path: root/drivers/serial/Makefile
2008-07-03[ARM] S3C24XX: Split serial driver into core and per-cpu driversBen Dooks
The S3C2410 serial driver in drivers/serial/s3c2410.c has been growing bigger with the addition of more variants of this hardware with the growing Samsung SoCs range. As such, it would be easier to split this code up into a core and per-cpu drivers to make driver addition easier, and the core smaller. Signed-off-by: Ben Dooks <ben-linux@fluff.org>
2008-04-30Blackfin serial driver: this driver enable SPORTs on Blackfin emulate UARTBryan Wu
Signed-off-by: Bryan Wu <bryan.wu@analog.com> Cc: Alan Cox <alan@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-28[MIPS] Alchemy: move UART platform code to its proper placeSergei Shtylyov
Move the code registering the Alchemy UART platform devices from drivers/serial/ to its proper place, into the Alchemy platform code. Fix the related Kconfig entry, while at it... Signed-off-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2008-04-17consoles: polling support, kgdbocJason Wessel
polled console handling support, to access a console in an irq-less way while in debug or irq context. absolutely zero impact as long as CONFIG_CONSOLE_POLL is disabled. (which is the default) [ jan.kiszka@siemens.com: lots of cleanups ] [ mingo@elte.hu: redesign, splitups, cleanups. ] Signed-off-by: Jason Wessel <jason.wessel@windriver.com> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Jan Kiszka <jan.kiszka@web.de> Reviewed-by: Thomas Gleixner <tglx@linutronix.de>
2008-02-06SC26XX: New serial driver for SC2681 uartsThomas Bogendoerfer
New serial driver for SC2681/SC2691 uarts. Older SNI RM400 machines are using these chips for onboard serial ports. Signed-off-by: Thomas Bogendoerfer <tsbogend@alpha.franken.de> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Cc: Torben Mathiasen <device@lanana.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-01m68knommu: build support for new ColdFire serial driverGreg Ungerer
Add build support for new ColdFire serial driver. Signed-off-by: Greg Ungerer <gerg@uclinux.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-01-23[POWERPC] qe-uart: add support for Freescale QUICCEngine UARTTimur Tabi
Add file ucc_uart.c, a serial device driver for the Freescale QUICCEngine. Update the Kconfig and Makefile accordingly. Signed-off-by: Timur Tabi <timur@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2007-07-18zs: move to the serial subsystemMaciej W. Rozycki
This is a reimplementation of the zs driver for the serial subsystem. Any resemblance to the old driver is purely coincidential. ;-) I do hope I got the handling of modem lines right -- better do not tackle me about the issue unless you feel too good... Any users of the old driver: please note the numbers of the serial lines have now been swapped, i.e. ttyS0 <-> ttyS1 and ttyS2 <-> ttyS3. It has to do with the modem lines mentioned above; basically the port A in a given chip has to be initialised before the port B if you want to use the latter as the serial console (which is usually the case), as operations on modem lines of the serial line associated with the port B access both ports (see the comment at the top of the driver for the details of wiring used). Please update your scripts. This is also the reason each SCC now requests an IRQ once only (as seen in "/proc/interrupts") -- the handler takes care of both ports at once as the line associated with the port B has to take status update interrupts from both ports (and yet the line of the port A takes its own for itself too). The old driver never got it right... Signed-off-by: Maciej W. Rozycki <macro@linux-mips.org> Cc: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-17sb1250-duart.c: SB1250 DUART serial supportMaciej W. Rozycki
This is a driver for the SB1250 DUART, a dual serial port implementation included in the Broadcom family of SOCs descending from the SiByte SB1250 MIPS64 chip multiprocessor. It is a new implementation replacing the old-fashioned driver currently present in the linux-mips.org tree. It supports all the usual features one would expect from a(n asynchronous) serial driver, including modem line control (as far as hardware supports it -- there is edge detection logic missing from the DCD and RI lines and the driver does not implement polling of these lines at the moment), the serial console, BREAK transmission and reception, including the magic SysRq. The receive FIFO threshold is not maintained though. The driver was tested with a SWARM board which uses a BCM1250 SOC (which is dual MIPS64 CMP) and has both ports of the single DUART implemented wired externally. Both were tested. Testing included using the ports as terminal lines at 1200bps (which is the ports minimum), 115200bps and a couple of random speeds inbetween. The modem lines were verified to operate correctly. No testing was performed with a use as a network interface, like with SLIP or PPP. Signed-off-by: Maciej W. Rozycki <macro@linux-mips.org> Acked-by: Ralf Baechle <ralf@linux-mips.org> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-11[ARM] 4332/2: KS8695: Serial driverAndrew Victor
A driver for the KS8695 internal UART. Based on the 2.6.9 driver from Micrel. Signed-off-by: Andrew Victor <andrew@sanpeople.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2007-05-07blackfin: serial driverBryan Wu
This patch implements the driver necessary use the Analog Devices Blackfin processor's Serial Port. Signed-off-by: Bryan Wu <bryan.wu@analog.com> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Cc: Russell King <rmk+lkml@arm.linux.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-14[PATCH] PNX8550 UART driverVitaly Wool
Add UART support for PNX8330/8550/8950 Philips MIPS-based SoCs. Signed-off-by: Vitaly Wool <vitalywool@gmail.com> Cc: Russell King <rmk@arm.linux.org.uk> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Cc: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-14[POWERPC] Open Firmware serial port driverArnd Bergmann
This can be used for serial ports that are connected to an OF platform bus but are not autodetected by the lecacy serial support. It will automatically take over devices that come from the legacy serial detection, which usually is only one device. In some cases, rtas may be set up to use the serial port in the firmware, which allows easier debugging before probing the serial ports. In this case, the "used-by-rtas" property must be set by the firmware. This patch also adds code to the legacy serial driver to check for this. Signed-off-by: Arnd Bergmann <arnd.bergmann@de.ibm.com> Signed-off-by: Paul Mackerras <paulus@samba.org>
2006-12-07[PATCH] Exar quad port serialPaul B Schroeder
This is on our "Envoy" boxes which we have, according to the documentation, an "Exar ST16C554/554D Quad UART with 16-byte Fifo's". The box also has two other "on-board" serial ports and a modem chip. The two on-board serial UARTs were being detected along with the first two Exar UARTs. The last two Exar UARTs were not showing up and neither was the modem. This patch was the only way I could the kernel to see beyond the standard four serial ports and get all four of the Exar UARTs to show up. [akpm@osdl.org: build fix] Signed-off-by: Paul B Schroeder <pschroeder@uplogix.com> Cc: Lennart Sorensen <lsorense@csclub.uwaterloo.ca> Acked-by: Alan Cox <alan@lxorguk.ukuu.org.uk> Cc: Russell King <rmk@arm.linux.org.uk> Cc: Greg KH <greg@kroah.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-07[PATCH] serial uartlite driverPeter Korsgaard
Add a driver for the Xilinx uartlite serial controller used in boards with the PPC405 core in the Xilinx V2P/V4 fpgas. The hardware is very simple (baudrate/start/stopbits fixed and no break support). See the datasheet for details: http://www.xilinx.com/bvdocs/ipcenter/data_sheet/opb_uartlite.pdf See http://thread.gmane.org/gmane.linux.serial/1237/ for the email thread. Signed-off-by: Peter Korsgaard <jacmet@sunsite.dk> Acked-by: Olof Johansson <olof@lixom.net> Cc: Russell King <rmk@arm.linux.org.uk> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-04[PATCH] at91_serial -> atmel_serial: Kconfig symbolsHaavard Skinnemoen
Rename the following Kconfig symbols: * CONFIG_SERIAL_AT91 -> CONFIG_SERIAL_ATMEL * CONFIG_SERIAL_AT91_CONSOLE -> CONFIG_SERIAL_ATMEL_CONSOLE * CONFIG_SERIAL_AT91_TTYAT -> CONFIG_SERIAL_ATMEL_TTYAT Signed-off-by: Haavard Skinnemoen <hskinnemoen@atmel.com> Acked-by: Andrew Victor <andrew@sanpeople.com> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-04[PATCH] at91_serial -> atmel_serial: at91_serial.cHaavard Skinnemoen
Rename at91_serial.c atmel_serial.c Signed-off-by: Haavard Skinnemoen <hskinnemoen@atmel.com> Acked-by: Andrew Victor <andrew@sanpeople.com> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-19[ARM] 3571/1: netX: serial driver for Hilscher netXSascha Hauer
Patch from Sascha Hauer This patch adds the serial driver for Hilscher's netX network processors. Signed-off-by: Robert Schwebel <r.schwebel@pengutronix.de> Signed-off-by: Sascha Hauer <s.hauer@pengutronix.de> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-03-29[SERIAL] Allow 8250 PCI, PNP, GSC and HP300 support to be disabledRussell King
Allow the 8250 probe modules to be disabled if we're building for with EMBEDDED enabled. This reduces the kernel size by not including unnecessary probe module support. Original idea from Matt Mackall for PCI only, expanded to others by rmk. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-03-26[SERIAL] Remove obsoleted au1x00_uart driverRalf Baechle
As announced in feature-removal-schedule.txt. Signed-off-by: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-03-25[SERIAL] remove 8250_acpi (replaced by 8250_pnp and PNPACPI)Bjorn Helgaas
With the combination of PNPACPI and 8250_pnp, we no longer need 8250_acpi. Signed-off-by: Bjorn Helgaas <bjorn.helgaas@hp.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-03-20[SPARC64]: Put sunhv.o earliest in the list of sparc serial drivers.David S. Miller
So that it will show up as /dev/ttyS0. Otherwise things like installers will try to run on whatever serial port gets probed first. Signed-off-by: David S. Miller <davem@davemloft.net>
2006-03-20[SPARC64]: Add SUN4V Hypervisor Console driver.David S. Miller
Since it can do things like BREAK and HUP, we implement this as a serial uart driver. This still needs interrupt probing code, as I haven't figured out how interrupts will work or be probed for on SUN4V yet. Signed-off-by: David S. Miller <davem@davemloft.net>
2006-01-14[PATCH] Altix: ioc3 serial supportPatrick Gefre
Add driver support for a 2 port PCI IOC3-based serial card on Altix boxes: This is a re-submission. On the original submission I was asked to organize the code so that the MIPS ioc3 ethernet and serial parts could be used with this driver. Stanislaw Skowronek was kind enough to provide the shim layer for this - thanks Stanislaw. This patch includes the shim layer and the Altix PCI ioc3 serial driver. The MIPS merged ioc3 ethernet and serial support is forthcoming. Signed-off-by: Patrick Gefre <pfg@sgi.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-10[ARM] 3242/2: AT91RM9200 support for 2.6 (Serial)Andrew Victor
Patch from Andrew Victor This patch adds support to the 2.6 kernel series for the Atmel AT91RM9200 processor. This patch is the Serial driver. This version uses the newly re-written GPL'ed hardware headers. Signed-off-by: Andrew Victor <andrew@sanpeople.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-01-08[ARM] Remove EPXA10DB machine supportRussell King
EPXA10DB seems to be uncared for: - the "PLD" code has never been merged - no one has reported that this platform has been broken since at least 2.6.10 - interest seems to have dried up around March 2003. Therefore, remove EPXA10DB support. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2005-11-06[SERIAL] Support Au1x00 8250 UARTs using the generic 8250 driver.Pantelis Antoniou
The offsets of the registers are in a different place, and some parts cannot handle a full set of modem control signals. Signed-off-by: Pantelis Antoniou <pantelis@embeddedalley.ocm> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2005-07-18[PATCH] ARM: 2818/1: BAST - Use platform device for SuperIO 16550sBen Dooks
Patch from Ben Dooks Use platform device for the 16500 UARTs in the onboard SuperIO controller. Signed-off-by: Ben Dooks <ben-linux@fluff.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2005-06-27[PATCH] Serial: Split 8250 port tableRussell King
Add separate files for the different 8250 ISA-based serial boards. Looking across all the various architectures, it seems reasonable that we can key the availability of the configuration options for these beasts to the bus-related symbols (iow, CONFIG_ISA). We also standardise the base baud/uart clock rate for these boards - I'm sure that isn't architecture specific, but is solely dependent on the crystal fitted on the board (which should be the same no matter what type of machine its fitted into.) Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2005-06-21[PATCH] ioc4: CONFIG splitBrent Casavant
The SGI IOC4 I/O controller chip drivers are currently all configured by CONFIG_BLK_DEV_SGIIOC4. This is undesirable as not all IOC4 hardware features are needed by all systems. This patch adds two configuration variables, CONFIG_SGI_IOC4 for core IOC4 driver support (see patch 1/3 in this series for further explanation) and CONFIG_SERIAL_SGI_IOC4 to independently enable serial port support. Signed-off-by: Brent Casavant <bcasavan@sgi.com> Acked-by: Pat Gefre <pfg@sgi.com> Acked-by: Jeremy Higdon <jeremy@sgi.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
