path: root/drivers/scsi
2015-05-31Merge git://git.kernel.org/pub/scm/linux/kernel/git/nab/target-pendingLinus Torvalds
Pull SCSI target fixes from Nicholas Bellinger: "These are mostly minor fixes, with the exception of the following that address fall-out from recent v4.1-rc1 changes: - regression fix related to the big fabric API registration changes and configfs_depend_item() usage, that required cherry-picking one of HCH's patches from for-next to address the issue for v4.1 code. - remaining TCM-USER -v2 related changes to enforce full CDB passthrough from Andy + Ilias. Also included is a target_core_pscsi driver fix from Andy that addresses a long standing issue with a Scsi_Host reference being leaked on PSCSI device shutdown" * git://git.kernel.org/pub/scm/linux/kernel/git/nab/target-pending: iser-target: Fix error path in isert_create_pi_ctx() target: Use a PASSTHROUGH flag instead of transport_types target: Move passthrough CDB parsing into a common function target/user: Only support full command pass-through target/user: Update example code for new ABI requirements target/pscsi: Don't leak scsi_host if hba is VIRTUAL_HOST target: Fix se_tpg_tfo->tf_subsys regression + remove tf_subsystem target: Drop signal_pending checks after interruptible lock acquire target: Add missing parentheses target: Fix bidi command handling target/user: Disallow full passthrough (pass_level=0) ISCSI: fix minor memory leak
2015-05-30target: Fix se_tpg_tfo->tf_subsys regression + remove tf_subsystemChristoph Hellwig
There is just one configfs subsystem in the target code, so we might as well add two helpers to reference / unreference it from the core code instead of passing pointers to it around. This fixes a regression introduced for v4.1-rc1 with commit 9ac8928e6, where configfs_depend_item() callers using se_tpg_tfo->tf_subsys would fail, because the assignment from the original target_core_subsystem[] is no longer happening at target_register_template() time. (Fix target_core_exit_configfs pointer dereference - Sagi) Signed-off-by: Christoph Hellwig <hch@lst.de> Reported-by: Himanshu Madhani <himanshu.madhani@qlogic.com> Signed-off-by: Nicholas Bellinger <nab@linux-iscsi.org>
2015-05-18MAINTAINERS, be2iscsi: change email domainMinh Tran
be2iscsi change of ownership from Emulex to Avago Technologies recently. We like to get the following updates in: changed "Emulex" to "Avago Technologies", changed email addresses from "emulex.com" to "avagotech.com", updated MAINTAINER list for be2iscsi driver. Signed-off-by: Minh Tran <minh.tran@avagotech.com> Signed-off-by: Jayamohan Kallickal <jayamohan.kallickal@avagotech.com> Signed-off-by: James Bottomley <JBottomley@Odin.com>
2015-05-18sd: Disable support for 256 byte/sector disksMark Hounschell
256 bytes per sector support has been broken since 2.6.X, and no-one stepped up to fix this. So disable support for it. Signed-off-by: Mark Hounschell <dmarkh@cfl.rr.com> Signed-off-by: Hannes Reinecke <hare@suse.de> Cc: stable@vger.kernel.org Signed-off-by: James Bottomley <JBottomley@Odin.com>
2015-05-11lpfc: Fix breakage on big endian kernelsAlexey Kardashevskiy
This reverts 4fbdf9cb it breaks LPFC on POWER7 machine, big endian kernel. Without this, the kernel enters an infinite oops loop. This is the hardware used for verification: 0005:01:00.0 Fibre Channel [0c04]: Emulex Corporation Saturn-X: LightPulse Fibre Channel Host Adapter [10df:f100] (rev 03) 0005:01:00.1 Fibre Channel [0c04]: Emulex Corporation Saturn-X: LightPulse Fibre Channel Host Adapter [10df:f100] (rev 03) Signed-off-by: Alexey Kardashevskiy <aik@ozlabs.ru> Reviewed-by: James Smart <james.smart@emulex.com> Signed-off-by: James Bottomley <JBottomley@Odin.com>
2015-05-11storvsc: Set the SRB flags correctly when no data transfer is neededK. Y. Srinivasan
Set the SRB flags correctly when there is no data transfer. Without this change some IHV drivers will fail valid commands such as TEST_UNIT_READY. Cc: <stable@vger.kernel.org> Signed-off-by: K. Y. Srinivasan <kys@microsoft.com> Reviewed-by: Long Li <longli@microsoft.com> Signed-off-by: James Bottomley <JBottomley@Odin.com>
2015-04-273w-9xxx: fix command completion raceChristoph Hellwig
The 3w-9xxx driver needs to tear down the dma mappings before returning the command to the midlayer, as there is no guarantee the sglist and count are valid after that point. Also remove the dma mapping helpers which have another inherent race due to the request_id index. Signed-off-by: Christoph Hellwig <hch@lst.de> Cc: stable@vger.kernel.org Acked-by: Adam Radford <aradford@gmail.com> Signed-off-by: James Bottomley <JBottomley@Odin.com>
2015-04-273w-xxxx: fix command completion raceChristoph Hellwig
The 3w-xxxx driver needs to tear down the dma mappings before returning the command to the midlayer, as there is no guarantee the sglist and count are valid after that point. Also remove the dma mapping helpers which have another inherent race due to the request_id index. Signed-off-by: Christoph Hellwig <hch@lst.de> Cc: stable@vger.kernel.org Acked-by: Adam Radford <aradford@gmail.com> Signed-off-by: James Bottomley <JBottomley@Odin.com>
2015-04-273w-sas: fix command completion raceChristoph Hellwig
The 3w-sas driver needs to tear down the dma mappings before returning the command to the midlayer, as there is no guarantee the sglist and count are valid after that point. Also remove the dma mapping helpers which have another inherent race due to the request_id index. Signed-off-by: Christoph Hellwig <hch@lst.de> Reported-by: Torsten Luettgert <ml-lkml@enda.eu> Tested-by: Bernd Kardatzki <Bernd.Kardatzki@med.uni-tuebingen.de> Cc: stable@vger.kernel.org Acked-by: Adam Radford <aradford@gmail.com> Signed-off-by: James Bottomley <JBottomley@Odin.com>
2015-04-27aha1542: Allocate memory before taking a lockOndrej Zary
The driver currently calls kmalloc with GFP_KERNEL while holding a lock. Fix it by doing the allocation earlier, before taking the lock. Tested on AHA-1542B. Signed-off-by: Ondrej Zary <linux@rainbow-software.org> Signed-off-by: James Bottomley <JBottomley@Odin.com>
2015-04-27SCSI: add 1024 max sectors black list flagMike Christie
This works around a issue with qnap iscsi targets not handling large IOs very well. The target returns: VPD INQUIRY: Block limits page (SBC) Maximum compare and write length: 1 blocks Optimal transfer length granularity: 1 blocks Maximum transfer length: 4294967295 blocks Optimal transfer length: 4294967295 blocks Maximum prefetch, xdread, xdwrite transfer length: 0 blocks Maximum unmap LBA count: 8388607 Maximum unmap block descriptor count: 1 Optimal unmap granularity: 16383 Unmap granularity alignment valid: 0 Unmap granularity alignment: 0 Maximum write same length: 0xffffffff blocks Maximum atomic transfer length: 0 Atomic alignment: 0 Atomic transfer length granularity: 0 and it is *sometimes* able to handle at least one IO of size up to 8 MB. We have seen in traces where it will sometimes work, but other times it looks like it fails and it looks like it returns failures if we send multiple large IOs sometimes. Also it looks like it can return 2 different errors. It will sometimes send iscsi reject errors indicating out of resources or it will send invalid cdb illegal requests check conditions. And then when it sends iscsi rejects it does not seem to handle retries when there are command sequence holes, so I could not just add code to try and gracefully handle that error code. The problem is that we do not have a good contact for the company, so we are not able to determine under what conditions it returns which error and why it sometimes works. So, this patch just adds a new black list flag to set targets like this to the old max safe sectors of 1024. The max_hw_sectors changes added in 3.19 caused this regression, so I also ccing stable. Reported-by: Christian Hesse <list@eworm.de> Signed-off-by: Mike Christie <michaelc@cs.wisc.edu> Cc: stable@vger.kernel.org Reviewed-by: Christoph Hellwig <hch@lst.de> Signed-off-by: James Bottomley <JBottomley@Odin.com>
2015-04-24Merge branch 'for-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/nab/target-pending Pull SCSI target updates from Nicholas Bellinger: "Lots of activity in target land the last months. The highlights include: - Convert fabric drivers tree-wide to target_register_template() (hch + bart) - iser-target hardening fixes + v1.0 improvements (sagi) - Convert iscsi_thread_set usage to kthread.h + kill iscsi_target_tq.c (sagi + nab) - Add support for T10-PI WRITE_STRIP + READ_INSERT operation (mkp + sagi + nab) - DIF fixes for CONFIG_DEBUG_SG=y + UNMAP file emulation (akinobu + sagi + mkp) - Extended TCMU ABI v2 for future BIDI + DIF support (andy + ilias) - Fix COMPARE_AND_WRITE handling for NO_ALLLOC drivers (hch + nab) Thanks to everyone who contributed this round with new features, bug-reports, fixes, cleanups and improvements. Looking forward, it's currently shaping up to be a busy v4.2 as well" * 'for-next' of git://git.kernel.org/pub/scm/linux/kernel/git/nab/target-pending: (69 commits) target: Put TCMU under a new config option target: Version 2 of TCMU ABI target: fix tcm_mod_builder.py target/file: Fix UNMAP with DIF protection support target/file: Fix SG table for prot_buf initialization target/file: Fix BUG() when CONFIG_DEBUG_SG=y and DIF protection enabled target: Make core_tmr_abort_task() skip TMFs target/sbc: Update sbc_dif_generate pr_debug output target/sbc: Make internal DIF emulation honor ->prot_checks target/sbc: Return INVALID_CDB_FIELD if DIF + sess_prot_type disabled target: Ensure sess_prot_type is saved across session restart target/rd: Don't pass incomplete scatterlist entries to sbc_dif_verify_* target: Remove the unused flag SCF_ACK_KREF target: Fix two sparse warnings target: Fix COMPARE_AND_WRITE with SG_TO_MEM_NOALLOC handling target: simplify the target template registration API target: simplify target_xcopy_init_pt_lun target: remove the unused SCF_CMD_XCOPY_PASSTHROUGH flag target/rd: reduce code duplication in rd_execute_rw() tcm_loop: fixup tpgt string to integer conversion ...
2015-04-20Merge tag 'scsi-misc' of git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsiLinus Torvalds
Pull SCSI fixes from James Bottomley: "I'd like to say these were a set of regressions for the recent merge window code. Unfortunately, they all predate the merge window code (stable cc'd). There are two fixes for data integrity (mostly only showing up on module removal), an mvsas crash with expander attached SATA devices which goes back to the dawn of the driver but is only just being picked up as sas expanders become a standard item in low end server hardware, an am53c974 one because the interrupt data isn't fully initialised before the line is and a megaraid_sas one because it uses smp_processor_id() to select MSI-X queues and that now triggers a WARN_ON()" * tag 'scsi-misc' of git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi: mvsas: fix panic on expander attached SATA devices am53c974: Fix crash during modprobe megaraid_sas: use raw_smp_processor_id() sd: Fix missing ATO tag check sd: Unregister integrity profile
2015-04-20Merge tag 'cpumask-next-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux Pull final removal of deprecated cpus_* cpumask functions from Rusty Russell: "This is the final removal (after several years!) of the obsolete cpus_* functions, prompted by their mis-use in staging. With these function removed, all cpu functions should only iterate to nr_cpu_ids, so we finally only allocate that many bits when cpumasks are allocated offstack" * tag 'cpumask-next-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux: (25 commits) cpumask: remove __first_cpu / __next_cpu cpumask: resurrect CPU_MASK_CPU0 linux/cpumask.h: add typechecking to cpumask_test_cpu cpumask: only allocate nr_cpumask_bits. Fix weird uses of num_online_cpus(). cpumask: remove deprecated functions. mips: fix obsolete cpumask_of_cpu usage. x86: fix more deprecated cpu function usage. ia64: remove deprecated cpus_ usage. powerpc: fix deprecated CPU_MASK_CPU0 usage. CPU_MASK_ALL/CPU_MASK_NONE: remove from deprecated region. staging/lustre/o2iblnd: Don't use cpus_weight staging/lustre/libcfs: replace deprecated cpus_ calls with cpumask_ staging/lustre/ptlrpc: Do not use deprecated cpus_* functions blackfin: fix up obsolete cpu function usage. parisc: fix up obsolete cpu function usage. tile: fix up obsolete cpu function usage. arm64: fix up obsolete cpu function usage. mips: fix up obsolete cpu function usage. x86: fix up obsolete cpu function usage. ...
2015-04-17mvsas: fix panic on expander attached SATA devicesJames Bottomley
mvsas is giving a General protection fault when it encounters an expander attached ATA device. Analysis of mvs_task_prep_ata() shows that the driver is assuming all ATA devices are locally attached and obtaining the phy mask by indexing the local phy table (in the HBA structure) with the phy id. Since expanders have many more phys than the HBA, this is causing the index into the HBA phy table to overflow and returning rubbish as the pointer. mvs_task_prep_ssp() instead does the phy mask using the port properties. Mirror this in mvs_task_prep_ata() to fix the panic. Reported-by: Adam Talbot <ajtalbot1@gmail.com> Tested-by: Adam Talbot <ajtalbot1@gmail.com> Cc: <stable@vger.kernel.org> Signed-off-by: James Bottomley <JBottomley@Odin.com>
2015-04-17am53c974: Fix crash during modprobeHannes Reinecke
On systems with shared interrupts the interrupt routine might be called as soon as the interrupt is enabled. As this might happen before pci_set_drvdata() is called the system would crash. Reported-by: Andreas Brogle <anbro@ok.de> Tested-by: Andreas Brogle <anbro@ok.de> Signed-off-by: Hannes Reinecke <hare@suse.de> Signed-off-by: James Bottomley <JBottomley@Odin.com>
2015-04-17Merge branch 'akpm' (patches from Andrew)Linus Torvalds
Merge third patchbomb from Andrew Morton: - various misc things - a couple of lib/ optimisations - provide DIV_ROUND_CLOSEST_ULL() - checkpatch updates - rtc tree - befs, nilfs2, hfs, hfsplus, fatfs, adfs, affs, bfs - ptrace fixes - fork() fixes - seccomp cleanups - more mmap_sem hold time reductions from Davidlohr * emailed patches from Andrew Morton <akpm@linux-foundation.org>: (138 commits) proc: show locks in /proc/pid/fdinfo/X docs: add missing and new /proc/PID/status file entries, fix typos drivers/rtc/rtc-at91rm9200.c: make IO endian agnostic Documentation/spi/spidev_test.c: fix warning drivers/rtc/rtc-s5m.c: allow usage on device type different than main MFD type .gitignore: ignore *.tar MAINTAINERS: add Mediatek SoC mailing list tomoyo: reduce mmap_sem hold for mm->exe_file powerpc/oprofile: reduce mmap_sem hold for exe_file oprofile: reduce mmap_sem hold for mm->exe_file mips: ip32: add platform data hooks to use DS1685 driver lib/Kconfig: fix up HAVE_ARCH_BITREVERSE help text x86: switch to using asm-generic for seccomp.h sparc: switch to using asm-generic for seccomp.h powerpc: switch to using asm-generic for seccomp.h parisc: switch to using asm-generic for seccomp.h mips: switch to using asm-generic for seccomp.h microblaze: use asm-generic for seccomp.h arm: use asm-generic for seccomp.h seccomp: allow COMPAT sigreturn overrides ...
2015-04-17bfs: bfad_worker cleanupJiri Slaby
This kthread is not loop at all due to break at the end of the loop. Make that function linear, with no while loop. And remove an unnecessary cast. Signed-off-by: Jiri Slaby <jslaby@suse.cz> Cc: Anil Gurumurthy <anil.gurumurthy@qlogic.com> Cc: James Bottomley <James.Bottomley@HansenPartnership.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-04-16Merge tag 'scsi-misc' of git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsiLinus Torvalds
Pull SCSI updates from James Bottomley: "This is the usual grab bag of driver updates (lpfc, qla2xxx, storvsc, aacraid, ipr) plus an assortment of minor updates. There's also a major update to aic1542 which moves the driver into this millenium" * tag 'scsi-misc' of git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi: (106 commits) change SCSI Maintainer email sd, mmc, virtio_blk, string_helpers: fix block size units ufs: add support to allow non standard behaviours (quirks) ufs-qcom: save controller revision info in internal structure qla2xxx: Update driver version to 8.07.00.18-k qla2xxx: Restore physical port WWPN only, when port down detected for FA-WWPN port. qla2xxx: Fix virtual port configuration, when switch port is disabled/enabled. qla2xxx: Prevent multiple firmware dump collection for ISP27XX. qla2xxx: Disable Interrupt handshake for ISP27XX. qla2xxx: Add debugging info for MBX timeout. qla2xxx: Add serdes read/write support for ISP27XX qla2xxx: Add udev notification to save fw dump for ISP27XX qla2xxx: Add message for sucessful FW dump collected for ISP27XX. qla2xxx: Add support to load firmware from file for ISP 26XX/27XX. qla2xxx: Fix beacon blink for ISP27XX. qla2xxx: Increase the wait time for firmware to be ready for P3P. qla2xxx: Fix crash due to wrong casting of reg for ISP27XX. qla2xxx: Fix warnings reported by static checker. lpfc: Update version to 10.5.0.0 for upstream patch set lpfc: Update copyright to 2015 ...
2015-04-16Merge tag 'stable/for-linus-4.1-rc0-tag' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/xen/tip Pull xen features and fixes from David Vrabel: - use a single source list of hypercalls, generating other tables etc. at build time. - add a "Xen PV" APIC driver to support >255 VCPUs in PV guests. - significant performance improve to guest save/restore/migration. - scsiback/front save/restore support. - infrastructure for multi-page xenbus rings. - misc fixes. * tag 'stable/for-linus-4.1-rc0-tag' of git://git.kernel.org/pub/scm/linux/kernel/git/xen/tip: xen/pci: Try harder to get PXM information for Xen xenbus_client: Extend interface to support multi-page ring xen-pciback: also support disabling of bus-mastering and memory-write-invalidate xen: support suspend/resume in pvscsi frontend xen: scsiback: add LUN of restored domain xen-scsiback: define a pr_fmt macro with xen-pvscsi xen/mce: fix up xen_late_init_mcelog() error handling xen/privcmd: improve performance of MMAPBATCH_V2 xen: unify foreign GFN map/unmap for auto-xlated physmap guests x86/xen/apic: WARN with details. x86/xen: Provide a "Xen PV" APIC driver to support >255 VCPUs xen/pciback: Don't print scary messages when unsupported by hypervisor. xen: use generated hypercall symbols in arch/x86/xen/xen-head.S xen: use generated hypervisor symbols in arch/x86/xen/trace.c xen: synchronize include/xen/interface/xen.h with xen xen: build infrastructure for generating hypercall depending symbols xen: balloon: Use static attribute groups for sysfs entries xen: pcpu: Use static attribute groups for sysfs entry
2015-04-16Merge tag 'powerpc-4.1-1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mpe/linux Pull powerpc updates from Michael Ellerman: - Numerous minor fixes, cleanups etc. - More EEH work from Gavin to remove its dependency on device_nodes. - Memory hotplug implemented entirely in the kernel from Nathan Fontenot. - Removal of redundant CONFIG_PPC_OF by Kevin Hao. - Rewrite of VPHN parsing logic & tests from Greg Kurz. - A fix from Nish Aravamudan to reduce memory usage by clamping nodes_possible_map. - Support for pstore on powernv from Hari Bathini. - Removal of old powerpc specific byte swap routines by David Gibson. - Fix from Vasant Hegde to prevent the flash driver telling you it was flashing your firmware when it wasn't. - Patch from Ben Herrenschmidt to add an OPAL heartbeat driver. - Fix for an oops causing get/put_cpu_var() imbalance in perf by Jan Stancek. - Some fixes for migration from Tyrel Datwyler. - A new syscall to switch the cpu endian by Michael Ellerman. - Large series from Wei Yang to implement SRIOV, reviewed and acked by Bjorn. - A fix for the OPAL sensor driver from Cédric Le Goater. - Fixes to get STRICT_MM_TYPECHECKS building again by Michael Ellerman. - Large series from Daniel Axtens to make our PCI hooks per PHB rather than per machine. - Small patch from Sam Bobroff to explicitly abort non-suspended transactions on syscalls, plus a test to exercise it. - Numerous reworks and fixes for the 24x7 PMU from Sukadev Bhattiprolu. - Small patch to enable the hard lockup detector from Anton Blanchard. - Fix from Dave Olson for missing L2 cache information on some CPUs. - Some fixes from Michael Ellerman to get Cell machines booting again. - Freescale updates from Scott: Highlights include BMan device tree nodes, an MSI erratum workaround, a couple minor performance improvements, config updates, and misc fixes/cleanup. * tag 'powerpc-4.1-1' of git://git.kernel.org/pub/scm/linux/kernel/git/mpe/linux: (196 commits) powerpc/powermac: Fix build error seen with powermac smp builds powerpc/pseries: Fix compile of memory hotplug without CONFIG_MEMORY_HOTREMOVE powerpc: Remove PPC32 code from pseries specific find_and_init_phbs() powerpc/cell: Fix iommu breakage caused by controller_ops change powerpc/eeh: Fix crash in eeh_add_device_early() on Cell powerpc/perf: Cap 64bit userspace backtraces to PERF_MAX_STACK_DEPTH powerpc/perf/hv-24x7: Fail 24x7 initcall if create_events_from_catalog() fails powerpc/pseries: Correct memory hotplug locking powerpc: Fix missing L2 cache size in /sys/devices/system/cpu powerpc: Add ppc64 hard lockup detector support oprofile: Disable oprofile NMI timer on ppc64 powerpc/perf/hv-24x7: Add missing put_cpu_var() powerpc/perf/hv-24x7: Break up single_24x7_request powerpc/perf/hv-24x7: Define update_event_count() powerpc/perf/hv-24x7: Whitespace cleanup powerpc/perf/hv-24x7: Define add_event_to_24x7_request() powerpc/perf/hv-24x7: Rename hv_24x7_event_update powerpc/perf/hv-24x7: Move debug prints to separate function powerpc/perf/hv-24x7: Drop event_24x7_request() powerpc/perf/hv-24x7: Use pr_devel() to log message ... Conflicts: tools/testing/selftests/powerpc/Makefile tools/testing/selftests/powerpc/tm/Makefile
2015-04-16megaraid_sas: use raw_smp_processor_id()Christoph Hellwig
We only want to steer the I/O completion towards a queue, but don't actually access any per-CPU data, so the raw_ version is fine to use and avoids the warnings when using smp_processor_id(). Signed-off-by: Christoph Hellwig <hch@lst.de> Reported-by: Andy Lutomirski <luto@kernel.org> Tested-by: Andy Lutomirski <luto@kernel.org> Acked-by: Sumit Saxena <sumit.saxena@avagotech.com> Cc: <stable@vger.kernel.org> Signed-off-by: James Bottomley <JBottomley@Odin.com>
2015-04-16sd: Fix missing ATO tag checkMartin K. Petersen
3aec2f41a8bae introduced a merge error where we would end up check for sdkp instead of sdkp->ATO. Fix this so we register app tag capability correctly. Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com> Cc: <stable@vger.kernel.org> # v3.17+ Reviewed-by: Sagi Grimberg <sagig@mellanox.com> Signed-off-by: James Bottomley <JBottomley@Odin.com>
2015-04-16sd: Unregister integrity profileMartin K. Petersen
The new integrity code did not correctly unregister the profile for SD disks. Call blk_integrity_unregister() when we release a disk. Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com> Reported-by: Sagi Grimberg <sagig@dev.mellanox.co.il> Tested-by: Sagi Grimberg <sagig@mellanox.com> Cc: stable@vger.kernel.org # v3.17+ Signed-off-by: James Bottomley <JBottomley@Odin.com>
2015-04-15Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-nextLinus Torvalds
Pull networking updates from David Miller: 1) Add BQL support to via-rhine, from Tino Reichardt. 2) Integrate SWITCHDEV layer support into the DSA layer, so DSA drivers can support hw switch offloading. From Floria Fainelli. 3) Allow 'ip address' commands to initiate multicast group join/leave, from Madhu Challa. 4) Many ipv4 FIB lookup optimizations from Alexander Duyck. 5) Support EBPF in cls_bpf classifier and act_bpf action, from Daniel Borkmann. 6) Remove the ugly compat support in ARP for ugly layers like ax25, rose, etc. And use this to clean up the neigh layer, then use it to implement MPLS support. All from Eric Biederman. 7) Support L3 forwarding offloading in switches, from Scott Feldman. 8) Collapse the LOCAL and MAIN ipv4 FIB tables when possible, to speed up route lookups even further. From Alexander Duyck. 9) Many improvements and bug fixes to the rhashtable implementation, from Herbert Xu and Thomas Graf. In particular, in the case where an rhashtable user bulk adds a large number of items into an empty table, we expand the table much more sanely. 10) Don't make the tcp_metrics hash table per-namespace, from Eric Biederman. 11) Extend EBPF to access SKB fields, from Alexei Starovoitov. 12) Split out new connection request sockets so that they can be established in the main hash table. Much less false sharing since hash lookups go direct to the request sockets instead of having to go first to the listener then to the request socks hashed underneath. From Eric Dumazet. 13) Add async I/O support for crytpo AF_ALG sockets, from Tadeusz Struk. 14) Support stable privacy address generation for RFC7217 in IPV6. From Hannes Frederic Sowa. 15) Hash network namespace into IP frag IDs, also from Hannes Frederic Sowa. 16) Convert PTP get/set methods to use 64-bit time, from Richard Cochran. * git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next: (1816 commits) fm10k: Bump driver version to 0.15.2 fm10k: corrected VF multicast update fm10k: mbx_update_max_size does not drop all oversized messages fm10k: reset head instead of calling update_max_size fm10k: renamed mbx_tx_dropped to mbx_tx_oversized fm10k: update xcast mode before synchronizing multicast addresses fm10k: start service timer on probe fm10k: fix function header comment fm10k: comment next_vf_mbx flow fm10k: don't handle mailbox events in iov_event path and always process mailbox fm10k: use separate workqueue for fm10k driver fm10k: Set PF queues to unlimited bandwidth during virtualization fm10k: expose tx_timeout_count as an ethtool stat fm10k: only increment tx_timeout_count in Tx hang path fm10k: remove extraneous "Reset interface" message fm10k: separate PF only stats so that VF does not display them fm10k: use hw->mac.max_queues for stats fm10k: only show actual queues, not the maximum in hardware fm10k: allow creation of VLAN on default vid fm10k: fix unused warnings ...
2015-04-15xenbus_client: Extend interface to support multi-page ringWei Liu
Originally Xen PV drivers only use single-page ring to pass along information. This might limit the throughput between frontend and backend. The patch extends Xenbus driver to support multi-page ring, which in general should improve throughput if ring is the bottleneck. Changes to various frontend / backend to adapt to the new interface are also included. Affected Xen drivers: * blkfront/back * netfront/back * pcifront/back * scsifront/back * vtpmfront The interface is documented, as before, in xenbus_client.c. Signed-off-by: Wei Liu <wei.liu2@citrix.com> Signed-off-by: Paul Durrant <paul.durrant@citrix.com> Signed-off-by: Bob Liu <bob.liu@oracle.com> Cc: Konrad Wilk <konrad.wilk@oracle.com> Cc: Boris Ostrovsky <boris.ostrovsky@oracle.com> Signed-off-by: David Vrabel <david.vrabel@citrix.com>
2015-04-14Merge branch 'for-linus-1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs Pull vfs update from Al Viro: "Part one: - struct filename-related cleanups - saner iov_iter_init() replacements (and switching the syscalls to use of those) - ntfs switch to ->write_iter() (Anton) - aio cleanups and splitting iocb into common and async parts (Christoph) - assorted fixes (me, bfields, Andrew Elble) There's a lot more, including the completion of switchover to ->{read,write}_iter(), d_inode/d_backing_inode annotations, f_flags race fixes, etc, but that goes after #for-davem merge. David has pulled it, and once it's in I'll send the next vfs pull request" * 'for-linus-1' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (35 commits) sg_start_req(): use import_iovec() sg_start_req(): make sure that there's not too many elements in iovec blk_rq_map_user(): use import_single_range() sg_io(): use import_iovec() process_vm_access: switch to {compat_,}import_iovec() switch keyctl_instantiate_key_common() to iov_iter switch {compat_,}do_readv_writev() to {compat_,}import_iovec() aio_setup_vectored_rw(): switch to {compat_,}import_iovec() vmsplice_to_user(): switch to import_iovec() kill aio_setup_single_vector() aio: simplify arguments of aio_setup_..._rw() aio: lift iov_iter_init() into aio_setup_..._rw() lift iov_iter into {compat_,}do_readv_writev() NFS: fix BUG() crash in notify_change() with patch to chown_common() dcache: return -ESTALE not -EBUSY on distributed fs race NTFS: Version 2.1.32 - Update file write from aio_write to write_iter. VFS: Add iov_iter_fault_in_multipages_readable() drop bogus check in file_open_root() switch security_inode_getattr() to struct path * constify tomoyo_realpath_from_path() ...
2015-04-14target: simplify the target template registration APIChristoph Hellwig
Instead of calling target_fabric_configfs_init() + target_fabric_configfs_register() / target_fabric_configfs_deregister() target_fabric_configfs_free() from every target driver, rewrite the API so that we have simple register/unregister functions that operate on a const operations vector. This patch also fixes a memory leak in several target drivers. Several target drivers namely called target_fabric_configfs_deregister() without calling target_fabric_configfs_free(). A large part of this patch is based on earlier changes from Bart Van Assche <bart.vanassche@sandisk.com>. (v2: Add a new TF_CIT_SETUP_DRV macro so that the core configfs code can declare attributes as either core only or for drivers) Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Nicholas Bellinger <nab@linux-iscsi.org>
2015-04-14Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial Pull trivial tree from Jiri Kosina: "Usual trivial tree updates. Nothing outstanding -- mostly printk() and comment fixes and unused identifier removals" * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: goldfish: goldfish_tty_probe() is not using 'i' any more powerpc: Fix comment in smu.h qla2xxx: Fix printks in ql_log message lib: correct link to the original source for div64_u64 si2168, tda10071, m88ds3103: Fix firmware wording usb: storage: Fix printk in isd200_log_config() qla2xxx: Fix printk in qla25xx_setup_mode init/main: fix reset_device comment ipwireless: missing assignment goldfish: remove unreachable line of code coredump: Fix do_coredump() comment stacktrace.h: remove duplicate declaration task_struct smpboot.h: Remove unused function prototype treewide: Fix typo in printk messages treewide: Fix typo in printk messages mod_devicetable: fix comment for match_flags
2015-04-13Merge branch 'for-4.1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tj/libata Pull libata updates from Tejun Heo: - Hannes's patchset implements support for better error reporting introduced by the new ATA command spec. - the deperecated pci_ dma API usages have been replaced by dma_ ones. - a bunch of hardware specific updates and some cleanups. * 'for-4.1' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/libata: ata: remove deprecated use of pci api ahci: st: st_configure_oob must be called after IP is clocked. ahci: st: Update the ahci_st DT documentation ahci: st: Update the DT example for how to obtain the PHY. sata_dwc_460ex: indent an if statement libata: Add tracepoints libata-eh: Set 'information' field for autosense libata: Implement support for sense data reporting libata: Implement NCQ autosense libata: use status bit definitions in ata_dump_status() ide,ata: Rename ATA_IDX to ATA_SENSE libata: whitespace fixes in ata_to_sense_error() libata: whitespace cleanup in ata_get_cmd_descript() libata: use READ_LOG_DMA_EXT libata: remove ATA_FLAG_LOWTAG sata_dwc_460ex: re-use hsdev->dev instead of dwc_dev sata_dwc_460ex: move to generic DMA driver sata_dwc_460ex: join messages back sata: xgene: add ACPI support for APM X-Gene SATA ports ata: sata_mv: add proper definitions for LP_PHY_CTL register values
2015-04-13Merge tag 'regulator-v4.1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/broonie/regulator Pull regulator updates from Mark Brown: "Another release, another set of regulator updates. Not much of it is showing up in the code yet but there's been a lot of discussion going on about how to enhance the regulator API to work better with modern SoCs which have a microcontroller sitting between Linux and the hardware. I'm hopeful that'll start to come through into mainline for v4.2 but it's not quite there for v4.1 - what we do have (along with the usual small updates is) is: - work from Bjorn Andersson on refactoring the configuration of regulator loading interfaces to be useful for use with microcontrollers, the existing interfaces were never actually useful for anything as-is since nobody was willing to put enough data into public code. - a summary tree display in debugfs from Heiko Stübner. - support for act6000 regulators" * tag 'regulator-v4.1' of git://git.kernel.org/pub/scm/linux/kernel/git/broonie/regulator: (34 commits) regulator: max8660: Handle empty regulator data regulator: output current-limit for all regulators in summary regulator: add a summary tree in debugfs regulator: qcom: Tidy up probe() regulator: qcom: Rework to single platform device regulator: qcom: Refactor of-parsing code regulator: qcom: Don't enable DRMS in driver regulator: max8660: fix assignment of pdata to data that becomes dead regulator: Defer lookup of supply to regulator_get mfd: max77693: Remove unused structures regulator: max77693: Let core parse DT and drop board files support regulator: Ensure unique regulator debugfs directory names regulator: stw481x: Remove unused fields from struct stw481x regulator: palmas: Add has_regen3 check for TPS659038 regulator: constify of_device_id array regulator: fixes for regulator_set_optimum_mode name change regulator: Drop temporary regulator_set_optimum_mode wrapper usb: phy: phy-msm-usb: Rename regulator_set_optimum_mode usb: phy: ab8500-usb: Rename regulator_set_optimum_mode ufs: Rename of regulator_set_optimum_mode ...
2015-04-11sg_start_req(): use import_iovec()Al Viro
2015-04-11sg_start_req(): make sure that there's not too many elements in iovecAl Viro
unfortunately, allowing an arbitrary 16bit value means a possibility of overflow in the calculation of total number of pages in bio_map_user_iov() - we rely on there being no more than PAGE_SIZE members of sum in the first loop there. If that sum wraps around, we end up allocating too small array of pointers to pages and it's easy to overflow it in the second loop. X-Coverup: TINC (and there's no lumber cartel either) Cc: stable@vger.kernel.org # way, way back Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2015-04-11Merge branch 'iocb' into for-nextAl Viro
2015-04-10Merge tag 'scsi-fixes' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi Pull SCSI fixes from James Bottomley: "This is our remaining set of three fixes for 4.0: two oops fixes(one for cable pulls triggering oopses and the other be2iscsi specific) and one warn on in sysfs on multipath devices using enclosures" * tag 'scsi-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi: Defer processing of REQ_PREEMPT requests for blocked devices be2iscsi: Fix kernel panic when device initialization fails enclosure: fix WARN_ON removing an adapter in multi-path devices
2015-04-10sd, mmc, virtio_blk, string_helpers: fix block size unitsJames Bottomley
The current string_get_size() overflows when the device size goes over 2^64 bytes because the string helper routine computes the suffix from the size in bytes. However, the entirety of Linux thinks in terms of blocks, not bytes, so this will artificially induce an overflow on very large devices. Fix this by making the function string_get_size() take blocks and the block size instead of bytes. This should allow us to keep working until the current SCSI standard overflows. Also fix virtio_blk and mmc (both of which were also artificially multiplying by the block size to pass a byte side to string_get_size()). The mathematics of this is pretty simple: we're taking a product of size in blocks (S) and block size (B) and trying to re-express this in exponential form: S*B = R*N^E (where N, the exponent is either 1000 or 1024) and R < N. Mathematically, S = RS*N^ES and B=RB*N^EB, so if RS*RB < N it's easy to see that S*B = RS*RB*N^(ES+EB). However, if RS*BS > N, we can see that this can be re-expressed as RS*BS = R*N (where R = RS*BS/N < N) so the whole exponent becomes R*N^(ES+EB+1) [jejb: fix incorrect 32 bit do_div spotted by kbuild test robot <fengguang.wu@intel.com>] Acked-by: Ulf Hansson <ulf.hansson@linaro.org> Reviewed-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: James Bottomley <JBottomley@Odin.com>
2015-04-10Merge remote-tracking branches 'regulator/topic/mode', ↵Mark Brown
'regulator/topic/notifier', 'regulator/topic/palmas', 'regulator/topic/qcom' and 'regulator/topic/stw481x' into regulator-next
2015-04-10ufs: add support to allow non standard behaviours (quirks)Yaniv Gardi
Some implementation of UFS host controller HW might have some non-standard behaviours (quirks) when compared to behaviour specified by UFSHCI specification. This patch add support to allow specifying all such quirks to standard UFS host controller driver so standard driver takes them into account. In this change a UFSHCD_QUIRK_DELAY_BEFORE_DME_CMDS is introduced, where a minimum delay of 1ms is required before DME commands for stability purposes. Signed-off-by: Yaniv Gardi <ygardi@codeaurora.org> Reviewed-by: Gilad Broner <gbroner@codeaurora.org> Signed-off-by: James Bottomley <JBottomley@Odin.com>
2015-04-10ufs-qcom: save controller revision info in internal structureYaniv Gardi
Sometimes, specific information about the UFS controller revision is required in order to determine certain operations or execute controller dependent quirks. In order to avoid reading the controller revision multiple times, we simply read it once and save this information in internal structure. Signed-off-by: Yaniv Gardi <ygardi@codeaurora.org> Reviewed-by: Gilad Broner <gbroner@codeaurora.org> Signed-off-by: James Bottomley <JBottomley@Odin.com>
2015-04-10qla2xxx: Update driver version to 8.07.00.18-kHimanshu Madhani
Signed-off-by: Giridhar Malavali <giridhar.malavali@qlogic.com> Signed-off-by: Himanshu Madhani <himanshu.madhani@qlogic.com> Reviewed-by: Hannes Reinecke <hare@suse.de> Signed-off-by: James Bottomley <JBottomley@Odin.com>
2015-04-10qla2xxx: Restore physical port WWPN only, when port down detected for ↵Sawan Chandak
FA-WWPN port. For FA-WWPN is enabled port, if NPIV created on that port and, if port link is brought down, then WWPN was restored from flash for both physical and NPIV port. This will result in NPIV port and physical port sharing same WWPN. Any application refreshing ports information will not be able to scan NPIV port because of this behavior. So while restoring WWPN, only restore physical port WWPN. Signed-off-by: Sawan Chandak <sawan.chandak@qlogic.com> Signed-off-by: Himanshu Madhani <himanshu.madhani@qlogic.com> Reviewed-by: Hannes Reinecke <hare@suse.de> Signed-off-by: James Bottomley <JBottomley@Odin.com>
2015-04-10qla2xxx: Fix virtual port configuration, when switch port is disabled/enabled.Sawan Chandak
On some vendor switches, when switch port is toggled (down /up), then in some condition driver tries to configure virtual port, before FW is actually in ready state to process any commands on wire. At this time, configuring virtual port can fail. Add fix in driver to make driver wait, for FW to be ready state before Signed-off-by: Sawan Chandak <sawan.chandak@qlogic.com> Signed-off-by: Himanshu Madhani <himanshu.madhani@qlogic.com> Reviewed-by: Hannes Reinecke <hare@suse.de> Signed-off-by: James Bottomley <JBottomley@Odin.com>
2015-04-10qla2xxx: Prevent multiple firmware dump collection for ISP27XX.Himanshu Madhani
For ISP27XX, driver will capture new firmware dump even if there is one already collected. Prevent this from happening by checking fw_dumped flag. Signed-off-by: Giridhar Malavali <giridhar.malavali@qlogic.com> Signed-off-by: Himanshu Madhani <himanshu.madhani@qlogic.com> Reviewed-by: Hannes Reinecke <hare@suse.de> Signed-off-by: James Bottomley <JBottomley@Odin.com>
2015-04-10qla2xxx: Disable Interrupt handshake for ISP27XX.Himanshu Madhani
2015-04-10qla2xxx: Add debugging info for MBX timeout.Himanshu Madhani
2015-04-10qla2xxx: Add serdes read/write support for ISP27XXAndrew Vasquez
Signed-off-by: Andrew Vasquez <andrew.vasquez@qlogic.com> Signed-off-by: Harish Zunjarrao <harish.zunjarrao@qlogic.com> Signed-off-by: Himanshu Madhani <himanshu.madhani@qlogic.com> Reviewed-by: Hannes Reinecke <hare@suse.de> Signed-off-by: James Bottomley <JBottomley@Odin.com>
2015-04-10qla2xxx: Add udev notification to save fw dump for ISP27XXHimanshu Madhani
2015-04-10qla2xxx: Add message for sucessful FW dump collected for ISP27XX.Himanshu Madhani
o Added message indicating firmware dump was sucessfully collected for ISP27XX. o Improve logging to help debug firmware dump process for ISP27XX. Signed-off-by: Giridhar Malavali <giridhar.malavali@qlogic.com> Signed-off-by: Himanshu Madhani <himanshu.madhani@qlogic.com> Reviewed-by: Hannes Reinecke <hare@suse.de> Signed-off-by: James Bottomley <JBottomley@Odin.com>
2015-04-10qla2xxx: Add support to load firmware from file for ISP 26XX/27XX.Sawan Chandak
2015-04-10qla2xxx: Fix beacon blink for ISP27XX.Nigel Kirkland
Signed-off-by: Nigel Kirkland <nigel.kirkland@qlogic.com> Signed-off-by: Himanshu Madhani <himanshu.madhani@qlogic.com> Reviewed-by: Hannes Reinecke <hare@suse.de> Signed-off-by: James Bottomley <JBottomley@Odin.com>
