path: root/drivers/serial/8250_gsc.c
2008-02-088250_gsc: coding styleAlan Cox
Signed-off-by: Alan Cox <alan@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-10-04[PARISC] Clean up asm-parisc/serial.hMatthew Wilcox
Russell King pointed out that asm/serial.h is anachronistic and we were misusing BASE_BAUD. So fix BASE_BAUD for PCI 16550 UARTs, move LASI_BASE_BAUD into 8250_gsc, and fix the obsolete comment about reserving serial port slots. Signed-off-by: Matthew Wilcox <matthew@wil.cx> Signed-off-by: Kyle McMartin <kyle@parisc-linux.org>
2006-10-01[PATCH] ioremap balanced with iounmap for drivers/serial/8250_gsc.cAmol Lad
ioremap must be balanced by an iounmap and failing to do so can result in a memory leak. Signed-off-by: Amol Lad <amol@verismonetworks.com> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-30[PARISC] I/O-Space must be ioremap_nocache()'dHelge Deller
Addresses in F-space must be accessed uncached on most parisc machines. Signed-off-by: Helge Deller <deller@parisc-linux.org> Signed-off-by: Kyle McMartin <kyle@parisc-linux.org>
2005-10-21[PARISC] Fix mux.c driverMatthew Wilcox
Missing spin_lock_init() made the Mux driver hang on SMP systems. Fix up users of ->hpa to use ->hpa.start instead Remove warning in 8250_gsc.c by eliminating serial_line_nr Signed-off-by: Matthew Wilcox <willy@parisc-linux.org> Signed-off-by: Kyle McMartin <kyle@parisc-linux.org>
2005-10-21[PARISC] Convert parisc_device to use struct resource for hpaMatthew Wilcox
Convert pa_dev->hpa from an unsigned long to a struct resource. Signed-off-by: Matthew Wilcox <willy@parisc-linux.org> Fix up users of ->hpa to use ->hpa.start instead. Signed-off-by: Matthew Wilcox <willy@parisc-linux.org> Signed-off-by: Kyle McMartin <kyle@parisc-linux.org>
