path: root/drivers/soc
2014-12-15Merge branch 'drm-next' of git://people.freedesktop.org/~airlied/linuxLinus Torvalds
Pull drm updates from Dave Airlie: "Highlights: - AMD KFD driver merge This is the AMD HSA interface for exposing a lowlevel interface for GPGPU use. They have an open source userspace built on top of this interface, and the code looks as good as it was going to get out of tree. - Initial atomic modesetting work The need for an atomic modesetting interface to allow userspace to try and send a complete set of modesetting state to the driver has arisen, and been suffering from neglect this past year. No more, the start of the common code and changes for msm driver to use it are in this tree. Ongoing work to get the userspace ioctl finished and the code clean will probably wait until next kernel. - DisplayID 1.3 and tiled monitor exposed to userspace. Tiled monitor property is now exposed for userspace to make use of. - Rockchip drm driver merged. - imx gpu driver moved out of staging Other stuff: - core: panel - MIPI DSI + new panels. expose suggested x/y properties for virtual GPUs - i915: Initial Skylake (SKL) support gen3/4 reset work start of dri1/ums removal infoframe tracking fixes for lots of things. - nouveau: tegra k1 voltage support GM204 modesetting support GT21x memory reclocking work - radeon: CI dpm fixes GPUVM improvements Initial DPM fan control - rcar-du: HDMI support added removed some support for old boards slave encoder driver for Analog Devices adv7511 - exynos: Exynos4415 SoC support - msm: a4xx gpu support atomic helper conversion - tegra: iommu support universal plane support ganged-mode DSI support - sti: HDMI i2c improvements - vmwgfx: some late fixes. - qxl: use suggested x/y properties" * 'drm-next' of git://people.freedesktop.org/~airlied/linux: (969 commits) drm: sti: fix module compilation issue drm/i915: save/restore GMBUS freq across suspend/resume on gen4 drm: sti: correctly cleanup CRTC and planes drm: sti: add HQVDP plane drm: sti: add cursor plane drm: sti: enable auxiliary CRTC drm: sti: fix delay in VTG programming drm: sti: prepare sti_tvout to support auxiliary crtc drm: sti: use drm_crtc_vblank_{on/off} instead of drm_vblank_{on/off} drm: sti: fix hdmi avi infoframe drm: sti: remove event lock while disabling vblank drm: sti: simplify gdp code drm: sti: clear all mixer control drm: sti: remove gpio for HDMI hot plug detection drm: sti: allow to change hdmi ddc i2c adapter drm/doc: Document drm_add_modes_noedid() usage drm/i915: Remove '& 0xffff' from the mask given to WA_REG() drm/i915: Invert the mask and val arguments in wa_add() and WA_REG() drm: Zero out DRM object memory upon cleanup drm/i915/bdw: Fix the write setting up the WIZ hashing mode ...
2014-12-14Merge tag 'driver-core-3.19-rc1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core Pull driver core update from Greg KH: "Here's the set of driver core patches for 3.19-rc1. They are dominated by the removal of the .owner field in platform drivers. They touch a lot of files, but they are "simple" changes, just removing a line in a structure. Other than that, a few minor driver core and debugfs changes. There are some ath9k patches coming in through this tree that have been acked by the wireless maintainers as they relied on the debugfs changes. Everything has been in linux-next for a while" * tag 'driver-core-3.19-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core: (324 commits) Revert "ath: ath9k: use debugfs_create_devm_seqfile() helper for seq_file entries" fs: debugfs: add forward declaration for struct device type firmware class: Deletion of an unnecessary check before the function call "vunmap" firmware loader: fix hung task warning dump devcoredump: provide a one-way disable function device: Add dev_<level>_once variants ath: ath9k: use debugfs_create_devm_seqfile() helper for seq_file entries ath: use seq_file api for ath9k debugfs files debugfs: add helper function to create device related seq_file drivers/base: cacheinfo: remove noisy error boot message Revert "core: platform: add warning if driver has no owner" drivers: base: support cpu cache information interface to userspace via sysfs drivers: base: add cpu_device_create to support per-cpu devices topology: replace custom attribute macros with standard DEVICE_ATTR* cpumask: factor out show_cpumap into separate helper function driver core: Fix unbalanced device reference in drivers_probe driver core: fix race with userland in device_add() sysfs/kernfs: make read requests on pre-alloc files use the buffer. sysfs/kernfs: allow attributes to request write buffer be pre-allocated. fs: sysfs: return EGBIG on write if offset is larger than file size ...
2014-12-09Merge tag 'drivers-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc Pull ARM SoC driver updates from Arnd Bergmann: "These are changes for drivers that are intimately tied to some SoC and for some reason could not get merged through the respective subsystem maintainer tree. The largest single change here this time around is the Tegra iommu/memory controller driver, which gets updated to the new iommu DT binding. More drivers like this are likely to follow for the following merge window, but we should be able to do those through the iommu maintainer. Other notable changes are: - reset controller drivers from the reset maintainer (socfpga, sti, berlin) - fixes for the keystone navigator driver merged last time - at91 rtc driver changes related to the at91 cleanups - ARM perf driver changes from Will Deacon - updates for the brcmstb_gisb driver" * tag 'drivers-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (53 commits) clocksource: arch_timer: Allow the device tree to specify uninitialized timer registers clocksource: arch_timer: Fix code to use physical timers when requested memory: Add NVIDIA Tegra memory controller support bus: brcmstb_gisb: Add register offset tables for older chips bus: brcmstb_gisb: Look up register offsets in a table bus: brcmstb_gisb: Introduce wrapper functions for MMIO accesses bus: brcmstb_gisb: Make the driver buildable on MIPS of: Add NVIDIA Tegra memory controller binding ARM: tegra: Move AHB Kconfig to drivers/amba amba: Add Kconfig file clk: tegra: Implement memory-controller clock serial: samsung: Fix serial config dependencies for exynos7 bus: brcmstb_gisb: resolve section mismatch ARM: common: edma: edma_pm_resume may be unused ARM: common: edma: add suspend resume hook powerpc/iommu: Rename iommu_[un]map_sg functions rtc: at91sam9: add DT bindings documentation rtc: at91sam9: use clk API instead of relying on AT91_SLOW_CLOCK ARM: at91: add clk_lookup entry for RTT devices rtc: at91sam9: rework the Kconfig description ...
2014-12-09Merge tag 'soc-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc Pull ARM SoC platform changes from Arnd Bergmann: "New and updated SoC support, notable changes include: - bcm: brcmstb SMP support initial iproc/cygnus support - exynos: Exynos4415 SoC support PMU and suspend support for Exynos5420 PMU support for Exynos3250 pm related maintenance - imx: new LS1021A SoC support vybrid 610 global timer support - integrator: convert to using multiplatform configuration - mediatek: earlyprintk support for mt8127/mt8135 - meson: meson8 soc and l2 cache controller support - mvebu: Armada 38x CPU hotplug support drop support for prerelease Armada 375 Z1 stepping extended suspend support, now works on Armada 370/XP - omap: hwmod related maintenance prcm cleanup - pxa: initial pxa27x DT handling - rockchip: SMP support for rk3288 add cpu frequency scaling support - shmobile: r8a7740 power domain support various small restart, timer, pci apmu changes - sunxi: Allwinner A80 (sun9i) earlyprintk support - ux500: power domain support Overall, a significant chunk of changes, coming mostly from the usual suspects: omap, shmobile, samsung and mvebu, all of which already contain a lot of platform specific code in arch/arm" * tag 'soc-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (187 commits) ARM: mvebu: use the cpufreq-dt platform_data for independent clocks soc: integrator: Add terminating entry for integrator_cm_match ARM: mvebu: add SDRAM controller description for Armada XP ARM: mvebu: adjust mbus controller description on Armada 370/XP ARM: mvebu: add suspend/resume DT information for Armada XP GP ARM: mvebu: synchronize secondary CPU clocks on resume ARM: mvebu: make sure MMU is disabled in armada_370_xp_cpu_resume ARM: mvebu: Armada XP GP specific suspend/resume code ARM: mvebu: reserve the first 10 KB of each memory bank for suspend/resume ARM: mvebu: implement suspend/resume support for Armada XP clk: mvebu: add suspend/resume for gatable clocks bus: mvebu-mbus: provide a mechanism to save SDRAM window configuration bus: mvebu-mbus: suspend/resume support clocksource: time-armada-370-xp: add suspend/resume support irqchip: armada-370-xp: Add suspend/resume support ARM: add lolevel debug support for asm9260 ARM: add mach-asm9260 ARM: EXYNOS: use u8 for val[] in struct exynos_pmu_conf power: reset: imx-snvs-poweroff: add power off driver for i.mx6 ARM: imx: temporarily remove CONFIG_SOC_FSL from LS1021A ...
2014-12-04soc: integrator: Add terminating entry for integrator_cm_matchAxel Lin
The of_device_id table is supposed to be zero-terminated. Signed-off-by: Axel Lin <axel.lin@ingics.com> Acked-by: Linus Walleij <linus.walleij@linaro.org> Signed-off-by: Arnd Bergmann <arnd@arndb.de>
2014-12-02soc/tegra: fuse: export tegra_sku_infoVince Hsu
Some Tegra drivers might be compiled as kernel modules, and they need the fuse information for initialization. One example is the GK20A Nouveau driver. It needs the GPU speedo value to calculate frequency-voltage table. So export the tegra_sku_info. Signed-off-by: Vince Hsu <vinceh@nvidia.com> Acked-by: Alexandre Courbot <acourbot@nvidia.com> Acked-by: Thierry Reding <treding@nvidia.com> Signed-off-by: Ben Skeggs <bskeggs@redhat.com>
2014-11-13soc: move SoC driver for the ARM IntegratorLinus Walleij
This creates a new SoC bus driver for the ARM Integrator family core modules to register the SoC bus and provide sysfs info for the core module. We delete the corresponding code from the Integrator machine and select this driver to get a clean result. Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2014-11-03soc: ti: knav_qmss_queue: Use list_for_each_entry_safe to prevent use after freeAxel Lin
list_for_each_entry_safe() is necessary if list objects are deleted from the list while traversing it. Signed-off-by: Axel Lin <axel.lin@ingics.com> Signed-off-by: Santosh Shilimkar <ssantosh@kernel.org>
2014-10-28soc: versatile: Add terminating entry for realview_soc_of_matchAxel Lin
2014-10-27soc: ti: knav_qmss_queue: Return proper error if devm_kzalloc failsAxel Lin
Return -ENOMEM if devm_kzalloc fails. Signed-off-by: Axel Lin <axel.lin@ingics.com> Signed-off-by: Santosh Shilimkar <ssantosh@kernel.org>
2014-10-27soc: ti: knav_qmss_queue: Fix unbalanced locking ins knav_pool_create()Axel Lin
Don't call mutex_unlock() in the error patch if the mutex_lock() is not called. Signed-off-by: Axel Lin <axel.lin@ingics.com> Signed-off-by: Santosh Shilimkar <ssantosh@kernel.org>
2014-10-27soc: ti: Use list_first_entry_or_null() at appropriate placesAxel Lin
Use list_first_entry_or_null() for first_region() and first_queue_range(). list_first_entry() expects the list is not empty, so first_region() and first_queue_range() never return NULL. Thus use list_first_entry_or_null() instead. Signed-off-by: Axel Lin <axel.lin@ingics.com> Signed-off-by: Santosh Shilimkar <ssantosh@kernel.org>
2014-10-20soc: ti: drop owner assignment from platform_driversWolfram Sang
A platform_driver does not need to set an owner, it will be populated by the driver core. Signed-off-by: Wolfram Sang <wsa@the-dreams.de>
2014-10-20soc: tegra: fuse: drop owner assignment from platform_driversWolfram Sang
2014-10-20soc: qcom: drop owner assignment from platform_driversWolfram Sang
2014-10-08Merge tag 'drivers-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc Pull ARM SoC driver updates from Arnd Bergmann: "These are changes for drivers that are intimately tied to some SoC and for some reason could not get merged through the respective subsystem maintainer tree. Most of the new code is for the Keystone Navigator driver, which is new base support that is going to be needed for their hardware accelerated network driver and other units. Most of the commits are for moving old code around from at91 and omap for things that are done in device drivers nowadays. - at91: move reset, poweroff, memory and clocksource code into drivers directories - socfpga: add edac driver (through arm-soc, as requested by Boris) - omap: move omap-intc code to drivers/irqchip - sunxi: added an RTC driver for sun6i - omap: mailbox driver related changes - keystone: support for the "Navigator" component - versatile: new reboot, led and soc drivers" * tag 'drivers-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (92 commits) bus: arm-ccn: Fix spurious warning message leds: add device tree bindings for register bit LEDs soc: add driver for the ARM RealView power: reset: driver for the Versatile syscon reboot leds: add a driver for syscon-based LEDs drivers/soc: ti: fix build break with modules MAINTAINERS: Add Keystone Multicore Navigator drivers entry soc: ti: add Keystone Navigator DMA support Documentation: dt: soc: add Keystone Navigator DMA bindings soc: ti: add Keystone Navigator QMSS driver Documentation: dt: soc: add Keystone Navigator QMSS bindings rtc: sunxi: Depend on platforms sun4i/sun7i that actually have the rtc rtc: sun6i: Add sun6i RTC driver irqchip: omap-intc: remove unnecessary comments irqchip: omap-intc: correct maximum number or MIR registers irqchip: omap-intc: enable TURBO idle mode irqchip: omap-intc: enable IP protection irqchip: omap-intc: remove unnecesary of_address_to_resource() call irqchip: omap-intc: comment style cleanup irqchip: omap-intc: minor improvement to omap_irq_pending() ...
2014-09-26soc: add driver for the ARM RealViewLinus Walleij
This adds a SoC driver to be used by the ARM RealView reference boards. We create the "versatile" directory to hold the different ARM reference designs as per the pattern of the clk directory layout. The driver utilze the syscon to get to the register needed. After this we can use sysfs to get at some SoC properties on RealView DT variants like this: > cd /sysbus/soc/devices/soc0 > ls board family machine power subsystem build fpga manufacturer soc_id uevent > cat family Versatile > cat fpga Multi-layer AXI > cat board HBI-0147 > cat build 03 Signed-off-by: Linus Walleij <linus.walleij@linaro.org> Signed-off-by: Arnd Bergmann <arnd@arndb.de> Conflicts: drivers/soc/Kconfig drivers/soc/Makefile
2014-09-24soc: ti: add Keystone Navigator DMA supportSantosh Shilimkar
The Keystone Navigator DMA driver sets up the dma channels and flows for the QMSS(Queue Manager SubSystem) who triggers the actual data movements across clients using destination queues. Every client modules like NETCP(Network Coprocessor), SRIO(Serial Rapid IO) and CRYPTO Engines has its own instance of packet dma hardware. QMSS has also an internal packet DMA module which is used as an infrastructure DMA with zero copy. Initially this driver was proposed as DMA engine driver but since the hardware is not typical DMA engine and hence doesn't comply with typical DMA engine driver needs, that approach was naked. Link to that discussion - https://lkml.org/lkml/2014/3/18/340 As aligned, now we pair the Navigator DMA with its companion Navigator QMSS subsystem driver. Cc: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Cc: Kumar Gala <galak@codeaurora.org> Cc: Olof Johansson <olof@lixom.net> Cc: Arnd Bergmann <arnd@arndb.de> Cc: Grant Likely <grant.likely@linaro.org> Cc: Rob Herring <robh+dt@kernel.org> Cc: Mark Rutland <mark.rutland@arm.com> Signed-off-by: Sandeep Nair <sandeep_n@ti.com> Signed-off-by: Santosh Shilimkar <santosh.shilimkar@ti.com>
2014-09-24soc: ti: add Keystone Navigator QMSS driverSandeep Nair
The QMSS (Queue Manager Sub System) found on Keystone SOCs is one of the main hardware sub system which forms the backbone of the Keystone Multi-core Navigator. QMSS consist of queue managers, packed-data structure processors(PDSP), linking RAM, descriptor pools and infrastructure Packet DMA. The Queue Manager is a hardware module that is responsible for accelerating management of the packet queues. Packets are queued/de-queued by writing or reading descriptor address to a particular memory mapped location. The PDSPs perform QMSS related functions like accumulation, QoS, or event management. Linking RAM registers are used to link the descriptors which are stored in descriptor RAM. Descriptor RAM is configurable as internal or external memory. The QMSS driver manages the PDSP setups, linking RAM regions, queue pool management (allocation, push, pop and notify) and descriptor pool management. The specifics on the device tree bindings for QMSS can be found in: Documentation/devicetree/bindings/soc/keystone-navigator-qmss.txt Cc: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Cc: Kumar Gala <galak@codeaurora.org> Cc: Olof Johansson <olof@lixom.net> Cc: Arnd Bergmann <arnd@arndb.de> Cc: Grant Likely <grant.likely@linaro.org> Cc: Rob Herring <robh+dt@kernel.org> Cc: Mark Rutland <mark.rutland@arm.com> Signed-off-by: Sandeep Nair <sandeep_n@ti.com> Signed-off-by: Santosh Shilimkar <santosh.shilimkar@ti.com>
2014-09-23drivers/soc: qcom: do not disable the iface clock in probeSrinivas Kandagatla
since commit 31964ffebbb9 ("tty: serial: msm: Remove direct access to GSBI")' serial hangs if earlyprintk are enabled. This hang is noticed only when the GSBI driver is probed and all the earlyprintks before gsbi probe are seen on the console. The reason why it hangs is because GSBI driver disables hclk in its probe function without realizing that the serial IP might be in use by a bootconsole. As gsbi driver disables the clock in probe the bootconsole locks up. Turning off hclk's could be dangerous if there are system components like earlyprintk using the hclk. This patch fixes the issue by delegating the clock management to probe and remove functions in gsbi rather than disabling the clock in probe. More detailed problem description can be found here: http://www.spinics.net/lists/linux-arm-msm/msg10589.html Tested-by: Linus Walleij <linus.walleij@linaro.org> Signed-off-by: Srinivas Kandagatla <srinivas.kandagatla@linaro.org> Signed-off-by: Olof Johansson <olof@lixom.net>
2014-07-17ARM: tegra: Convert PMC to a driverThierry Reding
This commit converts the PMC support code to a platform driver. Because the boot process needs to call into this driver very early, also set up a minimal environment via an early initcall. Signed-off-by: Thierry Reding <treding@nvidia.com>
2014-07-17soc/tegra: fuse: Set up in early initcallThierry Reding
Rather than rely on explicit initialization order called from SoC setup code, use a plain initcall and rely on initcall ordering to take care of dependencies. This driver exposes some functionality (querying the chip ID) needed at very early stages of the boot process. An early initcall is good enough provided that some of the dependencies are deferred to later stages. To make sure any abuses are easily caught, output a warning message if the chip ID is queried while it can't be read yet. Signed-off-by: Thierry Reding <treding@nvidia.com>
2014-07-17soc/tegra: Implement runtime check for Tegra SoCsThierry Reding
Subsequent patches will move some of the initialization code from SoC setup code to regular initcalls. To prevent breakage on other SoCs in multi-platform builds, these initcalls need to check that they indeed run on Tegra. Signed-off-by: Thierry Reding <treding@nvidia.com>
2014-07-17soc/tegra: fuse: fix dummy functionsStephen Warren
The Tegra fuse header's dummy functions for the case where Tegra20 is disabled are inconsistent with the correct prototypes, and have some syntax errors. Fix these. While at it, fix the indentation level of the dummy function bodies. Fixes: 783c8f4c8445 ("soc/tegra: Add efuse driver for Tegra") Cc: Peter De Schrijver <pdeschrijver@nvidia.com> Signed-off-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Thierry Reding <treding@nvidia.com>
2014-07-17soc/tegra: fuse: move APB DMA into Tegra20 fuse driverPeter De Schrijver
The Tegra20 fuse driver is the only user of tegra_apb_readl_using_dma(). Therefore we can simply the code by incorporating the APB DMA handling into the driver directly. tegra_apb_writel_using_dma() is dropped because there are no users. Signed-off-by: Peter De Schrijver <pdeschrijver@nvidia.com> Signed-off-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Thierry Reding <treding@nvidia.com>
2014-07-17soc/tegra: Add efuse driver for TegraPeter De Schrijver
Implement fuse driver for Tegra20, Tegra30, Tegra114 and Tegra124. This replaces functionality previously provided in arch/arm/mach-tegra, which is removed in this patch. While at it, move the only user of the global tegra_revision variable over to tegra_sku_info.revision and export tegra_fuse_readl() to allow drivers to read calibration fuses. Signed-off-by: Peter De Schrijver <pdeschrijver@nvidia.com> Signed-off-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Thierry Reding <treding@nvidia.com>
2014-05-26soc: qcom: fix of_device_id tableArnd Bergmann
The match tables must be zero-terminated, and Kbuild now helpfully fails to link the kernel if that isn't the case. Signed-off-by: Arnd Bergmann <arnd@arndb.de>
2014-05-23soc: qcom: Add GSBI driverAndy Gross
The GSBI (General Serial Bus Interface) driver controls the overarching configuration of the shared serial bus infrastructure on APQ8064, IPQ8064, and earlier QCOM processors. The GSBI supports UART, I2C, SPI, and UIM functionality in various combinations. Signed-off-by: Andy Gross <agross@codeaurora.org> Signed-off-by: Kumar Gala <galak@codeaurora.org>
2014-05-23soc: Introduce drivers/soc place-holder for SOC specific driversSantosh Shilimkar
Based on earlier thread "https://lkml.org/lkml/2013/10/7/662" and discussion at Kernel Summit'2013, it was agreed to create 'driver/soc' for drivers which are quite SOC specific. Further discussion on the subject is in response to the earlier version of the patch is here: http://lwn.net/Articles/588942/ Cc: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Cc: Kumar Gala <galak@codeaurora.org> Cc: Paul Walmsley <paul@pwsan.com> Cc: Olof Johansson <olof@lixom.net> Cc: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Sandeep Nair <sandeep_n@ti.com> Signed-off-by: Santosh Shilimkar <santosh.shilimkar@ti.com> Signed-off-by: Kumar Gala <galak@codeaurora.org>
