A bug report from Gerd Hoffmann has highlighted that unconditionally
enabling the transmit interrupt at the end of console writes is very
bad.
In Gerd's case, it causes the test for buggy UARTs to give false
positives, incorrectly identifying ports as buggy when they are not.
Moreover, if we unconditionally enable the interrupt, and the port
is sharing it's interrupt with other ports, there is the very real
possibility that we'll cause an interrupt storm. (Not all ports use
OUT2 as an interrupt mask.)
Hence, revert part of f91a3715db2bb44fcf08cec642e68f919b70f7f4 and
all of f5968b37b3ad35b682b574b578843a0361218aff until a better solution
can be found.
Alchemy SoC uart have got a non-standard divisor register that needs some
special handling.
This patch adds divisor read/write functions with test and special
handling for Alchemy internal uart.
Signed-off-by: Jon Anders Haugum <jonah@omegav.ntnu.no>
I've noticed that the 8250/Au1x00 driver (drivers/serial/8250_au1x00.c)
doesn't claim UART memory ranges and uses wrong (KSEG1-based) UART
addresses instead of the physical ones.
The locking for the uart_port is over complicated, and can be
simplified if we introduce a flag to indicate that a port is "dead"
and will be removed.
This also helps the validator because it removes a case of non-nested
unlock ordering.
Current address translation methods can produce wrong results, because
virt_to_bus and vice versa may not produce correct offsets on dma-allocated
memory. The right way is, while tracking both phys and virt address of the
window that has been allocated for boffer descriptors, and use those
numbers to compute the offset and make translation properly.
Signed-off-by: Vitaly Bordug <vbordug@ru.mvista.com>
This is intended to make the driver code more generic and flexible,
to get rid of board-specific layouts within driver, and generic rehaul,
yet keeping compatibility with the existing stuff utilizing it, being
compatible with legacy behavior (but with complaints that legacy mode
used).
/project/m32r-linux/kernel/linux-2.6.17-rc1-mm2/linux-2.6.17-rc1-mm2/drivers/serial/m32r_sio.c: In function 'm32r_sio_console_write':
/project/m32r-linux/kernel/linux-2.6.17-rc1-mm2/linux-2.6.17-rc1-mm2/drivers/serial/m32r_sio.c:1060: warning: unused variable 'i'
Signed-off-by: Hirokazu Takata <takata@linux-m32r.org>
* git://git.kernel.org/pub/scm/linux/kernel/git/bunk/trivial: (48 commits)
Documentation: fix minor kernel-doc warnings
BUG_ON() Conversion in drivers/net/
BUG_ON() Conversion in drivers/s390/net/lcs.c
BUG_ON() Conversion in mm/slab.c
BUG_ON() Conversion in mm/highmem.c
BUG_ON() Conversion in kernel/signal.c
BUG_ON() Conversion in kernel/ptrace.c
BUG_ON() Conversion in ipc/shm.c
BUG_ON() Conversion in fs/freevxfs/
BUG_ON() Conversion in fs/udf/
BUG_ON() Conversion in fs/sysv/
BUG_ON() Conversion in fs/inode.c
BUG_ON() Conversion in fs/fcntl.c
BUG_ON() Conversion in fs/dquot.c
BUG_ON() Conversion in md/raid10.c
BUG_ON() Conversion in md/raid6main.c
BUG_ON() Conversion in md/raid5.c
Fix minor documentation typo
BFP->BPF in Documentation/networking/tuntap.txt
* master.kernel.org:/pub/scm/linux/kernel/git/brodo/pcmcia-2.6: (33 commits)
[PATCH] pcmcia: declare pccard_iodyn_ops (fix m8xx_pcmcia.c compilation error)
[PATCH] pcmcia: fix pcmcia_device_remove oops
[PATCH] pcmcia: Add support for Possio GCC AKA PCMCIA Siemens MC45
[PATCH] pcmcia: pseudo device handling update
[PATCH] pcmcia: convert DEV_OK to pcmcia_dev_present
[PATCH] pcmcia: use bitfield instead of p_state and state
[PATCH] pcmcia: remove unused p_dev->state flags
[PATCH] pcmcia: make pcmcia_release_{io,irq} static
[PATCH] pcmcia: add return value to _config() functions
[PATCH] pcmcia: remove dev_link_t and client_handle_t indirection
[PATCH] pcmcia: embed dev_link_t into struct pcmcia_device
[PATCH] pcmcia: rename pcmcia_device.state
[PATCH] pcmcia: remove unneeded Vcc pseudo setting
[PATCH] pcmcia: remove export of pcmcia_release_configuration
[PATCH] pcmcia: default suspend and resume handling
[PATCH] pcmcia: convert remaining users of pcmcia_release_io and _irq
[PATCH] pcmcia: add pcmcia_disable_device
[PATCH] serial_cs: add Merlin U630 IDs
[PATCH] pcmcia: AT91RM9200 Compact Flash driver
[PATCH] pcmcia: socket.functions starts with 1
* master.kernel.org:/home/rmk/linux-2.6-serial:
[SERIAL] Allow 8250 PCI, PNP, GSC and HP300 support to be disabled
Replace a bouncing version of the email address of Wendy Xiong with a
working one.
Decrease the number of pointer derefs in drivers/serial/jsm/jsm_tty.c
Benefits of the patch:
- Fewer pointer dereferences should make the code slightly faster.
- Size of generated code is smaller
- Improved readability
Signed-off-by: Jesper Juhl <jesper.juhl@gmail.com>
Acked-by: "V. ANANDA KRISHNAN" <mansarov@us.ibm.com>
This ugly hack add support for Siemens MC45 PCMCIA GPRS card (which is
identical to Possio GCC, and which is offered by one of our local GPRS
providers). Card has unfortunate feature that after poweron oxcf950 chip
is fully powered and works, but attached MC45 modem is powered down :-(
There is a special sequence (which takes 1 sec :-( ) to poweron MC45 (and
after MC45 powers on, it takes more than 2 secs until firmware fully
boots...) which needs to be executed after all powerons.
I'm really not familiar with PCMCIA subsystem, so I have no idea whether I
should issue request_region() on rest of oxcf950 address range (0-7 is
UART, 8-F are special configuration registers), or how this should be
better integrated with PM system and so on - I just put it in same place
where another hack already lived...
Card uses 18.432MHz XTAL, so to get it to work you must add lines below to
the /etc/pcmcia/serial.opts.
case "$MANFID-$FUNCID-$PRODID_1-$PRODID_2-$PRODID_3-$PRODID_4" in
'030c,0003-2-GPRS-CARD--')
SERIAL_OPTS="baud_base 1152000"
esac
Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
Instead of the DEV_OK macro, drivers should use pcmcia_dev_present().
Instead of the two status values struct pcmcia_device->p_state and state,
use descriptive bitfields. Most value-checking in drivers was invalid, as
the core now only calls the ->remove() (a.k.a. detach) function in case the
attachement _and_ configuration was successful.
Most of the driver initialization isn't done in the .probe function, but in
the internal _config() functions. Make them return a value, so that .probe
can properly report whether the probing of the device succeeded or not.
dev_link_t * and client_handle_t both mean struct pcmcai_device * by now.
Therefore, remove all such indirections.
Embed dev_link_t into struct pcmcia_device(), as they basically address the
same entity. The actual contents of dev_link_t will be cleaned up step by step.
This patch includes a bugfix from and signed-off-by Andrew Morton.
As we do not allow setting Vcc in the pcmcia core, and Vpp1 and
Vpp2 can only be set to the same value, a lot of code can be
streamlined.
In all but one case, the suspend and resume functions of PCMCIA drivers
contain mostly of calls to pcmcia_release_configuration() and
pcmcia_request_configuration(). Therefore, move this code out of the
drivers and into the core.
pcmcia_disable_device(struct pcmcia_device *p_dev) performs the necessary
cleanups upon device or driver removal: it calls the appropriate
pcmcia_release_* functions, and can replace (most) of the current drivers'
_release() functions.
Add Merlin U630 IDs.
Signed-off-by: Domen Puncer <domen.puncer@ultra.si>
Addresses in F-space must be accessed uncached on most parisc machines.
Signed-off-by: Helge Deller <deller@parisc-linux.org>
Signed-off-by: Kyle McMartin <kyle@parisc-linux.org>
Allow the 8250 probe modules to be disabled if we're building for
with EMBEDDED enabled. This reduces the kernel size by not including
unnecessary probe module support.
Original idea from Matt Mackall for PCI only, expanded to others by
rmk.
[SERIAL] Provide Cirrus EP93xx AMBA PL010 serial support.
[SERIAL] amba-pl010: allow platforms to specify modem control method
[SERIAL] Remove obsoleted au1x00_uart driver
[SERIAL] Small time UART configuration fix for AU1100 processor
Fix a lot of typos. Eyeballed by jmc@ in OpenBSD.
The amba-pl010 hardware does not provide RTS and DTR control lines; it
is expected that these will be implemented using GPIO. Allow platforms
to supply a function to implement manipulation of modem control lines.
As announced in feature-removal-schedule.txt.
The AU1100 processor does not have an internal UART2. Only
UART0, UART1 and UART3 exist. This patch removes the non existing
UART2 and replaces it with a descriptive comment.
Signed-off-by: Freddy Spierenburg <freddy@dusktilldawn.nl>
[ARM] 3383/3: ixp2000: ixdp2x01 platform serial conversion
[SERIAL] amba-pl010: Remove accessor macros
[SERIAL] remove 8250_acpi (replaced by 8250_pnp and PNPACPI)
[SERIAL] icom: select FW_LOADER
Remove unnecessary accessor macros, using readb/writel directly
instead.
With the combination of PNPACPI and 8250_pnp, we no longer need 8250_acpi.
Signed-off-by: Bjorn Helgaas <bjorn.helgaas@hp.com>
The icom driver uses request_firmware()
and thus needs to select FW_LOADER.
Signed-off-by: maximilian attems <maks@sternwelten.at>
* git://git.kernel.org/pub/scm/linux/kernel/git/bunk/trivial: (21 commits)
BUG_ON() Conversion in drivers/video/
BUG_ON() Conversion in drivers/parisc/
BUG_ON() Conversion in drivers/block/
BUG_ON() Conversion in sound/sparc/cs4231.c
BUG_ON() Conversion in drivers/s390/block/dasd.c
BUG_ON() Conversion in lib/swiotlb.c
BUG_ON() Conversion in kernel/cpu.c
BUG_ON() Conversion in ipc/msg.c
BUG_ON() Conversion in block/elevator.c
BUG_ON() Conversion in fs/coda/
BUG_ON() Conversion in fs/binfmt_elf_fdpic.c
BUG_ON() Conversion in input/serio/hil_mlc.c
BUG_ON() Conversion in md/dm-hw-handler.c
BUG_ON() Conversion in md/bitmap.c
The comment describing how MS_ASYNC works in msync.c is confusing
rcu: undeclared variable used in documentation
fix typos "wich" -> "which"
typo patch for fs/ufs/super.c
Fix simple typos
tabify drivers/char/Makefile
Merge mpsc.h into mpsc.c because its the only file that #include's mpsc.h.
Signed-off-by: Mark A. Greer <mgreer@mvista.com>
serial_core.h
The definition of SUPPORT_SYSRQ must come before #include of serial_core.h.
This patch moves the definition of SUPPORT_SYSRQ to be just after the #include
of config.h to make it consistent with 8250.c.
Reported-by: Stephane Chazelas <Stephane@artesyncp.com>
The devname passed to request_irq() contained a '/' which is wrong. At
a minimum, the '/' prevented the devname from showing up in
/proc/irq/<irq>/<devname>. This patch replaces the '/' with a '-' to
fixes that problem.
Add rs422 support to the Altix ioc4 serial driver.
Signed-off-by: Patrick Gefre <pfg@sgi.com>
Remove the assumption that driver_register() returns the number of devices
bound to the driver. In fact, it returns zero for success or a negative
error value.
dio_module_init() used the device count to automatically unregister and
unload drivers that found no devices. That might have worked at one time,
but has been broken for some time because dio_register_driver() returned
either a negative error or a positive count (never zero). So it could only
unregister on failure, when it's not needed anyway.
This functionality could be resurrected in individual drivers by counting
devices in their .probe() methods.
Cc: Philip Blundell <philb@gnu.org>
Cc: Jochen Friedrich <jochen@scram.de>
Cc: "Antonino A. Daplas" <adaplas@pol.net>
Cc: Jeff Garzik <jeff@garzik.org>
Signed-off-by: Uwe Zeisberger <zeisberg@informatik.uni-freiburg.de>
This patch removes all occurances of _INLINE_ in the kernel.
With the exception of tty_flip.h, I've simply removed the inline's since
gcc should know best which functions to be inlined.
[SERIAL] Merge avlab serial board entries in parport_serial
[SERIAL] kernel console should send CRLF not LFCR
The patch does the following for v441xx seris drivers:
- stop using platform_device_register_simple() as it is going away
- mark ->probe() and ->remove() methods as __devinit and __devexit
respectively
- initialize "owner" field in driver structure so there is a link
from /sys/modules to the driver
- mark *_init() and *_exit() functions as __init and __exit
Update the serial_txx9 driver.
* More strict check in verify_port. Cleanup.
* Do not insert a char caused previous overrun.
* Fix some spin_locks.
* Do not call uart_add_one_port for absent ports.
Also, this patch removes a BROKEN tag from Kconfig. This driver has been
marked as BROKEN by removal of uart_register_port, but it has been solved
already on Sep 2005.
Signed-off-by: Atsushi Nemoto <anemo@mba.ocn.ne.jp>
platform_get_irq*() now returns on -ENXIO when the resource cannot be
found. Ensure all users of platform_get_irq*() handle this error
appropriately.
Signed-off-by: David Vrabel <dvrabel@arcom.com>
Glen Turner reported that writing LFCR rather than the more
traditional CRLF causes issues with some terminals.
Since this aflicts many serial drivers, extract the common code
to a library function (uart_console_write) and arrange for each
driver to supply a "putchar" function.
Caught by CONFIG_DEBUG_SPINLOCK.
Because we play this trick where we use ttyS? in increasing minor
numbers for different sunfoo.c drivers, we have to inform the TTY
layer of this.
Do so by setting the tty->name_base appropriately.
Probably there should be a generic way to do this in the serial core,
but for now...
Caller takes the lock already.
Also, fixup the poll loop in sunhv_break_ctl(). Just
like in console write, we udelay(2) and use a loop
limit of 1000000 iterations.
