Resolved kernel/bpf/btf.c using instructions from merge commit
69138b34a7248d2396ab85c8652e20c0c39beaba
The UDP reuseport conflict was a little bit tricky.
The net-next code, via bpf-next, extracted the reuseport handling
into a helper so that the BPF sk lookup code could invoke it.
At the same time, the logic for reuseport handling of unconnected
sockets changed via commit efc6b6f6c3113e8b203b9debfb72d81e0f3dcace
which changed the logic to carry on the reuseport result into the
rest of the lookup loop if we do not return immediately.
This requires moving the reuseport_has_conns() logic into the callers.
While we are here, get rid of inline directives as they do not belong
in foo.c files.
The other changes were cases of more straightforward overlapping
modifications.
I/O requests may be held in scheduler queue because of resource contention.
The starvation scenario was handled properly in the regular completion
path but we failed to account for it during I/O submission. This lead to
the hang captured below. Make sure we run the queue when resource
contention is encountered in the submission path.
[ 39.054963] scsi 13:0:0:0: rejecting I/O to dead device
[ 39.058700] scsi 13:0:0:0: rejecting I/O to dead device
[ 39.087855] sd 13:0:0:1: [sdd] Synchronizing SCSI cache
[ 39.088909] scsi 13:0:0:1: rejecting I/O to dead device
[ 39.095351] scsi 13:0:0:1: rejecting I/O to dead device
[ 39.096962] scsi 13:0:0:1: rejecting I/O to dead device
[ 247.021859] INFO: task scsi-stress-rem:813 blocked for more than 122 seconds.
[ 247.023258] Not tainted 5.8.0-rc2 #8
[ 247.024069] "echo 0 > /proc/sys/kernel/hung_task_timeout_secs" disables this message.
[ 247.025331] scsi-stress-rem D 0 813 802 0x00004000
[ 247.025334] Call Trace:
[ 247.025354] __schedule+0x504/0x55f
[ 247.027987] schedule+0x72/0xa8
[ 247.027991] blk_mq_freeze_queue_wait+0x63/0x8c
[ 247.027994] ? do_wait_intr_irq+0x7a/0x7a
[ 247.027996] blk_cleanup_queue+0x4b/0xc9
[ 247.028000] __scsi_remove_device+0xf6/0x14e
[ 247.028002] scsi_remove_device+0x21/0x2b
[ 247.029037] sdev_store_delete+0x58/0x7c
[ 247.029041] kernfs_fop_write+0x10d/0x14f
[ 247.031281] vfs_write+0xa2/0xdf
[ 247.032670] ksys_write+0x6b/0xb3
[ 247.032673] do_syscall_64+0x56/0x82
[ 247.034053] entry_SYSCALL_64_after_hwframe+0x44/0xa9
[ 247.034059] RIP: 0033:0x7f69f39e9008
[ 247.036330] Code: Bad RIP value.
[ 247.036331] RSP: 002b:00007ffdd8116498 EFLAGS: 00000246 ORIG_RAX: 0000000000000001
[ 247.037613] RAX: ffffffffffffffda RBX: 0000000000000002 RCX: 00007f69f39e9008
[ 247.039714] RDX: 0000000000000002 RSI: 000055cde92a0ab0 RDI: 0000000000000001
[ 247.039715] RBP: 000055cde92a0ab0 R08: 000000000000000a R09: 00007f69f3a79e80
[ 247.039716] R10: 000000000000000a R11: 0000000000000246 R12: 00007f69f3abb780
[ 247.039717] R13: 0000000000000002 R14: 00007f69f3ab6740 R15: 0000000000000002
Link: https://lore.kernel.org/r/20200720025435.812030-1-ming.lei@redhat.com
Cc: linux-block@vger.kernel.org
Reviewed-by: Bart Van Assche <bvanassche@acm.org>
Signed-off-by: Ming Lei <ming.lei@redhat.com>
Currently qed driver already ran out of 32 bits to store link modes,
and this doesn't allow to add and support more speeds.
Convert custom link mode to generic Ethtool bitmap and definitions
(convenient Phylink shorthands are used for elegance and readability).
This allowed us to drop all conversions/mappings between the driver
and Ethtool.
This involves changes in qede and qedf as well, as they used definitions
from shared "qed_if.h".
Suggested-by: Andrew Lunn <andrew@lunn.ch>
Signed-off-by: Alexander Lobakin <alobakin@marvell.com>
Signed-off-by: Igor Russkikh <irusskikh@marvell.com>
Reviewed-by: Andrew Lunn <andrew@lunn.ch>
As the ENABLE_IRQ_POLL macro is undefined, the check for ENABLE_IRQ_POLL
macro in ISR will always be false. This leads to irq polling being
non-functional.
Remove ENABLE_IRQ_POLL check from ISR.
Link: https://lore.kernel.org/r/20200715120153.20512-1-chandrakanth.patil@broadcom.com
Fixes: a6ffd5bf6819 ("scsi: megaraid_sas: Call disable_irq from process IRQ")
Cc: <stable@vger.kernel.org> # v5.3+
Signed-off-by: Chandrakanth Patil <chandrakanth.patil@broadcom.com>
Signed-off-by: Kashyap Desai <kashyap.desai@broadcom.com>
Add FUJITSU ETERNUS_AHB
Link: https://lore.kernel.org/r/DM6PR06MB5276CCA765336BD312C4282E8C660@DM6PR06MB5276.namprd06.prod.outlook.com
Signed-off-by: Steve Schremmer <steve.schremmer@netapp.com>
BRM_status_show() has several error branches, but none of them record the
error in the error return.
Also while at it remove the manual mutex_unlock() of the pci_access_mutex
in case of an ongoing pci error recovery or host removal and jump to the
cleanup label instead.
Note: We can safely jump to out from here as io_unit_pg3 is initialized to
NULL and if it hasn't been allocated, kfree() skips the NULL pointer.
[mkp: compilation warning]
Link: https://lore.kernel.org/r/20200701131454.5255-1-johannes.thumshirn@wdc.com
Reviewed-by: Damien Le Moal <damien.lemoal@wdc.com>
Acked-by: Sreekanth Reddy <sreekanth.reddy@broadcom.com>
Signed-off-by: Johannes Thumshirn <johannes.thumshirn@wdc.com>
In BRM_status_show(), if the condition "!ioc->is_warpdrive" tested on entry
to the function is true, a "goto out" is called. This results in unlocking
ioc->pci_access_mutex without this mutex lock being taken. This generates
the following splat:
[ 1148.539883] mpt3sas_cm2: BRM_status_show: BRM attribute is only for warpdrive
[ 1148.547184]
[ 1148.548708] =====================================
[ 1148.553501] WARNING: bad unlock balance detected!
[ 1148.558277] 5.8.0-rc3+ #827 Not tainted
[ 1148.562183] -------------------------------------
[ 1148.566959] cat/5008 is trying to release lock (&ioc->pci_access_mutex) at:
[ 1148.574035] [<ffffffffc070b7a3>] BRM_status_show+0xd3/0x100 [mpt3sas]
[ 1148.580574] but there are no more locks to release!
[ 1148.585524]
[ 1148.585524] other info that might help us debug this:
[ 1148.599624] 3 locks held by cat/5008:
[ 1148.607085] #0: ffff92aea3e392c0 (&p->lock){+.+.}-{3:3}, at: seq_read+0x34/0x480
[ 1148.618509] #1: ffff922ef14c4888 (&of->mutex){+.+.}-{3:3}, at: kernfs_seq_start+0x2a/0xb0
[ 1148.630729] #2: ffff92aedb5d7310 (kn->active#224){.+.+}-{0:0}, at: kernfs_seq_start+0x32/0xb0
[ 1148.643347]
[ 1148.643347] stack backtrace:
[ 1148.655259] CPU: 73 PID: 5008 Comm: cat Not tainted 5.8.0-rc3+ #827
[ 1148.665309] Hardware name: HGST H4060-S/S2600STB, BIOS SE5C620.86B.02.01.0008.031920191559 03/19/2019
[ 1148.678394] Call Trace:
[ 1148.684750] dump_stack+0x78/0xa0
[ 1148.691802] lock_release.cold+0x45/0x4a
[ 1148.699451] __mutex_unlock_slowpath+0x35/0x270
[ 1148.707675] BRM_status_show+0xd3/0x100 [mpt3sas]
[ 1148.716092] dev_attr_show+0x19/0x40
[ 1148.723664] sysfs_kf_seq_show+0x87/0x100
[ 1148.731193] seq_read+0xbc/0x480
[ 1148.737882] vfs_read+0xa0/0x160
[ 1148.744514] ksys_read+0x58/0xd0
[ 1148.751129] do_syscall_64+0x4c/0xa0
[ 1148.757941] entry_SYSCALL_64_after_hwframe+0x44/0xa9
[ 1148.766240] RIP: 0033:0x7f1230566542
[ 1148.772957] Code: Bad RIP value.
[ 1148.779206] RSP: 002b:00007ffeac1bcac8 EFLAGS: 00000246 ORIG_RAX: 0000000000000000
[ 1148.790063] RAX: ffffffffffffffda RBX: 0000000000020000 RCX: 00007f1230566542
[ 1148.800284] RDX: 0000000000020000 RSI: 00007f1223460000 RDI: 0000000000000003
[ 1148.810474] RBP: 00007f1223460000 R08: 00007f122345f010 R09: 0000000000000000
[ 1148.820641] R10: 0000000000000022 R11: 0000000000000246 R12: 0000000000000000
[ 1148.830728] R13: 0000000000000003 R14: 0000000000020000 R15: 0000000000020000
Fix this by returning immediately instead of jumping to the out label.
Link: https://lore.kernel.org/r/20200701085254.51740-1-damien.lemoal@wdc.com
Reviewed-by: Johannes Thumshirn <johannes.thumshirn@wdc.com>
Signed-off-by: Damien Le Moal <damien.lemoal@wdc.com>
Commit 3ce419662dd4 ("scsi: iscsi: Register sysfs for iscsi workqueue")
enabled 'cpumask' support for iSCSI workqueues. However, it is unnecessary
to set max_active = 2 since 'cpumask' can still be modified when max_active
is 1.
This patch sets max_active to 1 so as to keep the same behaviour as before.
Link: https://lore.kernel.org/r/20200701030745.16897-1-bob.liu@oracle.com
Reviewed-by: Mike Christie <michael.christie@oracle.com>
Signed-off-by: Bob Liu <bob.liu@oracle.com>
clang static analysis flags several null function pointer problems.
drivers/scsi/scsi_transport_spi.c:374:1: warning: Called function pointer is null (null dereference) [core.CallAndMessage]
spi_transport_max_attr(offset, "%d\n");
Reviewing the store_spi_store_max macro
if (i->f->set_##field)
return -EINVAL;
should be
if (!i->f->set_##field)
return -EINVAL;
Link: https://lore.kernel.org/r/20200627133242.21618-1-trix@redhat.com
Reviewed-by: James Bottomley <jejb@linux.ibm.com>
Signed-off-by: Tom Rix <trix@redhat.com>
When an rport event (RPORT_EV_READY) is updated without work being queued,
avoid taking an additional reference.
This issue was leading to memory leak. Trace from KMEMLEAK tool:
unreferenced object 0xffff8888259e8780 (size 512):
comm "kworker/2:1", jiffies 4433237386 (age 113021.971s)
hex dump (first 32 bytes):
58 0a ec cf 83 88 ff ff 00 00 00 00 00 00 00 00
01 00 00 00 08 00 00 00 13 7d f0 1e 0e 00 00 10
backtrace:
[<000000006b25760f>] fc_rport_recv_req+0x3c6/0x18f0 [libfc]
[<00000000f208d994>] fc_lport_recv_els_req+0x120/0x8a0 [libfc]
[<00000000a9c437b8>] fc_lport_recv+0xb9/0x130 [libfc]
[<00000000ad5be37b>] qedf_ll2_process_skb+0x73d/0xad0 [qedf]
[<00000000e0eb6893>] process_one_work+0x382/0x6c0
[<000000002dfd9e21>] worker_thread+0x57/0x5c0
[<00000000b648204f>] kthread+0x1a0/0x1c0
[<0000000072f5ab20>] ret_from_fork+0x35/0x40
[<000000001d5c05d8>] 0xffffffffffffffff
Below is the log sequence which leads to memory leak. Here we get the
RPORT_EV_READY and RPORT_EV_STOP back to back, which lead to overwrite the
event RPORT_EV_READY by event RPORT_EV_STOP. Because of this, kref_count
gets incremented by 1.
kernel: host0: rport fffce5: Received PLOGI request
kernel: host0: rport fffce5: Received PLOGI in INIT state
kernel: host0: rport fffce5: Port is Ready
kernel: host0: rport fffce5: Received PRLI request while in state Ready
kernel: host0: rport fffce5: PRLI rspp type 8 active 1 passive 0
kernel: host0: rport fffce5: Received LOGO request while in state Ready
kernel: host0: rport fffce5: Delete port
kernel: host0: rport fffce5: Received PLOGI in state Delete - send busy
kernel: host0: rport fffce5: work event 3
kernel: host0: rport fffce5: lld callback ev 3
kernel: host0: rport fffce5: work delete
Link: https://lore.kernel.org/r/20200626094959.32151-1-jhasan@marvell.com
Reviewed-by: Girish Basrur <gbasrur@marvell.com>
Reviewed-by: Saurav Kashyap <skashyap@marvell.com>
Reviewed-by: Shyam Sundar <ssundar@marvell.com>
Signed-off-by: Javed Hasan <jhasan@marvell.com>
Handling of extra kref which is done by lookup table in case rdata is
already present in list.
comm "kworker/2:1", pid 182614, jiffies 4433237386 (age 113021.971s)
backtrace:
nested "Received PLOGI request" for same port and this request leads to
call the fc_rport_create() twice for the same rport.
kernel: host1: rport fffce5: Received PLOGI request
kernel: host1: rport fffce5: Received PLOGI in INIT state
kernel: host1: rport fffce5: Port is Ready
kernel: host1: rport fffce5: Received PRLI request while in state Ready
kernel: host1: rport fffce5: PRLI rspp type 8 active 1 passive 0
kernel: host1: rport fffce5: Received LOGO request while in state Ready
kernel: host1: rport fffce5: Delete port
kernel: host1: rport fffce5: Received PLOGI in state Delete - send busy
Link: https://lore.kernel.org/r/20200622101212.3922-2-jhasan@marvell.com
This code doesn't make sense unless the correct "fcport" was found.
Link: https://lore.kernel.org/r/20200619143041.GD267142@mwanda
Fixes: 9dd9686b1419 ("scsi: qla2xxx: Add changes for devloss timeout in driver")
Reviewed-by: Himanshu Madhani <himanshu.madhani@oracle.com>
Commit cdb42becdd40 ("scsi: lpfc: Replace io_channels for nvme and fcp with
general hdw_queues per cpu") has introduced static checker warnings for
potential null dereferences in 'lpfc_sli4_hba_unset()' and commit 1ffdd2c0440d
("scsi: lpfc: resolve static checker warning in lpfc_sli4_hba_unset") has
tried to fix it. However, yet another potential null dereference is
remaining. This commit fixes it.
This bug was discovered and resolved using Coverity Static Analysis
Security Testing (SAST) by Synopsys, Inc.
Link: https://lore.kernel.org/r/20200623084122.30633-1-sjpark@amazon.com
Fixes: 1ffdd2c0440d ("scsi: lpfc: resolve static checker warning inlpfc_sli4_hba_unset")
Fixes: cdb42becdd40 ("scsi: lpfc: Replace io_channels for nvme and fcp with general hdw_queues per cpu")
Reviewed-by: James Smart <james.smart@broadcom.com>
Signed-off-by: SeongJae Park <sjpark@amazon.de>
The driver performs SCR (state change registration) in all modes including
pure target mode.
For each RSCN, scan_needed flag is set in qla2x00_handle_rscn() for the
port mentioned in the RSCN and fabric rescan is scheduled. During the
rescan, GNN_FT handler, qla24xx_async_gnnft_done() deletes session of the
port that caused the RSCN.
In target mode, the session deletion has an impact on ATIO handler,
qlt_24xx_atio_pkt(). Target responds with SAM STATUS BUSY to I/O incoming
from the deleted session. qlt_handle_cmd_for_atio() and
qlt_handle_task_mgmt() return -EFAULT if they are not able to find session
of the command/TMF, and that results in invocation of qlt_send_busy():
qlt_24xx_atio_pkt_all_vps: qla_target(0): type 6 ox_id 0014
qla_target(0): Unable to send command to target, sending BUSY status
Such response causes command timeout on the initiator. Error handler thread
on the initiator will be spawned to abort the commands:
scsi 23:0:0:0: tag#0 abort scheduled
scsi 23:0:0:0: tag#0 aborting command
qla2xxx [0000:af:00.0]-188c:23: Entered qla24xx_abort_command.
qla2xxx [0000:af:00.0]-801c:23: Abort command issued nexus=23:0:0 -- 0 2003.
Command abort is rejected by target and fails (2003), error handler then
tries to perform DEVICE RESET and TARGET RESET but they're also doomed to
fail because TMFs are ignored for the deleted sessions.
Then initiator makes BUS RESET that resets the link via
qla2x00_full_login_lip(). BUS RESET succeeds and brings initiator port up,
SAN switch detects that and sends RSCN to the target port and it fails
again the same way as described above. It never goes out of the loop.
The change breaks the RSCN loop by keeping initiator sessions mentioned in
RSCN payload in all modes, including dual and pure target mode.
Link: https://lore.kernel.org/r/20200605144435.27023-1-r.bolshakov@yadro.com
Fixes: 2037ce49d30a ("scsi: qla2xxx: Fix stale session")
Cc: Quinn Tran <qutran@marvell.com>
Cc: Arun Easi <aeasi@marvell.com>
Cc: Nilesh Javali <njavali@marvell.com>
Cc: Bart Van Assche <bvanassche@acm.org>
Cc: Daniel Wagner <dwagner@suse.de>
Cc: Himanshu Madhani <himanshu.madhani@oracle.com>
Cc: Martin Wilck <mwilck@suse.com>
Cc: stable@vger.kernel.org # v5.4+
Reviewed-by: Daniel Wagner <dwagner@suse.de>
Signed-off-by: Roman Bolshakov <r.bolshakov@yadro.com>
The qla2xxx driver knows when request was processed successfully or
not. But it always sets the NVMe status code to 0/NVME_SC_SUCCESS. The
upper layer needs to figure out from the rcv_rsplen and transferred_length
variables if the request was transferred successfully. This is not always
possible, e.g. when the request data length is 0, the transferred_length is
also set 0 which is interpreted as success in nvme_fc_fcpio_done(). Let's
inform the upper layer (nvme_fc_fcpio_done()) when something went wrong.
nvme_fc_fcpio_done() maps all non-NVME_SC_SUCCESS status codes to
NVME_SC_HOST_PATH_ERROR. There isn't any benefit to map the QLA status code
to the NVMe status code. Therefore, use NVME_SC_INTERNAL to indicate an
error which aligns it with the lpfc driver.
Link: https://lore.kernel.org/r/20200604100745.89250-1-dwagner@suse.de
Reviewed-by: Hannes Reinecke <hare@suse.de>
Signed-off-by: Daniel Wagner <dwagner@suse.de>
We need ata_scsi_dma_need_drain for all drivers wired up to drive ATAPI
devices through libata. That also includes the SAS HBA drivers in addition
to native libata HBA drivers.
Link: https://lore.kernel.org/r/20200615064624.37317-3-hch@lst.de
Fixes: cc97923a5bcc ("block: move dma drain handling to scsi")
Reported-by: Michael Ellerman <mpe@ellerman.id.au>
Tested-by: Michael Ellerman <mpe@ellerman.id.au>
Acked-by: Jack Wang <jinpu.wang@cloud.ionos.com>
Acked-by: John Garry <john.garry@huawei.com>
When ufs_bsg_alloc_desc_buffer() returns an error code, a pairing runtime
PM usage counter decrement is needed to keep the counter balanced.
Link: https://lore.kernel.org/r/20200522045932.31795-1-dinghao.liu@zju.edu.cn
Fixes: 74e5e468b664 (scsi: ufs-bsg: Wake the device before sending raw upiu commands)
Reviewed-by: Avri Altman <avri.altman@wdc.com>
Signed-off-by: Dinghao Liu <dinghao.liu@zju.edu.cn>
git://git.kernel.org/pub/scm/linux/kernel/git/masahiroy/linux-kbuild
Pull more Kbuild updates from Masahiro Yamada:
- fix build rules in binderfs sample
- fix build errors when Kbuild recurses to the top Makefile
- covert '---help---' in Kconfig to 'help'
* tag 'kbuild-v5.8-2' of git://git.kernel.org/pub/scm/linux/kernel/git/masahiroy/linux-kbuild:
treewide: replace '---help---' in Kconfig files with 'help'
kbuild: fix broken builds because of GZIP,BZIP2,LZOP variables
samples: binderfs: really compile this sample and fix build issues
Pull more SCSI updates from James Bottomley:
"This is the set of changes collected since just before the merge
window opened. It's mostly minor fixes in drivers.
The one non-driver set is the three optical disk (sr) changes where
two are error path fixes and one is a helper conversion.
The big driver change is the hpsa compat_alloc_userspace rework by Al
so he can kill the remaining user. This has been tested and acked by
the maintainer"
* tag 'scsi-misc' of git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi: (21 commits)
scsi: acornscsi: Fix an error handling path in acornscsi_probe()
scsi: storvsc: Remove memset before memory freeing in storvsc_suspend()
scsi: cxlflash: Remove an unnecessary NULL check
scsi: ibmvscsi: Don't send host info in adapter info MAD after LPM
scsi: sr: Fix sr_probe() missing deallocate of device minor
scsi: sr: Fix sr_probe() missing mutex_destroy
scsi: st: Convert convert get_user_pages() --> pin_user_pages()
scsi: target: Rename target_setup_cmd_from_cdb() to target_cmd_parse_cdb()
scsi: target: Fix NULL pointer dereference
scsi: target: Initialize LUN in transport_init_se_cmd()
scsi: target: Factor out a new helper, target_cmd_init_cdb()
scsi: hpsa: hpsa_ioctl(): Tidy up a bit
scsi: hpsa: Get rid of compat_alloc_user_space()
scsi: hpsa: Don't bother with vmalloc for BIG_IOCTL_Command_struct
scsi: hpsa: Lift {BIG_,}IOCTL_Command_struct copy{in,out} into hpsa_ioctl()
scsi: ufs: Remove redundant urgent_bkop_lvl initialization
scsi: ufs: Don't update urgent bkops level when toggling auto bkops
scsi: qedf: Remove redundant initialization of variable rc
scsi: mpt3sas: Fix memset() in non-RDPQ mode
scsi: iscsi: Fix reference count leak in iscsi_boot_create_kobj
Since commit 84af7a6194e4 ("checkpatch: kconfig: prefer 'help' over
'---help---'"), the number of '---help---' has been gradually
decreasing, but there are still more than 2400 instances.
This commit finishes the conversion. While I touched the lines,
I also fixed the indentation.
There are a variety of indentation styles found.
a) 4 spaces + '---help---'
b) 7 spaces + '---help---'
c) 8 spaces + '---help---'
d) 1 space + 1 tab + '---help---'
e) 1 tab + '---help---' (correct indentation)
f) 1 tab + 1 space + '---help---'
g) 1 tab + 2 spaces + '---help---'
In order to convert all of them to 1 tab + 'help', I ran the
following commend:
$ find . -name 'Kconfig*' | xargs sed -i 's/^[[:space:]]*---help---/\thelp/'
Signed-off-by: Masahiro Yamada <masahiroy@kernel.org>
'ret' is known to be 0 at this point. Explicitly return -ENOMEM if one of
the 'ecardm_iomap()' calls fail.
Link: https://lore.kernel.org/r/20200530081622.577888-1-christophe.jaillet@wanadoo.fr
Fixes: e95a1b656a98 ("[ARM] rpc: acornscsi: update to new style ecard driver")
Signed-off-by: Christophe JAILLET <christophe.jaillet@wanadoo.fr>
Remove memset with 0 for stor_device->stor_chns in storvsc_suspend() before
the call to kfree() as the memory contains no sensitive information.
Link: https://lore.kernel.org/r/20200605075934.8403-1-efremov@linux.com
Fixes: 56fb10585934 ("scsi: storvsc: Add the support of hibernation")
Suggested-by: Dexuan Cui <decui@microsoft.com>
Reviewed-by: Dexuan Cui <decui@microsoft.com>
Signed-off-by: Denis Efremov <efremov@linux.com>
The "cmd" pointer was already dereferenced a couple lines earlier so this
NULL check is too late. Fortunately, the pointer can never be NULL and the
check can be removed.
Link: https://lore.kernel.org/r/20200605110258.GD978434@mwanda
The adapter info MAD is used to send the client info and receive the host
info as a response. A persistent buffer is used and as such the client info
is overwritten after the response. During the course of a normal adapter
reset the client info is refreshed in the buffer in preparation for sending
the adapter info MAD.
However, in the special case of LPM where we reenable the CRQ instead of a
full CRQ teardown and reset we fail to refresh the client info in the
adapter info buffer. As a result, after Live Partition Migration (LPM) we
erroneously report the host's info as our own.
[mkp: typos]
Link: https://lore.kernel.org/r/20200603203632.18426-1-tyreld@linux.ibm.com
Signed-off-by: Tyrel Datwyler <tyreld@linux.ibm.com>
If the cdrom fails to be registered then the device minor should be
deallocated.
Link: https://lore.kernel.org/r/072dac4b-8402-4de8-36bd-47e7588969cd@0882a8b5-c6c3-11e9-b005-00805fc181fe
Signed-off-by: Simon Arlott <simon@octiron.net>
If the device minor cannot be allocated or the cdrom fails to be registered
then the mutex should be destroyed.
Link: https://lore.kernel.org/r/06e9de38-eeed-1cab-5e08-e889288935b3@0882a8b5-c6c3-11e9-b005-00805fc181fe
Fixes: 51a858817dcd ("scsi: sr: get rid of sr global mutex")
This code was using get_user_pages*(), in a "Case 1" scenario (Direct IO),
using the categorization from [1]. That means that it's time to convert the
get_user_pages*() + put_page() calls to pin_user_pages*() +
unpin_user_pages() calls.
There is some helpful background in [2]: basically, this is a small part of
fixing a long-standing disconnect between pinning pages, and file systems'
use of those pages.
Note that this effectively changes the code's behavior as well: it now
ultimately calls set_page_dirty_lock(), instead of SetPageDirty().This is
probably more accurate.
As Christoph Hellwig put it, "set_page_dirty() is only safe if we are
dealing with a file backed page where we have reference on the inode it
hangs off." [3]
Also, this deletes one of the two FIXME comments (about refcounting),
because there is nothing wrong with the refcounting at this point.
[1] Documentation/core-api/pin_user_pages.rst
[2] "Explicit pinning of user-space pages":
https://lwn.net/Articles/807108/
[3] https://lore.kernel.org/r/20190723153640.GB720@lst.de
Link: https://lore.kernel.org/r/20200526182709.99599-1-jhubbard@nvidia.com
Cc: "Kai Mäkisara (Kolumbus)" <kai.makisara@kolumbus.fi>
Cc: James E.J. Bottomley <jejb@linux.ibm.com>
Cc: Martin K. Petersen <martin.petersen@oracle.com>
Cc: linux-scsi@vger.kernel.org
Acked-by: Kai Mäkisara <kai.makisara@kolumbus.fi>
Signed-off-by: John Hubbard <jhubbard@nvidia.com>
The replacement of <asm/pgrable.h> with <linux/pgtable.h> made the include
of the latter in the middle of asm includes. Fix this up with the aid of
the below script and manual adjustments here and there.
import sys
import re
if len(sys.argv) is not 3:
print "USAGE: %s <file> <header>" % (sys.argv[0])
sys.exit(1)
hdr_to_move="#include <linux/%s>" % sys.argv[2]
moved = False
in_hdrs = False
with open(sys.argv[1], "r") as f:
lines = f.readlines()
for _line in lines:
line = _line.rstrip('
if line == hdr_to_move:
continue
if line.startswith("#include <linux/"):
in_hdrs = True
elif not moved and in_hdrs:
moved = True
print hdr_to_move
print line
Signed-off-by: Mike Rapoport <rppt@linux.ibm.com>
Cc: Brian Cain <bcain@codeaurora.org>
Cc: Chris Zankel <chris@zankel.net>
Cc: Greentime Hu <green.hu@gmail.com>
Cc: Greg Ungerer <gerg@linux-m68k.org>
Cc: Guan Xuetao <gxt@pku.edu.cn>
Cc: Guo Ren <guoren@kernel.org>
Cc: Helge Deller <deller@gmx.de>
Cc: Ley Foon Tan <ley.foon.tan@intel.com>
Cc: Mark Salter <msalter@redhat.com>
Cc: Matthew Wilcox <willy@infradead.org>
Cc: Matt Turner <mattst88@gmail.com>
Cc: Max Filippov <jcmvbkbc@gmail.com>
Cc: Michael Ellerman <mpe@ellerman.id.au>
Cc: Nick Hu <nickhu@andestech.com>
Cc: Paul Walmsley <paul.walmsley@sifive.com>
Cc: Richard Weinberger <richard@nod.at>
Cc: Rich Felker <dalias@libc.org>
Cc: Russell King <linux@armlinux.org.uk>
Cc: Stafford Horne <shorne@gmail.com>
Cc: Thomas Bogendoerfer <tsbogend@alpha.franken.de>
Cc: Vincent Chen <deanbo422@gmail.com>
Cc: Vineet Gupta <vgupta@synopsys.com>
Cc: Will Deacon <will@kernel.org>
Cc: Yoshinori Sato <ysato@users.sourceforge.jp>
Link: http://lkml.kernel.org/r/20200514170327.31389-4-rppt@kernel.org
The include/linux/pgtable.h is going to be the home of generic page table
manipulation functions.
Start with moving asm-generic/pgtable.h to include/linux/pgtable.h and
make the latter include asm/pgtable.h.
Link: http://lkml.kernel.org/r/20200514170327.31389-3-rppt@kernel.org
Patch series "mm: consolidate definitions of page table accessors", v2.
The low level page table accessors (pXY_index(), pXY_offset()) are
duplicated across all architectures and sometimes more than once. For
instance, we have 31 definition of pgd_offset() for 25 supported
architectures.
Most of these definitions are actually identical and typically it boils
down to, e.g.
static inline unsigned long pmd_index(unsigned long address)
return (address >> PMD_SHIFT) & (PTRS_PER_PMD - 1);
static inline pmd_t *pmd_offset(pud_t *pud, unsigned long address)
return (pmd_t *)pud_page_vaddr(*pud) + pmd_index(address);
These definitions can be shared among 90% of the arches provided
XYZ_SHIFT, PTRS_PER_XYZ and xyz_page_vaddr() are defined.
For architectures that really need a custom version there is always
possibility to override the generic version with the usual ifdefs magic.
These patches introduce include/linux/pgtable.h that replaces
include/asm-generic/pgtable.h and add the definitions of the page table
accessors to the new header.
This patch (of 12):
The linux/mm.h header includes <asm/pgtable.h> to allow inlining of the
functions involving page table manipulations, e.g. pte_alloc() and
pmd_alloc(). So, there is no point to explicitly include <asm/pgtable.h>
in the files that include <linux/mm.h>.
The include statements in such cases are remove with a simple loop:
for f in $(git grep -l "include <linux/mm.h>") ; do
sed -i -e '/include <asm\/pgtable.h>/ d' $f
done
Cc: Mike Rapoport <rppt@kernel.org>
Link: http://lkml.kernel.org/r/20200514170327.31389-1-rppt@kernel.org
Link: http://lkml.kernel.org/r/20200514170327.31389-2-rppt@kernel.org
Pull SCSI updates from James Bottomley:
:This series consists of the usual driver updates (qla2xxx, ufs, zfcp,
target, scsi_debug, lpfc, qedi, qedf, hisi_sas, mpt3sas) plus a host
of other minor updates.
There are no major core changes in this series apart from a
refactoring in scsi_lib.c"
* tag 'scsi-misc' of git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi: (207 commits)
scsi: ufs: ti-j721e-ufs: Fix unwinding of pm_runtime changes
scsi: cxgb3i: Fix some leaks in init_act_open()
scsi: ibmvscsi: Make some functions static
scsi: iscsi: Fix deadlock on recovery path during GFP_IO reclaim
scsi: ufs: Fix WriteBooster flush during runtime suspend
scsi: ufs: Fix index of attributes query for WriteBooster feature
scsi: ufs: Allow WriteBooster on UFS 2.2 devices
scsi: ufs: Remove unnecessary memset for dev_info
scsi: ufs-qcom: Fix scheduling while atomic issue
scsi: mpt3sas: Fix reply queue count in non RDPQ mode
scsi: lpfc: Fix lpfc_nodelist leak when processing unsolicited event
scsi: target: tcmu: Fix a use after free in tcmu_check_expired_queue_cmd()
scsi: vhost: Notify TCM about the maximum sg entries supported per command
scsi: qla2xxx: Remove return value from qla_nvme_ls()
scsi: qla2xxx: Remove an unused function
scsi: scsi_debug: Parser tables and code interaction
scsi: core: Refactor scsi_mq_setup_tags function
scsi: core: Fix incorrect usage of shost_for_each_device
scsi: qla2xxx: Fix endianness annotations in source files
Link: https://lore.kernel.org/r/20200529234028.46373-4-viro@ZenIV.linux.org.uk
Acked-by: Don Brace <don.brace@microsemi.com>
Tested-by: Don Brace <don.brace@microsemi.com>
No need for building a native struct on kernel stack, copying it to
userland one, then calling hpsa_ioctl() which copies it back into _another_
instance of the same struct.
Link: https://lore.kernel.org/r/20200529234028.46373-3-viro@ZenIV.linux.org.uk
"BIG" in the name refers to the amount of data being transferred, _not_ the
size of structure itself; it's 140 or 144 bytes (for 32bit and 64bit hosts
resp.). IOCTL_Command_struct is 136 or 144 bytes large...
No point whatsoever turning that into dynamic allocation, let alone vmalloc
one. Just keep it as local variable...
Link: https://lore.kernel.org/r/20200529234028.46373-2-viro@ZenIV.linux.org.uk
Link: https://lore.kernel.org/r/20200529234028.46373-1-viro@ZenIV.linux.org.uk
git://git.kernel.org/pub/scm/linux/kernel/git/hyperv/linux
Pull hyper-v updates from Wei Liu:
- a series from Andrea to support channel reassignment
- a series from Vitaly to clean up Vmbus message handling
- a series from Michael to clean up and augment hyperv-tlfs.h
- patches from Andy to clean up GUID usage in Hyper-V code
- a few other misc patches
* tag 'hyperv-next-signed' of git://git.kernel.org/pub/scm/linux/kernel/git/hyperv/linux: (29 commits)
Drivers: hv: vmbus: Resolve more races involving init_vp_index()
Drivers: hv: vmbus: Resolve race between init_vp_index() and CPU hotplug
vmbus: Replace zero-length array with flexible-array
Driver: hv: vmbus: drop a no long applicable comment
hyper-v: Switch to use UUID types directly
hyper-v: Replace open-coded variant of %*phN specifier
hyper-v: Supply GUID pointer to printf() like functions
hyper-v: Use UUID API for exporting the GUID (part 2)
asm-generic/hyperv: Add definitions for Get/SetVpRegister hypercalls
x86/hyperv: Split hyperv-tlfs.h into arch dependent and independent files
x86/hyperv: Remove HV_PROCESSOR_POWER_STATE #defines
KVM: x86: hyperv: Remove duplicate definitions of Reference TSC Page
drivers: hv: remove redundant assignment to pointer primary_channel
scsi: storvsc: Re-init stor_chns when a channel interrupt is re-assigned
Drivers: hv: vmbus: Introduce the CHANNELMSG_MODIFYCHANNEL message type
Drivers: hv: vmbus: Synchronize init_vp_index() vs. CPU hotplug
Drivers: hv: vmbus: Remove the unused HV_LOCALIZED channel affinity logic
PCI: hv: Prepare hv_compose_msi_msg() for the VMBus-channel-interrupt-to-vCPU reassignment functionality
Drivers: hv: vmbus: Use a spin lock for synchronizing channel scheduling vs. channel removal
hv_utils: Always execute the fcopy and vss callbacks in a tasklet
In ufshcd_probe_hba(), all BKOP SW tracking variables can be reset together
in ufshcd_force_reset_auto_bkops(), thus urgent_bkop_lvl initialization in
the beginning of ufshcd_probe_hba() can be merged into
ufshcd_force_reset_auto_bkops().
Link: https://lore.kernel.org/r/20200530141200.4616-1-stanley.chu@mediatek.com
Signed-off-by: Stanley Chu <stanley.chu@mediatek.com>
Urgent bkops level is used to compare against actual bkops status read from
UFS device. Urgent bkops level is set during initialization and might be
updated in exception event handler during runtime. But it should not be
updated to the actual bkops status every time when auto bkops is toggled.
Otherwise, if urgent bkops level is updated to 0, auto bkops shall always
be kept enabled.
Link: https://lore.kernel.org/r/1590632686-17866-1-git-send-email-cang@codeaurora.org
Fixes: 24366c2afbb0 ("scsi: ufs: Recheck bkops level if bkops is disabled")
Reviewed-by: Stanley Chu <stanley.chu@mediatek.com>
Signed-off-by: Can Guo <cang@codeaurora.org>
The variable rc is being initialized with a value that is never read and it
is being updated later with a new value. The initialization is redundant
and can be removed.
Link: https://lore.kernel.org/r/20200527115242.172344-1-colin.king@canonical.com
Addresses-Coverity: ("Unused value")
Fix memset() accessing out of range address when reply_queue count is less
than RDPQ_MAX_INDEX_IN_ONE_CHUNK (i.e. 16) in non-RDPQ mode.
In non-RDPQ mode, the driver allocates a single contiguous pool of size
reply_queue's count * reqly_post_free_sz. But the driver is always
memsetting this pool with size 16 * reqly_post_free_sz. If reply queue
count is less than 16 (i.e. when MSI-X vectors enabled < 16), the driver is
accessing out of range address and this results in 'BUG: unable to handle
kernel paging request at fff0x...x' bug.
Make driver use dma_pool_zalloc() API to allocate and zero the pool.
Link: https://lore.kernel.org/r/20200528145617.27252-1-suganath-prabu.subramani@broadcom.com
Fixes: 8012209eb26b ("scsi: mpt3sas: Handle RDPQ DMA allocation in same 4G region")
Signed-off-by: Suganath Prabu S <suganath-prabu.subramani@broadcom.com>
kobject_init_and_add() takes reference even when it fails. If this
function returns an error, kobject_put() must be called to properly
clean up the memory associated with the object.
Link: https://lore.kernel.org/r/20200528201353.14849-1-wu000273@umn.edu
Reviewed-by: Lee Duncan <lduncan@suse.com>
Signed-off-by: Qiushi Wu <wu000273@umn.edu>
Pull block driver updates from Jens Axboe:
"On top of the core changes, here are the block driver changes for this
merge window:
- NVMe changes:
- NVMe over Fibre Channel protocol updates, which also reach
over to drivers/scsi/lpfc (James Smart)
- namespace revalidation support on the target (Anthony
Iliopoulos)
- gcc zero length array fix (Arnd Bergmann)
- nvmet cleanups (Chaitanya Kulkarni)
- misc cleanups and fixes (me, Keith Busch, Sagi Grimberg)
- use a SRQ per completion vector (Max Gurtovoy)
- fix handling of runtime changes to the queue count (Weiping
Zhang)
- t10 protection information support for nvme-rdma and
nvmet-rdma (Israel Rukshin and Max Gurtovoy)
- target side AEN improvements (Chaitanya Kulkarni)
- various fixes and minor improvements all over, icluding the
nvme part of the lpfc driver"
- Floppy code cleanup series (Willy, Denis)
- Floppy contention fix (Jiri)
- Loop CONFIGURE support (Martijn)
- bcache fixes/improvements (Coly, Joe, Colin)
- q->queuedata cleanups (Christoph)
- Get rid of ioctl_by_bdev (Christoph, Stefan)
- md/raid5 allocation fixes (Coly)
- zero length array fixes (Gustavo)
- swim3 task state fix (Xu)"
* tag 'for-5.8/drivers-2020-06-01' of git://git.kernel.dk/linux-block: (166 commits)
bcache: configure the asynchronous registertion to be experimental
bcache: asynchronous devices registration
bcache: fix refcount underflow in bcache_device_free()
bcache: Convert pr_<level> uses to a more typical style
bcache: remove redundant variables i and n
lpfc: Fix return value in __lpfc_nvme_ls_abort
lpfc: fix axchg pointer reference after free and double frees
lpfc: Fix pointer checks and comments in LS receive refactoring
nvme: set dma alignment to qword
nvmet: cleanups the loop in nvmet_async_events_process
nvmet: fix memory leak when removing namespaces and controllers concurrently
nvmet-rdma: add metadata/T10-PI support
nvmet: add metadata support for block devices
nvmet: add metadata/T10-PI support
nvme: add Metadata Capabilities enumerations
nvmet: rename nvmet_check_data_len to nvmet_check_transfer_len
nvmet: rename nvmet_rw_len to nvmet_rw_data_len
nvmet: add metadata characteristics for a namespace
nvme-rdma: add metadata/T10-PI support
nvme-rdma: introduce nvme_rdma_sgl structure
Pull block updates from Jens Axboe:
"Core block changes that have been queued up for this release:
- Remove dead blk-throttle and blk-wbt code (Guoqing)
- Include pid in blktrace note traces (Jan)
- Don't spew I/O errors on wouldblock termination (me)
- Zone append addition (Johannes, Keith, Damien)
- IO accounting improvements (Konstantin, Christoph)
- blk-mq hardware map update improvements (Ming)
- Scheduler dispatch improvement (Salman)
- Inline block encryption support (Satya)
- Request map fixes and improvements (Weiping)
- blk-iocost tweaks (Tejun)
- Fix for timeout failing with error injection (Keith)
- Queue re-run fixes (Douglas)
- CPU hotplug improvements (Christoph)
- Queue entry/exit improvements (Christoph)
- Move DMA drain handling to the few drivers that use it (Christoph)
- Partition handling cleanups (Christoph)"
* tag 'for-5.8/block-2020-06-01' of git://git.kernel.dk/linux-block: (127 commits)
block: mark bio_wouldblock_error() bio with BIO_QUIET
blk-wbt: rename __wbt_update_limits to wbt_update_limits
blk-wbt: remove wbt_update_limits
blk-throttle: remove tg_drain_bios
blk-throttle: remove blk_throtl_drain
null_blk: force complete for timeout request
blk-mq: drain I/O when all CPUs in a hctx are offline
blk-mq: add blk_mq_all_tag_iter
blk-mq: open code __blk_mq_alloc_request in blk_mq_alloc_request_hctx
blk-mq: use BLK_MQ_NO_TAG in more places
blk-mq: rename BLK_MQ_TAG_FAIL to BLK_MQ_NO_TAG
blk-mq: move more request initialization to blk_mq_rq_ctx_init
blk-mq: simplify the blk_mq_get_request calling convention
blk-mq: remove the bio argument to ->prepare_request
nvme: force complete cancelled requests
blk-mq: blk-mq: provide forced completion method
block: fix a warning when blkdev.h is included for !CONFIG_BLOCK builds
block: blk-crypto-fallback: remove redundant initialization of variable err
block: reduce part_stat_lock() scope
block: use __this_cpu_add() instead of access by smp_processor_id()
Merge updates from Andrew Morton:
"A few little subsystems and a start of a lot of MM patches.
Subsystems affected by this patch series: squashfs, ocfs2, parisc,
vfs. With mm subsystems: slab-generic, slub, debug, pagecache, gup,
swap, memcg, pagemap, memory-failure, vmalloc, kasan"
* emailed patches from Andrew Morton <akpm@linux-foundation.org>: (128 commits)
kasan: move kasan_report() into report.c
mm/mm_init.c: report kasan-tag information stored in page->flags
ubsan: entirely disable alignment checks under UBSAN_TRAP
kasan: fix clang compilation warning due to stack protector
x86/mm: remove vmalloc faulting
mm: remove vmalloc_sync_(un)mappings()
x86/mm/32: implement arch_sync_kernel_mappings()
x86/mm/64: implement arch_sync_kernel_mappings()
mm/ioremap: track which page-table levels were modified
mm/vmalloc: track which page-table levels were modified
mm: add functions to track page directory modifications
s390: use __vmalloc_node in stack_alloc
powerpc: use __vmalloc_node in alloc_vm_stack
arm64: use __vmalloc_node in arch_alloc_vmap_stack
mm: remove vmalloc_user_node_flags
mm: switch the test_vmalloc module to use __vmalloc_node
mm: remove __vmalloc_node_flags_caller
mm: remove both instances of __vmalloc_node_flags
mm: remove the prot argument to __vmalloc_node
mm: remove the pgprot argument to __vmalloc
The pgprot argument to __vmalloc is always PAGE_KERNEL now, so remove it.
Reviewed-by: Michael Kelley <mikelley@microsoft.com> [hyperv]
Acked-by: Gao Xiang <xiang@kernel.org> [erofs]
Acked-by: Peter Zijlstra (Intel) <peterz@infradead.org>
Acked-by: Wei Liu <wei.liu@kernel.org>
Cc: Christian Borntraeger <borntraeger@de.ibm.com>
Cc: Christophe Leroy <christophe.leroy@c-s.fr>
Cc: Daniel Vetter <daniel.vetter@ffwll.ch>
Cc: David Airlie <airlied@linux.ie>
Cc: Haiyang Zhang <haiyangz@microsoft.com>
Cc: "K. Y. Srinivasan" <kys@microsoft.com>
Cc: Laura Abbott <labbott@redhat.com>
Cc: Mark Rutland <mark.rutland@arm.com>
Cc: Minchan Kim <minchan@kernel.org>
Cc: Nitin Gupta <ngupta@vflare.org>
Cc: Robin Murphy <robin.murphy@arm.com>
Cc: Sakari Ailus <sakari.ailus@linux.intel.com>
Cc: Stephen Hemminger <sthemmin@microsoft.com>
Cc: Sumit Semwal <sumit.semwal@linaro.org>
Cc: Paul Mackerras <paulus@ozlabs.org>
Cc: Vasily Gorbik <gor@linux.ibm.com>
Link: http://lkml.kernel.org/r/20200414131348.444715-22-hch@lst.de
Pull uaccess/__copy_to_user updates from Al Viro:
"Getting rid of __copy_to_user() callers - stuff that doesn't fit into
other series"
* 'uaccess.__copy_to_user' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs:
dlmfs: convert dlmfs_file_read() to copy_to_user()
esas2r: don't bother with __copy_to_user()
Pull uaccess/__put-user updates from Al Viro:
"Removal of __put_user() calls - misc patches that don't fit into any
other series"
* 'uaccess.__put_user' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs:
pcm_native: result of put_user() needs to be checked
scsi_ioctl.c: switch SCSI_IOCTL_GET_IDLUN to copy_to_user()
compat sysinfo(2): don't bother with field-by-field copyout
Pull uaccess/access_ok updates from Al Viro:
"Removals of trivially pointless access_ok() calls.
Note: the fiemap stuff was removed from the series, since they are
duplicates with part of ext4 series carried in Ted's tree"
* 'uaccess.access_ok' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs:
vmci_host: get rid of pointless access_ok()
hfi1: get rid of pointless access_ok()
usb: get rid of pointless access_ok() calls
lpfc_debugfs: get rid of pointless access_ok()
efi_test: get rid of pointless access_ok()
drm_read(): get rid of pointless access_ok()
via-pmu: don't bother with access_ok()
drivers/crypto/ccp/sev-dev.c: get rid of pointless access_ok()
omapfb: get rid of pointless access_ok() calls
amifb: get rid of pointless access_ok() calls
drivers/fpga/dfl-afu-dma-region.c: get rid of pointless access_ok()
drivers/fpga/dfl-fme-pr.c: get rid of pointless access_ok()
cm4000_cs.c cmm_ioctl(): get rid of pointless access_ok()
nvram: drop useless access_ok()
n_hdlc_tty_read(): remove pointless access_ok()
tomoyo_write_control(): get rid of pointless access_ok()
btrfs_ioctl_send(): don't bother with access_ok()
fat_dir_ioctl(): hadn't needed that access_ok() for more than a decade...
dlmfs_file_write(): get rid of pointless access_ok()
No, you do NOT need to "protect copy from user" that way.
Incidentally, your userland ABI stinks. I understand that you
wanted to accept "reset" and "reset\n" as equivalent, but I suspect
that accepting "reset this, you !@^!@!" had been an accident.
Nothing to do about that now - it is a userland ABI...
