path: root/drivers/scsi/sun3_scsi.h
2014-11-20sun3_scsi: Move macro definitionsFinn Thain
The #defines in sun3_scsi.h are intended to influence subsequent #includes in sun3_scsi.c. IMHO, that's too convoluted. Move sun3_scsi.h macro definitions to sun3_scsi.c, consistent with other NCR5380 drivers. Omit the unused NCR5380_local_declare() and NCR5380_setup() macros. Signed-off-by: Finn Thain <fthain@telegraphics.com.au> Reviewed-by: Hannes Reinecke <hare@suse.de> Signed-off-by: Christoph Hellwig <hch@lst.de>
2014-11-20sun3_scsi: Convert to platform deviceFinn Thain
Convert sun3_scsi to platform device and eliminate scsi_register(). Signed-off-by: Finn Thain <fthain@telegraphics.com.au> Reviewed-by: Hannes Reinecke <hare@suse.de> Acked-by: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: Christoph Hellwig <hch@lst.de>
2014-11-20ncr5380: Remove *_RELEASE macrosFinn Thain
The *_RELEASE macros don't tell me anything. In some cases the version in the macro contradicts the version in the comments. Anyway, the Linux kernel version is sufficient information. Remove these macros to improve readability. Signed-off-by: Finn Thain <fthain@telegraphics.com.au> Reviewed-by: Hannes Reinecke <hare@suse.de> Tested-by: Michael Schmitz <schmitzmic@gmail.com> Signed-off-by: Christoph Hellwig <hch@lst.de>
2014-11-20ncr5380: Remove pointless compiler command line override macrosFinn Thain
Compile-time override of scsi host defaults is pointless for drivers that provide module parameters and __setup options for that. Too many macros make the code hard to read so remove them. Signed-off-by: Finn Thain <fthain@telegraphics.com.au> Reviewed-by: Hannes Reinecke <hare@suse.de> Tested-by: Michael Schmitz <schmitzmic@gmail.com> Signed-off-by: Christoph Hellwig <hch@lst.de>
2014-11-20ncr5380: Cleanup host info() methodsFinn Thain
If the host->info() method is not set, then host->name is used by default. For atari_scsi, that is exactly the same text. So remove the redundant info() method. Keep sun3_scsi.c in line with atari_scsi. Some NCR5380 drivers return an empty string from the info() method (arm/cumana_1.c arm/oak.c mac_scsi.c) while other drivers use the default (dmx3191d dtc.c g_NCR5380.c pas16.c t128.c). Implement a common info() method to replace a lot of duplicated code which the various drivers use to announce the same information. This replaces most of the (deprecated) show_info() output and all of the NCR5380_print_info() output. This also eliminates a bunch of code in g_NCR5380 which just duplicates functionality in the core driver. Signed-off-by: Finn Thain <fthain@telegraphics.com.au> Reviewed-by: Hannes Reinecke <hare@suse.de> Tested-by: Michael Schmitz <schmitzmic@gmail.com> Signed-off-by: Christoph Hellwig <hch@lst.de>
2014-11-20ncr5380: Remove duplicate commentsFinn Thain
The LIMIT_TRANSFERSIZE, PSEUDO_DMA, PARITY and UNSAFE options are all documented in the core drivers where they are used. The same goes for the chip databook reference. Remove the duplicate comments. Signed-off-by: Finn Thain <fthain@telegraphics.com.au> Reviewed-by: Hannes Reinecke <hare@suse.de> Signed-off-by: Christoph Hellwig <hch@lst.de>
2014-11-20ncr5380: Remove useless prototypesFinn Thain
Add missing static qualifiers and remove the now pointless prototypes. The NCR5380_* prototypes are all declared in NCR5380.h and renamed using macros. Further declarations are redundant (some are completely unused). Remove them. Signed-off-by: Finn Thain <fthain@telegraphics.com.au> Reviewed-by: Hannes Reinecke <hare@suse.de> Tested-by: Michael Schmitz <schmitzmic@gmail.com> Signed-off-by: Christoph Hellwig <hch@lst.de>
2014-11-20ncr5380: Remove unused macrosFinn Thain
Some macros are never evaluated (i.e. FOO, USLEEP, SCSI2 and USE_WRAPPER; and in some drivers, NCR5380_intr and NCR5380_proc_info). DRIVER_SETUP serves no purpose anymore. Remove these macro definitions. Signed-off-by: Finn Thain <fthain@telegraphics.com.au> Reviewed-by: Hannes Reinecke <hare@suse.de> Tested-by: Michael Schmitz <schmitzmic@gmail.com> Signed-off-by: Christoph Hellwig <hch@lst.de>
2014-11-20ncr5380: Remove unused hostdata fieldsFinn Thain
Remove unused fields from hostdata structs declared with the NCR5380_implementation_fields macro. Signed-off-by: Finn Thain <fthain@telegraphics.com.au> Reviewed-by: Hannes Reinecke <hare@suse.de> Signed-off-by: Christoph Hellwig <hch@lst.de>
2014-05-28scsi/NCR5380: reduce depth of sun3_scsi nested includesFinn Thain
Move the #include "NCR5380.h" out of the sun3_scsi.h header file and into the driver .c files, like all the other NCR5380 drivers in the tree. This improves uniformity and reduces the depth of nested includes. The sequence of #include's, #define's and #if's no longer does my head in. Signed-off-by: Finn Thain <fthain@telegraphics.com.au> Acked-by: Sam Creasey <sammy@sammy.net> Signed-off-by: Christoph Hellwig <hch@lst.de>
2014-05-28scsi/NCR5380: remove unused macro definitionsFinn Thain
Remove the unused (and divergent) debugging macro definitions from the sun3_NCR5380 and atari_NCR5380 drivers. These drivers have been converted to use the common macros in NCR5380.h. Signed-off-by: Finn Thain <fthain@telegraphics.com.au> Acked-by: Sam Creasey <sammy@sammy.net> Acked-by: Michael Schmitz <schmitz@debian.org> Signed-off-by: Christoph Hellwig <hch@lst.de>
2014-05-28scsi/NCR5380: remove old CVS keywordsFinn Thain
2014-05-28scsi/NCR5380: remove redundant HOSTS_C macro testsFinn Thain
HOSTS_C is always undefined. There is no hosts.c anymore. Signed-off-by: Finn Thain <fthain@telegraphics.com.au> Acked-by: Sam Creasey <sammy@sammy.net> Signed-off-by: Christoph Hellwig <hch@lst.de>
2014-05-28scsi/NCR5380: remove unused BOARD_NORMAL and BOARD_NCR53C400Finn Thain
BOARD_NORMAL is completely unused and BOARD_NCR53C400 is used only by g_NCR5380 internally. Remove the unused definitions. Signed-off-by: Finn Thain <fthain@telegraphics.com.au> Acked-by: Sam Creasey <sammy@sammy.net> Signed-off-by: Christoph Hellwig <hch@lst.de>
2013-05-04sun3_scsi: add ->show_info()Geert Uytterhoeven
Based on Al's changes to atari_scsi. Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2010-11-16SCSI host lock push-downJeff Garzik
Move the mid-layer's ->queuecommand() invocation from being locked with the host lock to being unlocked to facilitate speeding up the critical path for drivers who don't need this lock taken anyway. The patch below presents a simple SCSI host lock push-down as an equivalent transformation. No locking or other behavior should change with this patch. All existing bugs and locking orders are preserved. Additionally, add one parameter to queuecommand, struct Scsi_Host * and remove one parameter from queuecommand, void (*done)(struct scsi_cmnd *) Scsi_Host* is a convenient pointer that most host drivers need anyway, and 'done' is redundant to struct scsi_cmnd->scsi_done. Minimal code disturbance was attempted with this change. Most drivers needed only two one-line modifications for their host lock push-down. Signed-off-by: Jeff Garzik <jgarzik@redhat.com> Acked-by: James Bottomley <James.Bottomley@suse.de> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-12-09[PATCH] Sun3 SCSI: Make sun3 scsi drivers compile/work againSam Creasey
Make sun3 scsi drivers compile/work again (though with way too many warnings...) Tested on 3/50, 3/60. Signed-off-by: Sam Creasey <sammy@sammy.net> Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-25[SCSI] Scsi_Cmnd convertion in sun3-driverHenne
Change the obsolete Scsi_Cmnd to struct scsi_cmnd in the sun3-driver. Signed-off-by: Henrik Kretzschmar <henne@nachtwindheim.de> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2005-11-09[SCSI] remove Scsi_Host_Template typedefChristoph Hellwig
