path: root/drivers/scsi/st.c
2006-07-09[SCSI] st.c: Improve sense outputLuben Tuikov
Convert this: st0: Error with sense data: <6>st: Current: sense key: Illegal Request Additional sense: Invalid field in cdb To this: st0: Current: sense key: Illegal Request Additional sense: Invalid field in cdb Signed-off-by: Luben Tuikov <ltuikov@yahoo.com> Acked-by: Kai Makisara <kai.makisara@kolumbus.fi> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2006-06-29[SCSI] st: remove unused st_buffer.in_useMartin Habets
I noticed that in_use in st_buffer is not used. The patch below against 2.6.17-rc3 removes it, assuming there is no future use for it. It was tested in a sparc SS20 with a DLT4000. Signed-off-by: Martin Habets <errandir_news@mph.eclipse.co.uk> Acked-by: Kai Mäkisara <kai.makisara@kolumbus.fi> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2006-06-26spelling fixesAndreas Mohr
acquired (aquired) contiguous (contigious) successful (succesful, succesfull) surprise (suprise) whether (weather) some other misspellings Signed-off-by: Andreas Mohr <andi@lisas.de> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-06-23[PATCH] vfs: add lock owner argument to flush operationMiklos Szeredi
Pass the POSIX lock owner ID to the flush operation. This is useful for filesystems which don't want to store any locking state in inode->i_flock but want to handle locking/unlocking POSIX locks internally. FUSE is one such filesystem but I think it possible that some network filesystems would need this also. Also add a flag to indicate that a POSIX locking request was generated by close(), so filesystems using the above feature won't send an extra locking request in this case. Signed-off-by: Miklos Szeredi <miklos@szeredi.hu> Cc: Trond Myklebust <trond.myklebust@fys.uio.no> Cc: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-10Merge ../linux-2.6James Bottomley
2006-06-10[SCSI] drivers/scsi: Use ARRAY_SIZE macroTobias Klauser
Use ARRAY_SIZE macro instead of sizeof(x)/sizeof(x[0]) and remove duplicates of the macro. Signed-off-by: Tobias Klauser <tklauser@nuerscht.ch> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2006-05-21[PATCH] missing newline in scsi/st.cRene Herman
st: Version 20050830, fixed bufsize 32768, s/g segs 256 st 0:0:6:0: Attached scsi tape st0<4>st0: try direct i/o: yes (alignment 512 B) Cc: James Bottomley <James.Bottomley@steeleye.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-12[SCSI] MODULE_ALIAS_{BLOCK,CHAR}DEV_MAJOR for drivers/scsiRene Herman
Add device-major aliases in drivers/scsi, allowing kmod autoload: MODULE_ALIAS_CHARDEV_MAJOR(SCSI_CHANGER_MAJOR) MODULE_ALIAS_CHARDEV_MAJOR(OSST_MAJOR) MODULE_ALIAS_CHARDEV_MAJOR(SCSI_TAPE_MAJOR) MODULE_ALIAS_BLOCKDEV_MAJOR(SCSI_CDROM_MAJOR) MODULE_ALIAS_BLOCKDEV_MAJOR(SCSI_DISKN_MAJOR) Signed-off-by: Andrew Morton <akpm@osdl.org> Acked-by: Kai Makisara <kai.makisara@kolumbus.fi> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2006-02-27[SCSI] Remove devfs support from the SCSI subsystemGreg KH
As devfs has been disabled from the kernel tree for a number of months now (5 to be exact), here's a patch against 2.6.16-rc1-git1 that removes support for it from the SCSI subsystem. The patch also removes the scsi_disk devfs_name field as it's no longer needed. Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2006-02-27[SCSI] SCSI core kmalloc2kzallocJes Sorensen
Change the core SCSI code to use kzalloc rather than kmalloc+memset where possible. Signed-off-by: Jes Sorensen <jes@sgi.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2006-01-26[SCSI] Prevent scsi_execute_async from guessing cdb lengthbrking@us.ibm.com
When the scsi_execute_async interface was added it ended up reducing the flexibility of userspace to send arbitrary scsi commands through sg using SG_IO. The SG_IO interface allows userspace to specify the CDB length. This is now ignored in scsi_execute_async and it is guessed using the COMMAND_SIZE macro, which is not always correct, particularly for vendor specific commands. This patch adds a cmd_len parameter to the scsi_execute_async interface to allow the caller to specify the length of the CDB. Signed-off-by: Brian King <brking@us.ibm.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2006-01-14[SCSI] always handle REQ_BLOCK_PC requests in common codeChristoph Hellwig
LLDDs should never see REQ_BLOCK_PC requests, we can handle them just fine in the core code. There is a small behaviour change in that some check in sr's rw_intr are bypassed, but I consider the old behaviour a bug. Mike found this cleanup opportunity and provdided early patches, so all the credit goes to him, even if I redid the patches from scratch beause that was easier than forward-porting the old patches. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2006-01-12[SCSI] turn most scsi semaphores into mutexesArjan van de Ven
the scsi layer is using semaphores in a mutex way, this patch converts these into using mutexes instead Signed-off-by: Arjan van de Ven <arjan@infradead.org> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2005-12-15Fix up SCSI mismergeJames Bottomley
I forgot to do a git-update-cache on the merged files ...
2005-12-15Merge by hand (conflicts in scsi_lib.c)James Bottomley
This merge is pretty extensive. The conflict is over the new req->retries parameter, so I had to change the prototype to scsi_setup_blk_pc_cmnd() and the usage in sd, sr and st. Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2005-12-15[SCSI] Fix st oops with new scsi_execute infrastructureKai Makisara
Patch from Kai minus last sg_segs clearing which was merged already. > > Was there a oops or lockup or any debug output you can send me? I will try > > some more large request tests with scsi_debug. You also have to compile your > > kernel with SCSI_MAX_PHYS_SEGMENTS == 255 to get larger requests now. > It was an oops in sgl_unmap_user_pages(). The reason is this: /* XXX: just for debug. Remove when PageReserved is removed */ BUG_ON(PageReserved(page)); I was using /dev/zero as input and it triggers this. When I used a file as input, this did not trigger. Should this BUG_ON be removed? In the same log I noticed that there was another ->sg_segs inconsistency. Also, the field ->last_SRpnt was not reset when scsi_execute_async() failed. This caused the error message "Async command already active" later and prevented proper close. While doing the changes, I noticed that the current code (since 2.6.0-test4) does not set the pages dirty when reading with direct i/o. All of these st problems (including the one I sent earlier) are fixed in the patch at the end of this message. These fixes should probably be included already in 2.6.15. After these fixes, the tape seems to operate as expected. Without other changes, the largest block size with sym53c896 SCSI adapter is 384 kB. The maximum number of sg segments is set to 96 and clustering is disabled in the driver. 96 x 4 kB = 384 kB. OK. I enabled clustering and set max_sectors to 10000 in the SCSI HBA driver. Now the block size limit is 5000 kB as expected. Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2005-12-14[SCSI] convert st to use scsi_execute_asyncMike Christie
convert st to always send scatterlists and kill scsi_request usage. This is the same as last time as it was posted, but with Kai's patches merged and we now pass the bytes value to scsi_execute_async. TODO: - move DIO code to common place or make block layers usable for ULDs. - move buffer allocation code to common place for all ULDs to use. And make buffer allocation code handle all queue limits so we can find out about problems before calling scsi_execute_async. - move indirect (copy_to/from_user) paths commone place or make block layers usable for ULDs. Signed-off-by: Mike Christie <michaelc@cs.wisc.edu> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2005-12-14[SCSI] complete the whole command when it is REQ_BLOCK_PCMike Christie
sd does not allow scsi_io_completion to retry commands for SG_IO requests, and it make sense that it should not happen for st SG_IO commands too. If for st we hit the bottom of scsi_io_completion we will probably screw things up pretty bad. This patch returns to the block layer that the whole command completed and relies on the caller to check the request errors field. For initialization commands like in sd, this adds the previous behavior where scsi_io_completion did not process the error. Signed-off-by: Mike Christie <michaelc@cs.wisc.edu> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2005-12-13[SCSI] Consolidate REQ_BLOCK_PC handling path (fix ipod panic)James Bottomley
This follows on from Jens' patch and consolidates all of the ULD separate handlers for REQ_BLOCK_PC into a single call which has his fix for our direction bug. Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2005-12-13[SCSI] Mark some core scsi data structures constArjan van de Ven
patch below marks a few scsi core datastructures as const, so that they end up in the .rodata section and don't cacheline share with things that get dirtied Signed-off-by: Arjan van de Ven <arjan@infradead.org> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2005-12-02[SCSI] sg and st unmap_user_pages allow PageReservedHugh Dickins
2.6.15-rc1 made sg's st_unmap_user_pages and st's sgl_unmap_user_pages BUG on a PageReserved page. But that's wrong: they could be unmapping the ZERO_PAGE, which is marked PG_reserved; and perhaps others (while get_user_pages is still permitted on VM_PFNMAP areas - that may change). More change is needed here: sg claims to dirty even pages written from, and st claims not to dirty even pages read into; and SetPageDirty is not adequate for this nowadays. Fixes to those follow in a later patch: for the moment just fix the 2.6.15 regression. Signed-off-by: Hugh Dickins <hugh@veritas.com> Acked-by: Nick Piggin <npiggin@suse.de> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2005-12-01[SCSI] st: fix a bug in sgl_map_user_pages failure path Hugh Dickins
Nick and I had already been looking at drivers/scsi/{sg.c,st.c}, brought there by __put_page in sg.c's peculiar sg_rb_correct4mmap, which we'd like to remove. But that's irrelevant to your pain, except... One extract from the patches I'd like to send Doug and Kai for 2.6.15 or 2.6.16 is this below: since the incomplete get_user_pages path omits to reset res, but has already released all the pages, it will result in premature freeing of user pages, and behaviour just like you've seen. Though I'd have thought incomplete get_user_pages was an exceptional case, and a bit surprised you'd encounter it. Perhaps there's some other premature freeing in the driver, and this instance has nothing whatever to do with it. If the problem were easily reproducible, it'd be great if you could try this patch; but I think you've said it's not :-( Signed-off-by: Kai Makisara <kai.makisara@kolumbus.fi> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2005-11-07[PATCH] kfree cleanup: drivers/scsiJesper Juhl
This is the drivers/scsi/ part of the big kfree cleanup patch. Remove pointless checks for NULL prior to calling kfree() in drivers/scsi/. Signed-off-by: Jesper Juhl <jesper.juhl@gmail.com> Cc: James Bottomley <James.Bottomley@steeleye.com> Acked-by: Kai Makisara <kai.makisara@kolumbus.fi> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-04Merge by HandJames Bottomley
Conflicts in dec_esp.c (Thanks Bacchus), scsi_transport_iscsi.c and scsi_transport_fc.h Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2005-10-29[PATCH] core remove PageReservedNick Piggin
Remove PageReserved() calls from core code by tightening VM_RESERVED handling in mm/ to cover PageReserved functionality. PageReserved special casing is removed from get_page and put_page. All setting and clearing of PageReserved is retained, and it is now flagged in the page_alloc checks to help ensure we don't introduce any refcount based freeing of Reserved pages. MAP_PRIVATE, PROT_WRITE of VM_RESERVED regions is tentatively being deprecated. We never completely handled it correctly anyway, and is be reintroduced in future if required (Hugh has a proof of concept). Once PageReserved() calls are removed from kernel/power/swsusp.c, and all arch/ and driver code, the Set and Clear calls, and the PG_reserved bit can be trivially removed. Last real user of PageReserved is swsusp, which uses PageReserved to determine whether a struct page points to valid memory or not. This still needs to be addressed (a generic page_is_ram() should work). A last caveat: the ZERO_PAGE is now refcounted and managed with rmap (and thus mapcounted and count towards shared rss). These writes to the struct page could cause excessive cacheline bouncing on big systems. There are a number of ways this could be addressed if it is an issue. Signed-off-by: Nick Piggin <npiggin@suse.de> Refcount bug fix for filemap_xip.c Signed-off-by: Carsten Otte <cotte@de.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-10-28[SCSI] use {sdev,scmd,starget,shost}_printk in generic codeJeff Garzik
rejections fixed and Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2005-10-28[SCSI] move the mid-layer printk's over to shost/starget/sdev_printkJames Bottomley
This should eliminate (at least in the mid layer) to make numeric assumptions about any of the enumeration variables. As a side effect, it will also make all the messages consistent and line us up nicely for the error logging strategy (if it ever shows itself again). Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2005-10-28Merge ../bleed-2.6Greg KH
2005-10-28[PATCH] Driver Core: fix up all callers of class_device_create()Greg Kroah-Hartman
The previous patch adding the ability to nest struct class_device changed the paramaters to the call class_device_create(). This patch fixes up all in-kernel users of the function. Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-10-28[PATCH] gfp_t: drivers/scsiAl Viro
2005-09-14[SCSI] scsi: sd, sr, st, and scsi_lib all fail to copy cmd_len to new cmdTimothy Thelin
This fixes an issue in scsi command initialization from a request where sd, sr, st, and scsi_lib all fail to copy the request's cmd_len to the scsi command's cmd_len field. Signed-off-by: Timothy Thelin <timothy.thelin@wdc.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2005-09-06Merge by hand (conflicts in sd.c)James Bottomley
2005-09-04This patch fixes in st.c the bug in the signed/unsigned int comparisonJames Bottomley
reported by Doug Gilbert and fixed by him in sg.c (see [PATCH] sg direct io/mmap oops). Doug fixed the comparison in sg.c. This fix for st.c does not touch the comparison but makes both arguments signed to remove the problem. The new code is adapted from linux/fs/bio.c. Signed-off-by: Kai Makisara <kai.makisara@kolumbus.fi> Rejections fixed up and Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2005-08-28Merge HEAD from ../scsi-misc-2.6-tmp James Bottomley
2005-08-08[SCSI] drivers/scsi/st.c: add reference count and related fixesKai Makisara
I have rediffed the patch against 2.6.13-rc5, done a couple of cosmetic cleanups, and run some tests. Brian King has acknowledged that it fixes the problems he has seen. Seems mature enough for inclusion into 2.6.14 (or later)? Nate's explanation of the changes: I've attached patches against 2.6.13rc2. These are basically identical to my earlier patches, as I found that all issues I'd seen in earlier kernels still existed in this kernel. To summarize, the changes are: (more details in my original email) - add a kref to the scsi_tape structure, and associate reference counting stuff - set sr_request->end_io = blk_end_sync_rq so we get notified when an IO is rejected when the device goes away - check rq_status when IOs complete, else we don't know that IOs rejected for a dead device in fact did not complete - change last_SRpnt so it's set before an async IO is issued (in case st_sleep_done is bypassed) - fix a bogus use of last_SRpnt in st_chk_result Signed-off-by: Nate Dailey <nate.dailey@stratus.com> Signed-off-by: Kai Makisara <kai.makisara@kolumbus.fi> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2005-08-02[SCSI] Fix SCSI tape oops at module removalKai Makisara
Removing the SCSI tape module results in an oops in class_device_destroy if any devices are present. The patch at the end of this message fixes the bug by moving class_destroy() later in exit_st() so that the class still exists when devices are removed. (The bug is old but class_simple_device_remove() did nothing when the class did not exist.) The patch also fixes a "class leak" in init_st() error path. I would like to get this into 2.6.13 but it may be too late? Signed-off-by: Kai Makisara <kai.makisara@kolumbus.fi> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2005-06-20[PATCH] class: convert drivers/scsi/* to use the new class api instead of ā†µgregkh@suse.de
class_simple Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-05-20[SCSI] SCSI tape: fix permissions for SG_IO, etc.Kai Makisara
This patch is against 2.6.12-rc3 + linus-patch from April 30. The patch contains the following fixes: - CAP_SYS_RAWIO is used instead of CAP_SYS_ADMIN; fix from Alan Cox - only direct sending of SCSI commands requires this permission - the st status is modified is successful unload is performed using SCSI_IOCTL_STOP_UNIT Signed-off-by: Kai Makisara <kai.makisara@kolumbus.fi> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
