Except for the mac_esp driver, which uses PIO or pseudo DMA, all drivers
share the same dma mapping calls. Move the dma mapping into the core
code using the scsi_dma_map / scsi_dma_unmap helpers, with a special
identify mapping variant triggered off a new ESP_FLAG_NO_DMA_MAP flag
for mac_esp.
Tested-by: Finn Thain <fthain@telegraphics.com.au>
We can simplify use esp->dev now.
esp->dev is a void pointer that points either to a struct device, or a
struct platform_device. As we can easily get from the device to the
platform_device if needed change it to always point to a struct device
and properly type the pointer to avoid errors.
esp_sbus_map_command_block is called straight from the probe routine
without any locks held, so we can safely use GFP_KERNEL here.
Remove usage of the legacy PCI DMA API. To make this easier we also
store a struct device instead of pci_dev in the dev field of struct
esp.
Per Qcom's UFS host controller HW design, the UFS Tx lane1 clock could be
muxed with Tx lane0 clock, hence keep Tx lane1 clock optional by ignoring
it if it is not provided in device tree. This change also performs some
cleanup to lanes per direction checks when enable/disable lane clocks
just for symmetry.
Signed-off-by: Venkat Gopalakrishnan <venkatg@codeaurora.org>
Signed-off-by: Subhash Jadavani <subhashj@codeaurora.org>
Signed-off-by: Can Guo <cang@codeaurora.org>
Reviewed-by: Vivek Gautam <vivek.gautam@codeaurora.org>
Reviewed-by: Douglas Anderson <dianders@chromium.org>
Tested-by: Douglas Anderson <dianders@chromium.org>
dma_alloc_coherent allocates memory that can be used by the cpu and the
device at the same time, calls to pci_dma_sync_* are not required, and in
fact actively harmful on some architectures like arm.
Reviewed-by: Johannes Thumshirn <jthumshirn@suse.de>
The dma_map_sg / dma_unmap_sg APIs called from scsi_dma_map /
scsi_dma_unmap already transfer memory ownership to the device or cpu
respectively. Adding additional calls to pci_dma_sync_sg_* will in fact
lead to data corruption if we end up using swiotlb for some reason.
Also remove the now pointless megaraid_mbox_sync_scb function.
There are extraneous parantheses that are causing clang to produce a
warning so remove these.
Clean up 3 clang warnings:
equality comparison with extraneous parentheses [-Wparentheses-equality]
Acked-by: Ching Huang <ching2048@areca.com.tw>
Make ufshcd_send_uic_cmd() public for that.
Signed-off-by: Avri Altman <avri.altman@wdc.com>
Reviewed-by: Bart Van Assche <Bart.VanAssche@wdc.com>
Do that for the currently supported UPIUs: query, nop out, and task
management.
We do not support UPIU of type scsi command yet, while we are using the
job's request and reply pointers to hold the payload. We will look into
it in later patches. We might need to elaborate the raw upiu api for
that.
We also still not supporting uic commands: For first phase, we plan to
use the existing api, and send only uic commands that are already
supported. Anyway, all that will come in the next patch.
The UFS host software uses a combination of a host register set and
Transfer Request Descriptors in system memory to communicate with host
controller hardware. In its mmio space, a separate places are assigned
to UTP Transfer Request Descriptor ("utrd") list, and to UTP Task
Management Request Descriptor ("utmrd") list.
The provided API supports utrd-typed requests: nop out and device
management commands. It also supports utmrd-type requests:
task management requests. Other UPIU types are not supported for now.
We utilize the already existing code for tag and task work queues.
That is, all utrd-typed UPIUs are "disguised" as device management
commands. Similarly, the utmrd-typed UPUIs uses the task management
infrastructure.
It is up to the caller to fill the upiu request properly, as it will be
copied without any further input validations.
Use the structure size in pointer arithmetic instead of an opaque 32
bytes for the over-allocation of descriptors.
For now, just provide an API to allocate and remove ufs-bsg node. We
will use this framework to manage ufs devices by sending UPIU
transactions.
For the time being, implements an empty bsg_request() - will add some
more functionality in coming patches.
Nonetheless, we reveal here the protocol we are planning to use: UFS
Transport Protocol Transactions. UFS transactions consist of packets
called UFS Protocol Information Units (UPIU).
There are UPIU’s defined for UFS SCSI commands, responses, data in and
data out, task management, utility functions, vendor functions,
transaction synchronization and control, and more.
By using UPIUs, we get access to the most fine-grained internals of this
protocol, and able to communicate with the device in ways, that are
sometimes beyond the capacity of the ufs driver.
Moreover and as a result, our core structure - ufs_bsg_node has a pretty
lean structure: using upiu transactions that contains the outmost
detailed info, so we don't really need complex constructs to support it.
in preparation to send UPIU requests via bsg.
Add a helper that takes a utp_task_req_desc and issues it, which will
be useful for UFS bsg support. Rewrite ufshcd_issue_tm_cmd0x to use
this new helper.
Remove the pointless task_req_upiu and task_rsp_upiu indirections,
which are __le32 arrays always cast to given structures and just add
the members directly. Also clean up variables names in use in the
callers a bit to make the code more readable.
lockdep_assert_held() is better suited to checking locking requirements, since
it won't get confused when someone else holds the lock. This is also a step
towards possibly removing spin_is_locked().
Signed-off-by: Lance Roy <ldr709@gmail.com>
Cc: Karan Tilak Kumar <kartilak@cisco.com>
Cc: Sesidhar Baddela <sebaddel@cisco.com>
Cc: "James E.J. Bottomley" <jejb@linux.vnet.ibm.com>
Cc: "Martin K. Petersen" <martin.petersen@oracle.com>
Cc: <linux-scsi@vger.kernel.org>
Reviewed-by: Bart Van Assche <bvanassche@acm.org>
Clang warns when multiple pairs of parentheses are used for a single
conditional statement.
drivers/scsi/mpt3sas/mpt3sas_base.c:535:11: warning: equality comparison
if ((ioc == NULL))
drivers/scsi/mpt3sas/mpt3sas_base.c:535:11: note: remove extraneous
parentheses around the comparison to silence this warning
if ((ioc == NULL))
drivers/scsi/mpt3sas/mpt3sas_base.c:535:11: note: use '=' to turn this
equality comparison into an assignment
if ((ioc == NULL))
drivers/scsi/mpt3sas/mpt3sas_base.c:539:12: warning: equality comparison
if ((pdev == NULL))
drivers/scsi/mpt3sas/mpt3sas_base.c:539:12: note: remove extraneous
if ((pdev == NULL))
drivers/scsi/mpt3sas/mpt3sas_base.c:539:12: note: use '=' to turn this
if ((pdev == NULL))
2 warnings generated.
Remove them and while we're at it, simplify the NULL checks as '!var' is
used more than 'var == NULL'.
Signed-off-by: Nathan Chancellor <natechancellor@gmail.com>
Replaced dma_pool_alloc + memset with dma_pool_zalloc.
Signed-off-by: Brajeswar Ghosh <brajeswar.linux@gmail.com>
Signed-off-by: Souptick Joarder <jrdr.linux@gmail.com>
Acked-by: Suganath Prabu <suganath-prabu.subramani@broadcom.com>
All the uses have been removed, delete the macro.
Convert these uses to ioc_<level> where appropriate.
Remove the logging level as panic calls stop the machine and should always be
emitted regardless of requested logging level.
These existing panic uses are perhaps inappropriate.
Miscellanea:
o Coalesce formats and convert MPT3SAS_FMT to "%s: " to improve clarity
Convert the existing 2 uses to make the format and arguments matching more
obvious.
Miscellanea:
o Move the word "enabled" into the format to trivially reduce object size
o Remove unnecessary parentheses
These have misordered uses of __func__ and ioc->name that could mismatch
MPT3SAS_FMT and "%s: ".
Convert them to ioc_<level>.
Use a more common logging style.
Done using the perl script below and some typing
$ git grep --name-only -w MPT3SAS_FMT -- "*.c" | \
xargs perl -i -e 'local $/; while (<>) { s/\bpr_(info|err|notice|warn)\s*\(\s*MPT3SAS_FMT\s*("[^"]+"(?:\s*\\?\s*"[^"]+"\s*){0,5}\s*),\s*ioc->name\s*/ioc_\1(ioc, \2/g; print;}'
Miscellanea for these conversions:
o Coalesce formats
o Realign arguments
o Use casts to u64 instead of unsigned long long where appropriate
o Convert broken pr_info uses to pr_cont
o Fix broken format string concatenation with line continuations and
excess whitespace
These macros can help identify specific logging uses and eventually perhaps
reduce object sizes.
This patch fixes commit bcc71cc3cde1 ("scsi: qla2xxx: Fix for double
free of SRB structure") which placed code in wrong routines.
Also updated the use of WARN_ON() to WARN_ON_ONCE() to prevent
flooding log messages.
Fixes: bcc71cc3cde1 ("scsi: qla2xxx: Fix for double free of SRB structure")
Signed-off-by: Himanshu Madhani <himanshu.madhani@cavium.com>
The SR_RST bit isn't latched. Hence, detecting a bus reset isn't reliable.
When it is detected, the right thing to do is to drop all connected and
disconnected commands. The code for that is already present so refactor it and
call it when SR_RST is set.
Tested-by: Michael Schmitz <schmitzmic@gmail.com>
Signed-off-by: Finn Thain <fthain@telegraphics.com.au>
The X3T9.2 specification (draft) says, under "6.1.4.2 RESELECTION time-out
procedure", that a target may assert RST or go to BUS FREE phase if the
initiator does not respond within 200 us. Something like this has been
observed with AztecMonster II target. When it happens, all we can do is wait
for the target to try again.
The X3T9.2 specification (draft) says, under "6.1.4.1 RESELECTION",
... The reselected initiator shall then assert the BSY signal
within a selection abort time of its most recent detection of being
reselected; this is required for correct operation of the time-out
procedure.
The selection abort time is only 200 us which may be insufficient time for a
printk() call. Move the diagnostics to the error paths.
When NCR5380_abort() returns FAILED, the driver forgets that the target is
still busy. Hence, further commands may be sent to the target, which may fail
during selection and produce the error message, "reselection after won
arbitration?". Prevent this by leaving the busy flag set when NCR5380_abort()
fails.
The X3T9.2 specification (draft) says, under "6.1.4.1 RESELECTION", that "the
initiator shall not respond to a RESELECTION phase if other than two SCSI ID
bits are on the DATA BUS." This issue (too many bits set) has been observed in
the wild, so add a check.
When sense data is valid, call set_driver_byte(cmd, DRIVER_SENSE). Otherwise
some callers of scsi_execute() will ignore sense data. Don't set DID_ERROR or
DID_RESET just because sense data is missing.
This is mostly needed because an AztecMonster II target has been observed
disconnecting REQUEST SENSE commands and then failing to reselect properly.
Suggested-by: Michael Schmitz <schmitzmic@gmail.com>
The return value is taken to mean "retry" or "don't retry". Change it to bool
to improve readability. Fix related comments. No functional change.
Replace a 'goto' statement with a simple 'return' where possible. This
improves readability. No functional change.
When doing a host reset we should be clearing all outstanding commands, not
just the command triggering the reset.
[mkp: adjusted Hannes' SoB address]
Signed-off-by: Hannes Reinecke <hare@suse.com>
Cc: Ondrey Zary <linux@rainbow-software.org>
The check for a non-zero drvr_wait is redundant as the same check is performed
earlier in the outer while loop, the inner check will always be true if we
reached this point inside the while loop. Remove the redundant if check.
Detected by cppcheck:
(warning) Identical inner 'if' condition is always true.
Acked-by: Manish Rangankar <Manish.Rangankar@cavium.com>
There is a probability that the SRB structure might have been released by the
time the debug log message dereferences it. This patch moved the log messages
before the command is issued to the firmware to prevent unknown behavior and
kernel crash
Fixes: 726b85487067 ("qla2xxx: Add framework for async fabric discovery")
Cc: <stable@vger.kernel.org>
Signed-off-by: Giridhar Malavali <giridhar.malavali@cavium.com>
Reviewed-by: Ewan D. Milne <emilne@redhat.com>
This patch fixes issue during switch command query where driver was freeing
SRB resources multiple times
Following stack trace will be seen
[ 853.436234] BUG: unable to handle kernel NULL pointer dereference at
0000000000000001
[ 853.436348] IP: [<ffffffff811df514>] kmem_cache_alloc+0x74/0x1e0
[ 853.436476] PGD 0
[ 853.436601] Oops: 0000 [#1] SMP
[ 853.454700] [<ffffffff81099f6a>] ? mod_timer+0x14a/0x220
[ 853.455543] [<ffffffff81185465>] mempool_alloc_slab+0x15/0x20
[ 853.456395] [<ffffffff811855a9>] mempool_alloc+0x69/0x170
[ 853.457257] [<ffffffff81098af2>] ? internal_add_timer+0x32/0x70
[ 853.458136] [<ffffffffc0092d2b>] qla2xxx_queuecommand+0x29b/0x3f0 [qla2xxx]
[ 853.459024] [<ffffffff8146535a>] scsi_dispatch_cmd+0xaa/0x230
[ 853.459923] [<ffffffff8146e11f>] scsi_request_fn+0x4df/0x680
[ 853.460829] [<ffffffff81029557>] ? __switch_to+0xd7/0x510
[ 853.461747] [<ffffffff812f7113>] __blk_run_queue+0x33/0x40
[ 853.462670] [<ffffffff812f7735>] blk_delay_work+0x25/0x40
[ 853.463603] [<ffffffff810a882a>] process_one_work+0x17a/0x440
[ 853.464546] [<ffffffff810a94f6>] worker_thread+0x126/0x3c0
[ 853.465501] [<ffffffff810a93d0>] ? manage_workers.isra.24+0x2a0/0x2a0
[ 853.466447] [<ffffffff810b099f>] kthread+0xcf/0xe0
[ 853.467379] [<ffffffff810b08d0>] ? insert_kthread_work+0x40/0x40
[ 853.470172] Code: db e2 7e 49 8b 50 08 4d 8b 20 49 8b 40 10 4d 85 e4 0f 84 20
01 00 00 48 85 c0 0f 84 17 01 00 00 49 63 46 20 48 8d 4a 01 4d 8b 06 <49> 8b 1c
04 4c 89 e0 65 49 0f c7 08 0f 94 c0 84 c0 74 ba 49 63
[ 853.472072] RIP [<ffffffff811df514>] kmem_cache_alloc+0x74/0x1e0
[ 853.472971] RSP <ffff88103726fc50>
This patch prevents user space mailbox request from doing chip reset if the
mailbox timed out. The chip reset is only reserved for the DPC thread to
ensure all mailbox requests are flushed properly. The DPC thread is
responsible for the flushing all MBs and chip reset.
Fixes: b2000805a975 ("scsi: qla2xxx: Flush mailbox commands on chip reset")
Cc: <stable@ger.kernel.org>
Signed-off-by: Quinn Tran <quinn.tran@cavium.com>
This patch fixes multiple call for qla_nvme_unregister_remote_port() as part
of qlt_schedule_session_for_deletion(), Do not call it again during
qla_nvme_delete()
Fixes: e473b3074104 ("scsi: qla2xxx: Add FC-NVMe abort processing")
This patch fixes issue where driver clears NPort ID map instead of marking
handle in use. Once driver clears NPort ID from the database, it can reuse
the same NPort ID resulting in a PLOGI failure.
[mkp: fixed Himanshu's SoB]
Fixes: a084fd68e1d2 ("scsi: qla2xxx: Fix re-login for Nport Handle in use")
Signed-of-by: Quinn Tran <quinn.tran@cavium.com>
Signed-off-by: Himanshu Madhani <hmadhani@cavium.com>
The response data buffer used in switch scan is reused 4 times. (For example,
for commands GPN_FT, GNN_FT for FCP and FC-NVME) Before driver reuses this
buffer, clear it to prevent duplicate entries in our database.
Fixes: a4239945b8ad1 ("scsi: qla2xxx: Add switch command to simplify fabric discovery"
This patch fixes issue when remoteport registers itself as both FCP and
FC-NVMe with the switch, driver will pick FC-NVMe personality as default when
scanning for targets.
Driver was using comaprative operator instead of bitwise operator to check for
fc4_type for both FCP and FC-NVME.
Fixes: 2b5b96473efc ("scsi: qla2xxx: Fix FC-NVMe LUN discovery")
Send aborts only when chip is active.
Fixes: 623ee824e579 ("scsi: qla2xxx: Fix FC-NVMe IO abort during driver reset")
Cc: <stable@vger.kernel.org> # 4.14
We shouldn't allow negative thresholds. I don't know what it would do
but it can't be good.
Fixes: 8b4673ba3a1b ("scsi: qla2xxx: Add support for ZIO6 interrupt threshold")
Acked-by: Himanshu Madhani <himanshu.madhani@cavium.com>
Default value of ql2xasynctmfenable for qla2xxx driver was set to 1 in
commit 043dc1d7e850 ("scsi: qla2xxx: Enable Async TMF processing") but
comment in MODULE_PARAM_DESC was not modified.
Signed-off-by: Masanari Iida <standby24x7@gmail.com>
When the lldd is processing the complete sas task in interrupt and set the
task stat as SAS_TASK_STATE_DONE, the smp timeout timer is able to be
triggered at the same time. And smp_task_timedout() will complete the task
wheter the SAS_TASK_STATE_DONE is set or not. Then the sas task may freed
before lldd end the interrupt process. Thus a use-after-free will happen.
Fix this by calling the complete() only when SAS_TASK_STATE_DONE is not
set. And remove the check of the return value of the del_timer(). Once the
LLDD sets DONE, it must call task->done(), which will call
smp_task_done()->complete() and the task will be completed and freed
correctly.
Reported-by: chenxiang <chenxiang66@hisilicon.com>
Signed-off-by: Jason Yan <yanaijie@huawei.com>
CC: John Garry <john.garry@huawei.com>
CC: Johannes Thumshirn <jthumshirn@suse.de>
CC: Ewan Milne <emilne@redhat.com>
CC: Christoph Hellwig <hch@lst.de>
CC: Tomas Henzl <thenzl@redhat.com>
CC: Dan Williams <dan.j.williams@intel.com>
CC: Hannes Reinecke <hare@suse.com>
Reviewed-by: Hannes Reinecke <hare@suse.com>
Reviewed-by: John Garry <john.garry@huawei.com>
