path: root/drivers/soc/tegra
2015-07-02Merge tag 'module-builtin_driver-v4.1-rc8' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/paulg/linux Pull module_platform_driver replacement from Paul Gortmaker: "Replace module_platform_driver with builtin_platform driver in non modules. We see an increasing number of non-modular drivers using modular_driver() type register functions. There are several downsides to letting this continue unchecked: - The code can appear modular to a reader of the code, and they won't know if the code really is modular without checking the Makefile and Kconfig to see if compilation is governed by a bool or tristate. - Coders of drivers may be tempted to code up an __exit function that is never used, just in order to satisfy the required three args of the modular registration function. - Non-modular code ends up including the <module.h> which increases CPP overhead that they don't need. - It hinders us from performing better separation of the module init code and the generic init code. So here we introduce similar macros for builtin drivers. Then we convert builtin drivers (controlled by a bool Kconfig) by making the following type of mapping: module_platform_driver() ---> builtin_platform_driver() module_platform_driver_probe() ---> builtin_platform_driver_probe(). The set of drivers that are converted here are just the ones that showed up as relying on an implicit include of <module.h> during a pending header cleanup. So we convert them here vs adding an include of <module.h> to non-modular code to avoid compile fails. Additonal conversions can be done asynchronously at any time. Once again, an unused module_exit function that is removed here appears in the diffstat as an outlier wrt all the other changes" * tag 'module-builtin_driver-v4.1-rc8' of git://git.kernel.org/pub/scm/linux/kernel/git/paulg/linux: drivers/clk: convert sunxi/clk-mod0.c to use builtin_platform_driver drivers/power: Convert non-modular syscon-reboot to use builtin_platform_driver drivers/soc: Convert non-modular soc-realview to use builtin_platform_driver drivers/soc: Convert non-modular tegra/pmc to use builtin_platform_driver drivers/cpufreq: Convert non-modular s5pv210-cpufreq.c to use builtin_platform_driver drivers/cpuidle: Convert non-modular drivers to use builtin_platform_driver drivers/platform: Convert non-modular pdev_bus to use builtin_platform_driver platform_device: better support builtin boilerplate avoidance
2015-06-26Merge tag 'armsoc-drivers' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc Pull ARM SoC driver updates from Kevin Hilman: "Some of these are for drivers/soc, where we're now putting SoC-specific drivers these days. Some are for other driver subsystems where we have received acks from the appropriate maintainers. Some highlights: - simple-mfd: document DT bindings and misc updates - migrate mach-berlin to simple-mfd for clock, pinctrl and reset - memory: support for Tegra132 SoC - memory: introduce tegra EMC driver for scaling memory frequency - misc. updates for ARM CCI and CCN busses" * tag 'armsoc-drivers' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (48 commits) drivers: soc: sunxi: Introduce SoC driver to map SRAMs arm-cci: Add aliases for PMU events arm-cci: Add CCI-500 PMU support arm-cci: Sanitise CCI400 PMU driver specific code arm-cci: Abstract handling for CCI events arm-cci: Abstract out the PMU counter details arm-cci: Cleanup PMU driver code arm-cci: Do not enable CCI-400 PMU by default firmware: qcom: scm: Add HDCP Support ARM: berlin: add an ADC node for the BG2Q ARM: berlin: remove useless chip and system ctrl compatibles clk: berlin: drop direct of_iomap of nodes reg property ARM: berlin: move BG2Q clock node ARM: berlin: move BG2CD clock node ARM: berlin: move BG2 clock node clk: berlin: prepare simple-mfd conversion pinctrl: berlin: drop SoC stub provided regmap ARM: berlin: move pinctrl to simple-mfd nodes pinctrl: berlin: prepare to use regmap provided by syscon reset: berlin: drop arch_initcall initialization ...
2015-06-16drivers/soc: Convert non-modular tegra/pmc to use builtin_platform_driverPaul Gortmaker
This file depends on Kconfig ARCH_TEGRA which is a bool, so we use the appropriate registration function, which avoids us relying on an implicit inclusion of <module.h> which we are doing currently. While this currently works, we really don't want to be including the module.h header in non-modular code, which we'd be forced to do, pending some upcoming code relocation from init.h into module.h. So we fix it now by using the non-modular equivalent. Cc: Stephen Warren <swarren@wwwdotorg.org> Cc: Thierry Reding <thierry.reding@gmail.com> Cc: Alexandre Courbot <gnurou@gmail.com> Cc: linux-tegra@vger.kernel.org Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2015-05-04soc/tegra: pmc: move to using a restart handlerDavid Riley
The pmc driver was previously exporting tegra_pmc_restart, which was assigned to machine_desc.init_machine, taking precedence over the restart handlers registered through register_restart_handler(). Signed-off-by: David Riley <davidriley@chromium.org> [tomeu.vizoso@collabora.com: Rebased] Signed-off-by: Tomeu Vizoso <tomeu.vizoso@collabora.com> Acked-by: Stephen Warren <swarren@nvidia.com> Reviewed-by: Alexandre Courbot <acourbot@nvidia.com> [treding@nvidia.com: minor cleanups] Signed-off-by: Thierry Reding <treding@nvidia.com>
2015-05-04soc/tegra: fuse: Add RAM code reader helperMikko Perttunen
Needed for the EMC and MC drivers to know what timings from the DT to use. Signed-off-by: Mikko Perttunen <mperttunen@nvidia.com> Signed-off-by: Tomeu Vizoso <tomeu.vizoso@collabora.com> Signed-off-by: Thierry Reding <treding@nvidia.com>
2015-05-04soc/tegra: Watch wait_for_completion_timeout() return typeNicholas Mc Guire
The return type of the wait_for_completion_timeout() function is not int but unsigned long. An appropriately named unsigned long is added and the assignment fixed up. Signed-off-by: Nicholas Mc Guire <hofrat@osadl.org> Signed-off-by: Thierry Reding <treding@nvidia.com>
2015-01-23soc: tegra: Add thermal reset (thermtrip) support to PMCMikko Perttunen
This adds a device tree controlled option to enable PMC-based thermal reset in overheating situations. Thermtrip is supported on Tegra30, Tegra114 and Tegra124. The thermal reset only works when the thermal sensors are calibrated, so a soctherm driver is also required. The thermtrip event is triggered by the soctherm block, and all soctherm sensors default to showing a temperature of zero Celsius before they are initialized. Because of this, it is safe to initialize thermtrip and soctherm in any order. Signed-off-by: Mikko Perttunen <mperttunen@nvidia.com> Signed-off-by: Thierry Reding <treding@nvidia.com>
2015-01-09soc/tegra: pmc: Add Tegra132 supportThierry Reding
Tegra132 uses the same GPU as Tegra124 and therefore requires the same method to remove clamps. However Tegra132 has a separate chip ID, so in order to avoid having to extend the list of chip IDs for the special case, add a feature flag to the SoC data. Reviewed-by: Paul Walmsley <pwalmsley@nvidia.com> Signed-off-by: Thierry Reding <treding@nvidia.com>
2015-01-09soc/tegra: fuse: Add Tegra132 supportThierry Reding
Tegra132 is very similar to Tegra124 from a peripheral point of view and uses the same fuse controller. Signed-off-by: Thierry Reding <treding@nvidia.com>
2015-01-09soc/tegra: fuse: Constify tegra_fuse_info structuresThierry Reding
These structures contain read-only data and are never modified, so they can be const. Signed-off-by: Thierry Reding <treding@nvidia.com>
2015-01-09soc/tegra: pmc: restrict compilation of suspend-related support to ARMPaul Walmsley
Tegra SoCs with 64-bit ARM support don't currently support deep CPU low-power states in mainline Linux. When this support is added in the future, it will probably look rather different from the existing 32-bit ARM support, since the ARM64 maintainers' strong preference is to use PSCI to implement it. So, for the time being, prevent the CPU suspend-related code and data in the Tegra PMC driver from compiling on ARM64. Signed-off-by: Paul Walmsley <paul@pwsan.com> Signed-off-by: Paul Walmsley <pwalmsley@nvidia.com> Cc: Thierry Reding <treding@nvidia.com> Cc: Allen Martin <amartin@nvidia.com> Cc: Stephen Warren <swarren@nvidia.com> Cc: Alexandre Courbot <gnurou@gmail.com> Signed-off-by: Thierry Reding <treding@nvidia.com>
2014-12-15Merge branch 'drm-next' of git://people.freedesktop.org/~airlied/linuxLinus Torvalds
Pull drm updates from Dave Airlie: "Highlights: - AMD KFD driver merge This is the AMD HSA interface for exposing a lowlevel interface for GPGPU use. They have an open source userspace built on top of this interface, and the code looks as good as it was going to get out of tree. - Initial atomic modesetting work The need for an atomic modesetting interface to allow userspace to try and send a complete set of modesetting state to the driver has arisen, and been suffering from neglect this past year. No more, the start of the common code and changes for msm driver to use it are in this tree. Ongoing work to get the userspace ioctl finished and the code clean will probably wait until next kernel. - DisplayID 1.3 and tiled monitor exposed to userspace. Tiled monitor property is now exposed for userspace to make use of. - Rockchip drm driver merged. - imx gpu driver moved out of staging Other stuff: - core: panel - MIPI DSI + new panels. expose suggested x/y properties for virtual GPUs - i915: Initial Skylake (SKL) support gen3/4 reset work start of dri1/ums removal infoframe tracking fixes for lots of things. - nouveau: tegra k1 voltage support GM204 modesetting support GT21x memory reclocking work - radeon: CI dpm fixes GPUVM improvements Initial DPM fan control - rcar-du: HDMI support added removed some support for old boards slave encoder driver for Analog Devices adv7511 - exynos: Exynos4415 SoC support - msm: a4xx gpu support atomic helper conversion - tegra: iommu support universal plane support ganged-mode DSI support - sti: HDMI i2c improvements - vmwgfx: some late fixes. - qxl: use suggested x/y properties" * 'drm-next' of git://people.freedesktop.org/~airlied/linux: (969 commits) drm: sti: fix module compilation issue drm/i915: save/restore GMBUS freq across suspend/resume on gen4 drm: sti: correctly cleanup CRTC and planes drm: sti: add HQVDP plane drm: sti: add cursor plane drm: sti: enable auxiliary CRTC drm: sti: fix delay in VTG programming drm: sti: prepare sti_tvout to support auxiliary crtc drm: sti: use drm_crtc_vblank_{on/off} instead of drm_vblank_{on/off} drm: sti: fix hdmi avi infoframe drm: sti: remove event lock while disabling vblank drm: sti: simplify gdp code drm: sti: clear all mixer control drm: sti: remove gpio for HDMI hot plug detection drm: sti: allow to change hdmi ddc i2c adapter drm/doc: Document drm_add_modes_noedid() usage drm/i915: Remove '& 0xffff' from the mask given to WA_REG() drm/i915: Invert the mask and val arguments in wa_add() and WA_REG() drm: Zero out DRM object memory upon cleanup drm/i915/bdw: Fix the write setting up the WIZ hashing mode ...
2014-12-02soc/tegra: fuse: export tegra_sku_infoVince Hsu
Some Tegra drivers might be compiled as kernel modules, and they need the fuse information for initialization. One example is the GK20A Nouveau driver. It needs the GPU speedo value to calculate frequency-voltage table. So export the tegra_sku_info. Signed-off-by: Vince Hsu <vinceh@nvidia.com> Acked-by: Alexandre Courbot <acourbot@nvidia.com> Acked-by: Thierry Reding <treding@nvidia.com> Signed-off-by: Ben Skeggs <bskeggs@redhat.com>
2014-10-20soc: tegra: fuse: drop owner assignment from platform_driversWolfram Sang
A platform_driver does not need to set an owner, it will be populated by the driver core. Signed-off-by: Wolfram Sang <wsa@the-dreams.de>
2014-07-17ARM: tegra: Convert PMC to a driverThierry Reding
This commit converts the PMC support code to a platform driver. Because the boot process needs to call into this driver very early, also set up a minimal environment via an early initcall. Signed-off-by: Thierry Reding <treding@nvidia.com>
2014-07-17soc/tegra: fuse: Set up in early initcallThierry Reding
Rather than rely on explicit initialization order called from SoC setup code, use a plain initcall and rely on initcall ordering to take care of dependencies. This driver exposes some functionality (querying the chip ID) needed at very early stages of the boot process. An early initcall is good enough provided that some of the dependencies are deferred to later stages. To make sure any abuses are easily caught, output a warning message if the chip ID is queried while it can't be read yet. Signed-off-by: Thierry Reding <treding@nvidia.com>
2014-07-17soc/tegra: Implement runtime check for Tegra SoCsThierry Reding
Subsequent patches will move some of the initialization code from SoC setup code to regular initcalls. To prevent breakage on other SoCs in multi-platform builds, these initcalls need to check that they indeed run on Tegra. Signed-off-by: Thierry Reding <treding@nvidia.com>
2014-07-17soc/tegra: fuse: fix dummy functionsStephen Warren
The Tegra fuse header's dummy functions for the case where Tegra20 is disabled are inconsistent with the correct prototypes, and have some syntax errors. Fix these. While at it, fix the indentation level of the dummy function bodies. Fixes: 783c8f4c8445 ("soc/tegra: Add efuse driver for Tegra") Cc: Peter De Schrijver <pdeschrijver@nvidia.com> Signed-off-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Thierry Reding <treding@nvidia.com>
2014-07-17soc/tegra: fuse: move APB DMA into Tegra20 fuse driverPeter De Schrijver
The Tegra20 fuse driver is the only user of tegra_apb_readl_using_dma(). Therefore we can simply the code by incorporating the APB DMA handling into the driver directly. tegra_apb_writel_using_dma() is dropped because there are no users. Signed-off-by: Peter De Schrijver <pdeschrijver@nvidia.com> Signed-off-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Thierry Reding <treding@nvidia.com>
2014-07-17soc/tegra: Add efuse driver for TegraPeter De Schrijver
Implement fuse driver for Tegra20, Tegra30, Tegra114 and Tegra124. This replaces functionality previously provided in arch/arm/mach-tegra, which is removed in this patch. While at it, move the only user of the global tegra_revision variable over to tegra_sku_info.revision and export tegra_fuse_readl() to allow drivers to read calibration fuses. Signed-off-by: Peter De Schrijver <pdeschrijver@nvidia.com> Signed-off-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Thierry Reding <treding@nvidia.com>
