should include linux/gpio.h
Signed-off-by: Steven Miao <realmz6@gmail.com>
Signed-off-by: Mark Brown <broonie@linaro.org>
Signed-off-by: Axel Lin <axel.lin@ingics.com>
This checking is already done in the implementation of spi_setup().
User-visible strings are more difficult to grep from sources if they are
separated to multiple source lines. This is worse than over 80 columns long
line code style violation.
Fix this by making those to single-line strings or by breaking them between
variables.
While at there, convert if (printk_ratelimit()) dev_warn() to use
dev_warn_ratelimited in spi-pxa2xx.c.
Signed-off-by: Jarkko Nikula <jarkko.nikula@linux.intel.com>
Subsystems like pinctrl and gpio rightfully make use of deferred probing at
core level. Now, deferred drivers won't be retried if they don't have a .probe
function specified in the driver struct. Fix this driver to have that, so the
devices it supports won't get lost in a deferred probe.
Signed-off-by: Wolfram Sang <wsa@the-dreams.de>
Instead of using legacy suspend/resume methods, using newer
dev_pm_ops structure allows better control over power management.
Signed-off-by: Jingoo Han <jg1.han@samsung.com>
Use the wrapper function for retrieving the platform data instead of
accessing dev->platform_data directly.
Fill in the recently added spi_master.bits_per_word_mask field in as
many drivers as possible. Make related cleanups, such as removing any
redundant error-checking, or empty setup callbacks.
Signed-off-by: Stephen Warren <swarren@wwwdotorg.org>
Acked-by: H Hartley Sweeten <hsweeten@visionengravers.com>
The driver core clears the driver data to NULL after device_release
or on probe failure, since commit 0998d0631001288a5974afc0b2a5f568bcdecb4d
(device-core: Ensure drvdata = NULL when no driver is bound).
Thus, it is not needed to manually clear the device driver data to NULL.
Acked-by: Grant Likely <grant.likely@linaro.org>
Some of the spi driver module remove hooks were annotated with __exit
and referenced with __exit_p(). Presumably these were supposed to be
__devinit, __devexit and __devexit_p() since __init/__exit for a
probe/remove hook has never been correct. They also got missed during
the big __devinit/__devexit purge since they didn't match the pattern.
Remove then now to be rid of it.
v2: purge __init also
[Arnd set a patch cleaning up one, and then I found more]
The spi core make sure that each transfer structure have the proper
setting for bits_per_word before calling low level transfer APIs.
Hence it is no more require to check again in low level driver for
this field whether this is set correct or not. Removing such code
from low level driver.
The txx9 change also removes a test for bits_per_word set to 0, and
forcing it to 8 in that case. This can also be removed now since
spi_setup() ensures spi->bits_per_word is not zero.
if (!spi->bits_per_word)
spi->bits_per_word = 8;
CONFIG_HOTPLUG is going away as an option. As result the __dev*
markings will be going away.
Remove use of __devinit, __devexit_p, __devinitdata, __devinitconst,
and __devexit.
Bill Pemberton has done most of the legwork on this series. I've used
his script to purge the attributes from the drivers/gpio tree.
Reported-by: Bill Pemberton <wfp5p@virginia.edu>
This patch ensures that the last bit of a transfer gets correctly
flushed out of the register.
Signed-off-by: Scott Jiang <scott.jiang.linux@gmail.com>
This condition is used to determine 8 bits or 16 and 32 bits transfer.
Obviously it is reversed.
No other SPI controller has this field, and SPI clients should be setting
this up in their own drivers. So drop it from the Blackfin controller to
keep people from using it.
Since commit [e58aa3d2: genirq: Run irq handlers with interrupts disabled],
We run all interrupt handlers with interrupts disabled
and we even check and yell when an interrupt handler
returns with interrupts enabled (see commit [b738a50a:
genirq: Warn when handler enables interrupts]).
So now this flag is a NOOP and can be removed.
Signed-off-by: Yong Zhang <yong.zhang0@gmail.com>
There's no need for these queue funcs to be inlined, so drop the
markings. This shaves off a few hundred duplicated bytes.
This array isn't written anywhere, so constify it.
Rather than hardcoding the register sizes/offsets in this file, use the
existing struct in the spi header for reading/writing the hardware.
Sort the SPI makefile and enforce the naming convention spi_*.c for
spi drivers.
This change also rolls the contents of atmel_spi.h into the .c file
since there is only one user of that particular include file.
v2: - Use 'spi-' prefix instead of 'spi_' to match what seems to be
be the predominant pattern for subsystem prefixes.
- Clean up filenames in Kconfig and header comment blocks
