path: root/drivers/scsi
2019-07-20Merge tag 'scsi-fixes' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi Pull SCSI fixes from James Bottomley: "This is the final round of mostly small fixes in our initial submit. It's mostly minor fixes and driver updates. The only change of note is adding a virt_boundary_mask to the SCSI host and host template to parametrise this for NVMe devices instead of having them do a call in slave_alloc. It's a fairly straightforward conversion except in the two NVMe handling drivers that didn't set it who now have a virtual infinity parameter added" * tag 'scsi-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi: (24 commits) scsi: megaraid_sas: set an unlimited max_segment_size scsi: mpt3sas: set an unlimited max_segment_size for SAS 3.0 HBAs scsi: IB/srp: set virt_boundary_mask in the scsi host scsi: IB/iser: set virt_boundary_mask in the scsi host scsi: storvsc: set virt_boundary_mask in the scsi host template scsi: ufshcd: set max_segment_size in the scsi host template scsi: core: take the DMA max mapping size into account scsi: core: add a host / host template field for the virt boundary scsi: core: Fix race on creating sense cache scsi: sd_zbc: Fix compilation warning scsi: libfc: fix null pointer dereference on a null lport scsi: zfcp: fix GCC compiler warning emitted with -Wmaybe-uninitialized scsi: zfcp: fix request object use-after-free in send path causing wrong traces scsi: zfcp: fix request object use-after-free in send path causing seqno errors scsi: megaraid_sas: Update driver version to 07.710.50.00 scsi: megaraid_sas: Add module parameter for FW Async event logging scsi: megaraid_sas: Enable msix_load_balance for Invader and later controllers scsi: megaraid_sas: Fix calculation of target ID scsi: lpfc: reduce stack size with CONFIG_GCC_PLUGIN_STRUCTLEAK_VERBOSE scsi: devinfo: BLIST_TRY_VPD_PAGES for SanDisk Cruzer Blade ...
2019-07-20Merge tag 'kbuild-v5.3-2' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/masahiroy/linux-kbuild Pull more Kbuild updates from Masahiro Yamada: - match the directory structure of the linux-libc-dev package to that of Debian-based distributions - fix incorrect include/config/auto.conf generation when Kconfig creates it along with the .config file - remove misleading $(AS) from documents - clean up precious tag files by distclean instead of mrproper - add a new coccinelle patch for devm_platform_ioremap_resource migration - refactor module-related scripts to read modules.order instead of $(MODVERDIR)/*.mod files to get the list of created modules - remove MODVERDIR - update list of header compile-test - add -fcf-protection=none flag to avoid conflict with the retpoline flags when CONFIG_RETPOLINE=y - misc cleanups * tag 'kbuild-v5.3-2' of git://git.kernel.org/pub/scm/linux/kernel/git/masahiroy/linux-kbuild: (25 commits) kbuild: add -fcf-protection=none when using retpoline flags kbuild: update compile-test header list for v5.3-rc1 kbuild: split out *.mod out of {single,multi}-used-m rules kbuild: remove 'prepare1' target kbuild: remove the first line of *.mod files kbuild: create *.mod with full directory path and remove MODVERDIR kbuild: export_report: read modules.order instead of .tmp_versions/*.mod kbuild: modpost: read modules.order instead of $(MODVERDIR)/*.mod kbuild: modsign: read modules.order instead of $(MODVERDIR)/*.mod kbuild: modinst: read modules.order instead of $(MODVERDIR)/*.mod scsi: remove pointless $(MODVERDIR)/$(obj)/53c700.ver kbuild: remove duplication from modules.order in sub-directories kbuild: get rid of kernel/ prefix from in-tree modules.{order,builtin} kbuild: do not create empty modules.order in the prepare stage coccinelle: api: add devm_platform_ioremap_resource script kbuild: compile-test headers listed in header-test-m as well kbuild: remove unused hostcc-option kbuild: remove tag files by distclean instead of mrproper kbuild: add --hash-style= and --build-id unconditionally kbuild: get rid of misleading $(AS) from documents ...
2019-07-19Merge branch 'work.mount0' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs Pull vfs mount updates from Al Viro: "The first part of mount updates. Convert filesystems to use the new mount API" * 'work.mount0' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (63 commits) mnt_init(): call shmem_init() unconditionally constify ksys_mount() string arguments don't bother with registering rootfs init_rootfs(): don't bother with init_ramfs_fs() vfs: Convert smackfs to use the new mount API vfs: Convert selinuxfs to use the new mount API vfs: Convert securityfs to use the new mount API vfs: Convert apparmorfs to use the new mount API vfs: Convert openpromfs to use the new mount API vfs: Convert xenfs to use the new mount API vfs: Convert gadgetfs to use the new mount API vfs: Convert oprofilefs to use the new mount API vfs: Convert ibmasmfs to use the new mount API vfs: Convert qib_fs/ipathfs to use the new mount API vfs: Convert efivarfs to use the new mount API vfs: Convert configfs to use the new mount API vfs: Convert binfmt_misc to use the new mount API convenience helper: get_tree_single() convenience helper get_tree_nodev() vfs: Kill sget_userns() ...
2019-07-17Merge tag 'for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mst/vhostLinus Torvalds
Pull virtio, vhost updates from Michael Tsirkin: "Fixes, features, performance: - new iommu device - vhost guest memory access using vmap (just meta-data for now) - minor fixes" * tag 'for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mst/vhost: virtio-mmio: add error check for platform_get_irq scsi: virtio_scsi: Use struct_size() helper iommu/virtio: Add event queue iommu/virtio: Add probe request iommu: Add virtio-iommu driver PCI: OF: Initialize dev->fwnode appropriately of: Allow the iommu-map property to omit untranslated devices dt-bindings: virtio: Add virtio-pci-iommu node dt-bindings: virtio-mmio: Add IOMMU description vhost: fix clang build warning vhost: access vq metadata through kernel virtual address vhost: factor out setting vring addr and num vhost: introduce helpers to get the size of metadata area vhost: rename vq_iotlb_prefetch() to vq_meta_prefetch() vhost: fine grain userspace memory accessors vhost: generalize adding used elem
2019-07-17scsi: remove pointless $(MODVERDIR)/$(obj)/53c700.verMasahiro Yamada
Nothing depends on this, so it is dead code. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2019-07-16scsi: megaraid_sas: set an unlimited max_segment_sizeChristoph Hellwig
When using a virt_boundary_mask, as done for NVMe devices attached to megaraid_sas controllers, we require an unlimited max_segment_size as the virt boundary merging code assumes that. But we also need to propagate that to the DMA mapping layer to make dma-debug happy. The SCSI layer takes care of that when using the per-host virt_boundary setting, but given that megaraid_sas only wants to set the virt_boundary for actual NVMe devices, we can't rely on that. The DMA layer maximum segment is global to the HBA however, so we have to set it explicitly. This patch assumes that megaraid_sas does not have a segment size limitation, which seems true based on the SGL format, but will need to be verified. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com>
2019-07-16scsi: mpt3sas: set an unlimited max_segment_size for SAS 3.0 HBAsChristoph Hellwig
When using a virt_boundary_mask, as done for NVMe devices attached to mpt3sas controllers, we require an unlimited max_segment_size as the virt boundary merging code assumes that. But we also need to propagate that to the DMA mapping layer to make dma-debug happy. The SCSI layer takes care of that when using the per-host virt_boundary setting, but given that mpt3sas only wants to set the virt_boundary for actual NVMe devices, we can't rely on that. The DMA layer maximum segment is global to the HBA however, so we have to set it explicitly. This patch assumes that mpt3sas does not have a segment size limitation, which seems true based on the SGL format, but will need to be verified. Signed-off-by: Christoph Hellwig <hch@lst.de> Acked-by: Suganath Prabu <suganath-prabu.subramani@broadcom.com> Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com>
2019-07-16scsi: storvsc: set virt_boundary_mask in the scsi host templateChristoph Hellwig
This ensures all proper DMA layer handling is taken care of by the SCSI midlayer. Signed-off-by: Christoph Hellwig <hch@lst.de> Reviewed-by: Bart Van Assche <bvanassche@acm.org> Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com>
2019-07-16scsi: ufshcd: set max_segment_size in the scsi host templateChristoph Hellwig
We need to also mirror the value to the device to ensure IOMMU merging doesn't undo it, and the SCSI host level parameter will ensure that. Signed-off-by: Christoph Hellwig <hch@lst.de> Reviewed-by: Bart Van Assche <bvanassche@acm.org> Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com>
2019-07-16scsi: core: take the DMA max mapping size into accountChristoph Hellwig
We need to limit the device's max_sectors to what the DMA mapping implementation can support. If not, we risk running out of swiotlb buffers easily. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com>
2019-07-16scsi: core: add a host / host template field for the virt boundaryChristoph Hellwig
This allows drivers setting it up easily instead of branching out to block layer calls in slave_alloc, and ensures the upgraded max_segment_size setting gets picked up by the DMA layer. Signed-off-by: Christoph Hellwig <hch@lst.de> Acked-by: Kashyap Desai < kashyap.desai@broadcom.com> Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com>
2019-07-16scsi: core: Fix race on creating sense cacheMing Lei
When scsi_init_sense_cache(host) is called concurrently from different hosts, each code path may find that no cache has been created and allocate a new one. The lack of locking can lead to potentially overriding a cache allocated by a different host. Fix the issue by moving 'mutex_lock(&scsi_sense_cache_mutex)' before scsi_select_sense_cache(). Fixes: 0a6ac4ee7c21 ("scsi: respect unchecked_isa_dma for blk-mq") Cc: Stable <stable@vger.kernel.org> Cc: Christoph Hellwig <hch@lst.de> Cc: Hannes Reinecke <hare@suse.com> Cc: Ewan D. Milne <emilne@redhat.com> Signed-off-by: Ming Lei <ming.lei@redhat.com> Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com>
2019-07-16scsi: sd_zbc: Fix compilation warningDamien Le Moal
kbuild test robot gets the following compilation warning using gcc 7.4 cross compilation for c6x (GCC_VERSION=7.4.0 make.cross ARCH=c6x). In file included from include/asm-generic/bug.h:18:0, from arch/c6x/include/asm/bug.h:12, from include/linux/bug.h:5, from include/linux/thread_info.h:12, from include/asm-generic/current.h:5, from ./arch/c6x/include/generated/asm/current.h:1, from include/linux/sched.h:12, from include/linux/blkdev.h:5, from drivers//scsi/sd_zbc.c:11: drivers//scsi/sd_zbc.c: In function 'sd_zbc_read_zones': >> include/linux/kernel.h:62:48: warning: 'zone_blocks' may be used uninitialized in this function [-Wmaybe-uninitialized] #define __round_mask(x, y) ((__typeof__(x))((y)-1)) ^ drivers//scsi/sd_zbc.c:464:6: note: 'zone_blocks' was declared here u32 zone_blocks; ^~~~~~~~~~~ This is a false-positive report. The variable zone_blocks is always initialized in sd_zbc_check_zones() before use. It is not initialized only and only if sd_zbc_check_zones() fails. Avoid this warning by initializing the zone_blocks variable to 0. Fixes: 5f832a395859 ("scsi: sd_zbc: Fix sd_zbc_check_zones() error checks") Cc: Stable <stable@vger.kernel.org> Signed-off-by: Damien Le Moal <damien.lemoal@wdc.com> Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com>
2019-07-16scsi: libfc: fix null pointer dereference on a null lportColin Ian King
Currently if lport is null then the null lport pointer is dereference when printing out debug via the FC_LPORT_DB macro. Fix this by using the more generic FC_LIBFC_DBG debug macro instead that does not use lport. Addresses-Coverity: ("Dereference after null check") Fixes: 7414705ea4ae ("libfc: Add runtime debugging with debug_logging module parameter") Signed-off-by: Colin Ian King <colin.king@canonical.com> Reviewed-by: Hannes Reinecke <hare@suse.com> Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com>
2019-07-15Merge tag 'for-linus-20190715' of git://git.kernel.dk/linux-blockLinus Torvalds
Pull more block updates from Jens Axboe: "A later pull request with some followup items. I had some vacation coming up to the merge window, so certain things items were delayed a bit. This pull request also contains fixes that came in within the last few days of the merge window, which I didn't want to push right before sending you a pull request. This contains: - NVMe pull request, mostly fixes, but also a few minor items on the feature side that were timing constrained (Christoph et al) - Report zones fixes (Damien) - Removal of dead code (Damien) - Turn on cgroup psi memstall (Josef) - block cgroup MAINTAINERS entry (Konstantin) - Flush init fix (Josef) - blk-throttle low iops timing fix (Konstantin) - nbd resize fixes (Mike) - nbd 0 blocksize crash fix (Xiubo) - block integrity error leak fix (Wenwen) - blk-cgroup writeback and priority inheritance fixes (Tejun)" * tag 'for-linus-20190715' of git://git.kernel.dk/linux-block: (42 commits) MAINTAINERS: add entry for block io cgroup null_blk: fixup ->report_zones() for !CONFIG_BLK_DEV_ZONED block: Limit zone array allocation size sd_zbc: Fix report zones buffer allocation block: Kill gfp_t argument of blkdev_report_zones() block: Allow mapping of vmalloc-ed buffers block/bio-integrity: fix a memory leak bug nvme: fix NULL deref for fabrics options nbd: add netlink reconfigure resize support nbd: fix crash when the blksize is zero block: Disable write plugging for zoned block devices block: Fix elevator name declaration block: Remove unused definitions nvme: fix regression upon hot device removal and insertion blk-throttle: fix zero wait time for iops throttled group block: Fix potential overflow in blk_report_zones() blkcg: implement REQ_CGROUP_PUNT blkcg, writeback: Implement wbc_blkcg_css() blkcg, writeback: Add wbc->no_cgroup_owner blkcg, writeback: Rename wbc_account_io() to wbc_account_cgroup_owner() ...
2019-07-12Merge tag 'driver-core-5.3-rc1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core Pull driver core and debugfs updates from Greg KH: "Here is the "big" driver core and debugfs changes for 5.3-rc1 It's a lot of different patches, all across the tree due to some api changes and lots of debugfs cleanups. Other than the debugfs cleanups, in this set of changes we have: - bus iteration function cleanups - scripts/get_abi.pl tool to display and parse Documentation/ABI entries in a simple way - cleanups to Documenatation/ABI/ entries to make them parse easier due to typos and other minor things - default_attrs use for some ktype users - driver model documentation file conversions to .rst - compressed firmware file loading - deferred probe fixes All of these have been in linux-next for a while, with a bunch of merge issues that Stephen has been patient with me for" * tag 'driver-core-5.3-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core: (102 commits) debugfs: make error message a bit more verbose orangefs: fix build warning from debugfs cleanup patch ubifs: fix build warning after debugfs cleanup patch driver: core: Allow subsystems to continue deferring probe drivers: base: cacheinfo: Ensure cpu hotplug work is done before Intel RDT arch_topology: Remove error messages on out-of-memory conditions lib: notifier-error-inject: no need to check return value of debugfs_create functions swiotlb: no need to check return value of debugfs_create functions ceph: no need to check return value of debugfs_create functions sunrpc: no need to check return value of debugfs_create functions ubifs: no need to check return value of debugfs_create functions orangefs: no need to check return value of debugfs_create functions nfsd: no need to check return value of debugfs_create functions lib: 842: no need to check return value of debugfs_create functions debugfs: provide pr_fmt() macro debugfs: log errors when something goes wrong drivers: s390/cio: Fix compilation warning about const qualifiers drivers: Add generic helper to match by of_node driver_find_device: Unify the match function with class_find_device() bus_find_device: Unify the match callback with class_find_device ...
2019-07-12Merge branch 'akpm' (patches from Andrew)Linus Torvalds
Merge updates from Andrew Morton: "Am experimenting with splitting MM up into identifiable subsystems perhaps with a view to gitifying it in complex ways. Also with more verbose "incoming" emails. Most of MM is here and a few other trees. Subsystems affected by this patch series: - hotfixes - iommu - scripts - arch/sh - ocfs2 - mm:slab-generic - mm:slub - mm:kmemleak - mm:kasan - mm:cleanups - mm:debug - mm:pagecache - mm:swap - mm:memcg - mm:gup - mm:pagemap - mm:infrastructure - mm:vmalloc - mm:initialization - mm:pagealloc - mm:vmscan - mm:tools - mm:proc - mm:ras - mm:oom-kill hotfixes: mm: vmscan: scan anonymous pages on file refaults mm/nvdimm: add is_ioremap_addr and use that to check ioremap address mm/memcontrol: fix wrong statistics in memory.stat mm/z3fold.c: lock z3fold page before __SetPageMovable() nilfs2: do not use unexported cpu_to_le32()/le32_to_cpu() in uapi header MAINTAINERS: nilfs2: update email address iommu: include/linux/dmar.h: replace single-char identifiers in macros scripts: scripts/decode_stacktrace: match basepath using shell prefix operator, not regex scripts/decode_stacktrace: look for modules with .ko.debug extension scripts/spelling.txt: drop "sepc" from the misspelling list scripts/spelling.txt: add spelling fix for prohibited scripts/decode_stacktrace: Accept dash/underscore in modules scripts/spelling.txt: add more spellings to spelling.txt arch/sh: arch/sh/configs/sdk7786_defconfig: remove CONFIG_LOGFS sh: config: remove left-over BACKLIGHT_LCD_SUPPORT sh: prevent warnings when using iounmap ocfs2: fs: ocfs: fix spelling mistake "hearbeating" -> "heartbeat" ocfs2/dlm: use struct_size() helper ocfs2: add last unlock times in locking_state ocfs2: add locking filter debugfs file ocfs2: add first lock wait time in locking_state ocfs: no need to check return value of debugfs_create functions fs/ocfs2/dlmglue.c: unneeded variable: "status" ocfs2: use kmemdup rather than duplicating its implementation mm:slab-generic: Patch series "mm/slab: Improved sanity checking": mm/slab: validate cache membership under freelist hardening mm/slab: sanity-check page type when looking up cache lkdtm/heap: add tests for freelist hardening mm:slub: mm/slub.c: avoid double string traverse in kmem_cache_flags() slub: don't panic for memcg kmem cache creation failure mm:kmemleak: mm/kmemleak.c: fix check for softirq context mm/kmemleak.c: change error at _write when kmemleak is disabled docs: kmemleak: add more documentation details mm:kasan: mm/kasan: print frame description for stack bugs Patch series "Bitops instrumentation for KASAN", v5: lib/test_kasan: add bitops tests x86: use static_cpu_has in uaccess region to avoid instrumentation asm-generic, x86: add bitops instrumentation for KASAN Patch series "mm/kasan: Add object validation in ksize()", v3: mm/kasan: introduce __kasan_check_{read,write} mm/kasan: change kasan_check_{read,write} to return boolean lib/test_kasan: Add test for double-kzfree detection mm/slab: refactor common ksize KASAN logic into slab_common.c mm/kasan: add object validation in ksize() mm:cleanups: include/linux/pfn_t.h: remove pfn_t_to_virt() Patch series "remove ARCH_SELECT_MEMORY_MODEL where it has no effect": arm: remove ARCH_SELECT_MEMORY_MODEL s390: remove ARCH_SELECT_MEMORY_MODEL sparc: remove ARCH_SELECT_MEMORY_MODEL mm/gup.c: make follow_page_mask() static mm/memory.c: trivial clean up in insert_page() mm: make !CONFIG_HUGE_PAGE wrappers into static inlines include/linux/mm_types.h: ifdef struct vm_area_struct::swap_readahead_info mm: remove the account_page_dirtied export mm/page_isolation.c: change the prototype of undo_isolate_page_range() include/linux/vmpressure.h: use spinlock_t instead of struct spinlock mm: remove the exporting of totalram_pages include/linux/pagemap.h: document trylock_page() return value mm:debug: mm/failslab.c: by default, do not fail allocations with direct reclaim only Patch series "debug_pagealloc improvements": mm, debug_pagelloc: use static keys to enable debugging mm, page_alloc: more extensive free page checking with debug_pagealloc mm, debug_pagealloc: use a page type instead of page_ext flag mm:pagecache: Patch series "fix filler_t callback type mismatches", v2: mm/filemap.c: fix an overly long line in read_cache_page mm/filemap: don't cast ->readpage to filler_t for do_read_cache_page jffs2: pass the correct prototype to read_cache_page 9p: pass the correct prototype to read_cache_page mm/filemap.c: correct the comment about VM_FAULT_RETRY mm:swap: mm, swap: fix race between swapoff and some swap operations mm/swap_state.c: simplify total_swapcache_pages() with get_swap_device() mm, swap: use rbtree for swap_extent mm/mincore.c: fix race between swapoff and mincore mm:memcg: memcg, oom: no oom-kill for __GFP_RETRY_MAYFAIL memcg, fsnotify: no oom-kill for remote memcg charging mm, memcg: introduce memory.events.local mm: memcontrol: dump memory.stat during cgroup OOM Patch series "mm: reparent slab memory on cgroup removal", v7: mm: memcg/slab: postpone kmem_cache memcg pointer initialization to memcg_link_cache() mm: memcg/slab: rename slab delayed deactivation functions and fields mm: memcg/slab: generalize postponed non-root kmem_cache deactivation mm: memcg/slab: introduce __memcg_kmem_uncharge_memcg() mm: memcg/slab: unify SLAB and SLUB page accounting mm: memcg/slab: don't check the dying flag on kmem_cache creation mm: memcg/slab: synchronize access to kmem_cache dying flag using a spinlock mm: memcg/slab: rework non-root kmem_cache lifecycle management mm: memcg/slab: stop setting page->mem_cgroup pointer for slab pages mm: memcg/slab: reparent memcg kmem_caches on cgroup removal mm, memcg: add a memcg_slabinfo debugfs file mm:gup: Patch series "switch the remaining architectures to use generic GUP", v4: mm: use untagged_addr() for get_user_pages_fast addresses mm: simplify gup_fast_permitted mm: lift the x86_32 PAE version of gup_get_pte to common code MIPS: use the generic get_user_pages_fast code sh: add the missing pud_page definition sh: use the generic get_user_pages_fast code sparc64: add the missing pgd_page definition sparc64: define untagged_addr() sparc64: use the generic get_user_pages_fast code mm: rename CONFIG_HAVE_GENERIC_GUP to CONFIG_HAVE_FAST_GUP mm: reorder code blocks in gup.c mm: consolidate the get_user_pages* implementations mm: validate get_user_pages_fast flags mm: move the powerpc hugepd code to mm/gup.c mm: switch gup_hugepte to use try_get_compound_head mm: mark the page referenced in gup_hugepte mm/gup: speed up check_and_migrate_cma_pages() on huge page mm/gup.c: remove some BUG_ONs from get_gate_page() mm/gup.c: mark undo_dev_pagemap as __maybe_unused mm:pagemap: asm-generic, x86: introduce generic pte_{alloc,free}_one[_kernel] alpha: switch to generic version of pte allocation arm: switch to generic version of pte allocation arm64: switch to generic version of pte allocation csky: switch to generic version of pte allocation m68k: sun3: switch to generic version of pte allocation mips: switch to generic version of pte allocation nds32: switch to generic version of pte allocation nios2: switch to generic version of pte allocation parisc: switch to generic version of pte allocation riscv: switch to generic version of pte allocation um: switch to generic version of pte allocation unicore32: switch to generic version of pte allocation mm/pgtable: drop pgtable_t variable from pte_fn_t functions mm/memory.c: fail when offset == num in first check of __vm_map_pages() mm:infrastructure: mm/mmu_notifier: use hlist_add_head_rcu() mm:vmalloc: Patch series "Some cleanups for the KVA/vmalloc", v5: mm/vmalloc.c: remove "node" argument mm/vmalloc.c: preload a CPU with one object for split purpose mm/vmalloc.c: get rid of one single unlink_va() when merge mm/vmalloc.c: switch to WARN_ON() and move it under unlink_va() mm/vmalloc.c: spelling> s/informaion/information/ mm:initialization: mm/large system hash: use vmalloc for size > MAX_ORDER when !hashdist mm/large system hash: clear hashdist when only one node with memory is booted mm:pagealloc: arm64: move jump_label_init() before parse_early_param() Patch series "add init_on_alloc/init_on_free boot options", v10: mm: security: introduce init_on_alloc=1 and init_on_free=1 boot options mm: init: report memory auto-initialization features at boot time mm:vmscan: mm: vmscan: remove double slab pressure by inc'ing sc->nr_scanned mm: vmscan: correct some vmscan counters for THP swapout mm:tools: tools/vm/slabinfo: order command line options tools/vm/slabinfo: add partial slab listing to -X tools/vm/slabinfo: add option to sort by partial slabs tools/vm/slabinfo: add sorting info to help menu mm:proc: proc: use down_read_killable mmap_sem for /proc/pid/maps proc: use down_read_killable mmap_sem for /proc/pid/smaps_rollup proc: use down_read_killable mmap_sem for /proc/pid/pagemap proc: use down_read_killable mmap_sem for /proc/pid/clear_refs proc: use down_read_killable mmap_sem for /proc/pid/map_files mm: use down_read_killable for locking mmap_sem in access_remote_vm mm: smaps: split PSS into components mm: vmalloc: show number of vmalloc pages in /proc/meminfo mm:ras: mm/memory-failure.c: clarify error message mm:oom-kill: mm: memcontrol: use CSS_TASK_ITER_PROCS at mem_cgroup_scan_tasks() mm, oom: refactor dump_tasks for memcg OOMs mm, oom: remove redundant task_in_mem_cgroup() check oom: decouple mems_allowed from oom_unkillable_task mm/oom_kill.c: remove redundant OOM score normalization in select_bad_process()" * akpm: (147 commits) mm/oom_kill.c: remove redundant OOM score normalization in select_bad_process() oom: decouple mems_allowed from oom_unkillable_task mm, oom: remove redundant task_in_mem_cgroup() check mm, oom: refactor dump_tasks for memcg OOMs mm: memcontrol: use CSS_TASK_ITER_PROCS at mem_cgroup_scan_tasks() mm/memory-failure.c: clarify error message mm: vmalloc: show number of vmalloc pages in /proc/meminfo mm: smaps: split PSS into components mm: use down_read_killable for locking mmap_sem in access_remote_vm proc: use down_read_killable mmap_sem for /proc/pid/map_files proc: use down_read_killable mmap_sem for /proc/pid/clear_refs proc: use down_read_killable mmap_sem for /proc/pid/pagemap proc: use down_read_killable mmap_sem for /proc/pid/smaps_rollup proc: use down_read_killable mmap_sem for /proc/pid/maps tools/vm/slabinfo: add sorting info to help menu tools/vm/slabinfo: add option to sort by partial slabs tools/vm/slabinfo: add partial slab listing to -X tools/vm/slabinfo: order command line options mm: vmscan: correct some vmscan counters for THP swapout mm: vmscan: remove double slab pressure by inc'ing sc->nr_scanned ...
2019-07-12scripts/spelling.txt: drop "sepc" from the misspelling listPaul Walmsley
The RISC-V architecture has a register named the "Supervisor Exception Program Counter", or "sepc". This abbreviation triggers checkpatch.pl's misspelling detector, resulting in noise in the checkpatch output. The risk that this noise could cause more useful warnings to be missed seems to outweigh the harm of an occasional misspelling of "spec". Thus drop the "sepc" entry from the misspelling list. [akpm@linux-foundation.org: fix existing "sepc" instances, per Joe] Link: http://lkml.kernel.org/r/20190518210037.13674-1-paul.walmsley@sifive.com Signed-off-by: Paul Walmsley <paul.walmsley@sifive.com> Cc: Joe Perches <joe@perches.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2019-07-11sd_zbc: Fix report zones buffer allocationDamien Le Moal
During disk scan and revalidation done with sd_revalidate(), the zones of a zoned disk are checked using the helper function blk_revalidate_disk_zones() if a configuration change is detected (change in the number of zones or zone size). The function blk_revalidate_disk_zones() issues report_zones calls that are very large, that is, to obtain zone information for all zones of the disk with a single command. The size of the report zones command buffer necessary for such large request generally is lower than the disk max_hw_sectors and KMALLOC_MAX_SIZE (4MB) and succeeds on boot (no memory fragmentation), but often fail at run time (e.g. hot-plug event). This causes the disk revalidation to fail and the disk capacity to be changed to 0. This problem can be avoided by using vmalloc() instead of kmalloc() for the buffer allocation. To limit the amount of memory to be allocated, this patch also introduces the arbitrary SD_ZBC_REPORT_MAX_ZONES maximum number of zones to report with a single report zones command. This limit may be lowered further to satisfy the disk max_hw_sectors limit. Finally, to ensure that the vmalloc-ed buffer can always be mapped in a request, the buffer size is further limited to at most queue_max_segments() pages, allowing successful mapping of the buffer even in the worst case scenario where none of the buffer pages are contiguous. Fixes: 515ce6061312 ("scsi: sd_zbc: Fix sd_zbc_report_zones() buffer allocation") Fixes: e76239a3748c ("block: add a report_zones method") Cc: stable@vger.kernel.org Reviewed-by: Christoph Hellwig <hch@lst.de> Reviewed-by: Martin K. Petersen <martin.petersen@oracle.com> Signed-off-by: Damien Le Moal <damien.lemoal@wdc.com> Signed-off-by: Jens Axboe <axboe@kernel.dk>
2019-07-11block: Kill gfp_t argument of blkdev_report_zones()Damien Le Moal
Only GFP_KERNEL and GFP_NOIO are used with blkdev_report_zones(). In preparation of using vmalloc() for large report buffer and zone array allocations used by this function, remove its "gfp_t gfp_mask" argument and rely on the caller context to use memalloc_noio_save/restore() where necessary (block layer zone revalidation and dm-zoned I/O error path). Reviewed-by: Christoph Hellwig <hch@lst.de> Reviewed-by: Martin K. Petersen <martin.petersen@oracle.com> Signed-off-by: Damien Le Moal <damien.lemoal@wdc.com> Signed-off-by: Jens Axboe <axboe@kernel.dk>
2019-07-11scsi: megaraid_sas: Update driver version to 07.710.50.00Shivasharan S
Signed-off-by: Shivasharan S <shivasharan.srikanteshwara@broadcom.com> Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com>
2019-07-11scsi: megaraid_sas: Add module parameter for FW Async event loggingShivasharan S
Add module parameter to control logging levels of async event notifications from firmware that get logged to system log. Also, allow changing the value from sysfs after driver load. Signed-off-by: Shivasharan S <shivasharan.srikanteshwara@broadcom.com> Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com>
2019-07-11scsi: megaraid_sas: Enable msix_load_balance for Invader and later controllersShivasharan S
Load balancing IO completions across all available MSI-X vectors should be enabled for Invader and later generation controllers only. This needs to be disabled for older controllers. Add an adapter type check before setting msix_load_balance flag. Fixes: 1d15d9098ad1 ("scsi: megaraid_sas: Load balance completions across all MSI-X") Signed-off-by: Shivasharan S <shivasharan.srikanteshwara@broadcom.com> Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com>
2019-07-11scsi: megaraid_sas: Fix calculation of target IDShivasharan S
In megasas_get_target_prop(), driver is incorrectly calculating the target ID for devices with channel 1 and 3. Due to this, firmware will either fail the command (if there is no device with the target id sent from driver) or could return the properties for a target which was not intended. Devices could end up with the wrong queue depth due to this. Fix target id calculation for channel 1 and 3. Fixes: 96188a89cc6d ("scsi: megaraid_sas: NVME interface target prop added") Cc: stable@vger.kernel.org Signed-off-by: Shivasharan S <shivasharan.srikanteshwara@broadcom.com> Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com>
2019-07-11scsi: lpfc: reduce stack size with CONFIG_GCC_PLUGIN_STRUCTLEAK_VERBOSEArnd Bergmann
The lpfc_debug_dump_all_queues() function repeatedly calls into lpfc_debug_dump_qe() which has a temporary 128 byte buffer. This was fine before the introduction of CONFIG_GCC_PLUGIN_STRUCTLEAK_VERBOSE because each instance could occupy the same stack slot. However, now they each get their own copy, which leads to a huge increase in stack usage as seen from the compiler warning: drivers/scsi/lpfc/lpfc_debugfs.c: In function 'lpfc_debug_dump_all_queues': drivers/scsi/lpfc/lpfc_debugfs.c:6474:1: error: the frame size of 1712 bytes is larger than 100 bytes [-Werror=frame-larger-than=] Avoid this by not marking lpfc_debug_dump_qe() as inline so the compiler can choose to emit a static version of this function when it's needed or otherwise silently drop it. As an added benefit, not inlining multiple copies of this function means we save several kilobytes of .text section, reducing the file size from 47kb to 43. It is somewhat unusual to have a function that is static but not inline in a header file, but this does not cause problems here because it is only used by other inline functions. It would however seem reasonable to move all the lpfc_debug_dump_* functions into lpfc_debugfs.c and not mark them inline as a later cleanup. Fixes: 81a56f6dcd20 ("gcc-plugins: structleak: Generalize to all variable types") Signed-off-by: Arnd Bergmann <arnd@arndb.de> Acked-by: James Smart <james.smart@broadcom.com> Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com>
2019-07-11scsi: devinfo: BLIST_TRY_VPD_PAGES for SanDisk Cruzer BladeMarcos Paulo de Souza
Currently, all USB devices skip VPD pages, even when the device supports them (SPC-3 and later), but some of them support VPD, like Cruzer Blade. Signed-off-by: Marcos Paulo de Souza <marcos.souza.org@gmail.com> Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com>
2019-07-11scsi: pm80xx: Fixed kernel panic during error recovery for SATA driveDeepak Ukey
Disabling the SATA drive interface cause kernel panic. When the drive Interface is disabled, device should be deregistered after aborting all pending I/Os. Also changed the port recovery timeout to 10000 ms for PM8006 controller. Signed-off-by: Deepak Ukey <deepak.ukey@microchip.com> Signed-off-by: Viswas G <Viswas.G@microchip.com> Reviewed-by: Jack Wang <jinpu.wang@cloud.ionos.com> Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com>
2019-07-11scsi: libsas: remove the exporting of sas_wait_ehDenis Efremov
The function sas_wait_eh is declared static and marked EXPORT_SYMBOL, which is at best an odd combination. Because the function is not used outside of the drivers/scsi/libsas/sas_scsi_host.c file it is defined in, this commit removes the EXPORT_SYMBOL() marking. Signed-off-by: Denis Efremov <efremov@linux.com> Reviewed-by: Jason Yan <yanaijie@huawei.com> Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com>
2019-07-11scsi: megaraid_sas: Make some symbols staticYueHaibing
Fix sparse warnings: drivers/scsi/megaraid/megaraid_sas_base.c:271:1: warning: symbol 'megasas_issue_dcmd' was not declared. Should it be static? drivers/scsi/megaraid/megaraid_sas_base.c:2227:6: warning: symbol 'megasas_do_ocr' was not declared. Should it be static? drivers/scsi/megaraid/megaraid_sas_base.c:3194:25: warning: symbol 'megaraid_host_attrs' was not declared. Should it be static? Reported-by: Hulk Robot <hulkci@huawei.com> Signed-off-by: YueHaibing <yuehaibing@huawei.com> Acked-by: Sumit Saxena <sumit.saxena@broadcom.com> Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com>
2019-07-11scsi: core: use scmd_printk() to print which command timed outMaurizio Lombardi
With a possibly faulty disk the following messages may appear in the logs: kernel: sd 0:0:9:0: timing out command, waited 180s kernel: sd 0:0:9:0: timing out command, waited 20s kernel: sd 0:0:9:0: timing out command, waited 20s kernel: sd 0:0:9:0: timing out command, waited 60s kernel: sd 0:0:9:0: timing out command, waited 20s This is not very informative because it's not possible to identify the command that timed out. This patch replaces sdev_printk() with scmd_printk(). Signed-off-by: Maurizio Lombardi <mlombard@redhat.com> Reviewed-by: Ewan D. Milne <emilne@redhat.com> Reviewed-by: Ming Lei <ming.lei@redhat.com> Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com>
2019-07-11Merge tag 'scsi-sg' of git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsiLinus Torvalds
Pull SCSI scatter-gather list updates from James Bottomley: "This topic branch covers a fundamental change in how our sg lists are allocated to make mq more efficient by reducing the size of the preallocated sg list. This necessitates a large number of driver changes because the previous guarantee that if a driver specified SG_ALL as the size of its scatter list, it would get a non-chained list and didn't need to bother with scatterlist iterators is now broken and every driver *must* use scatterlist iterators. This was broken out as a separate topic because we need to convert all the drivers before pulling the trigger and unconverted drivers kept being found, necessitating a rebase" * tag 'scsi-sg' of git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi: (21 commits) scsi: core: don't preallocate small SGL in case of NO_SG_CHAIN scsi: lib/sg_pool.c: clear 'first_chunk' in case of no preallocation scsi: core: avoid preallocating big SGL for data scsi: core: avoid preallocating big SGL for protection information scsi: lib/sg_pool.c: improve APIs for allocating sg pool scsi: esp: use sg helper to iterate over scatterlist scsi: NCR5380: use sg helper to iterate over scatterlist scsi: wd33c93: use sg helper to iterate over scatterlist scsi: ppa: use sg helper to iterate over scatterlist scsi: pcmcia: nsp_cs: use sg helper to iterate over scatterlist scsi: imm: use sg helper to iterate over scatterlist scsi: aha152x: use sg helper to iterate over scatterlist scsi: s390: zfcp_fc: use sg helper to iterate over scatterlist scsi: staging: unisys: visorhba: use sg helper to iterate over scatterlist scsi: usb: image: microtek: use sg helper to iterate over scatterlist scsi: pmcraid: use sg helper to iterate over scatterlist scsi: ipr: use sg helper to iterate over scatterlist scsi: mvumi: use sg helper to iterate over scatterlist scsi: lpfc: use sg helper to iterate over scatterlist scsi: advansys: use sg helper to iterate over scatterlist ...
2019-07-11Merge tag 'scsi-misc' of git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsiLinus Torvalds
Pull SCSI updates from James Bottomley: "This is mostly update of the usual drivers: qla2xxx, hpsa, lpfc, ufs, mpt3sas, ibmvscsi, megaraid_sas, bnx2fc and hisi_sas as well as the removal of the osst driver (I heard from Willem privately that he would like the driver removed because all his test hardware has failed). Plus number of minor changes, spelling fixes and other trivia. The big merge conflict this time around is the SPDX licence tags. Following discussion on linux-next, we believe our version to be more accurate than the one in the tree, so the resolution is to take our version for all the SPDX conflicts" Note on the SPDX license tag conversion conflicts: the SCSI tree had done its own SPDX conversion, which in some cases conflicted with the treewide ones done by Thomas & co. In almost all cases, the conflicts were purely syntactic: the SCSI tree used the old-style SPDX tags ("GPL-2.0" and "GPL-2.0+") while the treewide conversion had used the new-style ones ("GPL-2.0-only" and "GPL-2.0-or-later"). In these cases I picked the new-style one. In a few cases, the SPDX conversion was actually different, though. As explained by James above, and in more detail in a pre-pull-request thread: "The other problem is actually substantive: In the libsas code Luben Tuikov originally specified gpl 2.0 only by dint of stating: * This file is licensed under GPLv2. In all the libsas files, but then muddied the water by quoting GPLv2 verbatim (which includes the or later than language). So for these files Christoph did the conversion to v2 only SPDX tags and Thomas converted to v2 or later tags" So in those cases, where the spdx tag substantially mattered, I took the SCSI tree conversion of it, but then also took the opportunity to turn the old-style "GPL-2.0" into a new-style "GPL-2.0-only" tag. Similarly, when there were whitespace differences or other differences to the comments around the copyright notices, I took the version from the SCSI tree as being the more specific conversion. Finally, in the spdx conversions that had no conflicts (because the treewide ones hadn't been done for those files), I just took the SCSI tree version as-is, even if it was old-style. The old-style conversions are perfectly valid, even if the "-only" and "-or-later" versions are perhaps more descriptive. * tag 'scsi-misc' of git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi: (185 commits) scsi: qla2xxx: move IO flush to the front of NVME rport unregistration scsi: qla2xxx: Fix NVME cmd and LS cmd timeout race condition scsi: qla2xxx: on session delete, return nvme cmd scsi: qla2xxx: Fix kernel crash after disconnecting NVMe devices scsi: megaraid_sas: Update driver version to 07.710.06.00-rc1 scsi: megaraid_sas: Introduce various Aero performance modes scsi: megaraid_sas: Use high IOPS queues based on IO workload scsi: megaraid_sas: Set affinity for high IOPS reply queues scsi: megaraid_sas: Enable coalescing for high IOPS queues scsi: megaraid_sas: Add support for High IOPS queues scsi: megaraid_sas: Add support for MPI toolbox commands scsi: megaraid_sas: Offload Aero RAID5/6 division calculations to driver scsi: megaraid_sas: RAID1 PCI bandwidth limit algorithm is applicable for only Ventura scsi: megaraid_sas: megaraid_sas: Add check for count returned by HOST_DEVICE_LIST DCMD scsi: megaraid_sas: Handle sequence JBOD map failure at driver level scsi: megaraid_sas: Don't send FPIO to RL Bypass queue scsi: megaraid_sas: In probe context, retry IOC INIT once if firmware is in fault scsi: megaraid_sas: Release Mutex lock before OCR in case of DCMD timeout scsi: megaraid_sas: Call disable_irq from process IRQ poll scsi: megaraid_sas: Remove few debug counters from IO path ...
2019-07-11scsi: virtio_scsi: Use struct_size() helperGustavo A. R. Silva
One of the more common cases of allocation size calculations is finding the size of a structure that has a zero-sized array at the end, along with memory for some number of elements for that array. For example: struct virtio_scsi { ... struct virtio_scsi_vq req_vqs[]; }; Make use of the struct_size() helper instead of an open-coded version in order to avoid any potential type mistakes. So, replace the following form: sizeof(*vscsi) + sizeof(vscsi->req_vqs[0]) * num_queues with: struct_size(vscsi, req_vqs, num_queues) This code was detected with the help of Coccinelle. Signed-off-by: Gustavo A. R. Silva <gustavo@embeddedor.com> Signed-off-by: Michael S. Tsirkin <mst@redhat.com> Reviewed-by: Stefan Hajnoczi <stefanha@redhat.com>
2019-07-11Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-nextLinus Torvalds
Pull networking updates from David Miller: "Some highlights from this development cycle: 1) Big refactoring of ipv6 route and neigh handling to support nexthop objects configurable as units from userspace. From David Ahern. 2) Convert explored_states in BPF verifier into a hash table, significantly decreased state held for programs with bpf2bpf calls, from Alexei Starovoitov. 3) Implement bpf_send_signal() helper, from Yonghong Song. 4) Various classifier enhancements to mvpp2 driver, from Maxime Chevallier. 5) Add aRFS support to hns3 driver, from Jian Shen. 6) Fix use after free in inet frags by allocating fqdirs dynamically and reworking how rhashtable dismantle occurs, from Eric Dumazet. 7) Add act_ctinfo packet classifier action, from Kevin Darbyshire-Bryant. 8) Add TFO key backup infrastructure, from Jason Baron. 9) Remove several old and unused ISDN drivers, from Arnd Bergmann. 10) Add devlink notifications for flash update status to mlxsw driver, from Jiri Pirko. 11) Lots of kTLS offload infrastructure fixes, from Jakub Kicinski. 12) Add support for mv88e6250 DSA chips, from Rasmus Villemoes. 13) Various enhancements to ipv6 flow label handling, from Eric Dumazet and Willem de Bruijn. 14) Support TLS offload in nfp driver, from Jakub Kicinski, Dirk van der Merwe, and others. 15) Various improvements to axienet driver including converting it to phylink, from Robert Hancock. 16) Add PTP support to sja1105 DSA driver, from Vladimir Oltean. 17) Add mqprio qdisc offload support to dpaa2-eth, from Ioana Radulescu. 18) Add devlink health reporting to mlx5, from Moshe Shemesh. 19) Convert stmmac over to phylink, from Jose Abreu. 20) Add PTP PHC (Physical Hardware Clock) support to mlxsw, from Shalom Toledo. 21) Add nftables SYNPROXY support, from Fernando Fernandez Mancera. 22) Convert tcp_fastopen over to use SipHash, from Ard Biesheuvel. 23) Track spill/fill of constants in BPF verifier, from Alexei Starovoitov. 24) Support bounded loops in BPF, from Alexei Starovoitov. 25) Various page_pool API fixes and improvements, from Jesper Dangaard Brouer. 26) Just like ipv4, support ref-countless ipv6 route handling. From Wei Wang. 27) Support VLAN offloading in aquantia driver, from Igor Russkikh. 28) Add AF_XDP zero-copy support to mlx5, from Maxim Mikityanskiy. 29) Add flower GRE encap/decap support to nfp driver, from Pieter Jansen van Vuuren. 30) Protect against stack overflow when using act_mirred, from John Hurley. 31) Allow devmap map lookups from eBPF, from Toke Høiland-Jørgensen. 32) Use page_pool API in netsec driver, Ilias Apalodimas. 33) Add Google gve network driver, from Catherine Sullivan. 34) More indirect call avoidance, from Paolo Abeni. 35) Add kTLS TX HW offload support to mlx5, from Tariq Toukan. 36) Add XDP_REDIRECT support to bnxt_en, from Andy Gospodarek. 37) Add MPLS manipulation actions to TC, from John Hurley. 38) Add sending a packet to connection tracking from TC actions, and then allow flower classifier matching on conntrack state. From Paul Blakey. 39) Netfilter hw offload support, from Pablo Neira Ayuso" * git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next: (2080 commits) net/mlx5e: Return in default case statement in tx_post_resync_params mlx5: Return -EINVAL when WARN_ON_ONCE triggers in mlx5e_tls_resync(). net: dsa: add support for BRIDGE_MROUTER attribute pkt_sched: Include const.h net: netsec: remove static declaration for netsec_set_tx_de() net: netsec: remove superfluous if statement netfilter: nf_tables: add hardware offload support net: flow_offload: rename tc_cls_flower_offload to flow_cls_offload net: flow_offload: add flow_block_cb_is_busy() and use it net: sched: remove tcf block API drivers: net: use flow block API net: sched: use flow block API net: flow_offload: add flow_block_cb_{priv, incref, decref}() net: flow_offload: add list handling functions net: flow_offload: add flow_block_cb_alloc() and flow_block_cb_free() net: flow_offload: rename TCF_BLOCK_BINDER_TYPE_* to FLOW_BLOCK_BINDER_TYPE_* net: flow_offload: rename TC_BLOCK_{UN}BIND to FLOW_BLOCK_{UN}BIND net: flow_offload: add flow_block_cb_setup_simple() net: hisilicon: Add an tx_desc to adapt HI13X1_GMAC net: hisilicon: Add an rx_desc to adapt HI13X1_GMAC ...
2019-07-09Merge tag 'docs-5.3' of git://git.lwn.net/linuxLinus Torvalds
Pull Documentation updates from Jonathan Corbet: "It's been a relatively busy cycle for docs: - A fair pile of RST conversions, many from Mauro. These create more than the usual number of simple but annoying merge conflicts with other trees, unfortunately. He has a lot more of these waiting on the wings that, I think, will go to you directly later on. - A new document on how to use merges and rebases in kernel repos, and one on Spectre vulnerabilities. - Various improvements to the build system, including automatic markup of function() references because some people, for reasons I will never understand, were of the opinion that :c:func:``function()`` is unattractive and not fun to type. - We now recommend using sphinx 1.7, but still support back to 1.4. - Lots of smaller improvements, warning fixes, typo fixes, etc" * tag 'docs-5.3' of git://git.lwn.net/linux: (129 commits) docs: automarkup.py: ignore exceptions when seeking for xrefs docs: Move binderfs to admin-guide Disable Sphinx SmartyPants in HTML output doc: RCU callback locks need only _bh, not necessarily _irq docs: format kernel-parameters -- as code Doc : doc-guide : Fix a typo platform: x86: get rid of a non-existent document Add the RCU docs to the core-api manual Documentation: RCU: Add TOC tree hooks Documentation: RCU: Rename txt files to rst Documentation: RCU: Convert RCU UP systems to reST Documentation: RCU: Convert RCU linked list to reST Documentation: RCU: Convert RCU basic concepts to reST docs: filesystems: Remove uneeded .rst extension on toctables scripts/sphinx-pre-install: fix out-of-tree build docs: zh_CN: submitting-drivers.rst: Remove a duplicated Documentation/ Documentation: PGP: update for newer HW devices Documentation: Add section about CPU vulnerabilities for Spectre Documentation: platform: Delete x86-laptop-drivers.txt docs: Note that :c:func: should no longer be used ...
2019-07-09Merge tag 'for-5.3/block-20190708' of git://git.kernel.dk/linux-blockLinus Torvalds
Pull block updates from Jens Axboe: "This is the main block updates for 5.3. Nothing earth shattering or major in here, just fixes, additions, and improvements all over the map. This contains: - Series of documentation fixes (Bart) - Optimization of the blk-mq ctx get/put (Bart) - null_blk removal race condition fix (Bob) - req/bio_op() cleanups (Chaitanya) - Series cleaning up the segment accounting, and request/bio mapping (Christoph) - Series cleaning up the page getting/putting for bios (Christoph) - block cgroup cleanups and moving it to where it is used (Christoph) - block cgroup fixes (Tejun) - Series of fixes and improvements to bcache, most notably a write deadlock fix (Coly) - blk-iolatency STS_AGAIN and accounting fixes (Dennis) - Series of improvements and fixes to BFQ (Douglas, Paolo) - debugfs_create() return value check removal for drbd (Greg) - Use struct_size(), where appropriate (Gustavo) - Two lighnvm fixes (Heiner, Geert) - MD fixes, including a read balance and corruption fix (Guoqing, Marcos, Xiao, Yufen) - block opal shadow mbr additions (Jonas, Revanth) - sbitmap compare-and-exhange improvemnts (Pavel) - Fix for potential bio->bi_size overflow (Ming) - NVMe pull requests: - improved PCIe suspent support (Keith Busch) - error injection support for the admin queue (Akinobu Mita) - Fibre Channel discovery improvements (James Smart) - tracing improvements including nvmetc tracing support (Minwoo Im) - misc fixes and cleanups (Anton Eidelman, Minwoo Im, Chaitanya Kulkarni)" - Various little fixes and improvements to drivers and core" * tag 'for-5.3/block-20190708' of git://git.kernel.dk/linux-block: (153 commits) blk-iolatency: fix STS_AGAIN handling block: nr_phys_segments needs to be zero for REQ_OP_WRITE_ZEROES blk-mq: simplify blk_mq_make_request() blk-mq: remove blk_mq_put_ctx() sbitmap: Replace cmpxchg with xchg block: fix .bi_size overflow block: sed-opal: check size of shadow mbr block: sed-opal: ioctl for writing to shadow mbr block: sed-opal: add ioctl for done-mark of shadow mbr block: never take page references for ITER_BVEC direct-io: use bio_release_pages in dio_bio_complete block_dev: use bio_release_pages in bio_unmap_user block_dev: use bio_release_pages in blkdev_bio_end_io iomap: use bio_release_pages in iomap_dio_bio_end_io block: use bio_release_pages in bio_map_user_iov block: use bio_release_pages in bio_unmap_user block: optionally mark pages dirty in bio_release_pages block: move the BIO_NO_PAGE_REF check into bio_release_pages block: skd_main.c: Remove call to memset after dma_alloc_coherent block: mtip32xx: Remove call to memset after dma_alloc_coherent ...
2019-07-01Merge tag 'v5.2-rc6' into for-5.3/blockJens Axboe
Merge 5.2-rc6 into for-5.3/block, so we get the same page merge leak fix. Otherwise we end up having conflicts with future patches between for-5.3/block and master that touch this area. In particular, it makes the bio_full() fix hard to backport to stable. * tag 'v5.2-rc6': (482 commits) Linux 5.2-rc6 Revert "iommu/vt-d: Fix lock inversion between iommu->lock and device_domain_lock" Bluetooth: Fix regression with minimum encryption key size alignment tcp: refine memory limit test in tcp_fragment() x86/vdso: Prevent segfaults due to hoisted vclock reads SUNRPC: Fix a credential refcount leak Revert "SUNRPC: Declare RPC timers as TIMER_DEFERRABLE" net :sunrpc :clnt :Fix xps refcount imbalance on the error path NFS4: Only set creation opendata if O_CREAT ARM: 8867/1: vdso: pass --be8 to linker if necessary KVM: nVMX: reorganize initial steps of vmx_set_nested_state KVM: PPC: Book3S HV: Invalidate ERAT when flushing guest TLB entries habanalabs: use u64_to_user_ptr() for reading user pointers nfsd: replace Jeff by Chuck as nfsd co-maintainer inet: clear num_timeout reqsk_alloc() PCI/P2PDMA: Ignore root complex whitelist when an IOMMU is present net: mvpp2: debugfs: Add pmap to fs dump ipv6: Default fib6_type to RTN_UNICAST when not set net: hns3: Fix inconsistent indenting net/af_iucv: always register net_device notifier ...
2019-06-29Merge tag 'scsi-fixes' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi Pull SCSI fix from James Bottomley: "One simple fix for a driver use after free" * tag 'scsi-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi: scsi: vmw_pscsi: Fix use-after-free in pvscsi_queue_lck()
2019-06-27Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netDavid S. Miller
The new route handling in ip_mc_finish_output() from 'net' overlapped with the new support for returning congestion notifications from BPF programs. In order to handle this I had to take the dev_loopback_xmit() calls out of the switch statement. The aquantia driver conflicts were simple overlapping changes. Signed-off-by: David S. Miller <davem@davemloft.net>
2019-06-27Merge branch '5.3/scsi-sg' into scsi-nextMartin K. Petersen
2019-06-27scsi: qla2xxx: move IO flush to the front of NVME rport unregistrationQuinn Tran
On session deletion, current qla code would unregister an NVMe session before flushing IOs. This patch would move the unregistration of NVMe session after IO flush. This way FC-NVMe layer would not have to wait for stuck IOs. In addition, qla2xxx would stop accepting new IOs during session deletion. Signed-off-by: Quinn Tran <qutran@marvell.com> Signed-off-by: Himanshu Madhani <hmadhani@marvell.com> Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com>
2019-06-27scsi: qla2xxx: Fix NVME cmd and LS cmd timeout race conditionQuinn Tran
This patch uses kref to protect access between fcp_abort path and nvme command and LS command completion path. Stack trace below shows the abort path is accessing stale memory (nvme_private->sp). When command kref reaches 0, nvme_private & srb resource will be disconnected from each other. Any subsequence nvme abort request will not be able to reference the original srb. [ 5631.003998] BUG: unable to handle kernel paging request at 00000010000005d8 [ 5631.004016] IP: [<ffffffffc087df92>] qla_nvme_abort_work+0x22/0x100 [qla2xxx] [ 5631.004086] Workqueue: events qla_nvme_abort_work [qla2xxx] [ 5631.004097] RIP: 0010:[<ffffffffc087df92>] [<ffffffffc087df92>] qla_nvme_abort_work+0x22/0x100 [qla2xxx] [ 5631.004109] Call Trace: [ 5631.004115] [<ffffffffaa4b8174>] ? pwq_dec_nr_in_flight+0x64/0xb0 [ 5631.004117] [<ffffffffaa4b9d4f>] process_one_work+0x17f/0x440 [ 5631.004120] [<ffffffffaa4bade6>] worker_thread+0x126/0x3c0 Signed-off-by: Quinn Tran <qutran@marvell.com> Signed-off-by: Himanshu Madhani <hmadhani@marvell.com> Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com>
2019-06-27scsi: qla2xxx: on session delete, return nvme cmdQuinn Tran
- on session delete or chip reset, reject all NVME commands. - on NVME command submission error, free srb resource. Signed-off-by: Quinn Tran <qutran@marvell.com> Signed-off-by: Himanshu Madhani <hmadhani@marvell.com> Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com>
2019-06-27scsi: qla2xxx: Fix kernel crash after disconnecting NVMe devicesArun Easi
BUG: unable to handle kernel NULL pointer dereference at (null) IP: [<ffffffffc050d10c>] qla_nvme_unregister_remote_port+0x6c/0xf0 [qla2xxx] PGD 800000084cf41067 PUD 84d288067 PMD 0 Oops: 0000 [#1] SMP Call Trace: [<ffffffff98abcfdf>] process_one_work+0x17f/0x440 [<ffffffff98abdca6>] worker_thread+0x126/0x3c0 [<ffffffff98abdb80>] ? manage_workers.isra.26+0x2a0/0x2a0 [<ffffffff98ac4f81>] kthread+0xd1/0xe0 [<ffffffff98ac4eb0>] ? insert_kthread_work+0x40/0x40 [<ffffffff9918ad37>] ret_from_fork_nospec_begin+0x21/0x21 [<ffffffff98ac4eb0>] ? insert_kthread_work+0x40/0x40 RIP [<ffffffffc050d10c>] qla_nvme_unregister_remote_port+0x6c/0xf0 [qla2xxx] The crash is due to a bad entry in the nvme_rport_list. This list is not protected, and when a remoteport_delete callback is called, driver traverses the list and crashes. Actually, the list could be removed and driver could traverse the main fcport list instead. Fix does exactly that. Signed-off-by: Arun Easi <aeasi@marvell.com> Signed-off-by: Himanshu Madhani <hmadhani@redhat.com> Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com>
2019-06-27scsi: megaraid_sas: Update driver version to 07.710.06.00-rc1Chandrakanth Patil
Signed-off-by: Chandrakanth Patil <chandrakanth.patil@broadcom.com> Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com>
2019-06-27scsi: megaraid_sas: Introduce various Aero performance modesChandrakanth Patil
For Aero adapters, driver provides three different performance modes controlled through module parameter named 'perf_mode'. Below are those performance modes: 0: Balanced - Additional high IOPS reply queues will be enabled along with low latency queues. Interrupt coalescing will be enabled only for these high IOPS reply queues. 1: IOPS - No additional high IOPS queues are enabled. Interrupt coalescing will be enabled on all reply queues. 2: Latency - No additional high IOPS queues are enabled. Interrupt coalescing will be disabled on all reply queues. This is a legacy behavior similar to Ventura & Invader Series. Default performance mode settings: - Performance mode set to 'Balanced', if Aero controller is working in 16GT/s PCIe speed. - Performance mode will be set to 'Latency' mode for all other cases. Through module parameter 'perf_mode', user can override default performance mode to desired one. Captured some performance numbers with these performance modes. 4k Random Read IO performance numbers on 24 SAS SSD drives for above three performance modes. Performance data is from Intel Skylake and HGST SS300 (drive model SDLL1DLR400GCCA1). IOPS: ----------------------------------------------------------------------- |perf_mode | qd = 1 | qd = 64 | note | |-------------|--------|---------|------------------------------------- |balanced | 259K | 3061k | Provides max performance numbers | | | | | both on lower QD workload & | | | | | also on higher QD workload | |-------------|--------|---------|------------------------------------- |iops | 220K | 3100k | Provides max performance numbers | | | | | only on higher QD workload. | |-------------|--------|---------|------------------------------------- |latency | 246k | 2226k | Provides good performance numbers | | | | | only on lower QD worklaod. | ----------------------------------------------------------------------- Average Latency: ----------------------------------------------------- |perf_mode | qd = 1 | qd = 64 | |-------------|--------------|----------------------| |balanced | 92.05 usec | 501.12 usec | |-------------|--------------|----------------------| |iops | 108.40 usec | 498.10 usec | |-------------|--------------|----------------------| |latency | 97.10 usec | 689.26 usec | ----------------------------------------------------- Signed-off-by: Sumit Saxena <sumit.saxena@broadcom.com> Signed-off-by: Chandrakanth Patil <chandrakanth.patil@broadcom.com> Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com>
2019-06-27scsi: megaraid_sas: Use high IOPS queues based on IO workloadChandrakanth Patil
The driver will use round-robin method for IO submission in batches within the high IOPS queues when the number of in-flight ios on the target device is larger than 8. Otherwise the driver will use low latency reply queues. Signed-off-by: Kashyap Desai <kashyap.desai@broadcom.com> Signed-off-by: Chandrakanth Patil <chandrakanth.patil@broadcom.com> Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com>
2019-06-27scsi: megaraid_sas: Set affinity for high IOPS reply queuesChandrakanth Patil
High iops queues are mapped to non-managed IRQs. Set affinity of non-managed irqs to local numa node. Low latency queues are mapped to managed IRQs. Driver reserves some reply queues for high IOPS queues (through pci_alloc_irq_vectors_affinity and .pre_vectors interface). The rest of queues are for low latency. Based on IO workload, driver will decide which group of reply queues (either high IOPS queues or low latency queues) to be used. High IOPS queues will be mapped to local numa node of controller and low latency queues will be mapped to CPUs across numa nodes. In general, high IOPS and low latency queues should fit into 128 reply queues which is the max number of reply queues supported by Aero adapters. Signed-off-by: Kashyap Desai <kashyap.desai@broadcom.com> Signed-off-by: Chandrakanth Patil <chandrakanth.patil@broadcom.com> Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com>
2019-06-27scsi: megaraid_sas: Enable coalescing for high IOPS queuesChandrakanth Patil
Driver should enable interrupt coalescing (during driver load and after Controller Reset) for High IOPS queues by masking appropriate bits in IOC INIT frame. Signed-off-by: Kashyap Desai <kashyap.desai@broadcom.com> Signed-off-by: Chandrakanth Patil <chandrakanth.patil@broadcom.com> Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com>
2019-06-27scsi: megaraid_sas: Add support for High IOPS queuesChandrakanth Patil
Aero controllers support balanced performance mode through the ability to configure queues with different properties. Reply queues with interrupt coalescing enabled are called "high iops reply queues" and reply queues with interrupt coalescing disabled are called "low latency reply queues". The driver configures a combination of high iops and low latency reply queues if: - HBA is an AERO controller; - MSI-X vectors supported by the HBA is 128; - Total CPU count in the system more than high iops queue count; - Driver is loaded with default max_msix_vectors module parameter; and - System booted in non-kdump mode. Signed-off-by: Kashyap Desai <kashyap.desai@broadcom.com> Signed-off-by: Chandrakanth Patil <chandrakanth.patil@broadcom.com> Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com>
