path: root/drivers/serial/bfin_sport_uart.c
2011-01-13tty: move drivers/serial/ to drivers/tty/serial/Greg Kroah-Hartman
The serial drivers are really just tty drivers, so move them to drivers/tty/ to make things a bit neater overall. This is part of the tty/serial driver movement proceedure as proposed by Arnd Bergmann and approved by everyone involved a number of months ago. Cc: Arnd Bergmann <arnd@arndb.de> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Rogier Wolff <R.E.Wolff@bitwizard.nl> Cc: Michael H. Warfield <mhw@wittsend.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-10-24Merge branch 'for-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial * 'for-next' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (39 commits) Update broken web addresses in arch directory. Update broken web addresses in the kernel. Revert "drivers/usb: Remove unnecessary return's from void functions" for musb gadget Revert "Fix typo: configuation => configuration" partially ida: document IDA_BITMAP_LONGS calculation ext2: fix a typo on comment in ext2/inode.c drivers/scsi: Remove unnecessary casts of private_data drivers/s390: Remove unnecessary casts of private_data net/sunrpc/rpc_pipe.c: Remove unnecessary casts of private_data drivers/infiniband: Remove unnecessary casts of private_data drivers/gpu/drm: Remove unnecessary casts of private_data kernel/pm_qos_params.c: Remove unnecessary casts of private_data fs/ecryptfs: Remove unnecessary casts of private_data fs/seq_file.c: Remove unnecessary casts of private_data arm: uengine.c: remove C99 comments arm: scoop.c: remove C99 comments Fix typo configue => configure in comments Fix typo: configuation => configuration Fix typo interrest[ing|ed] => interest[ing|ed] Fix various typos of valid in comments ... Fix up trivial conflicts in: drivers/char/ipmi/ipmi_si_intf.c drivers/usb/gadget/rndis.c net/irda/irnet/irnet_ppp.c
2010-10-22serial: bfin_sport_uart: speed up sport RX sample rate to be 3% fasterSonic Zhang
The actual uart baud rate of devices vary between +/-2% of what is asked. The SPORT RX sample rate should be faster than double of the worst case. Otherwise, wrong data may be received. So set SPORT RX clock to be 3% faster in general. Reported-by: Olivier STOCK <ostockemer@ereca.fr> Signed-off-by: Sonic Zhang <sonic.zhang@analog.com> Signed-off-by: Mike Frysinger <vapier@gentoo.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-10-18Update broken web addresses in the kernel.Justin P. Mattock
The patch below updates broken web addresses in the kernel Signed-off-by: Justin P. Mattock <justinmattock@gmail.com> Cc: Maciej W. Rozycki <macro@linux-mips.org> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Finn Thain <fthain@telegraphics.com.au> Cc: Randy Dunlap <rdunlap@xenotime.net> Cc: Matt Turner <mattst88@gmail.com> Cc: Dimitry Torokhov <dmitry.torokhov@gmail.com> Cc: Mike Frysinger <vapier.adi@gmail.com> Acked-by: Ben Pfaff <blp@cs.stanford.edu> Acked-by: Hans J. Koch <hjk@linutronix.de> Reviewed-by: Finn Thain <fthain@telegraphics.com.au> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2010-09-03serial: bfin_sport_uart: restore transmit frame sync fixSonic Zhang
The large cleanup/rewrite of resources in commit ccf68e59e93181df9353c0cc accidentally reverted an earlier fix in commit a19e8b205915b2925aca75b. So restore it here. Signed-off-by: Sonic Zhang <sonic.zhang@analog.com> Signed-off-by: Mike Frysinger <vapier@gentoo.org> Cc: stable <stable@kernel.org> [.34 and newer] Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-05-21serial: bfin_sport_uart: Use resource size to fix off-by-one errorTobias Klauser
Use the resource_size function instead of manually calculating the resource size. This actually fixes an off-by-one error. Signed-off-by: Tobias Klauser <tklauser@distanz.ch> Signed-off-by: Mike Frysinger <vapier@gentoo.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-05-21serial: bfin_sport_uart: pull in bfin_sport.h for SPORT definesMike Frysinger
Now that the SPORT MMR defines have been unified, switch over to it. Signed-off-by: Mike Frysinger <vapier@gentoo.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-05-21serial: bfin_sport_uart: only enable SPORT TX if data is to be sentSonic Zhang
Rather than always turn on the SPORT TX interrupt, only do it when we've actually queued up data for transmission. This avoids useless interrupt processing. Signed-off-by: Sonic Zhang <sonic.zhang@analog.com> Signed-off-by: Mike Frysinger <vapier@gentoo.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-05-21serial: bfin_sport_uart: drop useless status masksMike Frysinger
These were all copied over from the Blackfin UART driver, but they don't make sense here because these bits are all specific to the Blackfin UART. Signed-off-by: Mike Frysinger <vapier@gentoo.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-05-21serial: bfin_sport_uart: zero sport_uart_port if allocated dynamicallySonic Zhang
Need to initialize the SPORT state rather than using random memory. Signed-off-by: Sonic Zhang <sonic.zhang@analog.com> Signed-off-by: Mike Frysinger <vapier@gentoo.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-05-21serial: bfin_sport_uart: protect changes to uart_portSonic Zhang
Common serial API says we need to grab the port lock before modifying the port state to prevent inconsistent state between threads. Signed-off-by: Sonic Zhang <sonic.zhang@analog.com> Signed-off-by: Mike Frysinger <vapier@gentoo.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-05-21serial: bfin_sport_uart: add support for CTS/RTS via GPIOsSonic Zhang
Some people need flow control on their ports, so now boards can support that via any GPIOs. Signed-off-by: Sonic Zhang <sonic.zhang@analog.com> Signed-off-by: Mike Frysinger <vapier@gentoo.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-05-21serial: bfin_sport_uart: rename early platform driver class stringSonic Zhang
Clarifies command line set up for devices between consoles and early devices. Signed-off-by: Sonic Zhang <sonic.zhang@analog.com> Signed-off-by: Mike Frysinger <vapier@gentoo.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-05-21serial: bfin_sport_uart: add missing mapbase initializationSonic Zhang
The driver doesn't care about this, but the common serial core wants it. Signed-off-by: Sonic Zhang <sonic.zhang@analog.com> Signed-off-by: Mike Frysinger <vapier@gentoo.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-05-21serial: bfin_sport_uart: remove unused peripheral pin listsSonic Zhang
All the resources are in the boards files now. Signed-off-by: Sonic Zhang <sonic.zhang@analog.com> Signed-off-by: Mike Frysinger <vapier@gentoo.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-05-21serial: bfin_sport_uart: shorten the SPORT TX waiting loopSonic Zhang
The waiting loop to stop SPORT TX from TX interrupt is too long. This may block the SPORT RX interrupts and cause the RX FIFO to overflow. So, do stop sport TX only after the last char in TX FIFO is moved into the shift register. Signed-off-by: Sonic Zhang <sonic.zhang@analog.com> Signed-off-by: Mike Frysinger <vapier@gentoo.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2010-03-02serial: fit blackfin uart over sport driver into common uart infrastructuresonic zhang
Fit blackfin uart over sport driver into common uart inftrastructure. It is based on the early platform interfaces to get the platform data early when the console is initilized. 1. Enable sport uart driver to change uart baud, data bit, stop bit at runtime. Bind the index of uart device nodes to physical index of sports. 2. Move all platform data into arch specific board files. Register and probe platform device data in both early and normal stages. 3. Console is registered in sport uart driver as well. 4. Remove 500 us block waiting in sport tx stop code by putting a dummy data into tx fifo to make sure the sport tx stops when all bytes are shifted out except for the dummy data. 5. clean up a bit and fix up coding style. Signed-off-by: Sonic Zhang <sonic.zhang@analog.com> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Cc: Mike Frysinger <vapier@gentoo.org> Cc: Bryan Wu <cooloney@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-09-19serial: kill off uart_infoAlan Cox
We moved this into uart_state, now move the fields out of the separate structure and kill it off. Signed-off-by: Alan Cox <alan@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-07-16drivers/serial/bfin_sport_uart.c: remove wrong and unneeded memsetAndrew Morton
dcb314@hotmail.com notes that this memset has its args reversed. It's unneeded anyway, so remove it. Addresses http://bugzilla.kernel.org/show_bug.cgi?id=13587 Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Alan Cox <alan@lxorguk.ukuu.org.uk> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-06-11Blackfin SPORT UART: rewrite inline assemblyMike Frysinger
Hopefuly the new version is easier to read, but in the process it declares proper clobber lists and better constraints so that GCC can do a better job at allocating free registers. Signed-off-by: Mike Frysinger <vapier@gentoo.org> Signed-off-by: Bryan Wu <cooloney@kernel.org> Signed-off-by: Alan Cox <alan@linux.intel.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-06-11Blackfin SPORT UART: fix data misses while using transmit frame syncMichael Hennerich
SPORT transmit frame sync (TFS) isn't used as an electrical signal during normal SPORT UART emulation. However, it is useful in EIA RS-485 emulation as RS-485 Transceiver Driver Enable DE strobe. This patch configures: TFS to be active high in order to drive an DE strobe of an eventually connected RS-485 Transceiver. Late frame sync mode (LATFS) gating the entire TX shift cycle. Signed-off-by: Michael Hennerich <michael.hennerich@analog.com> Signed-off-by: Mike Frysinger <vapier@gentoo.org> Signed-off-by: Bryan Wu <cooloney@kernel.org> Signed-off-by: Alan Cox <alan@linux.intel.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-06-11Blackfin SPORT UART: fix typo in sport_set_termios prototypeMike Frysinger
2009-01-02__FUNCTION__ is gcc-specific, use __func__Harvey Harrison
Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Alan Cox <alan@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-20Fix compile errors in SGI console drivers (linux-next tree)Takashi Iwai
The below is the patch to replace blindly all possible places, including Jack's fixes. Signed-off-by: Takashi Iwai <tiwai@suse.de> (Reviewed and checked rather than blindly added) Signed-off-by: Alan Cox <alan@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-30Blackfin serial driver: this driver enable SPORTs on Blackfin emulate UARTBryan Wu
Signed-off-by: Bryan Wu <bryan.wu@analog.com> Cc: Alan Cox <alan@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
