path: root/drivers/sh/superhyway
2006-01-13[PATCH] Add superhyway_bus_type probe and remove methodsRussell King
Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-11-07[PATCH] superhyway: multiple block support and VCR reworkPaul Mundt
This extends the API somewhat to allow for platform-specific VCR reading and writing. Some platforms (like SH4-202) implement the VCR in a split VCRL and VCRH, but end up being in reverse order or have other quirks that need to be dealt with, so we add a set of superhyway_ops per-bus to accomodate this. We also have to extend the per-device resources somewhat, as some devices now conveniently split control and data blocks. So we allow a platform to register its set of SuperHyway devices via superhyway_add_devices() with the control block always ordered as the first resource (as this is the one that userspace cares about). Signed-off-by: Paul Mundt <lethal@linux-sh.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-10-30[PATCH] fix missing includesTim Schmielau
I recently picked up my older work to remove unnecessary #includes of sched.h, starting from a patch by Dave Jones to not include sched.h from module.h. This reduces the number of indirect includes of sched.h by ~300. Another ~400 pointless direct includes can be removed after this disentangling (patch to follow later). However, quite a few indirect includes need to be fixed up for this. In order to feed the patches through -mm with as little disturbance as possible, I've split out the fixes I accumulated up to now (complete for i386 and x86_64, more archs to follow later) and post them before the real patch. This way this large part of the patch is kept simple with only adding #includes, and all hunks are independent of each other. So if any hunk rejects or gets in the way of other patches, just drop it. My scripts will pick it up again in the next round. Signed-off-by: Tim Schmielau <tim@physik3.uni-rostock.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-20[PATCH] Driver Core: drivers/s390/net/qeth_sys.c - ↵Yani Ioannou
drivers/usb/gadget/pxa2xx_udc.c: update device attribute callbacks Signed-off-by: Yani Ioannou <yani.ioannou@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
