path: root/drivers/soundwire
2018-08-27soundwire: Fix acquiring bus lock twice during master releaseSanyog Kale
As part of sdw_stream_remove_master(), sdw_stream_remove_slave() is called which results in bus lock being acquired twice. So, fix it by performing specific Slave remove operations in sdw_release_master_stream() instead of calling sdw_stream_remove_slave(). Signed-off-by: Sanyog Kale <sanyog.r.kale@intel.com> Signed-off-by: Shreyas NC <shreyas.nc@intel.com> Acked-by: Pierre-Louis Bossart <pierre-louis.bossart@linux.intel.com> Signed-off-by: Vinod Koul <vkoul@kernel.org>
2018-08-27soundwire: Fix incorrect exit after configuring streamShreyas NC
In sdw_stream_add_master() after the Master ports are configured, the stream is released incorrectly. So, fix it by avoiding stream release after configuring the Master for the stream. While at it, rename the label appropriately. Signed-off-by: Shreyas NC <shreyas.nc@intel.com> Acked-by: Pierre-Louis Bossart <pierre-louis.bossart@linux.intel.com> Signed-off-by: Vinod Koul <vkoul@kernel.org>
2018-08-27soundwire: Fix duplicate stream state assignmentShreyas NC
For a SoundWire stream it is expected that a Slave is added to the stream before Master is added. So, move the stream state to CONFIGURED after the first Slave is added and remove the stream state assignment for Master add. Along with these changes, add additional comments to explain the same. Signed-off-by: Shreyas NC <shreyas.nc@intel.com> Acked-by: Pierre-Louis Bossart <pierre-louis.bossart@linux.intel.com> Signed-off-by: Vinod Koul <vkoul@kernel.org>
2018-06-15docs: Fix more broken referencesMauro Carvalho Chehab
As we move stuff around, some doc references are broken. Fix some of them via this script: ./scripts/documentation-file-ref-check --fix Manually checked that produced results are valid. Acked-by: Matthias Brugger <matthias.bgg@gmail.com> Acked-by: Takashi Iwai <tiwai@suse.de> Acked-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com> Acked-by: Guenter Roeck <linux@roeck-us.net> Acked-by: Miguel Ojeda <miguel.ojeda.sandonis@gmail.com> Signed-off-by: Mauro Carvalho Chehab <mchehab+samsung@kernel.org> Acked-by: Jonathan Corbet <corbet@lwn.net>
2018-06-05Merge tag 'char-misc-4.18-rc1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/char-misc Pull char/misc driver updates from Greg KH: "Here is the "big" char and misc driver patches for 4.18-rc1. It's not a lot of stuff here, but there are some highlights: - coreboot driver updates - soundwire driver updates - android binder updates - fpga big sync, mostly documentation - lots of minor driver updates All of these have been in linux-next for a while with no reported issues" * tag 'char-misc-4.18-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/char-misc: (81 commits) vmw_balloon: fixing double free when batching mode is off MAINTAINERS: Add driver-api/fpga path fpga: clarify that unregister functions also free documentation: fpga: move fpga-region.txt to driver-api documentation: fpga: add bridge document to driver-api documentation: fpga: move fpga-mgr.txt to driver-api Documentation: fpga: move fpga overview to driver-api fpga: region: kernel-doc fixes fpga: bridge: kernel-doc fixes fpga: mgr: kernel-doc fixes fpga: use SPDX fpga: region: change api, add fpga_region_create/free fpga: bridge: change api, don't use drvdata fpga: manager: change api, don't use drvdata fpga: region: don't use drvdata in common fpga code Drivers: hv: vmbus: Removed an unnecessary cast from void * ver_linux: Drop redundant calls to system() to test if file is readable ver_linux: Move stderr redirection from function parameter to function body misc: IBM Virtual Management Channel Driver (VMC) rpmsg: Correct support for MODULE_DEVICE_TABLE() ...
2018-05-14soundwire: Respect all error codes from dev_pm_domain_attach()Ulf Hansson
The limitation of being able to check only for -EPROBE_DEFER from dev_pm_domain_attach() has been removed. Hence let's respect all error codes and bail out accordingly. Signed-off-by: Ulf Hansson <ulf.hansson@linaro.org> Acked-by: Vinod Koul <vkoul@kernel.org> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2018-05-11soundwire: intel: Add audio DAI opsVinod Koul
Add DAI registration and DAI ops for the Intel driver along with callback for topology configuration. Signed-off-by: Sanyog Kale <sanyog.r.kale@intel.com> Signed-off-by: Shreyas NC <shreyas.nc@intel.com> Signed-off-by: Vinod Koul <vkoul@kernel.org>
2018-05-11soundwire: intel: Add stream initializationVinod Koul
Add Intel stream init routines which initialize the Physical Data Interface (PDI), Audio Link Hub (ALH) and Audio shim. Also add bank switch routines. Signed-off-by: Hardik T Shah <hardik.t.shah@intel.com> Signed-off-by: Sanyog Kale <sanyog.r.kale@intel.com> Signed-off-by: Shreyas NC <shreyas.nc@intel.com> Signed-off-by: Vinod Koul <vkoul@kernel.org>
2018-05-11soundwire: cdns: Add stream routinesVinod Koul
Add support for Cadence stream initialization and implement stream APIs. Signed-off-by: Sanyog Kale <sanyog.r.kale@intel.com> Signed-off-by: Shreyas NC <shreyas.nc@intel.com> Signed-off-by: Vinod Koul <vkoul@kernel.org>
2018-05-11soundwire: cdns: Add port routinesVinod Koul
Add support for Cadence port management and implement master port ops. Signed-off-by: Sanyog Kale <sanyog.r.kale@intel.com> Signed-off-by: Shreyas NC <shreyas.nc@intel.com> Signed-off-by: Vinod Koul <vkoul@kernel.org>
2018-05-11soundwire: Remove cdns_master_opsShreyas NC
There can be instances where drivers using Cadence IP might want to set sdw_master_ops differently per instance of it's use, so remove the cdns_master_ops and export the APIs. Signed-off-by: Shreyas NC <shreyas.nc@intel.com> Signed-off-by: Vinod Koul <vkoul@kernel.org>
2018-05-11soundwire: Add stream configuration APIsSanyog Kale
Add APIs for prepare, enable, disable and de-prepare stream. Signed-off-by: Sanyog Kale <sanyog.r.kale@intel.com> Signed-off-by: Shreyas NC <shreyas.nc@intel.com> Signed-off-by: Vinod Koul <vkoul@kernel.org>
2018-05-11soundwire: Add bank switch routineSanyog Kale
SoundWire supports two registers banks. So, program the alternate bank with new configuration and then performs bank switch. Signed-off-by: Sanyog Kale <sanyog.r.kale@intel.com> Signed-off-by: Shreyas NC <shreyas.nc@intel.com> Signed-off-by: Vinod Koul <vkoul@kernel.org>
2018-05-11soundwire: Add helpers for ports operationsSanyog Kale
Add helpers to configure, prepare, enable, disable and de-prepare ports. Signed-off-by: Sanyog Kale <sanyog.r.kale@intel.com> Signed-off-by: Shreyas NC <shreyas.nc@intel.com> Signed-off-by: Vinod Koul <vkoul@kernel.org>
2018-05-11soundwire: Add Master and Slave port programmingSanyog Kale
Master and Slave port registers need to be programmed for each port used in a stream. Add the helpers for port register programming. Signed-off-by: Sanyog Kale <sanyog.r.kale@intel.com> Signed-off-by: Shreyas NC <shreyas.nc@intel.com> Signed-off-by: Vinod Koul <vkoul@kernel.org>
2018-05-11soundwire: Add support for port managementSanyog Kale
Add Soundwire port data structures and APIS for initialization and release of ports. Signed-off-by: Sanyog Kale <sanyog.r.kale@intel.com> Signed-off-by: Shreyas NC <shreyas.nc@intel.com> Signed-off-by: Vinod Koul <vkoul@kernel.org>
2018-05-11soundwire: Add support for SoundWire stream managementSanyog Kale
This patch adds APIs and relevant stream data structures for initialization and release of stream. Signed-off-by: Hardik T Shah <hardik.t.shah@intel.com> Signed-off-by: Sanyog Kale <sanyog.r.kale@intel.com> Signed-off-by: Shreyas NC <shreyas.nc@intel.com> Signed-off-by: Vinod Koul <vkoul@kernel.org>
2018-01-22soundwire: Fix a signedness bugDan Carpenter
"ret" is an int and "buf" is a u8. sdw_read() returns negative error codes which are truncated to the u8, 0-255 range before being stored as an int. It means that "ret" can't be less than zero. Fixes: b0a9c37b0178 ("soundwire: Add slave status handling") Signed-off-by: Dan Carpenter <dan.carpenter@oracle.com> Signed-off-by: Vinod Koul <vinod.koul@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-01-09soundwire: select REGMAP_SOUNDWIREVinod Koul
SoundWire bus needs to select the regmap support. So, add it Signed-off-by: Vinod Koul <vinod.koul@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-01-09soundwire: Fix incorrect return value checkShreyas NC
pm_runtime_get_sync will return negative values for error and 0 or 1 for success. Update the error check accordingly. Signed-off-by: Shreyas NC <shreyas.nc@intel.com> Reported-by: Dan Carpenter <dan.carpenter@oracle.com> Fixes: 9d715fa005eb: ("soundwire: Add IO transfer") Signed-off-by: Vinod Koul <vinod.koul@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-01-08soundwire: Fix typo in return value check of sdw_read()Wei Yongjun
Fix the typo, 'status' should be instead of 'status2'. Fixes: b0a9c37b0178 ("soundwire: Add slave status handling") Signed-off-by: Wei Yongjun <weiyongjun1@huawei.com> Acked-by: Pierre-Louis Bossart <pierre-louis.bossart@linux.intel.com> Acked-by: Vinod Koul <vinod.koul@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-01-08soundwire: intel: fix missing assignment to retColin Ian King
Currently the return status ret is being checked but it has not been updated since the previous check on ret. It appears that assignment of ret from return status of the call to sdw_cdns_enable_interrupt was accidentally ommited. Fix this. Detected by CoverityScan, CID#1463148 ("Logically dead code") Fixes: 71bb8a1b059e ("soundwire: intel: Add Intel Master driver") Signed-off-by: Colin Ian King <colin.king@canonical.com> Acked-by: Vinod Koul <vinod.koul@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-01-08soundwire: fix sign extension when shifting buf[2] 24 placesColin Ian King
The buf[2] left shift by 24 bits is promoted to int (32 bit signed) and then signed-extended to unsigned long long. Hence if the upper bit to buf[2] is set then all the upper bits of addr end up as 1. Fix this by casting it to u64 before shifting it. Also replace the unsigned long long casts to u64 casts to match the same type of addr. Detected by CoverityScan, CID#1463147 ("Unintended sign extension") Fixes: d52d7a1be02c ("soundwire: Add Slave status handling helpers") Signed-off-by: Colin Ian King <colin.king@canonical.com> Acked-by: Vinod Koul <vinod.koul@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-12-19soundwire: intel: Add Intel init moduleVinod Koul
The SoundWire Master is implemented as part of Audio controller in Intel platforms. Add a init module which creates SoundWire Master platform devices based on the links supported in the hardware. Signed-off-by: Sanyog Kale <sanyog.r.kale@intel.com> Reviewed-by: Philippe Ombredanne <pombredanne@nexb.com> Acked-By: Pierre-Louis Bossart <pierre-louis.bossart@linux.intel.com> Reviewed-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Vinod Koul <vinod.koul@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-12-19soundwire: intel: Add Intel Master driverVinod Koul
Some Intel platforms have SoundWire Master, so add Intel SoundWire Master driver which uses Cadence module. This patch adds probe and initialization routines for Intel Master driver. Signed-off-by: Hardik T Shah <hardik.t.shah@intel.com> Signed-off-by: Sanyog Kale <sanyog.r.kale@intel.com> Reviewed-by: Philippe Ombredanne <pombredanne@nexb.com> Acked-By: Pierre-Louis Bossart <pierre-louis.bossart@linux.intel.com> Reviewed-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Vinod Koul <vinod.koul@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-12-19soundwire: cdns: Add sdw_master_ops and IO transfer supportSanyog Kale
Implement sdw_master_ops with support for xfer_msg, xfer_msg_defer and reset_page_addr. Since Cadence module doesn't know the systems it will be used, set the read_prop to the bus helper. Signed-off-by: Hardik T Shah <hardik.t.shah@intel.com> Signed-off-by: Sanyog Kale <sanyog.r.kale@intel.com> Reviewed-by: Philippe Ombredanne <pombredanne@nexb.com> Acked-By: Pierre-Louis Bossart <pierre-louis.bossart@linux.intel.com> Reviewed-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Vinod Koul <vinod.koul@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-12-19soundwire: cdns: Add cadence libraryVinod Koul
Cadence IP implements SoundWire Master. Add base cadence library initialization and interrupt handling Signed-off-by: Hardik T Shah <hardik.t.shah@intel.com> Signed-off-by: Sanyog Kale <sanyog.r.kale@intel.com> Reviewed-by: Philippe Ombredanne <pombredanne@nexb.com> Acked-By: Pierre-Louis Bossart <pierre-louis.bossart@linux.intel.com> Reviewed-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Vinod Koul <vinod.koul@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-12-19soundwire: Add slave status handlingVinod Koul
Add status handling API sdw_handle_slave_status() to handle Slave status changes. Signed-off-by: Hardik T Shah <hardik.t.shah@intel.com> Signed-off-by: Sanyog Kale <sanyog.r.kale@intel.com> Reviewed-by: Philippe Ombredanne <pombredanne@nexb.com> Acked-By: Pierre-Louis Bossart <pierre-louis.bossart@linux.intel.com> Reviewed-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Vinod Koul <vinod.koul@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-12-19soundwire: Add Slave status handling helpersSanyog Kale
SoundWire Slaves report status to bus. Add helpers to handle the status changes. Signed-off-by: Hardik T Shah <hardik.t.shah@intel.com> Signed-off-by: Sanyog Kale <sanyog.r.kale@intel.com> Reviewed-by: Philippe Ombredanne <pombredanne@nexb.com> Acked-By: Pierre-Louis Bossart <pierre-louis.bossart@linux.intel.com> Reviewed-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Vinod Koul <vinod.koul@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-12-19soundwire: Add IO transferVinod Koul
SoundWire bus supports read or write register(s) for SoundWire Slave device. sdw_read() and sdw_write() APIs are provided for single register read/write. sdw_nread() and sdw_nwrite() for operations on contiguous registers. Signed-off-by: Sanyog Kale <sanyog.r.kale@intel.com> Reviewed-by: Philippe Ombredanne <pombredanne@nexb.com> Acked-By: Pierre-Louis Bossart <pierre-louis.bossart@linux.intel.com> Reviewed-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Vinod Koul <vinod.koul@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-12-19soundwire: Add MIPI DisCo property helpersVinod Koul
MIPI Discovery And Configuration (DisCo) Specification for SoundWire specifies properties to be implemented for SoundWire Masters and Slaves. The DisCo spec doesn't mandate these properties. However, SDW bus cannot work without knowing these values. The helper functions read the Master and Slave properties. Implementers of Master or Slave drivers can use any of the below three mechanisms: a) Use these APIs here as .read_prop() callback for Master and Slave b) Implement own methods and set those as .read_prop(), but invoke APIs in this file for generic read and override the values with platform specific data c) Implement ones own methods which do not use anything provided here Signed-off-by: Sanyog Kale <sanyog.r.kale@intel.com> Reviewed-by: Philippe Ombredanne <pombredanne@nexb.com> Acked-By: Pierre-Louis Bossart <pierre-louis.bossart@linux.intel.com> Reviewed-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Vinod Koul <vinod.koul@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-12-19soundwire: Add Master registrationVinod Koul
A Master adds a SoundWire bus instance which scans the firmware provided for device description. In this patch we scan ACPI namespaces and create SoundWire Slave devices based on ACPI description Signed-off-by: Sanyog Kale <sanyog.r.kale@intel.com> Reviewed-by: Philippe Ombredanne <pombredanne@nexb.com> Acked-By: Pierre-Louis Bossart <pierre-louis.bossart@linux.intel.com> Reviewed-by: Takashi Iwai <tiwai@suse.de> Acked-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Signed-off-by: Vinod Koul <vinod.koul@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-12-19soundwire: Add SoundWire bus typeVinod Koul
This adds the base SoundWire bus type, bus and driver registration. along with changes to module device table for new SoundWire device type. Signed-off-by: Sanyog Kale <sanyog.r.kale@intel.com> Reviewed-by: Philippe Ombredanne <pombredanne@nexb.com> Acked-By: Pierre-Louis Bossart <pierre-louis.bossart@linux.intel.com> Reviewed-by: Takashi Iwai <tiwai@suse.de> Acked-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Signed-off-by: Vinod Koul <vinod.koul@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
