path: root/drivers/sh/Makefile
2013-01-25sh-pfc: Move driver from drivers/sh/ to drivers/pinctrl/Laurent Pinchart
Signed-off-by: Laurent Pinchart <laurent.pinchart+renesas@ideasonboard.com> Acked-by: Paul Mundt <lethal@linux-sh.org> Acked-by: Linus Walleij <linus.walleij@linaro.org> Signed-off-by: Simon Horman <horms+renesas@verge.net.au>
2012-07-10sh: pfc: Shuffle PFC support core.Paul Mundt
This follows the intc/clk changes and shuffles the PFC support code under its own directory. This will facilitate better code sharing, and allow us to trim down the exported interface by quite a margin. Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2012-06-20sh: pfc: Make gpio chip support optional where possible.Paul Mundt
This implements some Kconfig knobs for ensuring that the PFC gpio chip can be disabled or built as a module in the cases where it's optional, or forcibly enabled in cases where it's not. Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2012-06-20sh: pfc: Split out gpio chip support.Paul Mundt
This implements a bit of rework for the PFC code, making the core itself slightly more pluggable and moving out the gpio chip handling completely. The API is preserved in such a way that platforms that depend on it for early configuration are still able to do so, while making it possible to migrate to alternate interfaces going forward. This is the first step of chainsawing necessary to support the pinctrl API, with the eventual goal being able to decouple pin function state from the gpio API while retaining gpio chip tie-in for gpio pin functions only, relying on the pinctrl/pinmux API for non-gpio function demux. Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2012-01-12sh: also without PM_RUNTIME pm_runtime.o must be builtGuennadi Liakhovetski
When CONFIG_PM_RUNTIME is off, drivers/sh/pm_runtime.o still has to be built on sh platforms, because then it provides means to statically switch on device PM clocks. Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2011-11-18sh: Kill off remaining private runtime PM bits.Paul Mundt
This kills of the now unused runtime PM stub in favour of the generic one. Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2011-11-18sh: sh7723: use runtime PM implementation, common with arm/mach-shmobileGuennadi Liakhovetski
Switch sh7723 to a runtime PM implementation, common with ARM-based sh-mobile platforms. Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2011-11-18sh: sh7722: use runtime PM implementation, common with arm/mach-shmobileGuennadi Liakhovetski
Switch sh7722 to a runtime PM implementation, common with ARM-based sh-mobile platforms. Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2011-11-18sh: sh7724: use runtime PM implementation, common with arm/mach-shmobileGuennadi Liakhovetski
Switch sh7724 to a runtime PM implementation, common with ARM-based sh-mobile platforms. Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2011-11-11drivers: sh: Generalize runtime PM platform stub.Paul Mundt
The runtime PM platform support stub in use by ARM-based SH/R-Mobile platforms contains nothing that's specifically ARM-related and instead of wholly generic to anything using the clock framework. The recent runtime PM changes interact rather badly with the lazy disabling of clocks late in the boot process through the clock framework, leading to situations where the runtime suspend/resume paths are entered without a clock being actively driven due to having been lazily gated off. In order to correct this we can trivially tie in the aforementioned stub as a general fallback for all SH platforms that don't presently have their own runtime PM implementations (the corner case being SH-based SH-Mobile platforms, which have their own stub through the hwblk API -- which in turn has bitrotted and will be subsequently adapted to use the same stub as everyone else), regardless of whether the platforms choose to define power domains of their own or not. This fixes up regressions for clock framework users who also build in runtime PM support without any specific power domains of their own, which was previously causing the serial console to be lost when warring with lazy clock disabling. Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2010-10-18sh: clkfwk: Shuffle around to match the intc split up.Paul Mundt
This shuffles the clock framework code around to a drivers/sh/clk subdir, to follow the intc split up. This will make it easier to subsequently break things out as well as plug in different helpers for non-CPG users. Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2010-10-05sh: intc: Split up the INTC code.Paul Mundt
This splits up the sh intc core in to something more vaguely resembling a subsystem. Most of the functionality was alread fairly well compartmentalized, and there were only a handful of interdependencies that needed to be resolved in the process. This also serves as future-proofing for the genirq and sparseirq rework, which will make some of the split out functionality wholly generic, allowing things to be killed off in place with minimal migration pain. Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2010-05-20ARM: mach-shmobile: Use shared clock frameworkMagnus Damm
Teach SH-Mobile ARM how to make use of the shared SH clock framework. This commit is one atomic switch that dumps the local hackery and instead links in the shared clock framework code in drivers/sh. A few local functions are kept in clock.c. Signed-off-by: Magnus Damm <damm@opensource.se> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2010-05-13sh: move sh clock-cpg.c contents to drivers/sh/clk-cpg.cMagnus Damm
Move the CPG helpers to drivers/sh/clk-cpg.c V2. This to allow SH-Mobile ARM to share the code with SH. All functions except the legacy CPG stuff is moved. Signed-off-by: Magnus Damm <damm@opensource.se> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2010-05-13sh: move sh clock.c contents to drivers/sh/clk.Magnus Damm
This patch is V2 of the SH clock framework move from arch/sh/kernel/cpu/clock.c to drivers/sh/clk.c. All code except the following functions are moved: clk_init(), clk_get() and clk_put(). The init function is still kept in clock.c since it depends on the SH-specific machvec implementation. The symbols clk_get() and clk_put() already exist in the common ARM clkdev code, those symbols are left in the SH tree to avoid duplicating them for SH-Mobile ARM. Signed-off-by: Magnus Damm <damm@opensource.se> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2009-11-30sh: Break out SuperH PFC codeMagnus Damm
This file breaks out the SuperH PFC code from arch/sh/kernel/gpio.c + arch/sh/include/asm/gpio.h to drivers/sh/pfc.c + include/linux/sh_pfc.h. Similar to the INTC stuff. The non-SuperH specific file location makes it possible to share the code between multiple architectures. Signed-off-by: Magnus Damm <damm@opensource.se> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2008-10-01sh: Move the shared INTC code out to drivers/sh/Paul Mundt
The INTC code will be re-used across different architectures, so move this out to drivers/sh/ and include/linux/sh_intc.h respectively. Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2007-09-21sh: Add maple bus support for the SEGA Dreamcast.Adrian McMenamin
The Maple bus is SEGA's proprietary serial bus for peripherals (keyboard, mouse, controller etc). The bus is capable of some (limited) hotplugging and operates at up to 2 M/bits. Drivers of one sort or another existed/exist for 2.4 and a rudimentary port, which didn't support the 2.6 device driver model was also in existence. This driver - for the bus logic itself and for the keyboard (other drivers will follow) are based on the code and concepts of those old drivers but have lots of completely rewritten parts. I have the maple bus code as a built in now as that seems the sane and rational way to handle something like that - you either want the bus or you don't. Signed-off-by: Adrian McMenamin <adrian@mcmen.demon.co.uk> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
