path: root/drivers/scsi/sr.c
2006-07-09[SCSI] hide EH backup data outside the scsi_cmndChristoph Hellwig
Currently struct scsi_cmnd has various fields that are used to backup original data after the corresponding fields have been overridden for EH commands. This means drivers can easily get at it and misuse it. Due to the old_ naming this doesn't happen for most of them, but two that have different names have been used wrong a lot (see previous patch). Another downside is that they unessecarily bloat the scsi_cmnd size. This patch moves them onstack in scsi_send_eh_cmnd to fix those two issues aswell as allowing future EH fixes like moving the EH command submissions to use SG lists like everything else. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2006-06-26[SCSI] sd/scsi_lib simplify sd_rw_intr and scsi_io_completionLuben Tuikov
This patch simplifies "good_bytes" computation in sd_rw_intr(). sd: "good_bytes" computation is always done in terms of the resolution of the device's medium, since after that it is the number of good bytes we pass around and other layers/contexts (as opposed ot sd) can translate that to their own resolution (block layer:512). It also makes scsi_io_completion() processing more straightforward, eliminating the 3rd argument to the function. It also fixes a couple of bugs like not checking return value, using "break" instead of "return;", etc. I've been running with this patch for some time now on a test (do-it-all) system. Signed-off-by: Luben Tuikov <ltuikov@yahoo.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2006-06-06[SCSI] fix up request buffer reference in various scsi driversChristoph Hellwig
Various scsi drivers use scsi_cmnd.buffer and scsi_cmnd.bufflen in their queuecommand functions. Those fields are internal storage for the midlayer only and are used to restore the original payload after request_buffer and request_bufflen have been overwritten for EH. Using the buffer and bufflen fields means they do very broken things in error handling. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2006-03-23[PATCH] kill cdrom ->dev_ioctl methodChristoph Hellwig
Since early 2.4.x all cdrom drivers implement the block_device methods themselves, so they can handle additional ioctls directly instead of going through the cdrom layer. Signed-off-by: Christoph Hellwig <hch@lst.de> Acked-by: Jens Axboe <axboe@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-12[SCSI] MODULE_ALIAS_{BLOCK,CHAR}DEV_MAJOR for drivers/scsiRene Herman
Add device-major aliases in drivers/scsi, allowing kmod autoload: MODULE_ALIAS_CHARDEV_MAJOR(SCSI_CHANGER_MAJOR) MODULE_ALIAS_CHARDEV_MAJOR(OSST_MAJOR) MODULE_ALIAS_CHARDEV_MAJOR(SCSI_TAPE_MAJOR) MODULE_ALIAS_BLOCKDEV_MAJOR(SCSI_CDROM_MAJOR) MODULE_ALIAS_BLOCKDEV_MAJOR(SCSI_DISKN_MAJOR) Signed-off-by: Andrew Morton <akpm@osdl.org> Acked-by: Kai Makisara <kai.makisara@kolumbus.fi> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2006-02-27[SCSI] Remove devfs support from the SCSI subsystemGreg KH
As devfs has been disabled from the kernel tree for a number of months now (5 to be exact), here's a patch against 2.6.16-rc1-git1 that removes support for it from the SCSI subsystem. The patch also removes the scsi_disk devfs_name field as it's no longer needed. Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2006-02-27[SCSI] SCSI core kmalloc2kzallocJes Sorensen
Change the core SCSI code to use kzalloc rather than kmalloc+memset where possible. Signed-off-by: Jes Sorensen <jes@sgi.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2006-01-14[PATCH] Unlinline a bunch of other functionsArjan van de Ven
Remove the "inline" keyword from a bunch of big functions in the kernel with the goal of shrinking it by 30kb to 40kb Signed-off-by: Arjan van de Ven <arjan@infradead.org> Signed-off-by: Ingo Molnar <mingo@elte.hu> Acked-by: Jeff Garzik <jgarzik@pobox.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-14[SCSI] always handle REQ_BLOCK_PC requests in common codeChristoph Hellwig
LLDDs should never see REQ_BLOCK_PC requests, we can handle them just fine in the core code. There is a small behaviour change in that some check in sr's rw_intr are bypassed, but I consider the old behaviour a bug. Mike found this cleanup opportunity and provdided early patches, so all the credit goes to him, even if I redid the patches from scratch beause that was easier than forward-porting the old patches. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2006-01-12[SCSI] Mask capabilities for SCSI-1 CD driveChuck Ebbert
SCSI-1 CD drives can't do MRW or be opened for writing, so mask off those capabilities. Signed-off-by: Chuck Ebbert <76306.1226@compuserve.com> Acked-by: Jens Axboe <axboe@suse.de> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2006-01-12[SCSI] turn most scsi semaphores into mutexesArjan van de Ven
the scsi layer is using semaphores in a mutex way, this patch converts these into using mutexes instead Signed-off-by: Arjan van de Ven <arjan@infradead.org> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2005-12-15Fix up SCSI mismergeJames Bottomley
I forgot to do a git-update-cache on the merged files ...
2005-12-15Merge by hand (conflicts in scsi_lib.c)James Bottomley
This merge is pretty extensive. The conflict is over the new req->retries parameter, so I had to change the prototype to scsi_setup_blk_pc_cmnd() and the usage in sd, sr and st. Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2005-12-13[SCSI] Consolidate REQ_BLOCK_PC handling path (fix ipod panic)James Bottomley
This follows on from Jens' patch and consolidates all of the ULD separate handlers for REQ_BLOCK_PC into a single call which has his fix for our direction bug. Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2005-12-13[SCSI] Mark some core scsi data structures constArjan van de Ven
patch below marks a few scsi core datastructures as const, so that they end up in the .rodata section and don't cacheline share with things that get dirtied Signed-off-by: Arjan van de Ven <arjan@infradead.org> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2005-10-28[SCSI] use {sdev,scmd,starget,shost}_printk in generic codeJeff Garzik
rejections fixed and Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2005-10-28[SCSI] sr: remove dead codeJayachandran C
This patch fixes an issue reported in drivers/scsi/sr.c by Coverity Error reported: Pointer returned from "scsi_cd" is never used Patch description: Remove the scsi_cd() call as it does not have any effect. Signed-off-by: Jayachandran C. <c.jayachandran@gmail.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2005-10-28[SCSI] move the mid-layer printk's over to shost/starget/sdev_printkJames Bottomley
This should eliminate (at least in the mid layer) to make numeric assumptions about any of the enumeration variables. As a side effect, it will also make all the messages consistent and line us up nicely for the error logging strategy (if it ever shows itself again). Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2005-09-14[SCSI] scsi: sd, sr, st, and scsi_lib all fail to copy cmd_len to new cmdTimothy Thelin
This fixes an issue in scsi command initialization from a request where sd, sr, st, and scsi_lib all fail to copy the request's cmd_len to the scsi command's cmd_len field. Signed-off-by: Timothy Thelin <timothy.thelin@wdc.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2005-08-28Merge by hand (conflicts in sr.c)James Bottomley
2005-08-28[SCSI] convert sr to scsi_execute_reqJames Bottomley
This follows almost the identical model to sd, except that there's one ioctl which returns raw sense data, so it had to use scsi_execute() instead. Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2005-08-28[SCSI] convert the remaining mid-layer pieces to scsi_execute_reqJames Bottomley
After this, we just have some drivers, all the ULDs and the SPI transport class using scsi_wait_req(). Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2005-08-28[SCSI] sr.c: Fix getting wrong sizePete Zaitcev
Here's the problem. Try to do this on 2.6.12: - Kill udev and HAL - Insert a CD-ROM into a SCSI or USB CD-ROM drive - Run dd if=/dev/scd0 - cat /sys/block/sr0/size - Eject the CD, insert a different one - Run dd if=/dev/scd0 This is likely to do "access beyond the end of device", if you let it - cat /sys/block/sr0/size This shows the size of a previous CD, even though dd was supposed to revalidate the device. - Run dd if=/dev/scd0 The second run of dd works correctly! The bug was introduced in 2.5.31, when Al fixes the recursive opens in partitioning. Before, the code worked like this: - Block layer called cdrom_open directly - cdrom_open called sr_open - sr_open called check_disk_change - check_disk_change called sr_media_change - sr_media_change did cd->needs_disk_change=1 - before returning sr_open tested cd->needs_disk_change and called get_sector_size. In 2.6.12, the check_disk_change is called from cdrom_open only. Thus: - Block layer calls sr_bd_open - sr_bd_open calls cdrom_open - cdrom_open calls sr_open - sr_open tests cd->needs_disk_change, which wasn't set yet; returns - cdrom_open calls check_disk_change - check_disk_change calls sr_media_change - sr_media_change does cd->needs_disk_change=1, but nobody cares Acked by: Alexander Viro <aviro@redhat.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
