path: root/drivers/serial/mpsc.c
2008-07-23kgdb: kgdboc console poll hooks for mpsc uartJason Wessel
Add in console polling hooks for the mpsc uart for use with kgdb and kgdboc. Signed-off-by: Jason Wessel <jason.wessel@windriver.com>
2008-07-20Fix compile errors in SGI console drivers (linux-next tree)Takashi Iwai
The below is the patch to replace blindly all possible places, including Jack's fixes. Signed-off-by: Takashi Iwai <tiwai@suse.de> (Reviewed and checked rather than blindly added) Signed-off-by: Alan Cox <alan@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-20drivers/serial/: remove CVS keywordsAdrian Bunk
This patch removes CVS keywords that weren't updated for a long time in comments, printk's and MODULE_DESCRIPTION's (no printk's or MODULE_DESCRIPTION's are completely removed). While doing this I also found and fixed a missing \n in a printk in m32r_sio.c Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: Alan Cox <alan@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-15serial: fix platform driver hotplug/coldplugKay Sievers
Since 43cc71eed1250755986da4c0f9898f9a635cb3bf, the platform modalias is prefixed with "platform:". Add MODULE_ALIAS() to the hotpluggable serial platform drivers, to re-enable auto loading. NOTE that Kconfig for some of these drivers doesn't allow modular builds, and thus doesn't match the driver source's unload support. Presumably their unload code is buggy and/or weakly tested... [dbrownell@users.sourceforge.net: more drivers, registration fixes] Signed-off-by: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Acked-by: Peter Korsgaard <jacmet@sunsite.dk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-05serial: MPSC: set baudrate when BRG divider is set.Mark A. Greer
The clock to generate the desired baudrate with the MPSC is first divided by the Baud Rate Generator (BRG) and then by the MPSC itself. So, when the BRG divider is changed, the MPSC divider must also be changed to generate the correct baudrate. During MPSC initialization, the BRG divider is changed but the MPSC divider isn't changed until much later. This results in some printk's coming out garbled. To fix that, set the MPSC divider at the same time that the BRG divider is changed. Signed-off-by: Mark A. Greer <mgreer@mvista.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-31serial: MPSC: Fix coding style and whitespace issuesMark A. Greer
Fix up mpsc.c to be aligned with Documentation/CodingStyle. Also fix up some whitespace issues. Signed-off-by: Mark A. Greer <mgreer@mvista.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-31serial: MPSC: Remove duplicate SUPPORT_SYSRQ definitionMark A. Greer
Remove the duplicate definition of SUPPORT_SYSRQ in mpsc driver. Signed-off-by: Mark A. Greer <mgreer@mvista.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-31serial: MPSC: Stop rx engine when CREAD clearedStephane Chazelas
Currently, the MPSC driver doesn't stop recieving characters when the CREAD flag in termios->c_cflag is cleared. It should. Also, only start receiving if its not already started. Signed-off-by: Stephane Chazelas <stephane@artesyncp.com> Signed-off-by: Mark A. Greer <mgreer@mvista.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-31serial: MPSC: Remove race between Rx stop & restartCarlos Sanchez
The patch in commit ID f7232056bff5fe2d3bfeab35252a66ebaeb5bbde stops (aborts) the MPSC's receive engine just before restarting it. Unfortunately, it doesn't wait for the abort to complete before restarting it which creates a race between the abort and the restart. If the restart occurs first, the in-progress abort stops it again and the rx engine remains stopped. Instead, do the abort when the SDMA engine is being stopped. Make sure to wait for the abort to complete before continuing. Signed-off-by: Carlos Sanchez <carlos.sanchez@gecoinc.com> Signed-off-by: Mark A. Greer <mgreer@mvista.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-06-28serial: clear proper MPSC interrupt cause bitsJay Lubomirski
The interrupt clearing code in mpsc_sdma_intr_ack() mistakenly clears the interrupt for both controllers instead of just the one its supposed to. This can result in the other controller appearing to hang because its interrupt was effectively lost. So, don't clear the interrupt cause bits for both MPSC controllers when clearing the interrupt for one of them. Just clear the one that is supposed to be cleared. Signed-off-by: Jay Lubomirski <jaylubo@motorola.com> Acked-by: Mark A. Greer <mgreer@mvista.com> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-07MPSC serial driver tx lockingDave Jiang
The MPSC serial driver assumes that interrupt is always on to pick up the DMA transmit ops that aren't submitted while the DMA engine is active. However when irqs are off for a period of time such as operations under kernel crash dump console messages do not show up due to additional DMA ops are being dropped. This makes console writes to process through all the tx DMAs queued up before submitting a new request. Also, the current locking mechanism does not protect the hardware registers and ring buffer when a printk is done during the serial write operations. The additional per port transmit lock provides a finer granular locking and protects registers being clobbered while printks are nested within UART writes. Signed-off-by: Dave Jiang <djiang@mvista.com> Signed-off-by: Mark A. Greer <mgreer@mvista.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-12-08[PATCH] tty: switch to ktermiosAlan Cox
This is the grungy swap all the occurrences in the right places patch that goes with the updates. At this point we have the same functionality as before (except that sgttyb() returns speeds not zero) and are ready to begin turning new stuff on providing nobody reports lots of bugs If you are a tty driver author converting an out of tree driver the only impact should be termios->ktermios name changes for the speed/property setting functions from your upper layers. If you are implementing your own TCGETS function before then your driver was broken already and its about to get a whole lot more painful for you so please fix it 8) Also fill in c_ispeed/ospeed on init for most devices, although the current code will do this for you anyway but I'd like eventually to lose that extra paranoia [akpm@osdl.org: bluetooth fix] [mp3@de.ibm.com: sclp fix] [mp3@de.ibm.com: warning fix for tty3270] [hugh@veritas.com: fix tty_ioctl powerpc build] [jdike@addtoit.com: uml: fix ->set_termios declaration] Signed-off-by: Alan Cox <alan@redhat.com> Signed-off-by: Martin Peschke <mp3@de.ibm.com> Acked-by: Peter Oberparleiter <oberpar@de.ibm.com> Cc: Cornelia Huck <cornelia.huck@de.ibm.com> Signed-off-by: Hugh Dickins <hugh@veritas.com> Signed-off-by: Jeff Dike <jdike@addtoit.com> Cc: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-07[PATCH] Pass struct dev pointer to dma_cache_sync()Ralf Baechle
Pass struct dev pointer to dma_cache_sync() dma_cache_sync() is ill-designed in that it does not have a struct device pointer argument which makes proper support for systems that consist of a mix of coherent and non-coherent DMA devices hard. Change dma_cache_sync to take a struct device pointer as first argument and fix all its callers to pass it. Signed-off-by: Ralf Baechle <ralf@linux-mips.org> Cc: James Bottomley <James.Bottomley@steeleye.com> Cc: "David S. Miller" <davem@davemloft.net> Cc: Greg KH <greg@kroah.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
Maintain a per-CPU global "struct pt_regs *" variable which can be used instead of passing regs around manually through all ~1800 interrupt handlers in the Linux kernel. The regs pointer is used in few places, but it potentially costs both stack space and code to pass it around. On the FRV arch, removing the regs parameter from all the genirq function results in a 20% speed up of the IRQ exit path (ie: from leaving timer_interrupt() to leaving do_IRQ()). Where appropriate, an arch may override the generic storage facility and do something different with the variable. On FRV, for instance, the address is maintained in GR28 at all times inside the kernel as part of general exception handling. Having looked over the code, it appears that the parameter may be handed down through up to twenty or so layers of functions. Consider a USB character device attached to a USB hub, attached to a USB controller that posts its interrupts through a cascaded auxiliary interrupt controller. A character device driver may want to pass regs to the sysrq handler through the input layer which adds another few layers of parameter passing. I've build this code with allyesconfig for x86_64 and i386. I've runtested the main part of the code on FRV and i386, though I can't test most of the drivers. I've also done partial conversion for powerpc and MIPS - these at least compile with minimal configurations. This will affect all archs. Mostly the changes should be relatively easy. Take do_IRQ(), store the regs pointer at the beginning, saving the old one: struct pt_regs *old_regs = set_irq_regs(regs); And put the old one back at the end: set_irq_regs(old_regs); Don't pass regs through to generic_handle_irq() or __do_IRQ(). In timer_interrupt(), this sort of change will be necessary: - update_process_times(user_mode(regs)); - profile_tick(CPU_PROFILING, regs); + update_process_times(user_mode(get_irq_regs())); + profile_tick(CPU_PROFILING); I'd like to move update_process_times()'s use of get_irq_regs() into itself, except that i386, alone of the archs, uses something other than user_mode(). Some notes on the interrupt handling in the drivers: (*) input_dev() is now gone entirely. The regs pointer is no longer stored in the input_dev struct. (*) finish_unlinks() in drivers/usb/host/ohci-q.c needs checking. It does something different depending on whether it's been supplied with a regs pointer or not. (*) Various IRQ handler function pointers have been moved to type irq_handler_t. Signed-Off-By: David Howells <dhowells@redhat.com> (cherry picked from 1b16e7ac850969f38b375e511e3fa2f474a33867 commit)
2006-10-01[PATCH] ioremap balanced with iounmap for drivers/serial/mpsc.cAmol Lad
ioremap must be balanced by an iounmap and failing to do so can result in a memory leak. Signed-off-by: Amol Lad <amol@verismonetworks.com> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Cc: Mark A. Greer <mgreer@mvista.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-02[PATCH] irq-flags: serial: Use the new IRQF_ constantsThomas Gleixner
Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@elte.hu> Cc: "David S. Miller" <davem@davemloft.net> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Russell King <rmk@arm.linux.org.uk> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-26[PATCH] devfs: Remove devfs support from the serial subsystemGreg Kroah-Hartman
Also fixes all serial drivers. Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-03-25[PATCH] serial: merge mpsc.h into mpsc.cMark A. Greer
Merge mpsc.h into mpsc.c because its the only file that #include's mpsc.h. Signed-off-by: Mark A. Greer <mgreer@mvista.com> Cc: Russell King <rmk@arm.linux.org.uk> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-25[PATCH] serial: mpsc driver passes bad devname to request_irq()Mark A. Greer
The devname passed to request_irq() contained a '/' which is wrong. At a minimum, the '/' prevented the devname from showing up in /proc/irq/<irq>/<devname>. This patch replaces the '/' with a '-' to fixes that problem. Reported-by: Stephane Chazelas <Stephane@artesyncp.com> Signed-off-by: Mark A. Greer <mgreer@mvista.com> Cc: Russell King <rmk@arm.linux.org.uk> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-10[PATCH] TTY layer buffering revampAlan Cox
The API and code have been through various bits of initial review by serial driver people but they definitely need to live somewhere for a while so the unconverted drivers can get knocked into shape, existing drivers that have been updated can be better tuned and bugs whacked out. This replaces the tty flip buffers with kmalloc objects in rings. In the normal situation for an IRQ driven serial port at typical speeds the behaviour is pretty much the same, two buffers end up allocated and the kernel cycles between them as before. When there are delays or at high speed we now behave far better as the buffer pool can grow a bit rather than lose characters. This also means that we can operate at higher speeds reliably. For drivers that receive characters in blocks (DMA based, USB and especially virtualisation) the layer allows a lot of driver specific code that works around the tty layer with private secondary queues to be removed. The IBM folks need this sort of layer, the smart serial port people do, the virtualisers do (because a virtualised tty typically operates at infinite speed rather than emulating 9600 baud). Finally many drivers had invalid and unsafe attempts to avoid buffer overflows by directly invoking tty methods extracted out of the innards of work queue structs. These are no longer needed and all go away. That fixes various random hangs with serial ports on overflow. The other change in here is to optimise the receive_room path that is used by some callers. It turns out that only one ldisc uses receive room except asa constant and it updates it far far less than the value is read. We thus make it a variable not a function call. I expect the code to contain bugs due to the size alone but I'll be watching and squashing them and feeding out new patches as it goes. Because the buffers now dynamically expand you should only run out of buffering when the kernel runs out of memory for real. That means a lot of the horrible hacks high performance drivers used to do just aren't needed any more. Description: tty_insert_flip_char is an old API and continues to work as before, as does tty_flip_buffer_push() [this is why many drivers dont need modification]. It does now also return the number of chars inserted There are also tty_buffer_request_room(tty, len) which asks for a buffer block of the length requested and returns the space found. This improves efficiency with hardware that knows how much to transfer. and tty_insert_flip_string_flags(tty, str, flags, len) to insert a string of characters and flags For a smart interface the usual code is len = tty_request_buffer_room(tty, amount_hardware_says); tty_insert_flip_string(tty, buffer_from_card, len); More description! At the moment tty buffers are attached directly to the tty. This is causing a lot of the problems related to tty layer locking, also problems at high speed and also with bursty data (such as occurs in virtualised environments) I'm working on ripping out the flip buffers and replacing them with a pool of dynamically allocated buffers. This allows both for old style "byte I/O" devices and also helps virtualisation and smart devices where large blocks of data suddenely materialise and need storing. So far so good. Lots of drivers reference tty->flip.*. Several of them also call directly and unsafely into function pointers it provides. This will all break. Most drivers can use tty_insert_flip_char which can be kept as an API but others need more. At the moment I've added the following interfaces, if people think more will be needed now is a good time to say int tty_buffer_request_room(tty, size) Try and ensure at least size bytes are available, returns actual room (may be zero). At the moment it just uses the flipbuf space but that will change. Repeated calls without characters being added are not cumulative. (ie if you call it with 1, 1, 1, and then 4 you'll have four characters of space. The other functions will also try and grow buffers in future but this will be a more efficient way when you know block sizes. int tty_insert_flip_char(tty, ch, flag) As before insert a character if there is room. Now returns 1 for success, 0 for failure. int tty_insert_flip_string(tty, str, len) Insert a block of non error characters. Returns the number inserted. int tty_prepare_flip_string(tty, strptr, len) Adjust the buffer to allow len characters to be added. Returns a buffer pointer in strptr and the length available. This allows for hardware that needs to use functions like insl or mencpy_fromio. Signed-off-by: Alan Cox <alan@redhat.com> Cc: Paul Fulghum <paulkf@microgate.com> Signed-off-by: Hirokazu Takata <takata@linux-m32r.org> Signed-off-by: Serge Hallyn <serue@us.ibm.com> Signed-off-by: Jeff Dike <jdike@addtoit.com> Signed-off-by: John Hawkes <hawkes@sgi.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com> Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-09[DRIVER MODEL] Convert platform drivers to use struct platform_driverRussell King
This allows us to eliminate the casts in the drivers, and eventually remove the use of the device_driver function pointer methods for platform device drivers. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk> Acked-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-10-31Merge master.kernel.org:/home/rmk/linux-2.6-drvmodelLinus Torvalds
Manual #include fixups for clashes - there may be some unnecessary
2005-10-30[PATCH] Added a Receive_Abort to the Marvell serial driverCarlos Sanchez
Added a Receive_Abort to the Marvell serial driver Fix occasional input overrun errors on Marvell serial driver - If the Marvell serial driver is repeatedly started and then stopped it will occasionally report an input overrun error when started. - Added a Receive_Abort to the Marvell serial driver to abort previously received receive errors when re-starting the receive Acked-by: Mark A. Greer <mgreer@mvista.com> Signed-off-by: Carlos Sanchez <csanchez@mvista.com> Cc: Russell King <rmk@arm.linux.org.uk> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-10-29Create platform_device.h to contain all the platform device details.Russell King
Convert everyone who uses platform_bus_type to include linux/platform_device.h. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk> Acked-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-08-31[SERIAL] Clean up and fix tty transmission start/stopingRussell King
The start_tx and stop_tx methods were passed a flag to indicate whether the start/stop was from the tty start/stop callbacks, and some drivers used this flag to decide whether to ask the UART to immediately stop transmission (where the UART supports such a feature.) There are other cases when we wish this to occur - when CTS is lowered, or if we change from soft to hard flow control and CTS is inactive. In these cases, this flag was false, and we would allow the transmitter to drain before stopping. There is really only one case where we want to let the transmitter drain before disabling, and that's when we run out of characters to send. Hence, re-jig the start_tx and stop_tx methods to eliminate this flag, and introduce new functions for the special "disable and allow transmitter to drain" case. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2005-06-29[PATCH] Serial: Adjust serial lockingRussell King
This patch changes the way serial ports are locked when getting modem status. This change is necessary because we will need to atomically read the modem status and take action depending on the CTS status. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2005-06-25[PATCH] compilation errors in drivers/serial/mpsc.cLee Nicks
The following patch fix gcc 4 compilation errors in drivers/serial/mpsc.c Signed-off-by: Lee Nicks <allinux@gmail.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-04-25[PATCH] ppc annotations: mpscAl Viro
Usual iomem annotations + NULL noise removal. Signed-off-by: Al Viro <viro@parcelfarce.linux.theplanet.co.uk> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
