path: root/drivers/serial/mpc52xx_uart.c
2006-01-06[PATCH] ppc32/serial: Change mpc52xx_uart.c to use the Low Density Serial ↵Sylvain Munaut
port major Before this patch we were just using the "classic" /dev/ttySx devices. However when another on the system is loaded that uses those (like drivers for serial PCMCIA), that creates a conflict for the minors. Therefore, we now use /dev/ttyPSC[0:5] (note the 0-based numbering !) with some minors we've been assigned in the "Low Density Serial port major" Signed-off-by: Sylvain Munaut <tnt@246tNt.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-06[PATCH] ppc32/serial: Fix compiler errors with GCC 4.x in mpc52xx_uart.cSylvain Munaut
Signed-off-by: Wolfgang Denk <wd@denx.de> Signed-off-by: Sylvain Munaut <tnt@246tNt.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-12[SERIAL] Fix mpc52xx_uart.cAndrey Volkov
Fix copy-paste bug in mpc52xx_uart.c (pdev<->dev) Signed-off-by: Andrey Volkov <avolkov@varma-el.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2005-11-09[DRIVER MODEL] Convert platform drivers to use struct platform_driverRussell King
This allows us to eliminate the casts in the drivers, and eventually remove the use of the device_driver function pointer methods for platform device drivers. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk> Acked-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-10-29Create platform_device.h to contain all the platform device details.Russell King
Convert everyone who uses platform_bus_type to include linux/platform_device.h. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk> Acked-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-10-28[PATCH] DRIVER MODEL: Get rid of the obsolete tri-level suspend/resume callbacksRussell King
In PM v1, all devices were called at SUSPEND_DISABLE level. Then all devices were called at SUSPEND_SAVE_STATE level, and finally SUSPEND_POWER_DOWN level. However, with PM v2, to maintain compatibility for platform devices, I arranged for the PM v2 suspend/resume callbacks to call the old PM v1 suspend/resume callbacks three times with each level in order so that existing drivers continued to work. Since this is obsolete infrastructure which is no longer necessary, we can remove it. Here's an (untested) patch to do exactly that. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-09-17[PATCH] Fix up some pm_message_t typesRichard Purdie
Fix up some pm_message_t types Signed-Off-By: Richard Purdie <rpurdie@rpsys.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-08-31[SERIAL] Clean up and fix tty transmission start/stopingRussell King
The start_tx and stop_tx methods were passed a flag to indicate whether the start/stop was from the tty start/stop callbacks, and some drivers used this flag to decide whether to ask the UART to immediately stop transmission (where the UART supports such a feature.) There are other cases when we wish this to occur - when CTS is lowered, or if we change from soft to hard flow control and CTS is inactive. In these cases, this flag was false, and we would allow the transmitter to drain before stopping. There is really only one case where we want to let the transmitter drain before disabling, and that's when we run out of characters to send. Hence, re-jig the start_tx and stop_tx methods to eliminate this flag, and introduce new functions for the special "disable and allow transmitter to drain" case. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
