd54 (PM: Kconfig: Set PM_RUNTIME if
PM_SLEEP is selected) PM_RUNTIME is always set if PM is set, so one
of these macros is now redundant.
For this reason, replace SET_PM_RUNTIME_PM_OPS() with
SET_RUNTIME_PM_OPS() everywhere and redefine the SET_PM_RUNTIME_PM_OPS
symbol as SET_RUNTIME_PM_OPS in case new code is starting to use the
macro being removed here.
Acked-by: Kevin Hilman <khilman@linaro.org>
When mapped RX DMA entries are unmapped in an error condition when DMA
is firstly configured in the driver, the number of TX DMA entries was
passed in, which is incorrect
Signed-off-by: Ray Jui <rjui@broadcom.com>
'spi/topic/rspi', 'spi/topic/sh-msiof' and 'spi/topic/sirf' into spi-next
Add support for a extended PL022 which has an extra register for controlling up
to five chip select signals. This controller is found on the AXM5516 SoC.
Unfortunately the PrimeCell identification registers are identical to a
standard ARM PL022. To work around this, the peripheral ID must be overridden
in the device tree using the "arm,primecell-periphid" property with the value
0x000b6022.
Signed-off-by: Anders Berg <anders.berg@avagotech.com>
Acked-by: Russell King <rmk+kernel@arm.linux.org.uk>
Currently this driver is missing a check on the return value of devm_kzalloc,
which would cause a NULL pointer dereference in a OOM situation.
This patch adds a missing check.
Signed-off-by: Kiran Padwal <kiran.padwal@smartplayin.com>
This patch fixes an error message typo ("not" missing).
Signed-off-by: Roland Stigge <stigge@antcom.de>
Signed-off-by: Mark Brown <broonie@linaro.org>
When building on 64 bit architectures the use of bitwise negation generates
constants larger than 32 bits which won't fit in u32s used to represent
32 bit register values on the device. Explicitly cast to let the compiler
know that the higher bits are not significant and can be discarded.
The site-specific OOM messages are unnecessary, because they
duplicate the MM subsystem generic OOM message.
Signed-off-by: Jingoo Han <jg1.han@samsung.com>
'spi/topic/omap2', 'spi/topic/orion', 'spi/topic/pl022', 'spi/topic/qup', 'spi/topic/rspi' and 'spi/topic/s3c24xx' into spi-next
Previously only the resources controlled by the driver were put into
low power state at system suspend. Both the amba bus and a potential
power domain were ignored.
Moreover, while putting the device into low power state we first
brought it back to full power, but for no particular reason.
To handle both issues above, use pm_runtime_force_suspend|resume() from
the system suspend|resume callbacks.
Signed-off-by: Ulf Hansson <ulf.hansson@linaro.org>
Convert to the SET_PM_RUNTIME_PM macro while defining the runtime PM
callbacks. This means the callbacks becomes available for both
CONFIG_PM_SLEEP and CONFIG_PM_RUNTIME, which is needed to handle the
combinations of these scenarios.
Signed-off-by: Axel Lin <axel.lin@ingics.com>
The driver core is now taking care of putting our pins into default
state at probe. Thus we can remove the redundant call for it in probe.
Make use of clk_prepare_enable and clk_disable_unprepare to simplify
code. No functional change.
When the driver was converted to clk_prepare() the suspend path didn't
have any changes made so the clock remains prepared throughout the runtime
of the driver. Unprepare it when suspended so that any savings that can be
made as a result are made.
Change raw printk() call to dev_info() to provide a better message
to userspace so it can properly identify the device.
Use devm_spi_register_master() to make cleanup paths simpler.
The driver core clears the driver data to NULL after device_release
or on probe failure. Thus, it is not needed to manually clear the
device driver data to NULL.
'break' immediately after return has no effect.
Signed-off-by: Sachin Kamat <sachin.kamat@linaro.org>
Use the wrapper function for retrieving the platform data instead of
accessing dev->platform_data directly.
When CONFIG_ARM_LPAE=y the following build warning is generated:
drivers/spi/spi-pl022.c:2178:9: warning: format '%x' expects argument of type 'unsigned int', but argument 2 has type 'resource_size_t' [-Wformat]
According to Documentation/printk-formats.txt '%pa' can be used to properly
print 'resource_size_t'.
Reported-by: Kevin Hilman <khilman@linaro.org>
git://git.kernel.org/pub/scm/linux/kernel/git/linusw/linux-pinctrl
Pull pin control changes from Linus Walleij:
- A large slew of improvements of the Genric pin configuration support,
and deployment in four different platforms: Rockchip, Super-H PFC,
ABx500 and TZ1090. Support BIAS_BUS_HOLD, get device tree parsing
and debugfs support into shape.
- We also have device tree support with generic naming conventions for
the generic pin configuration.
- Delete the unused and confusing direct pinconf API. Now state
transitions is *the* way to control pins and multiplexing.
- New drivers for Rockchip, TZ1090, and TZ1090 PDC.
- Two pin control states related to power management are now handled in
the device core: "sleep" and "idle", removing a lot of boilerplate
code in drivers. We do not yet know if this is the final word for
pin PM, but it already make things a lot easier to handle.
- Handle sparse GPIO ranges passing a list of disparate pins, and
utilize these in the new BayTrail (x86 Atom SoC) driver.
- Make the sunxi (AllWinner) driver handle external interrupts.
- Make it possible for pinctrl-single to handle the case where several
pins are managed by a single register, and augment it to handle sleep
modes.
- Cleanups and improvements for the abx500 drivers.
- Move Sirf pin control drivers to their own directory, support
save/restore of context and add support for the SiRFatlas6 SoC.
- PMU muxing for the Dove pinctrl driver.
- Finalization and support for VF610 in the i.MX6 pinctrl driver.
- Smoothen out various Exynos rough edges.
- Generic cleanups of various kinds.
* tag 'pinctrl-for-v3.11-1' of git://git.kernel.org/pub/scm/linux/kernel/git/linusw/linux-pinctrl: (82 commits)
pinctrl: vt8500: wmt: remove redundant dev_err call in wmt_pinctrl_probe()
pinctrl: remove bindings for pinconf options needing more thought
pinctrl: remove slew-rate parameter from tz1090
pinctrl: set unit for debounce time pinconfig to usec
pinctrl: more clarifications for generic pull configs
pinctrl: rip out the direct pinconf API
pinctrl-tz1090-pdc: add TZ1090 PDC pinctrl driver
pinctrl-tz1090: add TZ1090 pinctrl driver
pinctrl: samsung: Staticize drvdata_list
pinctrl: rockchip: Add missing irq_gc_unlock() call before return error
pinctrl: abx500: rework error path
pinctrl: abx500: suppress hardcoded value
pinctrl: abx500: factorize code
pinctrl: abx500: fix abx500_gpio_get()
pinctrl: abx500: fix abx500_pin_config_set()
pinctrl: abx500: Add device tree support
sh-pfc: Guard DT parsing with #ifdef CONFIG_OF
pinctrl: add Intel BayTrail GPIO/pinctrl support
pinctrl: fix pinconf_ops::pin_config_dbg_parse_modify kerneldoc
pinctrl: Staticize local symbols
drivers/net/ethernet/ti/davinci_mdio.c
drivers/pinctrl/Makefile
Removes the warnings:
drivers/spi/spi-pl022.c: In function 'pl022_suspend_resources':
drivers/spi/spi-pl022.c:2322:24: warning: unused variable 'pins_state' [-Wunused-variable]
drivers/spi/spi-pl022.c:2321:6: warning: unused variable 'ret' [-Wunused-variable]
drivers/spi/spi-pl022.c: In function 'pl022_resume_resources':
drivers/spi/spi-pl022.c:2334:6: warning: unused variable 'ret' [-Wunused-variable]
introduced in:
f1c9cf0 spi: pl022: use pinctrl PM helpers
Signed-off-by: Fabio Baltieri <fabio.baltieri@linaro.org>
Acked-by: Mark Brown <broonie@linaro.org>
In the past we controlled the selection of DMA for a certain
host by a boolean switch in the platform data. Currently
there is no way to enable DMA on a PL022 probed from the
device tree. Let's default to trying to obtain DMA channels
in the DT case, and then we can always fail (and thus fall
back to PIO mode).
This utilize the new pinctrl core PM helpers to transition
the driver to "sleep" and "idle" states, cutting away some
boilerplate code.
Cc: Hebbar Gururaja <gururaja.hebbar@ti.com>
Cc: Dmitry Torokhov <dmitry.torokhov@gmail.com>
Cc: Kevin Hilman <khilman@linaro.org>
Cc: Stephen Warren <swarren@wwwdotorg.org>
Cc: Wolfram Sang <wsa@the-dreams.de>
With the new OF DMA binding, it is possible to completely avoid the
need for platform_data for configuring a DMA channel. In cases where the
platform has already been converted, calling dma_request_slave_channel
should get all the necessary information from the device tree.
Like the patch that converts the dw_dma controller, this is completely
untested and is looking for someone to try it out.
Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
Cc: spi-devel-general@lists.sourceforge.net
Cc: Viresh Kumar <viresh.kumar@linaro.org>
Cc: Andy Shevchenko <andriy.shevchenko@linux.intel.com>
Cc: Vinod Koul <vinod.koul@linux.intel.com>
Cc: devicetree-discuss@lists.ozlabs.org
