path: root/drivers/scsi
2009-06-18Merge commit 'origin/master' into nextBenjamin Herrenschmidt
2009-06-17Merge git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi-misc-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi-misc-2.6: [SCSI] aic79xx: make driver respect nvram for IU and QAS settings [SCSI] don't attach ULD to Dell Universal Xport [SCSI] lpfc 8.3.3 : Update driver version to 8.3.3 [SCSI] lpfc 8.3.3 : Add support for Target Reset handler entrypoint [SCSI] lpfc 8.3.3 : Fix a couple of spin_lock and memory issues and a crash [SCSI] lpfc 8.3.3 : FC/FCOE discovery fixes [SCSI] lpfc 8.3.3 : Fix various SLI-3 vs SLI-4 differences [SCSI] qla2xxx: Resolve a performance issue in interrupt [SCSI] cnic, bnx2i: Fix build failure when CONFIG_PCI is not set. [SCSI] nsp_cs: time_out reaches -1 [SCSI] qla2xxx: fix printk format warnings [SCSI] ncr53c8xx: div reaches -1 [SCSI] compat: don't perform unneeded copy in sg_io code [SCSI] zfcp: Update FC pass-through support [SCSI] zfcp: Add FC pass-through support [SCSI] FC Pass Thru support
2009-06-17Merge commit 'origin/master' into nextBenjamin Herrenschmidt
2009-06-15debugfs: Fix terminology inconsistency of dir name to mount debugfs filesystem.GeunSik Lim
Many developers use "/debug/" or "/debugfs/" or "/sys/kernel/debug/" directory name to mount debugfs filesystem for ftrace according to ./Documentation/tracers/ftrace.txt file. And, three directory names(ex:/debug/, /debugfs/, /sys/kernel/debug/) is existed in kernel source like ftrace, DRM, Wireless, Documentation, Network[sky2]files to mount debugfs filesystem. debugfs means debug filesystem for debugging easy to use by greg kroah hartman. "/sys/kernel/debug/" name is suitable as directory name of debugfs filesystem. - debugfs related reference: http://lwn.net/Articles/334546/ Fix inconsistency of directory name to mount debugfs filesystem. * From Steven Rostedt - find_debugfs() and tracing_files() in this patch. Signed-off-by: GeunSik Lim <geunsik.lim@samsung.com> Acked-by : Inaky Perez-Gonzalez <inaky@linux.intel.com> Reviewed-by : Steven Rostedt <rostedt@goodmis.org> Reviewed-by : James Smart <james.smart@emulex.com> CC: Jiri Kosina <trivial@kernel.org> CC: David Airlie <airlied@linux.ie> CC: Peter Osterlund <petero2@telia.com> CC: Ananth N Mavinakayanahalli <ananth@in.ibm.com> CC: Anil S Keshavamurthy <anil.s.keshavamurthy@intel.com> CC: Masami Hiramatsu <mhiramat@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-06-15ibmvscsi: gadget: at91_udc: remove driver_data direct access of struct deviceGreg Kroah-Hartman
In the near future, the driver core is going to not allow direct access to the driver_data pointer in struct device. Instead, the functions dev_get_drvdata() and dev_set_drvdata() should be used. These functions have been around since the beginning, so are backwards compatible with all older kernel versions. Cc: linux-scsi@vger.kernel.org Cc: James Bottomley <James.Bottomley@HansenPartnership.com> Cc: Brian King <brking@linux.vnet.ibm.com> Cc: Robert Jennings <rcj@linux.vnet.ibm.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-06-15scsi: remove driver_data direct access of struct deviceGreg Kroah-Hartman
In the near future, the driver core is going to not allow direct access to the driver_data pointer in struct device. Instead, the functions dev_get_drvdata() and dev_set_drvdata() should be used. These functions have been around since the beginning, so are backwards compatible with all older kernel versions. Cc: linux-scsi@vger.kernel.org Cc: James Bottomley <James.Bottomley@HansenPartnership.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-06-16ps3rom: Use ps3_system_bus_[gs]et_drvdata() instead of direct accessGeert Uytterhoeven
Signed-off-by: Geert Uytterhoeven <Geert.Uytterhoeven@sonycom.com> Acked-by: James E.J. Bottomley <James.Bottomley@HansenPartnership.com> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2009-06-15[SCSI] aic79xx: make driver respect nvram for IU and QAS settingsJames Bottomley
This patch allows the Adaptec firmware to pass on its values for Packetize and QAS. To do this, the settings max_iu and max_qas have been introduced into the SPI transport class and populated from the adaptec NVram tables. Domain validation in the SPI transport class will respect the max settings when configuring to the highest possible speed for testing. Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2009-06-15[SCSI] don't attach ULD to Dell Universal XportJames Bottomley
We already have blacklists for SGI, IBM and SUN versions of this; apparently there's a Dell version too. Reported-by: Thomas Witzel <witzel.thomas@gmail.com> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2009-06-15[SCSI] lpfc 8.3.3 : Update driver version to 8.3.3James Smart
Signed-off-by: James Smart <James.Smart@emulex.com> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2009-06-15[SCSI] lpfc 8.3.3 : Add support for Target Reset handler entrypointJames Smart
Patch was originally submitted upstream on 4/21/2008: http://marc.info/?l=linux-scsi&m=120880973719266&w=2 Somewhere, it never get merged. The patch restructures the task mgmt routines, commonizing like behavior. Then the patch changes device reset to LUN resets, and adds a target reset handler. Signed-off-by: James Smart <james.smart@emulex.com> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2009-06-15[SCSI] lpfc 8.3.3 : Fix a couple of spin_lock and memory issues and a crashJames Smart
Contains the following changes: - Fixed error paths retaking a spin lock which they already hold - Added code to free memory in a couple of error paths - Added code to free RPI bit map while unloading driver - Added code to write zero to memory object allocated through dma_alloc_coherent - Fixed crash/hang with target or LUN resets Signed-off-by: James Smart <James.Smart@emulex.com> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2009-06-15[SCSI] lpfc 8.3.3 : FC/FCOE discovery fixesJames Smart
Contains the following changes: - Force vport to send LOGO to fabric controller when deleting vport - Fixed driver failing to register login when a PLOGI is received - Fixes for FIP discovery - Added stricter checks for FCF addressing mode - Added code to send only FLOGI, FDISC and LOGO to Fabric controller as FIP - Fixed handling of LOGO from Fabric port - Fixed consecutive link up events skipped link_down processing Signed-off-by: James Smart <James.Smart@emulex.com> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2009-06-15[SCSI] lpfc 8.3.3 : Fix various SLI-3 vs SLI-4 differencesJames Smart
Contains the following changes - Set the CT field of FDISC to 3 - Fixed over allocation of SCSI buffers on SLI4 - Removed unused jump table entries - Increase LPFC_WQE_DEF_COUNT to 256 - Updated FDISC context to VPI - Fixed immediate SCSI command for LUN reset translation to WQE - Extended mailbox handling to allow MBX_POLL commands in between async MBQ commands - Fixed SID used for FDISC - Fix crash when accessing ctlregs from sysfs for SLI4 HBAs - Fix SLI4 firmware version not being saved or displayed correctly - Expand CQID field in WQE structure to 16 bits - Fix post header template mailbox command timing out - Removed FCoE PCI device ID 0x0705 Signed-off-by: James Smart <James.Smart@emulex.com> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2009-06-15[SCSI] qla2xxx: Resolve a performance issue in interruptAnirban Chakraborty
Reverted back a change in qla*_intr_handler code that caused an increase in cpu cycles by allowing interrupts to occur while the instance hardware lock was being held. Fix by taking the lock in irqsave mode. Reported-and-tested-by: Douglas W. Styner <douglas.w.styner@intel.com> Signed-off-by: Anirban Chakraborty <anirban.chakraborty@qlogic.com> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2009-06-15[SCSI] cnic, bnx2i: Fix build failure when CONFIG_PCI is not set.Michael Chan
CNIC and BNX2I must depend on PCI. Dependencies do not get propagated through select. Signed-off-by: Michael Chan <mchan@broadcom.com> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2009-06-15[SCSI] nsp_cs: time_out reaches -1Roel Kluin
With a postfix decrement timeouts will reach -1 rather than 0, so the errors do not appear. Signed-off-by: Roel Kluin <roel.kluin@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2009-06-15[SCSI] qla2xxx: fix printk format warningsRandy Dunlap
Fix qla2xxx printk format warnings: drivers/scsi/qla2xxx/qla_sup.c:915: warning: long long unsigned int format, u64 arg (arg 5) drivers/scsi/qla2xxx/qla_sup.c:915: warning: long long unsigned int format, u64 arg (arg 6) drivers/scsi/qla2xxx/qla_sup.c:923: warning: long long unsigned int format, u64 arg (arg 5) drivers/scsi/qla2xxx/qla_sup.c:923: warning: long long unsigned int format, u64 arg (arg 6) Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Acked-by: Seokmann Ju <seokmann.ju@qlogic.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2009-06-15[SCSI] ncr53c8xx: div reaches -1Roel Kluin
With while(--div >= 0) { ... } div reaches -1. Signed-off-by: Roel Kluin <roel.kluin@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2009-06-15Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/torvalds/linux-2.6 Conflicts: Documentation/feature-removal-schedule.txt drivers/scsi/fcoe/fcoe.c net/core/drop_monitor.c net/core/net-traces.c
2009-06-14Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (31 commits) trivial: remove the trivial patch monkey's name from SubmittingPatches trivial: Fix a typo in comment of addrconf_dad_start() trivial: usb: fix missing space typo in doc trivial: pci hotplug: adding __init/__exit macros to sgi_hotplug trivial: Remove the hyphen from git commands trivial: fix ETIMEOUT -> ETIMEDOUT typos trivial: Kconfig: .ko is normally not included in module names trivial: SubmittingPatches: fix typo trivial: Documentation/dell_rbu.txt: fix typos trivial: Fix Pavel's address in MAINTAINERS trivial: ftrace:fix description of trace directory trivial: unnecessary (void*) cast removal in sound/oss/msnd.c trivial: input/misc: Fix typo in Kconfig trivial: fix grammo in bus_for_each_dev() kerneldoc trivial: rbtree.txt: fix rb_entry() parameters in sample code trivial: spelling fix in ppc code comments trivial: fix typo in bio_alloc kernel doc trivial: Documentation/rbtree.txt: cleanup kerneldoc of rbtree.txt trivial: Miscellaneous documentation typo fixes trivial: fix typo milisecond/millisecond for documentation and source comments. ...
2009-06-12[SCSI] FC Pass Thru supportJames Smart
Attached is the ELS/CT pass-thru patch for the FC Transport. The patch creates a generic framework that lays on top of bsg and the SGIO v4 ioctl in order to pass transaction requests to LLDD's. The interface supports the following operations: On an fc_host basis: Request login to the specified N_Port_ID, creating an fc_rport. Request logout of the specified N_Port_ID, deleting an fc_rport Send ELS request to specified N_Port_ID w/o requiring a login, and wait for ELS response. Send CT request to specified N_Port_ID and wait for CT response. Login is required, but LLDD is allowed to manage login and decide whether it stays in place after the request is satisfied. Vendor-Unique request. Allows a LLDD-specific request to be passed to the LLDD, and the passing of a response back to the application. On an fc_rport basis: Send ELS request to nport and wait for ELS response. Send CT request to nport and wait for CT response. The patch also exports several headers from include/scsi such that they can be available to user-space applications: include/scsi/scsi.h include/scsi/scsi_netlink.h include/scsi/scsi_netlink_fc.h include/scsi/scsi_bsg_fc.h For further information, refer to the last RFC: http://marc.info/?l=linux-scsi&m=123436574018579&w=2 Note: Documentation is still spotty and will be added later. [bharrosh@panasas.com: update for new block API] Signed-off-by: James Smart <james.smart@emulex.com> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2009-06-12trivial: fix typo milisecond/millisecond for documentation and source comments.Martin Olsson
Signed-off-by: Martin Olsson <martin@minimum.se> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2009-06-12trivial: fix typos s/paramter/parameter/ and s/excute/execute/ in ↵Martin Olsson
documentation and source comments. Signed-off-by: Martin Olsson <martin@minimum.se> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2009-06-12trivial: typo (en|dis|avail|remove)bale -> (en|dis|avail|remove)ableThadeu Lima de Souza Cascardo
Signed-off-by: Thadeu Lima de Souza Cascardo <cascardo@holoscopio.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2009-06-12[SCSI] Merge branch 'linus'James Bottomley
Conflicts: drivers/message/fusion/mptsas.c fixed up conflict between req->data_len accessors and mptsas driver updates. Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2009-06-11Merge branch 'for-2.6.31' of git://git.kernel.dk/linux-2.6-blockLinus Torvalds
* 'for-2.6.31' of git://git.kernel.dk/linux-2.6-block: (153 commits) block: add request clone interface (v2) floppy: fix hibernation ramdisk: remove long-deprecated "ramdisk=" boot-time parameter fs/bio.c: add missing __user annotation block: prevent possible io_context->refcount overflow Add serial number support for virtio_blk, V4a block: Add missing bounce_pfn stacking and fix comments Revert "block: Fix bounce limit setting in DM" cciss: decode unit attention in SCSI error handling code cciss: Remove no longer needed sendcmd reject processing code cciss: change SCSI error handling routines to work with interrupts enabled. cciss: separate error processing and command retrying code in sendcmd_withirq_core() cciss: factor out fix target status processing code from sendcmd functions cciss: simplify interface of sendcmd() and sendcmd_withirq() cciss: factor out core of sendcmd_withirq() for use by SCSI error handling code cciss: Use schedule_timeout_uninterruptible in SCSI error handling code block: needs to set the residual length of a bidi request Revert "block: implement blkdev_readpages" block: Fix bounce limit setting in DM Removed reference to non-existing file Documentation/PCI/PCI-DMA-mapping.txt ... Manually fix conflicts with tracing updates in: block/blk-sysfs.c drivers/ide/ide-atapi.c drivers/ide/ide-cd.c drivers/ide/ide-floppy.c drivers/ide/ide-tape.c include/trace/events/block.h kernel/trace/blktrace.c
2009-06-10Merge branch 'tracing-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'tracing-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (244 commits) Revert "x86, bts: reenable ptrace branch trace support" tracing: do not translate event helper macros in print format ftrace/documentation: fix typo in function grapher name tracing/events: convert block trace points to TRACE_EVENT(), fix !CONFIG_BLOCK tracing: add protection around module events unload tracing: add trace_seq_vprint interface tracing: fix the block trace points print size tracing/events: convert block trace points to TRACE_EVENT() ring-buffer: fix ret in rb_add_time_stamp ring-buffer: pass in lockdep class key for reader_lock tracing: add annotation to what type of stack trace is recorded tracing: fix multiple use of __print_flags and __print_symbolic tracing/events: fix output format of user stack tracing/events: fix output format of kernel stack tracing/trace_stack: fix the number of entries in the header ring-buffer: discard timestamps that are at the start of the buffer ring-buffer: try to discard unneeded timestamps ring-buffer: fix bug in ring_buffer_discard_commit ftrace: do not profile functions when disabled tracing: make trace pipe recognize latency format flag ...
2009-06-10[SCSI] osd: Remove out-of-tree left oversBoaz Harrosh
* Delete Makefile. It is only used for out-of-tree compilation and was never needed. It slipped in by mistake. * Remove from Kbuild all the out of tree stuff as promised. Signed-off-by: Boaz Harrosh <bharrosh@panasas.com> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2009-06-10[SCSI] libosd: Use REQ_QUIET requests.Boaz Harrosh
libosd has it's own sense decoding and printout. Don't let scsi_lib duplicate that printout. (Which is done wrong in regard to osd commands) Signed-off-by: Boaz Harrosh <bharrosh@panasas.com> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2009-06-10[SCSI] osduld: use filp_open() when looking up an osd-deviceBoaz Harrosh
This patch was inspired by Al Viro, for simplifying and fixing the retrieval of osd-devices by in-kernel users, eg: file systems. In-Kernel users, now, go through the same path user-mode does by opening a file on the osd char-device and though holding a reference to both the device and the Module. A file pointer was added to the osd_dev structure which is now allocated for each user. The internal osd_dev is no longer exposed outside of the uld. I wanted to do that for a long time so each libosd user can have his own defaults on the device. The API is left the same, so user code need not change. It is no longer needed to open/close a file handle on the osd char-device from user-mode, before mounting an exofs on it. Signed-off-by: Boaz Harrosh <bharrosh@panasas.com> CC: Al Viro <viro@ZenIV.linux.org.uk> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2009-06-10[SCSI] libosd: Define an osd_dev wrapper to retrieve the request_queueBoaz Harrosh
libosd users that need to work with bios, must sometime use the request_queue associated with the osd_dev. Make a wrapper for that, and convert all in-tree users. Signed-off-by: Boaz Harrosh <bharrosh@panasas.com> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2009-06-10[SCSI] libosd: osd_req_{read,write} takes a length parameterBoaz Harrosh
For supporting of chained-bios we can not inspect the first bio only, as before. Caller shall pass the total length of the request, ie. sum_bytes(bio-chain). Also since the bio might be a chain we don't set it's direction on behalf of it's callers. The bio direction should be properly set prior to this call. So fix a couple of write users that now need to set the bio direction properly [In this patch I change both library code and user sites at exofs, to make it easy on integration. It should be submitted via James's scsi-misc tree.] Signed-off-by: Boaz Harrosh <bharrosh@panasas.com> CC: Jeff Garzik <jeff@garzik.org> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2009-06-10[SCSI] libosd: Let _osd_req_finalize_data_integrity receive number of out_bytesBoaz Harrosh
_osd_req_finalize_data_integrity was trying to deduce the number of out_bytes from passed osd_request->out.bio. This is wrong when the bio is chained. The caller of _osd_req_finalize_data_integrity has more ready available information and should just pass it. Also in the light of future support for CDB-continuation segment this is a better solution. Signed-off-by: Boaz Harrosh <bharrosh@panasas.com> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2009-06-10[SCSI] libosd: osd_req_{read,write}_kern new APIBoaz Harrosh
By popular demand, define usefull wrappers for osd_req_read/write that recieve kernel pointers. All users had their own. Also remove these from exofs Signed-off-by: Boaz Harrosh <bharrosh@panasas.com> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2009-06-10[SCSI] libosd: Better printout of OSD target system informationBoaz Harrosh
Shorten out the Attributes names. Align all results on column 24. Print system ID in a new line. Signed-off-by: Boaz Harrosh <bharrosh@panasas.com> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2009-06-09[SCSI] gdth: fix overlapping snprintf usersAlan Cox
Closes-bug: http://bugzilla.kernel.org/show_bug.cgi?id=13438 Closes-bug: http://bugzilla.kernel.org/show_bug.cgi?id=13437 Signed-off-by: Alan Cox <alan@linux.intel.com> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2009-06-09[SCSI] bnx2i: Add bnx2i iSCSI driver.Michael Chan
New iSCSI driver for Broadcom BNX2 devices. The driver interfaces with the CNIC driver to access the hardware. Signed-off-by: Anil Veerabhadrappa <anilgv@broadcom.com> Signed-off-by: Michael Chan <mchan@broadcom.com> Signed-off-by: Mike Christie <michaelc@cs.wisc.edu> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2009-06-09[SCSI] iscsi class: Add new NETLINK_ISCSI messages for cnic/bnx2i driver.Michael Chan
Add ISCSI_NETLINK messages for iSCSI NICs to get information such as path from userspace. Original iscsid messages are now always sent as multicast to group 1. The new messages are sent to group 2. The multicast changes were made by Mike Christie. Signed-off-by: Michael Chan <mchan@broadcom.com> Signed-off-by: Benjamin Li <benli@broadcom.com> Signed-off-by: Mike Christie <michaelc@cs.wisc.edu> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2009-06-08[SCSI] ibmvscsi: Add support for capabilities MADBrian King
Add support to ibmvscsi for the capabilities MAD. This command gets sent to the Virtual I/O server prior to login in order to communicate client capabilities. Additionally it returns information regarding capabilities that the server supports. The two main capabilities communicated in this MAD are related to partition migration and client reserve. Client reserve allows for SCSI-2 reservations to be sent to virtual disks which are backed by physical LUNs and will result in the reservation being sent to the physical LUN. Signed-off-by: Brian King <brking@linux.vnet.ibm.com> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2009-06-08[SCSI] ibmvscsi: Enable fast fail featureRobert Jennings
A new mode of error reporting, fast fail, has been added to the VIOS which allows failover to happen more quickly. If this new fast fail mode is enabled on the VIOS and the vSCSI client supports the mode, the VIOS will not return MEDIUM error on path failures, but rather return VIOSRP_ADAPTER_FAIL in the crq response, which ibmvscsi will translate to DID_ERROR. This new mode can be enabled for single path configurations as well, so it is the new default error reporting mode. A module parameter is provided to disable this new behavior on the off chance it causes a problem on some old VIOS version. Signed-off-by: Brian King <brking@linux.vnet.ibm.com> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2009-06-08[SCSI] ibmvscsi: Send adapter info before loginBrian King
The ibmvscsi driver currently sends the SRP Login before sending the Adapter Info MAD, which can result in commands getting sent to the virtual adapter before we are ready for them. This results in a slight window where the target devices may not behave as expected. Change the order and close the window. Signed-off-by: Brian King <brking@linux.vnet.ibm.com> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2009-06-08[SCSI] ibmvscsi: Add specific timeouts for operationsRobert Jennings
Previously we had one timeout that was used for all types of operations. This adds specific timeout values for different operations (init, login, adapter info MAD, abort task, and LUN reset). Signed-off-by: Brian King <brking@linux.vnet.ibm.com> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2009-06-08[SCSI] ibmvscsi: Add 16 byte CDB supportBrian King
Adds support for 16 byte CDBs to the ibmvscsi driver. Signed-off-by: Brian King <brking@linux.vnet.ibm.com> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2009-06-08[SCSI] qla2xxx: Update version number to 8.03.01-k3.Andrew Vasquez
Signed-off-by: Andrew Vasquez <andrew.vasquez@qlogic.com> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2009-06-08[SCSI] qla2xxx: Synchronize MPI settings after a PE Reset.Andrew Vasquez
Ensure MPS remains in synchronization across all NIC/FCoE functions after a reset. Signed-off-by: Andrew Vasquez <andrew.vasquez@qlogic.com> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2009-06-08[SCSI] qla2xxx: Export additional firmware-states for application support.Andrew Vasquez
2009-06-08[SCSI] qla2xxx: Reduce lock-contention during do-work processing.Andrew Vasquez
Queued work processing will now be serialized with its own lower-priority spinlock. This also simplifies the work-queue interface for future work-queue consumers. Signed-off-by: Andrew Vasquez <andrew.vasquez@qlogic.com> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2009-06-08[SCSI] qla2xxx: Avoid explicit LOGO during driver host tear-down.Andrew Vasquez
As firmware will ultimately terminate (stop) and port states-cleared. Signed-off-by: Andrew Vasquez <andrew.vasquez@qlogic.com> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2009-06-08[SCSI] qla2xxx: Query supported RISC registers bits in determining a ↵Andrew Vasquez
paused-state. ISP24xx and above must query the host-status register, not HCCR. Signed-off-by: Andrew Vasquez <andrew.vasquez@qlogic.com> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
